digi card
my digi card threw up a fault code 41. any one know wot to do
burn it, failing that urm wipe the chip, failing that send it back for a replacement
Card Communication Error (Presume faulty card?)
Check here:-
Siemens Event and Error Codes
01 A serious fault has appeared in the device or a
communication fault
02 Ditto
03 Ditto
04 A serious fault has occurred in the device
05 Communication fault
06 Time error
07 Display fault (i.e. no display)
08 Keypad error
09 Calibration memory error
10 v-pulse output (B7) fault
11 Printer fault
12 A communication error has occurred while
downloading card or mass memory*
13 CAN, internal error
14 CAN fault, bus off
15 CAN, communication error between recording
unit and external display instrument
16 Internal sensor fault
17 Fault in sensor data authentication
18 Error in sensor authentication
19 Sensor power interruption
20 Error in sensor communication
21 Error in sensor communication — no real time
signal
22 Error in sensor communication
23 Sensor authentication error
24 Unknown sensor serial no.
25 Error in data memory
26 Housing of recording unit opened
27 Invalid signals at calibration interface
28 Driving without a valid card in slot 1 or driving
with an invalid card combination in card slots 1
and 2
29 Invalid card combination in card slots 1 and 2 * Also if the battery power had been disconnected during the download period, indicating that no data can be downloaded for those particular days. (if this occurs then the download process can continue normally)
30 The programmed overspeed setting was
exceeded for longer than 60 secs
31 Recording unit power interruption
32 Calibration error
33 Motion sensor impulse when ignition is switched off ejection not
possible
34 A card cannot be ejected (i.e. whilst driving) process delayed
35 Card processing delayed printout not possible
36 Printout not possible due to no ignition, driving,
temperature rise or low/high voltage printout delayed
37 Printout delayed or cancelled due to temperature
rise or under/overvoltage
38 Printer drawer open no paper
39 No paper in the printer
40 Card mechanical system fault
41 Card communication error Try putting it in other way up!
42 Authenticity of card data can not be ensured
43 Card exchanged, missing or interlock open
44 Last card session was not closed correctly
45 Negative time difference compared to the last
vehicle
46 The driver card was inserted whilst driving
47 Authenticity of card failed
48 The card has either expired, is not yet valid or
the authentication has failed
49 While reading in a card (in slot 1), an
inconsistency is found in the links within the data
50 The inserted card (in card slot 1) cannot be read
or written to.
51 The card inserted is not a valid tachograph card
52 The inserted Workshop Card (in slot 1) is
blocked
53 Process not possible, tachograph card is not
accepted and is ejected
1 Break! 14h30 00h15 56 Continuous driving period of 4 hours 30mins exceeded+
1 Break!14h15 00h15
57 Continuous driving period of 4 hours 15mins
exceeded+
58 Card mechanical system fault — Slot 2
59 Card communication error — Slot 2
60 Authenticity of card data can not be ensured — Slot 2
61 Card exchanged, missing or interlock open — Slot 2
62 Last card session was not closed correctly — Slot 2
63 Negative time difference compared to the last
vehicle — Slot 2
64 The driver card was inserted whilst driving — Slot 2
65 Authenticity of card failed — Slot 2
66 The card has either expired, is not yet valid or
the authentication has failed — Slot 2
67 While reading in a card (in slot 2), an
68 The inserted card (in card slot 2) cannot be read
or written to.
69 The card inserted is not a valid tachograph card
— Slot 2
70 The inserted Workshop Card (in slot 2) is
blocked
71 Process not possible, tachograph card is not
accepted and is ejected — Slot 2
2 Break! 14h30 00h15 -
74 Continuous driving period of 4 hours 30mins
exceeded+
2 Break! 14h15 00h15 -
75 Continuous driving period of 4 hours 15mins
exceeded+
77 The DTCO 1381 is not fitted with a software upgrade
Upgrade failed
78 The upgrade file is defective or damaged. The software upgrade has been cancelled
79 The management device could not be
authenticated. The software upgrade has been cancelled.
  • Continuous Driving Time is computed within the recording equipment as the current accumulated driving times of a particular driver, since the end of his last AVAILABILITY or BREAK/REST or UNKNOWN period of 45 minutes or more (this period may have been split in several periods of 15 minutes or more).
Please Note: If an error or fault is repeated on a regular basis, please contact a VOSA approved Digital Tachograph Centre
It could just need a wipe with a soft cloth to clean it.
( 80) take your tesco clubcard out & all previous points will be lost :laughing: :laughing:
