Class 2 course do I need to learn manual gears?
Hi Guys
Looking to do my class 2 but been told I would be learning using unit with automatic transmission
Would this cause a problem if I passed my class 2 test then went on to apply for jobs using a manual gearbox?
I’ve driven a car with manual gearbox for the past 15 years if that helps
Many thanks
Alex2020:
Hi Guys
Many thanks
New rules came into force a few years ago where those with a manual car licence then passing LGV in autos will get LGV MANUAL
EDITTED FOR ERROR :blush:
Ahh ok thanks Rog
Sounds like I need to specify with my training provider before booking that I’m looking to get a manual license
Should maximise my job opportunities that way
Thanks again
Alex2020:
Ahh ok thanks Rog
No need to as DVLA will automatically give you LGV manual after passing in auto as long as you have a manual car licence
ROG:
New rules came into force a few years ago where those with a manual car licence then passing LGV in autos will get LGV auto
I think ROG had a small typo. If you pass your car in a manual, then you can sit subsequent tests in an auto and still have manual in the new class.
Noremac:
ROG:
TA - have corrected my post :smiley:
The vast majority of class 2’s are manual 6 speed or auto boxes these days, but you do occasionally get the 8 speed manuals with range switch.
In my experience, those are usually the wrecked bits of kit, but saw less and less of them as my agency days went through. Likely because thry became too expensive to fix.
Do it in an auto and uou can quickly learn the pld style manual if needed.
As said anything 18 ton or less will either be a standard 6 speed manual box or auto usually apart from some trucks like skip wagons and anything above 18 ton will maybe have an 8 speed box but most newer trucks are all automated manual trucks these days.
I’ve done mostly Class 2 agency work since passing my test in February 2019. It’s been easily mostly automatic gearbox since. Done some 5-6 manual gearbox which is no different to a car or van. I did a week last year on a manual 4 over 4 gearbox which is a manual gear lever with a switch at the back. You have gears 1-4 as normal and then flick the switch to get 5-8. Takes a little getting used to as you can be in 6th and only doing 30mph. Went to Ireland this week and had it again but it all came back to me. Mind you, my first time was driving around central London so that was a fast learning curve. You’ll be fine I’m sure.
I quiet like the 4 over 4s after the first minute or two of ‘oh no not one of these again’ you soon get into it. I usually go 2/4 switch 5/6/8 occasionally start in 3 then switch and into 5. You soon remember to switch it at lights before you pull off. Once or twice trying to pull off in 6th and you soon get it.
So find the manuals easier to reverse , a some autos even with crawl mode tend to go from stopped to zoom quick, when reversing onto a dock it’s easier to kiss it rather than smack it with a manual.
Sent from my moto g(6) play using Tapatalk
