BEST 'ERGO' ?
VALKYRIE:
Best Ergomatic Cabbed-Lorry Model? PART 15.Page 21.TRUCKNETUK.
LEYLAND 700-SERIES FIXEDHEAD HEADLESS WONDER DIESEL ENGINE - DR.ALBERT D.FOGG’S IDEA AND PROJECT.
Carryfast.
I draw your attention to what Gingerfold has correctly said about Michael Knowles:-
“Thanks for the link. I will read it over the weekend. All I will say if it is by Mike Knowles…, well,this man is well known in certain circles for opinions and views that are eccentric to say the least.Gingerfold.”
And this is what I said in regard to Michael Knowles in my POST 13 of this thread:-
VALKYRIE,“But Michael Knowles seems to be obsessed with feet,inches,fractions,meters,centimeters,milimeters,
fixings and fastenings in the British Commercial Vehicle Industry,and has had several articles
published on this overall subject,namely The Metrication of the British Commercial Vehicle
Industry,in various publications,including the HISTORIC COMMERCIAL VEHICLE SOCIETY’S Historic Commercial Magazine.
Some of what he says in this report is wrong.For example,as I said in my PART No. 10 of this
thread:-
“The Leyland Group had cylinder head gasket problems with some of it’s AEC and Leyland
engines,but,although these blown gasket problems were largely cured,it was our old friend
Dr.Albert Fogg :slight_smile: that came up with the idea of using a fixed cylinder head for the new engine
range”.
So it wasn’t Dr.Mueller’s idea.”
So add the above two comments together,plus the other fact that Doug Jack is almost certainly
a more accurate and reliable historian and writer with more balanced views,and you must come
to the conclusion that it was Dr.Albert D.Fogg,Leyland’s Director of Engineering,who was
the mastermind of the Leyland 700-Series Fixedhead Headless Wonder Diesel Engine.
I said that Dr-Ing Alfred Mueller worked for Leyland until the early 1960s,Albert Fogg became
Leyland’s Director of Engineering in 1964 - Doug Jack said that Albert sometimes came up with
unconventional solutions to technical problems,and he somehow did not fully fit at Leyland.
Thus,bearing all that in mind,it isn’t really suprising that Albert came up with the Leyland
700-Series fixed cylinder head engine.
LEYLAND L60 TWO STROKE MULTI-FUEL TANK ENGINE.
As for the fascinating and MUSICAL Junkers aeroplane two stroke diesel engine-inspired
Leyland L60 19-Litre 6-cylinder Opposed Piston Two Stroke Multi-Fuel Engine for the Chieftain
Tanks,surely it was more reliable than it’s made out to be. It also offered a better power to weight ratio than a four-stroke engine - tanks are heavy,and the designers wanted to save weight,yet use a powerful engine that was light in weight,hence the Leyland L60 engine which was the ideal engine.
VALKYRIE
Firstly the point which I was making was that it seems to have been Spurrier,acting on the advise of Dr Mueller,who introduced the idea of the headless Leyland 500 ci capacity engine not the AEC 700 ci idea as Dr Fogg rightly intended.Which by all account seems to have been on the drawing board at least before Spurrier’s unfortunate demise which if I’ve read it right was in 1964. :bulb: :wink:
Secondly no the L60 in the Chieftain tank was far from ideal.I spent long enough at the MVEE at Chobham to hear first hand it’s record in military service and it really did deserve that description of being an absolute dog of an engine which cost Leyland a fortune in sorting out it’s problems.Therefore it was no surprise that the MOD ( rightly ) specced the Challenger replacement to the Chieftan with the Rolls CV12 four stroke.Which provided almost double the overall vehicle power to weight ratio of the Chieftain.However if you’re going to use a two stroke then use a good one in which case the Detroit 12V71 in the Vickers MBT Mk 3 of 1975 provided around a similar amount of power as the L60 and a similar overall vehicle power to weight ratio as the CV12 in the Challenger.While even the old Rolls Meteor in the Centurion provided a better overall vehicle power to weight ratio than the L60 in the Chieftain did. :wink:
We do go off on some weird and wonderful tangents on these threads. :exclamation: :exclamation: :exclamation:
So if you will please indulge me, I managed to wade through Michael Knowles’ waffle of a report last night and would make the following observations.
  1. Spurrier had no involvemement in the day-to-day management of Leyland Motors in the days when the 500 series engine was being planned and developed.
