Daf / Alpha diesel tanks
Anyone know if they are all the same with regard to fitting a night heater / pick up pipe or do I need to fit a stack pipe ,my Alpha for some reason didn’t have a heater from new but it looks the same tank top as the 85 Daf which does have a heater .i would think I just need an end of a scrapper to connect to ?
The tractor unit is identical ,will probably have DAF stamped on it …tractor unit wise the only real difference was the engine , some badges and different skins on the door…Preferred the Foden headlamps with the black backing though
It’s a mk1 Norb ,so really it’s a foden with a Daf cab ,rather than the Daf with a ■■■■■■■ engine .so if I get a pipe end will it pick up fuel ?
Hi Dan,will have a look for you in morning,has your’s got a plastic fitting round the stack pipe?
Ahhhh sorry I couldn’t say wether the mark 1 alpha tank is the same
Iam sure it’s and that they’re all the same I think the top 2 are pick up and return leaving the bottom ones for breather and night heater ?
Sounds like the same as a Daf,if it’s not the same swop it for one of Seth’s,then he got the earhole off his driver!
I’ve twisted the top out today ,top 2 are pick up & return ,bottom 2 one is pick up ,one is return ,the breather is separate ,the bottom one with the out facing arrow has a stack pipe to the bottom of the tank so all I need is a end of a scrapper to fit in .
