Deep pin 14.04 metre Krone trailer
We’ve just got 6 of these Krones used from BG. Anyone know the pin depth of a 14.04m? Wont make any difference to me as lwb 4x2 with slider but with one of our Spanish drivers tonight and the questions cropped up as his 5th is fixed…
AndrewG:
Andrew,
You’re the only chap in Spain with a slider. They ain’t allowed you don’t get the ficha técnica when fitted with a slider.
How have you managed it ?
Is the maximum pin depth not 1600mm, regardless of the overall length of the trailer. (At least within C and U regs)
Tubbysboy:
AndrewG:
Andrew,
Bought new around 3 months ago from a NL dealer, delivered to Spain and retro fitted with a low ride SAF slider. The six other units the company i sub for has with sliders (Scania R620’s) are NL reg…
Old John:
I thought it was 2.04 metres but cant be sure…
It possibly can be 2.04 if measured to the front of a contoured fridge unit, but I think it will be 1.6 to the actual headboard of the trailer
If the projection was 2.04, the unit would need a wheelbase around 4.5 metres to get the weight distribution right, and even then, with a 2axle unit , the potential to overload the unit would be considerable.
Having said all that, a lot of these regulations are not pan-European, so may very well be all good in some countries.
AndrewG:
Old John:
I seem to recall it’s a 2.04m arc forward from the pin, so front corners are 2.04m from the pin but a straight line from the pin to the centre of the headboard is 1.6m, unless you have a bowed headboard or fridge motor on the front of it.
I also seem to recall there is a maximum of 12m from the pin to the rear of the trailer, not including loading devices such as taillifts.
Thanks for the replies, appreciated… :wink:
