ERF LV range & various cab updates
Thank you ERF for the explanation and picures. Are these the same LV number? The top grille mesh slots are different.
ccmv.aecsouthall.co.uk/p3299728 … #h3dd0d49e
ccmv.aecsouthall.co.uk/p3299728 … #h4917e55e
cav551:
You are welcome.
No, these are different cabs.
The 1966 D’ reg unit should have a 4LV cab with the 3 slots in the top grille, but has been re-cabbed at some point with a 6LV - you can see it’s got the later dashboard through the windscreen.
The 1967 E’ reg unit has it’s correct 4LV cab but featuring the larger top grille air intakes that I mentioned above were fitted to the later variants of the 3 and 4LV.
Just to clarify the top grilles for cav551…
The first vented ‘3 slot’ top grille was fitted to early 3 & 4LV cabs…
Later 3 & 4LV cabs got larger rectangular holes for additional cooling, the ends of the lower grille were also squared off to match, with additional slots opened up in the bottom panel…
Then the 5 & 6LV had even larger rectangular holes for even more cooling capacity…
Great photos ERF they all show a centre towing pin,but as I said in my earlier post we ran some E 1967 reg with one each side of the lower panel bolted to the chassis rails,or has my memory failed me.I’ll try to dig some photos out and persuade one of my lads to put one on.
Thanks once again ERF for the clarification which will help in identifying a fleet line up picture.
One other query has just occurred to me please: did 7LV cabs having a bustle to cover the rear cylinders of an 8 potter chassis have a type number suffix?
Singo55:
The two flat towing eye brackets either side of the lower front panel were used when a ■■■■■■■ engine was fitted. The round jaw was used with Gardners, and the optional starting handle passed through the middle of it!.
cav551:
The 7LV cab used on an 8LXB equipped A’ Series didn’t have a significantly larger bustle to cover the rear of the engine, not from the factory anyway. I have seen some, but they have always been homemade creations. To be honest most of the engine is covered, but the very rear of the engine was originally exposed to the elements, something the starter motor doesn’t like at all!. The rear of the engine was exposed to a lesser extent, even in the B’ Series day cab units with an 8LXB.
ERF:
Singo55:
Cheers ERF I didn’t think I had imagined it ours had the ■■■■■■■ fitted maybe they thought they wouldn’t need a tow!!
ERF:
Our Gardner 180 engined Fodens had a cowl covering the rear of the engine but we removed them to help with engine cooling, and yes, the starter motors did suffer but at least they were easier to access! :wink:
Pete.
Singo55:
ERF:
Singo55:
More confusion with the LVs: Castrol ■■■■■■■ powered, Henley Gardner powered: is this something to do with the K and L reg period?
I saw an ERF Chinese 6 on the M62 today . It was on the back of a Volvo low loader from a plant hire firm in Bury. The ERF was in the colours of Paul Cooper ( i think ) from Bury St Edmunds .
ramone:
THIS ONE
Ex-Killingbeck Transport from Blackburn. Another of Dr John’s tinkerings…
Great info here!
I notice that each pairing, eg 5LV and 6LV are only differentiated by the position of the axle. What was the significance of this? Was there a reason to do this?
The odd numbers denote set-back axle and the even numbers denote set-forward axle. The same works for the metal-cabbed MWs (4MW, 5MW, 6MW, 7MW & 8MW). Before the LV cab, the same system worked for the MV cab.
I’m not sure why both were offered but I suspect that it was to do with the fact that in general, the set-forward axled units were 6x4, so it might be a heavy haulage issue. Having said that, there wasn’t a 6x4 A-series so there must be other reasons. Or it may have been a clients’ preference thing.
SEE EDIT BELOW …
Just found an article by Peter Davies I once scanned and put on one of these A-series / ERF threads. It’s in the Feb '98 issue of Trucking International pp. 78-80 and is about the A-series.
He says this: ’ All were built on a short front overhang layout using the 4LV and 6LV cabs. Set forward cabs (3LV & 5LV) had appeared on lighter weight tractors in the early '60s, but with the advent of 32-tonners, a short front overhang was favoured in order to achieve the maximum outer axle spread.
A 13m legal length limit was in force between 1964 and 1968, so axles needed to be as far forward as possible to qualify for the highest gross weight ratings. When the weight limit was extended to 15m in 1968, designers had greater flexibility in axle positioning.’
… and here, a reminder of how early these ERFs became regular visitors to the Continent:
