Conor:
Williams9881:
What’s the difference between lorry drivers and nurses? Since when was giving a few injections and wiping ■■■ a hard job? We have to put up with high stress isolation and no social life.
I’ll bite.
3 years doing a degree. Nursing has moved way beyond jabbing someone with a needle and wiping someone’s arse. Nurses are now doing some of the jobs doctors do including patient diagnosis and issuing prescriptions.
Anyone with a pulse can drive a truck as many on this forum prove. You don’t need to be a rocket scientist. Many on this forum though wouldn’t even make it past the first stage of application to be a nurse because they’re too thick.
How old ARE you?? You must be over a hundred, what with all the ■■■■ you’ve done in your life.
the nodding donkey:
Conor:
Williams9881:
I’ll bite.
How old ARE you?? You must be over a hundred, what with all the [zb] you’ve done in your life.
You not worked it out yet Mule? CONOR…as in Connor MacLeod (immortal) born 1518. There can be only one
Conor:
Williams9881:
I’ll bite.
