Getting red diesel in France with AS24
brookie:
toby1234abc:
My ex boss used to run Gibraltar and the UK with Kerosene and Paraffin,he had a 30,000 litre tank in the yard,bless his cotton socks,the engines did not like it.
:open_mouth: I’ve heard of a few people using kerosene, I can’t remember what they added to it to make a cleaner burn, but alot of £££’s at risk if your motor goes bang!!
I worked for a bloke who ran on kerosene if you mixed 50 50 with diesel it would be ok but he got greedy and started running on 100% kerosene and started blowing engines to bits.
I was driving down the westway one morning in an old leyland constructor looked in the mirror and there were flames coming out of the exhaust and a massive bang and oil and bits of engine everywhere. This bloke bought lorrys out of the breakers private tax and away so wasn’t a major financial disaster.
Apart from Kerosene having a much lower flashpoint than diesel it hasn’t got the lubricating properties of DERV.
The problem with kero is the highly explosive early detonation which can bend a rod or in my case split a conrod down the oilway, it wasnt my intention to run kero, just a yorkshireman sniffing out a deal rather than sniffing the fuel.
Rub some diesel between your fingers, now do the same with paraffin, the paraffin is dry, so when people cut biodiesel / chip fat with methanol and add kero, it washes any lubricity out of the mix
Actually incorrect there mate, you don’t ā€œcutā€ used cooking oil with methanol, methanol is mixed with a catalist (either sodium or potasium hydroxide) which when introduced to UCO at between 40 & 55 deg causes a chemical reaction called, wait for it, ā€˜transesterification’. This doesn’t remove any of the lubricity from the oil, it seperated the glycerine from the cooking oil which burns really slowly and even then, not completely & leaves a toffee like deposit behind.
This is the process used in the production of bio-diesel, without this the fuel your running is NOT ā€˜legally’ bio-fuel and doesn’t earn the 20ppl duty break (discount) from HMRC.
Ross.
welshboyinspain:
you can’t buy red diesel in an AS24 in france unless you have a different company card as the normal AS24 cards do not allow purchse of said diesel :stuck_out_tongue: :stuck_out_tongue:
if you have a fridge you need a special card and even then its very hard to get these cards :wink:
most UK hauliers will buy their red diesel in the UK before shipping out
You cant get Red Diesel in the UK with an AS24 EuroTraffic card! Its a bloody nightmare!
BuzzardBoy:
You can, I gave got red diesel at Lympne and at Husks with an AS24 card.
Harry Monk:
BuzzardBoy:
I struggle like ā– ā– ā– ā–  to get it anywhere North of Dartford, everywhere we try we get knocked back. We now use a Keyfuels card just for Red diesel!
there is a difference between an AS24 card and an AS24 eurotraffic card.
you can get your card authorised by the issuer but you need to prove what its for (obviously :blush: )
bigr250:
Ross.
Thanks for that Ross, I have heard of transester, but never used or made biofuel. I stand on what I say with kerosene though
& I’m right with you on that, (I understand) that to make kero safe in a diesel engine you need to introduce a lubricant to the fuel, hydraulic oil (i understand) was the norm a few years ago but to make it really safe the ammount required made the truck a little smokey!!. The way around this was to use 46 weight hyd’ oil rather than 30 & use less.
[allegedly].
Ross.
bigr250:
[allegedly].
Ross.
If we can make it smell like Castrol R, we will be millionaires next year :laughing:
Now yer talking, that’s a smell which always makes me go dewey eyed:) Castrol do a modern castor based semi synthetic two stroke oil called R747 which I used up to 2006 when I bought a new bike that ran unleaded race fuel, this requires an oil designed to suit to the very agressive 107 octain 20% oxygenated race fuel, rather than avgas which was ideally suited to ā€˜747’:frowning:
Ross.
bigr250:
Me too, reminds me of oval racing at Crayford in the 1970s…
