The brakes jammed on on our 3 year old DAf this week, due to a problem with the 4 way valve.
Apparently when the vehicles were made ( 2006) they fitted the 4 way valve and air dryer, but didn’t include a filter, so there have been loads of problems with oil contamination.
If this fails under warranty they will replace it with the new improved model.
However even though they know it is a design fault they have never had a recall on this as far as we know - even though it can be quite dangerous if all brakes lock on!!
When you replace the 4 way valve you are advised to also change the air dryer for the new model as it is likely to contaminate again without the new oil filter. You cannot get the old model without the filter and also have to get a new bracket as well.
How do you find out if there has been a recall? Is there a central list like there is for cars?
Has anyone else experienced this? Apparently a number of companies have taken this up with DAF who have rejected all claims.
If you have a DAF - see if you can get it changed while under warranty and don’t wait for 3 weeks after it has run out !!!
