JSingh:
Thanks for the commentsIt definitely does 90kmh at 950rpm. The truck has been maintained by scania for all its life so I’m guessing by some of the comments it’s probably normal for it to be sitting at 950 but is it healthy for it to keep changing down to 11th? As some of you know opticruise isn’t the sharpest of changing gears and sometimes the truck goes up an incline and realises it’s in the wrong gear and knocks it down to 11th 1/4 way up the incline and then obviously you lose the momentum!!
Is the only option to change the diff? What would you guys suggest doing? Btw it’s a 520 so perhaps it’s designed to get best fuel economy but I’m averaging 7.5/8mpg. I’ve got other trucks giving me minimum 9/9.5mpg for the same work
Has it got a manual option.If so leave it in manual and experiment with downshift and upshift points.Bearing in mind that,according to it’s graphs,it will put out around 380 - 500 hp under full load between around 1,000 rpm - 1,300 rpm.While anything much over 1,400 rpm is realistically just burning money bearing in mind that it’s only putting out less than an extra 20 hp at 1,900 rpm than at 1,400 even under full load.On that note who needs revs or a ‘run’ at the hills although 950 rpm at anything other than very light engine load could possibly be costing fuel rather than saving it.While it’s my bet that any of the big power Scanias would do better on fuel with an 18 speed Fuller,to allow the driver to optimise engine speeds under all types of engine load conditions,than a 12 speed auto.
I used to drive an R730 and it sat at 58mph and that did 8mpg so i would say your R520 needs looked.I would say it should sit between 1200-1300 rpm any truck i’ve driven has sat about there.
