Help on Renault midlum
Driving a hired 7.5 tonne Renault Midlum for the next few days and would like to know a couple of things and as there are no documents in the cab I hope someone on here knows.
The display shows he mileage and at top right a number beside 1/100, the number changes as you drive. What is it ■■? Possibly something to do with efficiency maybe.
There is a switch with a picture of a truck with the word ON over the back of it when switched on a legend on the display says system unlocked. What is it ■■?
I had this vehicle a few weeks ago for 3 days, took it all the way from Peterborough up to Arbroath. Found out today that it’s got cruise control…
sheesh, didn’t think hire clunkers would be this sophisticated and all that time pushing the pedal down on the way to Scotland and back.
this figure is the amount of litres of fuel you are doing to every hundred Kilometers you travel.
At the end of the right hand stalk on the steering column there will be a button.(thats if the controls are the same as the premium)
Press the button and the display will change to your present trip average fuel consumption and tripometer(keep it pressed for 3 secs to reset), press again and it will show how many hours you have been driving
not got a clue,
could be your vehicle security device.
Read the hand book!
munibear:
Read the hand book!
Might be an idea to read the post before making suggestions, Willy wrote the following which would make your suggestion a non starter.
Willy Gofar:
Coffee, thanks for pointing out the importance of reading before putting foot in mouth.
Davis, bit frightening as it fluctuates wildly between 0 and about 46 or so.
Must say that it does go like the proverbial off of a shovel, will do over 60 in 4th so will be breezing past you big guys and wont even have to use top gear. :laughing:
