Especially For Volvo Fans!
For the likes of Pat and others,
Came across this Press release, from Volvo Trucks.
Enjoy!
Jim.
Volvo unveils “most powerful engine” ever built
GREENSBORO, N.C. (Feb. 7, 2005) – Volvo Trucks North America says “the most
powerful diesel engine on North American highways” will be available this
summer. It was introduced in conjunction with Volvos new flagship truck,
the Volvo VT 880, and is available in North America exclusively in the VT 880.
Volvo Truck says the 16-litre, inline six-cylinder diesel Volvo D16 engine
with 625 hp and an unmatched 2,250 lbs.-ft. of torque, has the power to
handle the biggest loads and the steepest roads.
“The D16 is the most powerful truck engine Volvo has ever built, but it is
powerful for a reason,” said Peter Karlsten, president and CEO. “This engine
is for customers who haul heavy loads or need to maintain a high average
speed through the mountains for reduced trip times. And since it is paired
with the bold new Volvo VT 880 owner-operator truck, it will be very popular
with customers who seek a strong image and serious performance.”
The Volvo D16 was designed to have more usable power than competitors,
best-in-class fuel economy, high-speed gradeability, and driveability. The
engines unmatched torque allows it to pull heavy loads up long grades
without losing speed or needing to downshift. An example of this high-speed
gradeability is the D16s ability to propel the Volvo VT 880 up a 3 per cent
grade at 65 mph at 1,400 rpm, while loaded to 80,000 pounds, the company says.
In addition to 625 hp and 2250 lbs.-ft., the Volvo D16 will have three other
power ratings: 500 hp at 1850 lbs.-ft.; 550 hp at 1850 lbs.-ft.; and 600 hp
@ 2050 lbs.-ft.
The D16 – designed to meet stringent 2007 and 2010 emissions standards –
introduces a new Volvo technology called Intelligent Torque, or I-Torque, to
protect drivelines from excessive torque at low speeds. I-Torque should
extend tire wear and protect drivelines by limiting engine torque output to
1,650 lbs.-ft. in startup gears, switching to 1,850 lbs.-ft. as speed
increases. Two stages are used to phase in the higher torque for the 600 hp
and 625 hp ratings.
The engine’s larger displacement gives it advantages over existing 15-litre
engines. The larger bore (or diameter) of the D16s cylinders gives the tops
of its pistons more surface area. This means it can generate more power and
torque than a 15-litre engine, with lower internal forces, Volvo says,
adding that its shorter stroke means less piston travel inside the cylinder,
which Volvo has found leads to less engine wear.
Service life is also enhanced by the length of the Volvo D16 engine block.
The D16s block has more space between the cylinders, which makes the base
engine stronger, and results in more consistent engine temperatures. This
reduces mechanical and thermal stresses, which can prematurely weaken engines.
The Volvo D16 has a rear-mounted gear train, which drives the camshaft, air
compressor, and power steering pump. The D16 also uses a damper on the
camshaft to reduce torsional vibration, for a quiet and smooth running
engine. The cam is designed to lift up and out from the engine for easy
servicing, if needed, unlike other designs which require the removal of the
engine or radiator to service the cam.
The VolvoD16 includes a number of other Volvo engine features, including:
– The Volvo Engine Brake is an integrated engine compression brake that
provides 335 hp of braking power at 1,500 rpm, to control vehicle speed on
downhills, while conserving foundation brake service life. The VEB
performance is not as sensitive to altitude as other engine brakes.
– The Volvo Exhaust Pressure Governor allows the engine to warm up quickly
and to maintain engine temperature at very low idle speeds, thus saving fuel
and money, and reducing emissions. It also works in conjunction with the
Volvo Engine Brake to provide very high retarding power throughout the
entire rpm range.
– The Volvo Pre-Heater heats the intake air for fast and reliable engine
startup in cold weather, without white smoke.