    2.The report’s author claims to have been Donald Stokes’ personal assistant…enough said.
  2. He makes no mention of AEC who designed the V8 as a “metric engine” some time before the 500 engine even got onto the drawing boards at Leyland. AEC later re-designed the V8 as an “imperial” engine.
  3. I can demolish Michael Knowles’ obsessive ramblings about metrication very easily, but I really cannot be bothered. Anyone with any common sense can work out that what he has written is nonsense.
gingerfold:
Graham, I totally agree with both your conclusions, and what you say in your post. Cheerio for now.
VALKYRIE:
With respect,if you carefully read my Post No.10 and Post No.13 I actually state that,to avoid cylinder head gasket problems in the new 700-Series -11.4-litre diesel engine,Dr.Albert D.Fogg,Leyland’s Director of Engineering,strongly favoured a fixed cylinder head for this new engine :slight_smile:
Doug Jack,who worked for Leyland as a legal advisor and later became the Secretary of the Truck
and Bus Division,and who has written several books on Leyland motorcoaches and buses,has stated
that the fixedhead engine was Albert Fogg’s idea as was the 700 CID-11.4-litre capacity.
Albert Fogg joined Leyland in 1964,and became a board member in 1965,Dr-Ing Alfred Mueller left
Leyland in the early 1960s and had nothing to do with the 700-Series engine.Albert Fogg developed
this engine,and when the Leyland marketing men called for the engine to be reduced in capacity
to 8.2-litres because supposedly it was too heavy and too physically large,and had to weigh less
than 1000 Kgs :unamused: ,Albert Fogg walked out of Leyland! :exclamation: :laughing: He must have known that a 500 CID engine was just too small and was not fit for purpose to work in 32 ton GTW lorries :unamused: :slight_smile:
I also state in Part 10 that this sudden reduction in engine capacity resulted in quality control
problems in the production of these engines :unamused:
VALKYRIE
It does not seem a bad decision to make the fixed-head engine the size it became. The group already had two 11 litre engines, a 12.6 and another 12-13 litre one on the board. It was not a rash claim, that an 8 litre engine would power a range of vehicles up to 32 ton gross- the Buffalo was a popular 32 tonner, as were the Scania LB80/81, Volvo F86 and DAF F2000-2300 (Good post, Lilladan). The fixed-head idea was a bold step, and any new design will take a large investment to make it work- Leyland’s desire to spread the appeal of the engine over as many market segments as possible was a good one.
If Dr Fogg resigned his post, I find it difficult to believe that the capacity of this engine was the reason. The capacity of an engine has no bearing over the quality control of a factory.
this is the best ergo i got, :blush: :smiley: :smiley: cheers benkku
bma.finland:
I remember them running across the M62 in their droves when i was a kid Benkku
Most on here could see the potential down at Southall ,wouldn`t you think that either ,1 of the Europeans or even the Americans would have stepped in and bought them even if only for a foothold into the UK market, a dealer network and even a loyal customer base not forgetting the products that desperately needed the investment they so badly lacked ?
[zb]
anorak:
VALKYRIE:
VALKYRIE
It does not seem a bad decision to make the fixed-head engine the size it became. It was not a rash claim, that an 8 litre engine would power a range of vehicles up to 32 ton gross- the Buffalo was a popular 32 tonner, as were the Scania LB80/81, Volvo F86 and DAF F2000-2300 (Good post, Lilladan). The fixed-head idea was a bold step, and any new design will take a large investment to make it work- Leyland’s desire to spread the appeal of the engine over as many market segments as possible was a good one.
:open_mouth:
The bore/stroke and overall ‘size’ of an engine are 3 of the most important basic starting parameters that will determine it’s eventual performance,efficiency and reliability in service.Accepted ( and proven ) engineering practice shows that a good reasonably stressed big engine will always beat a good overstressed small one.Maybe you can list how many 8 wheeler 32 tonner tippers or even many 4 and 6 wheelers are powered by engines of overall capacities matching those which you’ve listed there today after all these years of development in finding out what works best.The fact is the small overstressed engine idea was a relative flash in the pan based on some dodgy,if not downright incompetent,thinking on both the part of the engineers who believed in it and those customers who bought into such bs.
