Gardner Engines And Turbocharging.
Hello Everybody.
Carryfast.Hello Everybody.
Carryfast. Here is a definition of Brake Mean Effective Pressure that I came across on an Internet website:-
BMEP.
“The term BMEP is an engineering term that means Brake Mean Effective Pressure. Mean is another word for average, which in this case means average effective pressure of all stroke cycles. This is used to evaluate all engines whether they are Two or Four Cycle.
BMEP is a function of temperature of the gases in the cylinder. To increase the temperature you need to burn more fuel, thus making more heat. Or another way is to make better use of the existing fuel.
Torque is a function of BMEP and displacement only. HP is a function of torque and rpm.
It is said a high BMEP and a low rpm, or a low BMEP and a high rpm, can equal the same power. Larger valves, ports, pipes, compression, etc. all come into play to increase the volumetric efficiency of the engine. The most effective is to increase the number of cylinders. The more efficient it is, the higher the average pressure or BMEP.” From XPLORER.CO.ZA.
SPECIFIC POWER OUTPUT.
"Specific output is an index quantifying the amount of power produced per unit of piston displacement. (Piston displacement being, of course, a precise measure of an engine’s internal size.) Large engines are capable of generating huge amounts of power, but a tougher challenge is producing ample power from a small engine. Specific output provides a handy means of comparing the power-generating capability of all engines regardless of size."From CAR AND DRIVER.
In one of the books that I own (published in 1940) it states that the maximum BMEP for an original Gardner LW Diesel Engine is 102 lb.per.sq.in.
Anyway,here are a few questions:-
1.How does an engine designer achieve the target BHP and torque outputs?
2.Why has the Gardner 6LW got a low BMEP/Stress factor?
However,what I am trying to say is about the physical strain on a Gardner 6LW engine which is caused by the
overall weight of the lorry that it’s trying to power and move - not the BMEP kind of stress. The stress on
parts of the engine as it tries to move 24 tons of GVW,or 32 tons tons of GTW if the lorry is pulling a trailer -
some of the weight must be transmitted and/or indicated back to the engine via the driving axles,prop shafts and gearbox (although the gearing helps to overcome some of the weight). Therefore,AEC and Leyland
150 BHP engines (designed for 150 BHP and future upratings) were more powerful than Gardner 6LW 102-112
BHP engines,so there would be less physical strain and stress on the AEC and Leyland engines and would find it easier to move 24 tons GVW or 32 tons GTW of lorry. Hence less wear and tear on the the driver and lorry:
less use of the clutch,less gear changes,faster journey times,and,in certain cases,better fuel consumption
figures,better all round efficency and more satisfaction for the driver,operater and customer - these are the great benefits of using more powerful engines!
…so it’s goodbye to Gardner diesel engines.
Cav 551.You accuse me of being unfair in regard to compairing the Gardner 6LW K-Type 112 BHP Diesel Engine with the AEC A221 and Leyland O.680 150 BHP Diesel Engines.
I am not being unfair at all. It was the Gardner company and the misguided Hugh Gardner that were being unfair:-
They expected hauliers to buy and operatate Gardner 6LW K-Type engined 32 ton GTW rigid eight wheeler
lorry drawbar trailer outfits using just a mere 112 BHP!
Gardner must have been living in Cloud
Cuckoo Land! (Actually,a few very misguided hauliers did buy them
Or Gardner expected hauliers to use the Gardner 8LW 150 BHP Straight Eight Diesel Engine (QV my earlier post of the 18th of August) to power their eight wheeler drawbar trailer outfits,but this was expensive,too long -it took up too much valuable load space - and was probably too heavy.
Thus lorry operaters rightly deserted Gardner in droves and bought 150 BHP AEC,Leyland and AEC-engined
Atkinson rigid eight wheeler lorries for drawbar trailer work. It is true that a minority of lorry operators
bought the less powerful 125 BHP AEC,Leyland,AEC-engined Atkinson,Foden two stroke (126 BHP),etc,rigid
eight wheelers.
But Cav 551 should note that,as far as AEC and Leyland were concerned,the standard engines for rigid eight
wheeler drawbar trailer outfits were the AEC A221 and Leyland O.680 150 BHP Diesel Engines. So I was not being unfair,but the very misguided and somewhat self-delusional L.Gardner & Sons Ltd was.
[ZB] Anorak.I’ve re-printed the Supercharged and Turbocharged Engine production commencement list
below,and I did state “The list below shows dates or periods when certain well known commercial vehicle engine manufacturers BEGAN TO PRODUCE supercharged (S) and/or turbocharged (T) diesel engines:-”
But this time I’ll be more specific
In regard to the [ZB] Anorak comments. Here are some more objective facts:The list below shows dates or
periods when certain well known commercial vehicle engine manufacturers began to produce supercharged (S) and/or turbocharged (T) diesel engines:-
AEC.T 1950s.AVT690/AHT690,etc, For industrial,freight and passenger vehicles.
Berliet.T 1959. M635 (640). Magic engine models.MDO3.
