Daf radio problem
Hi guys, bit of a long shot this one but hopefully someone knows the solution
Came back from a weeks holiday to find the radio in the truck is on mute. It’s one of the fancy Daf all singing ones with the built in sat nav.
Volume won’t adjust with either the knob on the unit or the controls on the steering wheel.
If I go in to factory settings and reset, it will play at 5 volume but still no control up or down and once engine is switched off again , no volume until reset.
Anyone experienced this before or have any ideas?
Thanks Duncan
Dunky123:
Is it under warranty?
Technology, don’t you just love it - - - not !
Have you tried turning it off and on again :bulb:
Lol, yeah tried turning on and off again. No it’s not under warranty
There’s a mute sign showing on the display, I’m going to try and get the unit swapped over as the sat nav never shows the correct location of where it is eg in our yard in East Kilbride it thinks it’s in Ireland.
Thanks for all the replies.
pull out the fuse for the phone for a minute then put it back in and that should sort it, if not do the same for the radio
Thanks, I’ll give that a try tomorrow and will let you know.
It could just need a reboot,
I had a landy once and the Radio gave endless problems. It was fixed by disconnecting the batteries overnight which reset the system including the radio.
Pulled the fuse out radio working as normal
Thanks guys
DAF repair kit
(I really like DAF, great cab to be away in, but they really have gone downhill electronics wise. I now think the new Gen Scania is a better truck. Hopefully the new DAF is a beter truck than the 106)