carryfast is right in a way ,a elephants heartbite is about 40/sec and a rabbit abit over 160 .but can a elephant do everything as …the rabbit in a lifetime . yes the elepanth is stonger and lives longer ,but the rabbit,s are smaller and can go true the neadles eye in many generations thought :confused: so what to prefere,cheers benkku
ramone:
Firstly it’s difficult to see what was in it for the Americans or the Euro manufacturers.However they did try to do exactly that in many other cases with the logical conclusion ending up with some reasonably successful Foden products.Which then of course had to be killed off because they were creating in house competition against the host company’s products in the colonial markets.While in the case of Leyland just building DAF’s here was the logical conclusion which anyone could see was going to end up being all that was left of the British truck manufacturing industry from at least the mid 1970’s.While even in the case of DAF development costs eventually started to outrun investment and income revenues just as happened with Leyland. :bulb:
bma.finland:
I think the reality of truck development history over the years answers that question.I think most customers with any sense know that you can’t use an ordinary horse let alone a rabbit,to do the job of a Shire Horse,let alone an Elephant.Which is why you don’t see stupid low capacity engine designs,such as those in the old DAF 2300 etc,being used to pull heavy weights today.While even at lower weights less stress means more reliabity as speeds and distances increase.Which is why that Green Line Routemaster was fitted with the AV 690 not one of the smaller options. :wink:
Iveco use small engines to push some fairly big outputs out. Newmercman may know more but i belive a lot of it is to do with turbo design.
kr79:
In general if you want to increase specific torque of an engine you’ll need to increase forced induction boost pressures.Which creates stress with massive rates of increase as boost pressures rise.The idea of getting rid of the head gasket,which is one of the weak links in the case of increased boost pressures,would seem logical in that case.Although if you’ve increased boost pressures to the point where head gasket failure is becoming an issue it’s a fair bet that other componentry is also more likely to fail.In which case the headless engine idea seems pointless as engine development history proves.All those issues are increased even further in the case of small overall capacity resulting in a compromised stroke dimension which reduces specific torque which will need to be compenstated for by yet more boost pressure.
While in the early days of the small engine idea it was usually just a case of hiding the basic failings in torque output by making the engine run faster to provide a top end power figure on paper.In either case there’s no such thing as free lunch and the only way to get a lot more torque and power from a small engine is to put it under a lot more stress in which the increase in the rate of stress always exceeds the increase in the rate of torque and power outputs.
man and iveco and even daf have “small” motores whit high output ,and whit light weight and cheaper price they are in good market in europe now when only big companys buy fleet motors,sweeds rely on high weights in scandinavia and do the 16 litre big power engines ,not needed to 44tonnes,so in euro we are back to 9 10 litre engines in the same as in the 80,s for 44tn,s output then about 300 now 440 hps techniks goes forewards but reability not, cheer benkku
bma.finland:
In the case of the Scania 9 Litre it seems to be putting out a lot less than 440 hp. :confused: However unlike the previous generation of small capacity engines like the Leyland 500 and DAF 2300 etc,it seems like they’ve got the benefit of 5 cylinder technology as opposed to dividing that type of overall capacity by 6 cylinders.Which obviously means that the stroke measurement can be kept reasonable thereby reducing the amount of boost which would be required to get the equivalent amount of torque.But for reasonable 440 hp capability it’s no surprise that Scania at least seems to be ( rightly ) using a 13 litre engine for that job. :bulb:
As for DAF it’s plans seem to be all about moving away from the idea of it’s small engine ideas in going for around 11 litres to replace 9.2 litres.Which obviously suggests that engineers everywhere are looking for the ideal compromise between stress and specific outputs and less than 10 litres doesn’t seem to be it. :bulb: :wink:
autoindustrynewsletter.blogspot. … litre.html
infact i did say not scania 250 to 340 from 9 l and volvo new 9,5 to 380? but the other eurpreans ,i,ll think cheers benkku
ZB]
Anorak:
VALKYRIE:
VALKYRIE
:open_mouth:
Best Ergomatic Cabbed-Lorry Model? PART 16.Page 22.TRUCKNETUK
LEYLAND 500-SERIES - LEYLAND 700-SERIES FIXEDHEAD HEADLESS WONDER DIESEL ENGINES.
[ZB]Anorak.
I’ll quote some of what I said in the following posts,VALKYRIE:-
1.
"Best Ergomatic Cabbed-Lorry Model? PART 10.Page 19.TRUCKNETUK
THE LEYLAND 500-SERIES ENGINE WAS ORIGINALLY PLANNED TO BE THE LEYLAND 700-SERIES ENGINE.
