Hello! I need to pick your brains if possible please.
I have a '53 plate LF45 horsebox, used weekly. Went to it a few weeks ago, totally dead - nothing - as in turned key, no attempt to turn over, no clicking. Called mechanic, batteries were flat (despite isolators being off) - batteries replaced, isolators now off and out of the key hole totally when parked up. Assumed problem solved. Prior to replacing batteries, starting had been a bit rough - as in turning over and eventually firing.
Went out 29th July, started first time, normally (turned key, fired up straight away, not struggling). Drove for 20 mins, stopped for diesel - wouldn’t start, not even turning over - all lights/camera as normal, so definitely power there, just nothing happening engine wise! Tried phoning for help, no one answered - turned key one last time, fired straight up and drove normally. Drove to destination, parked - tried to turn back on, nothing. Competed, loaded up a few hours later, turned key - started as normal.
I looked online and saw some comments about the chip in the key dislodging. Tried the spare, fired straight up! Problem solved, I thought. Drove to Coventry, parked up for four days. Turned key to come home yesterday, nothing - one little chuffed from the engine, then nothing. Isolators off all the time we were away, no hook up, no lights used. Initial attempt was with spare key (which worked straight away at home), swapped to normal key - started.
I’ve got no warning lights, it’s running beautifully apart from this…does anyone have any suggestions/experience of the same thing?! Thank you for reading ![]()
