Digi tacho moved to POA
Parked up at 19:19hrs last night tacho onto break, any around 20:34 it went to POA no doubt I must of hit it accidentally and recorded 1hr 29mins worth.
When I noticed I put it back on break and did a print out, to explain the mode change.
Started work again at 04:20 hrs, do you think VOSA would get exited about it? Did a check this morning and yesterday’s driving was cleared.
I leave card in from mon - fri away all week.
weeto:
You would be better off doing two printouts and writing an explanation on both of them, hand one in when your card is downloaded and keep the other with you in case you get stopped.
I assume you was on a night out in the vehicle so I doubt VOSA would be too bothered as long as you’ve got a printout and an explanation.
Cheers tachograph, I did 1, I will do another and keep the one I did last night.
