This will seem like a stupid one, but the last time I tramped it was on the paper charts and only done digi on day work.
Do you leave your card in when your on daily rest? At the end of the shift and you park up do you just put it on bed and thats it or is there something else you should do to show end of shift? Same the next morning, do you just change it to work and record your checks?
Like I say, may be obvious but the last time I tramped we were on the old discs
Take it out or leave it in - your choice, although I think most leave them in.
If you do leave it in, you MUST still record the start and end country at the beginning and end of your work period (even if you never go abroad).
Sent from my VOG-L09 using Tapatalk
I always pulled it. Just on the off chance you need to move ya vehicle, due to unforeseen circumstances. It happens…
as soon as the wheels stop,pull it…that way if you need to move its all down to the lies you write on the manual entry if your doing anything unexpected or naughty,which is the only time you will need to do a manual entry unless your working for a company that wants them,in which case its up to your own discretion.