The fuel system is similar to the Volvo D12s system, and provides constant
fuel temperature to the injectors, while using a low flow fuel return. This
means more consistent power output and longer injector service life. – from
TruckinInfo.com
Gimmie, Gimmie, Gimmie! :laughing:
You mean we Volvo lovers will get a choice of Volvo engines from now on?, you mean no more " well sir, if you want a Volvo engine we can only offer you a 465bhp or a 465bhp, unless of course sir would prefer the 465bhp" :open_mouth: :unamused: :laughing:
I talked to Volvo at last years MATS, they told me the 16 litre/ 610bhp would be available for 2007, seems they got it wrong, but there again, when I asked about ‘I’ shift, they did’nt know what the hell I was talking about :unamused: Maybe suits at Volvo NA, should get out and about a little more.
Cheers for that info Scouse Express, I am still hoping to be able to spec’ out a brand new Volvo before 2007, at least I now know the big engine will have arrived, I only hope they make 'em in Sweden and not over here as I’m afraid American made Volvos are not up to the standards of European built ones.
Cliff,
I’m a bit of a Volvo fan myself.
I used to have a Volvo car in the UK (then I got married), and used to drive Volvo Coaches when I was in the UK.
It looks as if Volvo are also going to put a Volvo engine in Prevost Coaches;
prevostcar.com
which is a company they now own 100%. Up until now, Detroit Diesels have been the only engine available.
Jim.
G,day all
Gave up my older volvo the other day for a brand spanking new one…Well wot can i say…nice inside,glad they stuck the doors on the storage now…even the top bunk is wrapped up still,sad git no friends to take…Anyway i will keep you updated on the way she runs…so far gutless uphills(but that could be thet keep giving me 45000 loads)…Working for Western Express again in Nashville,so i will keep my eyes open for anyone over here
Skippy
Stick a Bloody Great Aussie Flag across the grill Skippy, then I’ll know it’s you coming down the road, I see Western Express Trucks all the time…they’re always getting in my way! :wink:
I saw the handout for that new volvo at the dealer in the Peg. Looks ugly, like a long-nosed volvo would :frowning:
Nice engine tho, and if you buy early, you get Swedish made engines, as the NC plant won’t be up to making them until june.
I love volvo, turns on a dime, unlike that FL I did yard shunting with the other day :frowning: Apparantly the long nosed volvo will have a major league 45 degree full lock, which is said to keep the legendary turn circle.
Oh, and Wisconsin looks good in the snow :stuck_out_tongue: I’m headed for OH with a reload in PA back to Winnipeg. Just driver training right now, with my full provincial road test next monday. Here’s hoping, then I can get out on my own! yay! WITH A VOLVO :stuck_out_tongue:
G,day cliff
Good to hear from ya.Mate you always spot me ,im the one that can drive in a straight line :stuck_out_tongue: we will have tio meet up for a tube…ill pm my number
Skippy
I hope you are one that can reverse round corners too :exclamation: :exclamation:
I ain’t seen a western express driver who can yet :laughing:
(especially that ginger haired woman with the long platt down to bellow het ■■■ :laughing: I watched trying to get on a dock at C & S windsor locks for an hour once)
well pat, i use to drive for them and rest assured i had no problem wigglin my ■■■■ back into docks. i sometimes see my old truck. it is one of the es proline blue volvos no 19035.
Like Alikat, I’ve seen the press release for it too, and it looks the ugliest Volvo I’ve ever seen!, They taken the Volvo VN 780 Cab/Sleeper and married to a ’ large car’ undercarrige, it looks bloody awful, they’ve even stuck a bloody great elongated bonnet on it too. Huge exposed fuel tanks, 1/2 ton of chrome all round.
It really does look ridiculous. I know I’d never have one, not even if Volvo gave it! :imp: , I’d give it back and take a proper aerodynamic 630. I reckon Volvo have really got their collective heads up their arse’s on this one, seems they are trying to immitate Freightliners lame duck the ’ Coronado ', which is a ’ large car ’ version of the Century/Columbia.
This is to all you pratts at Volvo NA :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue: :stuck_out_tongue:
