Ferry crossing and driving/rest hours
Concretejim:
toby1234abc:
Barrykam, there is nothing writing in EU law to say you need to keep and show proof of travel for an interupted daily rest break.
Your only allowed to interrupt if you have access to a bunk or couchette on the train/ferry, now if you have no way of proving this you could of been anywhere moving for any reason. Hence normally the need for proof for 28 days.
I know plenty of idiots who think they can use ferry mode on dover to calais.
Rest has only to be 11 hours total not 12. Its not a split.
I have used it when crossing from Calais to Dover on several occasions and was pulled in Holyhead the day after doing it and nothing was said, sometimes with the frequent delays on that crossing it is the only way to get across and I think the authorities understand this
Further to all the previous on ferry movements: I take 2 precautions. I always keep the ticket so that I can prove I was on the ship and secondly, not always popular, I try to politely inform the loaders that I will make 1 movement only, and that is straight onto ship. If they don’t like it, too bad. As ever, if we all did the same, they’d have to rethink loading strategy.
El Majo:
You don’t use Portsmouth then, they keep the ticket at the exit gate.
El Majo:
I havn’t driven a lorry onto a ferry for donkeys years but don’t remember ever having a problem with the way lorries were loaded.
I’m just curious about what they do now that causes problems ?
some ships,for example the birkenhead/belfast then one your in the queue,you dont get a clear run to load.you could be shuffling up closer to the boad like gridlock traffic once they start to load.it looks like your still driving half a mile in a traffic jam.
dover,kilinghome and the likes,then your more likely to fire it up and charge straight on with minimal fuss.
either way ive never found it to make any difference when stopped days or weeks later.
ive never kept a ticket,nor ever had to prove i was on the boat in the 1st place.
for uk ferries,i dont think ive ever used my real name on a crossing yet as its never required.
the plus point depending on who you work for is that you could be taking your time off in carnryan,larne birkenhead,or belfast and nothing can be done to disprove you.
dieseldog999:
OK thanks, presumably the problem is wasted driving/working time which can result in more down time and will also leave less available time for the next daily rest interruption if there’s going to be one.
What is correct.??Start at 1000 am and go to .About 1500 go to ferry and simply closed country and put yo rest.About 11pm back to truck press ferry mode and drive of for parking and stay fir 6 hour in rest again.Some people talk who need press ferry at time when just come to ferry.
Ferry breaks are simple, if the crossing you are to take is shorter than a daily rest reduced or regular just remember to be at the exit port and parked in the lanes no more than 12 hours from your starting time ( this is to include your 1 hour allowed movements ).
Park in the lanes and place on rest, end country and ferry mode ( this will clear your first movement onto the ship ), once onboard press rest and ferry mode, if the total time of the first two breaks is 11hrs drive off and carry on with your journey, if not then drive off find parking and complete your rest, so long as you’ve taken a total of 11 hours plus any movements within your 24 hour spread over and you have not exceeded your max daily driving limit its legal.
Start 05:00
Deliveries / collections
Arrive port 16:30
In lanes 16:45
Rest / end country / ferry mode
Ferry 20:30 ( 15 mins movement )
Rest / ferry mode
Arrive 0:30
Disembark 0:45 and find parking ( max 45 mins drive allowed )
Park complete remainder of 11 hour rest
Start 04:45 other work / begin country
Hi all, sorry to ■■■■ in on this thread!
i,m having my first ferry trip to Belfast from Birkenhead Tues morning. Looks like there is some really good advice here but would like some help.
i,m going to start my shift at 22:00 tonight and the ferry departs at 03:30 Tues morning. When you park up at the docks waiting for the ferry, do you put it on break at that point or ferry mode then break. Some have suggested you dont put it on ferry mode until you are on the boat.
The ferry arrives in belfast about 011:00 Tues morning then there is a 10 minute drive to where we park up. We wont be starting our next shift until Wednesday morning, (easy life!!)
We are actually taking a week to do 1 days work with 2 nights in an hotel with meals included!!! :smiley:
paulant18:
Also, you dont need to change country do you? its still UK
paulant18:
paulant18:
Get to the port get checked in ,go to lanes ,Rest. Put in end country
When called to board ,Put to ferry mode
When on board ,back on rest ,if you had 11 hours Plus shunt on board taken before getting off ,then just start country and crack on ,
If not 11 taken ,use ferry again go and park up back to rest .
Use ferry just before boarding .
As has been said several times, you are allowed two interuptions to your rest, for moving on and off a ferry or train.
The time allowed is 1 hour spread over both movements.
As everything has to fit into the 24 hours from the time you start day 1 until the time you start day 2, you should arrive and be parked up on the dock no more than 12 hours after you started, to give you that 1 hours movement time.
It isn’t essential that you use it for every ferry journey. Only if time parked on the ferry is less than 9 hours and you need to get a rest in. If you’ll get 9 hours + on the ferry and you’ve got a 9 hr rest available, you don’t need to do any of this. Humber crossings to European ports are well over 11 hours, so there’s no need for ferry mode. Just log off for the country you’re in, rest, log on for the disembarkation country, go.
Using ferry ‘mode’.
1 arrive at dock, park up, log off on your tacho and put it on rest.
2 on being told to board the ferry/train, go through the menu and press ferry mode.
3 board ferry/train, put it back on rest
4 in the arrival port, if your total rest so far doesn’t equal 11 hours, just before moving again press ferry mode.
4a if you’ve already got 11 hours rest in total, you’re good to go, jump to step 6
5 Drive off, find somewhere to park up asap, put it back on rest.
6 Once you have 11 hours total rest, log back on to start your shift including start country. You’re good to go.[/list:u]
Pressing ferry mode puts a ‘flag’ on your tacho record, it isn’t a ‘mode’ as such, like driving, rest etc are.
You put the flag on your tacho records just before each movement, to inform whoever wants to look at your records that this movement was for going aboard or disembarking from a ferry or train.
Just a quick question,
On arriving at a French port. On nigh on 13 hours to: ie. Start 0415. Park in dock 1715. Can I move onto ferry after this time? Using ferry mode before I move of course. Tho I have booked off and entered end country. Thanks
Legally no ,as with your shunt onto ferry takes you overtime for it all to fit in 24 hours ,but personally if my 11 hours were up once getting off ferry I would get on the boat .
bossman:
I think you’re incorrect bossman. You ARE allowed to interupt your daily break in order to board or alight the ferry.
barrykam:
bossman:
I think you’re incorrect bossman. You ARE allowed to interupt your daily break in order to board or alight the ferry.[/quote
You are allowed to interrupt your rest to get on and off the ferry provided you have the time to do so arriving at the port 12hrs 59mins into your spread does not allow any time for the movements on and off in effect if you are going to use the full shunt then you must arrive at the port at the 12 hour point in your spread, the whole of your 11 hour break must finish within 24 hours of your start time
barrykam:
bossman:
Yes but if you’ve already done 13 hours before parking up and you then interrupt the rest period you will not be able to complete an 11 hour rest period within the period of 24 hours.
When interrupting a daily rest period the 11 hour rest period and any interruptions should be completed within the period of 24 hours from the start of the shift just like any other daily rest period.
Sent from my mobile.
Mazzer2:
barrykam:
bossman:
[/quote
Isn’t that what I said ?
tachograph:
barrykam:
bossman:
Exactly .
Im surprised I don’t get more infringements sometimes. :wink:
Been using ferry mode a couple of times a week lately without a thought for the 24hr rule just remembering I can’t use a 9hr break and add minutes moving on to the 11hr.
