Like most things it will probably come down to price, the cost of the device and the cost of the hardware inside it.
So no idea how to answer such a question.
Your pixel GPS specs are
PositioningGPS, GLONASS, BDS, GALILEO
My Oppo find x 3 pro specs are
PositioningGPS (L1+L5), GLONASS (L1), BDS (B1I+B1c+B2a), GALILEO (E1+E5a), QZSS (L1+L5)
Both according to gsmarena assuming the info is 100% correct on each devices specs.
So looks similar up to a point.
Prices ar time of release as far as I can tell
Pixel £699
Oppo find X3 pro £1099
Not a massive difference in phones prices.
My previous Huawei P30 pro shows the exact same god specs as my Oppo find X3 pro on gsmarena.
That’s just searching a few phones and results may vary depending on spec of the phone, materials it’s made of etc and locations it has been used. But every GPS device in very built up areas will have some issues and lose its location.
Google says
Since four satellites must be visible from any point on the planet and the satellites are arranged into six orbital planes, the minimum number of satellites needed to provide full coverage at any location on Earth is 24.
en.m.wikipedia.org/wiki/List_of … Satellites
31 satellites currently orbit the earth. According to the wiki link above. You need a minimum of 4 satellite’s in view for GPS to work. The more it can see the better.
That’s the best I can do to quantify your gps question. But how the specs on different devices can translate into a more reliable GPS device who knows. It all depends on how many satellites are visible and on built up areas no matter what device if there isn’t at least 4 visible then nothing it going to work until it can see at least 4 satellite’s again.
I guess the higher the specs as shown above should make it more reliable in theory. And if it uses L1 and L5 again it should be more reliable and accurate.
And that’s all I can figure out but I’d expect black spots in any dense city with lots of tall buildings around. Older devices will obviously be less reliable due to older tech. Newer devices should be more reliable due to newer tech.
Sent from my CPH2173 using Tapatalk
