Hi
I am looking to swap my 65plate XF TNR stereo for a DAB radio,as the Bluetooth and CD are knackered.
Upon getting the unit out,it is 12v and made by Bosch,but the connector is quite big,anyone know where I can get a iso wiring adapter from please?
Has anybody even gone and changed the TNR unit(radio/satnav/CD/Bluetooth)?
Is it even possible?
Cheers
It is most certainly possible as all of our fleet are fitted with single DIN Kenwood DAB head units. It does require an additional antenna to be fitted for the DAB side though as it uses a different frequency to broadcast FM so the normal antenna isn’t usable. Ours use one stuck on the window but the reception isn’t as good as an external one on the roof would be.
I’d try a DAF dealership as a first port of call.
A photo of the block would help, I’m assuming it’s a standard iso din conno,if so should be any head unit with standard iso din connection.
