CPC conversion test revison
Hello, sorry if this has been asked before.
What is the best revison material for the HGV CPC conversion test? I’m told I’m doing a slightly different test than the HGV case studies test as I have CPC for buses.
Thank you
Did you pass car test before 1997 :question:
If no then ignore this post
Thanks for your response.
No I didnt.
I’ve passed both bus and HGV driving tests recently, but just need the CPC for HGV.
Do you have any idea what revision material I should be using to get the CPC?
stevegregory96:
No I didnt.
Same as the normal Mod 2 test but just ignore the PCV bits
drivingtheory4all.co.uk/lgv … heory-test is the only one I can find
Thank you very much for this