B.M.M.O.-Midland Red .T 1959.KL 8.028-litre Turbocharged 138 BHP Diesel Engines,with CAV Turbochargers.
Caterpillar.T 1955.
Crossley.S 1947.HOE9.
■■■■■■■■■ 1954.Six-cylinder NT,NRT,JT and V12-cylinder VT12.
DAF.T 1959. DS537.
Daimler.T 1958. CDS6 Turbocharged CVD6-SD Single Decker Motorcoaches and Buses.
Detroit Diesel.S 1938,T 1957. 71-Series Vee-Type Range:6V71 V6, 8V71 V8,12V71 V12,16V71 V16.
Fiat-IVECO.T 1981.
Foden.S 1948,T 1962. Supercharged FD4,FD6. Turbocharged Dynamic FD6 Mk 7. An experimental FD6 Mk III,fitted with a CAV turbocharger,producing 210 BHP was built in 1960.
Gardner.T 1981. 6LXCT.8LXCT.
Leyland.T 1968.690, Beaver Freightline BV69.32PTR Tractive Unit,with two pedal semi-automatic transmission.
Magirus-Deutz.T 1950s.Deutz BF12L 614,etc.
MAN.T.1956.D1246T.
Meadows.T 1950s.
Mercedes-Benz.T 1948.Produced turbocharged diesel engines for special vehicles,turbocharged engines became optional in 1968 and standard in 1980.
OM.S 1958. Tigre,6870 cc, 135 BHP.
Perkins.T 1964.T6.354.
Rolls-Royce.S,T 1952.Supercharged C6SFL,etc,Turbocharged C6TFL,etc.
Scania,Scania-Vabis.T 1951. Not used in lorries until 1954,DS10 introduced in 1958.
Thornycroft.T 1950s.KRN6/S,etc.
Volvo.T 1954.TD96AS. In the early 1960s turbocharged engines accounted for 75% of heavy lorry engine production.
The above list does ring true.
As for the question: How many turbocharged Leyland,Magirus-Deutz and Foden lorries were sold before 1975?
In the cases of Foden and especially Leyland,a hell of a lot! I don’t know about Magirus-Deutz.
Most of the Leyland lorry,and some of the Leyland bus,ranges were powered by the Leyland 500-System
“Headless Wonder” Fixed Cylinder Head Diesel Engine Range - the 510 and 511 versions were turbocharged
and powered the:-
Buffalo 4x2 and 6x4 Tractive Units,
Octopus Rigid Eight Wheeler Lorry,
Super Buffalo 4x2 and 6x4 Drawbar Trailer Lorries,
Bristol VRT Double Decker Bus,
Leyland National Single Decker Bus.
The export Leyland Victory Mk11 Single Decker Bus was powered by the 690.
There were the turbocharged 410 and 411 Diesel Engines that powered Leyland Chieftans,Reivers and Clydesdales and the AEC AV760-based Leyland TL12 Turbocharged Diesel Engine that powered the Leyland Marathon and the later Roadtrain ranges.
All these engines were in production from at least 1971-1972 (TL12 from 1973) then came the O.680-based TL11 Turbocharged Diesel Engine in 1979.
In the case of the superb Foden Dynamic FD6 Mk VII Two Stroke Turbocharged Diesel Engine,produced from 1962 to 1972,this popular engine powered everything: dump trucks,the Foden S24 Sabrina Twin Load
8AE7/32 Rigid Eight Wheeler Tractive Unit Articulated Lorry,heavy haulage ballast road locomotives,4x2 and
6x4 tractive units,rigid eight wheeler freight,tanker and tipper lorries,etc,etc.
Photographs:-
Foden S24 Sabrina 4TE7/50,GWV 616D:-
flickr.com/photos/29179064@N05/3780913028/
Foden S24 Sabrina TE7/24,PMB 149B:-
ccmv.aecsouthall.co.uk/p25827268 … #h142d0442
Foden S24 Sabrina Twin Load 8AE7/32,007 MB:-
flickr.com/photos/37322606@N08/7017081727/
Foden S21 Spaceship 8E7/28,ETJ 346F:-
truck-photos.net/picture/number4360.asp
This Foden S18 FGHT6/50 4x2 Heavy Haulage Road Locomotive,PBT 973,is actually powered by a TURBOCHARGED Gardner 6LW Diesel Engine!
It has a Simms turbocharger,which was fitted by it’s
original operator,L.V.Brooksbank and is now preserved by this heavy haulage company:-
ccmv.aecsouthall.co.uk/p40328673 … 41#h1f3841
Saviem.Here is a quite attractive Neoplan N722/3/Plaxton Paramount 4000 6x2 Double Decker Motorcoach,
4195 HE,operated by the Yorkshire Traction Company,Barnsley,which had six of these motorcoaches,all
powered by Gardner 6LYT 320-350 Diesel Engines - now the Gardner 6LYT is a proper Gardner Diesel Engine
-ie,for one thing it’s powerful…for a change:-
google.com/imgres?q=YORKSHIR … ,s:0,i:101
And here endeth yet another long sermon
Cheers.
VALKYRIE.