The new engine had an overhead camshaft from the start,very durable Stellite valves and was
to be produced as an 11.4-litre - 700 cubic inch displacement engine with slim and compact
dimensions - several prototypes were built.
At a critical stage,the decision was made to reduce the cubic capacity down to 8.2 litres -
500 cid :unamused: ,one of the reasons was to get the engine’s weight down below 1000 kg.Leyland wanted to offer a better power to weight ratio - the 700-Series was too heavy.Because of this interference from Leyland management in regard to the engine capacity :unamused: ,the development engineer walked out!!! :exclamation: :exclamation: :exclamation: :smiley:
The 500-Series engine was developed to power the new mass-produced Leyland National Single
Decker Bus,certain other bus models and Leyland’s standard medium and heavy lorry range.
COST CUTTING AND WARRANTY COSTS.
A projected military version of the 500-Series,using two cylinder blocks and one crankshaft
to create a V12 engine! :exclamation: ,never went ahead.
Power output range of the 500-Series was from 150 BHP to 220 BHP,but there was a plan to produce
a turbocharged 260 BHP version :slight_smile:
The development of the 500-Series engine suffered a double blow! :exclamation: :-Insufficient development
funds,and,because of the late decision to reduce the cubic capacity of this engine,quality
control was relaxed - it became a skimpey and slipshod rush job :unamused: Hence production tooling
quality fluctuated,which resulted in some good engines,but most were bad - according to the
late great Pat Kennett,around 60 percent were faulty! :exclamation: :unamused:
These faulty 500-Series engines cost Leyland dearly in warranty payouts :unamused:
2.
"Best Ergomatic Cabbed-Lorry Model? PART 11.Page 19.TRUCKNETUK
And here is a very telling piece from BIGLORRYBLOG about the anything but precision-made and disasterous Leyland 500-Series Fixed Cylinder Head Headless Wonder Diesel Engine :unamused: :laughing: :-
It’s that Leyland Buffalo moment says Biglorryblog. Let’s hear it for the fixed head engine…or not
12 July 2007
By BIGLORRYBLOG:-
Buffaload2.jpg Obviously the irony of this headline probably escaped the copywriter for this Leyland Buffalo 2 ad from 1979. Good truck better? Let’s face it, given all the problems Buffalo had with the famous (make that infamous) fixed-head 500 engine it probably couldn’t have got any worse! No doubt operators rushed to buy the Buffalo with the TL11, which I think was based old Leyland 680 six-pot (though no doubt my trusty BLB army will tell me if I’m wrong).
The late, and sadly-missed Graham Montgomerie (ex-engineering editor of Commercial Motor) once told me that as a young Leyland technician one of his jobs was to find out why the fixed-head engine kept seizing up. So they took a bunch of engines into the test lab and tried to get them to mis-behave. Only to everyone’s amazement they all ran perfectly. It wasn’t until later that Graham realised that the engines they’d been given were effectively ‘blue-printed’. When they checked the tolerance on the production engines they were all over the place–hence their appalling durability. I certainly remember riding in a Buffalo 2 on a CM roadtest. It was the first time I’d ever been in a truck. (My back has only just recovered…)" UNQUOTE.
DR ALBERT D.FOGG MUST HAVE HAD ENOUGH OF THE MAD AND INCOMPETENT WAYS AND POLICIES OF BRITISH LEYLAND MIS-MANAGEMENT! :exclamation: :imp: :unamused: :laughing: :smiley:
BRITISH LEYLAND WAS A MADHOUSE! :exclamation: :imp: :unamused: :laughing: :smiley:
The transformation of the Leyland 700-Series engine into the 500-Series engine,which obviously
went against :unamused: Albert’s engineering ideals,was probably the last straw for Albert in one of a series of stupid and very misguided Leyland policies :unamused: that he didn’t agree with :slight_smile:
These also must have included:-
1.The axing of the AEC Super Mandator V8 3VTG High Tower 6x4 Tractive Unit :unamused:
2.The axing of the AEC 800-Series/801-Series V8 Diesel Engine programme :unamused:
3.Problems with another one of his pet projects:The Leyland National Single Decker Omnibus :unamused:
4.All of the precious profits of the British Leyland Truck and Bus Division being used to support the Morris Austin Car Division :unamused: ,when the money should really have been spent on Leyland’s obviously more successful and fundimentally MORE IMPORTANT AND CORE BUSINESS of designing,developing and producing lorries,motorcoaches and buses :smiley: - NOT on the lost cause of an irretrievable Morris Austin Car Division! :exclamation: :imp: :unamused:
5.And,of course,The transformation of the Leyland 700-Series engine into the 500-Series engine :unamused:
6.There were probably a number of other reasons why Albert Fogg resigned from his several
jobs and positions at British Leyland,including probably being overruled by that very misguided bloody fool,the late Ron Ellis :imp: :unamused: :unamused: ,who was the General Manager of the Truck and Bus Division :imp: :unamused: ,and Albert could also see that British Leyland as a whole,and the lorry and bus division,were all
“Going Down The Swanee River” - British Leyland was heading for disaster and was doomed! :exclamation: :unamused:
Thus Albert Fogg got the hell out of the British Leyand madhouse! :exclamation: :unamused: :laughing: :smiley:
10,11,12,13 AND 14-LITRE DIESEL ENGINES WERE THE NORMAL SIZE ENGINES FOR MOST MAXIMUM WEIGHT LORRIES,BUSES AND MOTORCOACHES.
