Mazzer2:
To the OP can you get your officers on the ground to all sing off the same hymn sheet when it comes to ferry movements. Everytime I’m stopped at the end of the check yet another way to use the ferry mode is explained to me, last summer in Crick I was told to do it as follows, stop in lane enter end country, move onto ferry press ferry mode, press ferry mode again on leaving ferry finish break and enter start country, all fine except if you are driving onto the ferry outside of your 15 hours by entering fery mode after you get onto the ferry it will throw up an infringement of driving outside your spread, press it before moving and there is no infringement.
Two weeks ago my friend was stopped an Liverpool docks and told the following way was correct, stop in lane enter end country press ferry mode, move onto ferry press ferry mode, press ferry mode as you leave the ferry, finish rest enter begin country.
Surely all your officers should be using one method only as it seems each checkpoint has it’s own method I have had several ways explained to me and saying “Well that’s the way the last DVSA officer told me to do it” cuts no ice and can you also ensure that police officers even know what a ferry break is, the amount of times a policeman has downloaded the card come back to the lorry and told me I have total disregard for drivers hours and am looking at going to court. Turns rather sheepish when a diary is produced and about 10 ferry movements are shown to him.
That sounds like a can of worms you`ve opened there!
I was getting lots of infringemnets flagged up, but now rarely get them.
Firstly about interrupting a daily rest after a 15?
Only a “regular daily rest” can be interrupted. So if “doing a 15” will need to have had a 3hr solid break during the day or else you are interrupting a reduced daily rest, which is a no-no.
The daily rest still needs to be completed 24hrs from the start of the shift. Even if it is split by ferry moves. That 24hr rule stands.
(Ignoring “15 spreads” for the moment)
If you start at 06hrs00 and arrive in the lanes at 18hrs30 and book off,for instance, you will not have 1hr movement available. There is 11hrs 30 until 06hrs00, that is 24hrs from shift start. To get your 11hrs rest in you can only have a total of 30mins interrption, be that in one or two slices.
To have your full 1 hr interruption available you need to limit to a 12hr spread. Start at 06hr00, book off in lanes at 18hrs00 and you`ll have time for 1hr of ferry movement plus your 1hrs daily rest before 06hrs00 the next day.
Ive got a Stoneridge Exact Duo Tacho. I arrive in lanes, book off including end country. When about to board hit ferry mode and 60mins will appear. (less if Ive gone over a 12hrs spread). That available time counts down from when the vehicle makes a move, not from the instant of hitting the button. On board, push button to get bed symbol back again, and daily rest continues.
To move off assuming daily rest not finished: enter ferry mode again. The countdown will be 60mins less the time taken to move on, (so might be 30mins or so left) again that doesnt countdown until the wheels turn. Off the boat, park until daily rest completed, and then book on in new country. Doing that Ive had no problems with analysis recently.
We run into Pompey a lot, and because of the Waterguard clearance time I wont normally board a ferry in France, until I know I can get off with my daily rest completed. It takes so long to debarque, Ill let one boat go, and catch a later one to keep it legal. Pain in the ■■■■, but better than a fine from the police or gendarme, be it weeks later.
That works for me, anyway.
(Touch wood
Ed to add:
gov.uk/guidance/drivers-hou … vers-hours
“Where the regular daily rest period is interrupted in this way, the total accumulated daily rest period must still be at least 11 hours or 12 hours if split.”
“Any regular daily rest period that is interrupted must be completed within the 24-hour period (if single manned)”
