Well, I’ve had a chance to look through the software offerings and their respected prices for some of the evening, there are quite a few out there but most either don’t seem to work as well or are too restrictive in their ‘demo’ mode or even that they don’t offer such things. It would have been nice to ‘trial’ some of these bits of software but you know how restrictive some companies are
Maybe they are more interested in targeting bigger companies than the little fish. Anyway.
My card has not had heavy use and as such has records back to 2008, well, the old card does anyway. Thanks to the Code 48 issue I have 2 cards, and the fresh one is empty. So. Having borrowed a card reader I set about to see what was out there.
I took the suggestion of the GloboFleet software for £20, the electronic download variant and it does seem quite comprehensive, but there are gaps to what it can do. A fair bit of stuff is kept out to encourage, perhaps, you to move up to their ‘plus’ version which is about £60.
The £20 version will show you most of the information stored on your driver card, such as the Serial number, your driver licence number, DOB, Issue from and valid too date.
For actual days it will show activities, country of use, start and end times of those activities as well as the registration number of the vehicle, if stored. If you are single or double manned and the graph at the top showing your mode selection at the time.
The more expensive version will give you information such as infringements (violations).
If you want more than that, such as detailed reporting of each days activities in report form then you would probably want to consider the Tachomaster instead. It is between the two prices of the basic and plus option in GlobaFleet but does a lot more, and is probably better suited for those who would be using it more than I would, just for keeping records.
The other two differences between these software packages are that the latter is more of an on-line service and the former can be used off-line without any problem.
I was also pleased that all the software as well as this XP computer recognised the card reader (GemPlus) OK without any problem at all… The Tachomaster is about £52 per year with other additions here and there.
GloboFleet
TachoMaster Pricing
Both of those I have gone for software each and not the full package as I have the card reader here.
