Rentadent:
Unless you’re loaded and the sensors won’t allow it then just lift it and carry on.
Even if it put the drive axle overweight briefly it would make more sense to get the tyre changed at a services or in a decent lay-by than on the hard shoulder, if you weren’t chancing being overweight then I’d run back to the yard or the tyre place with it up.
A transport company would be happy for you to do that, a logistics company would have you sitting at the side of the road.
Cheers mate.
FarnboroughBoy11:
Why do you run with the mid lift down all the time■■?
Talk about throwing money down the drain.
You must spin up your drive wheels all the time when it’s wet.
And not to mention giving other trucks a false impression that you are heavy when you’re not.
My gaffer would give me a disciplinary if I came back into the yard empty with the mid lift down and quite rightly so. Ridiculous ridiculous ridiculous!!!
It’s the most unprofessional sight on the road when you see a tractor unit running solo along the motorway with his mid lift down. I don’t know why but its that sort of thing that really bugs me
I drive a Scania, which, when you put the midlift up, ■■■■■ it’s arse in the air. Which means the whole cab is tilted forward which quite often makes my mug slide off the coffee machine on the dash, my dinner plate slide of the steering wheel, my curtains which have frills on the frills slide forward so that they almost touch the windscreen
With it lifted, it can overload the steering axle too. I’ve weighed out with a steering axle at 7200 before, dropped the axle and it’s gone down to 6900. Not too sure of the reasons, think it’s something to do with the truck being canted forward.
Not sure why they do this, is it something to do with having a steering midlift… I digress. Also, I find it can bugger up the gearbox computer (3 pedal opticruise), it thinks it’s got a heavier load on than it has so uses too many gears etc.
Don’t spin my wheels up much, due to having extreme finesse in my right foot… And using the weight transfer switch when it’s wet too. And I’m on Tesco chilled, so the trailer is always loaded, even if it’s just with cardboard in cages, but normally have plastic trays on the headboard which tend give enough weight to stop spinning up too.
FarnboroughBoy11:
switchlogic:
Blimey, maybe you should have let him answer your question before tearing him apart.
I wasn’t meaning to tear anyone apart, I was just saying its pointless and defies the whole point of the invention of the mid lift. Might as well just run double drives.
No worries.
Pansie Division:
Not just the fuel wastage, the tyre bills as well!! What annoys me is that you say ‘no fuel bonus here’ so that’s why you do it to spite your boss? So you need to be paid ‘bonuses’ to be a professional driver?
If any of our drivers had that attitude, I’d chin them!
Nope. See my reasons above. The no fuel bonus bit was to stop the “you’re wasting diesel comments”.
the maoster:
Happysack you may be able to answer this; I’m sure I read on here recently that Stobbies like you to run with it down even when empty, why is that?
Yes they do. Axle up on a Scania adds 2/3 inches to running height is the main reason, or that’s the last reason I was told…
