Muckaway:
I use the standard twig supplied by Daf: Are these any good? I donât get out very far (none of us who use these do) and I was wondering if I took out said twig and swapped it for something else, would I get a better result? Would attaching some wire from twig to cab make any difference?
Attaching some wire from your twig to your cab will make things worse. The original Daf fitted mount will have a good earth to your cab, which should be good enough. If you can get to the back of your mount, you could try giving it a clean-up with emery paper and tightening up the fitting to get a good earth. If itâs at all loose, do that asap.
I donât know how good those Daf aerials are. The Volvo ones were crap but you could buy better ones made to fit the Volvo mount. I expect the same aerial would improve things for you.
Moose:
so called Pre tuned aerials are only tuned roughly and as a rusult iâve never fitted one yet that does not need tuning!
the crap thats written on the packet is just that crap!
the reflected power off an un tuned aerial will damage the transmitter (output transistors) in no time
OK then Moose, which channel (frequency) do you tune your rig too if itâs SO important for the health of your CBs transmit side? And do you tune it to the same channel if you have a CB that does both UK and EU frequencies? If I use my 480 channel CB, do I tune it to the middle of its range and pray that the standing wave isnât too far out at either end of its frequency range, or do I tune it to channel 19 in the UK frequency range and hope no-one wants to use the furthest away channels because Iâll burn out my transmit side?
Fine tuning your aerial and co-ax to your CB on a channel will give you optimum reception and output on that channel. Each frequency has a slightly different wavelength in its standing wave, which gets further out of tune with your co-ax/aerial the further away from that tuned channel you get. How far out does your tuning have to be before the reflected power of your 4w CBs standing wave starts to seriously affect your transmit side?
In short, as I said earlier, a properly tuned co-ax/aerial will pull in and get out further than a rig that hasnât been tuned. But not spending that extra ÂŁ5 or so isnât going to burn out your rig unless itâs REALLY out of tune, which a new co-ax/aerial wonât be. Even tuned, itâs still only âroughlyâ in tune by the time you get 20 channels away from the channel you tuned it to, let alone 40 or 240.
Iâve spent many hours making all sorts of tunable antennae, for long range radio transmission and reception. Iâm talking about 100s of miles, using military frequencies on military kit. Granted that kit was much more robust than a CB. It also had much higher transmit power, but we still used the same length of antenna for a wide frequency range, only changing antenna length when reception started to tail off. This was a change of at least a foot, not a couple of mmâs (at most) which is what weâre talking about in tuning a CB aerial.