The likes of Volvo and Scania had small capacity,turbocharged diesel engines for some of their
lorry,bus and motorcoach ranges,but being of small capicity,they more stressed and had to work
harder than the average-sized 10,11,12,13 and 14-litre diesel engines.They therefore probably
had higher shorter service lives - they definately had higher maintenance costs! :exclamation:
So obviously,Leyland had planned the 700-Series to,maybe,replace the 0.680 engine,but jumped on the Volvo and Scania small capacity engine bandwagon by turning it in to the reduced capacity
500-Series :unamused:
But why didn’t Leyland produce the engine in two model-sizes? :question: :The 500-Series and 700-Series :slight_smile:
But Leyland Truck and Bus was starved of money :unamused: ,so Leyland,although it had a new 8.2-litre
engine,it seriously lacked a brand new 11-12-litre engine :unamused: ,which should have been the 700-Series,so Leyland could properly compete with the similar sized engines of ■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■■ :slight_smile: …but,on the other hand,as [ZB] Anorak says,there were the AEC 11.3,12.47 six-cylinder,and AEC 800-Series/801-Series V8-cylinder,plus the Leyland 680 and 690 11.1-litre six-cylinder engines :smiley:
Ramone and Carryfast.
AEC Ltd was a very worthwhile and successful company to own,that made a well-engineered top quality range of commercial and military vehicles :smiley: - some of the best lorries,motorcoaches,buses and engines in the world :smiley: - a golden marque name :smiley: ,A E C,and motor vehicle manufacture :smiley: - which,if it had been properly properly managed,would still have been producing lorries,motorcoaches,buses and engines today :smiley: ,probably as part of a multi-marque global motor corporation :smiley: - one of the objective facts I said in my PART 13 of this thread :smiley: :-MULTI MARQUE COMPANIES HAVE FAR BIGGER MARKET SHARES :smiley: :smiley:
As usual of late,I’ll let another famous marque name have the last say in this POST 16 :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: ,although Leyland very misguidedly dropped the Albion marque from commercial vehicles :imp: :unamused: ,Albion continued to make motor vehicle components :smiley: - which they still do today :smiley: - and is one of the very few companies to survive the British Leyland disaster! :exclamation: :smiley:
Albion was,and is,the motor vehicle pride of Scotland :smiley: :-
ALBION CHIEFTIAN 57 OVAL SCOTTISH FLAG WITH FLOWER OF SCOTLAND SPEAR THISTLE MODEL NAME BADGE :smiley: :-
ALBION MARQUE SUNRISE AND SURE AS THE SUNRISE SLOGAN BADGE :smiley: :-
Albion named most of their various motorcoach and bus models with wonderful names that began
with the letter V:VALIANT,VALOROUS,VENTURER,VICTOR,VIKING and my great,charismatic and very attractive TruckNetUK username namesake of Aryan- Germanic-Norse-Teutonic origin:VALKYRIE :wink: :smiley: :-
And here is a magnificent and preserved Albion Valkyrie motorcoach :smiley: :-
Albion Valkyrie CX13/1950 Burlingham C33F Motorcoach,DYG 53,1941.Chassis No.58023A,Body No.3737,new with Duple C35F body,re-bodied in 1958.South Yorkshire 57,owned by two friends of mine :smiley: :smiley: :-
VALKYRIE
VALKYRIE:
[zb]Anorak.
1.
VALKYRIE
That description of the possible arguments,which took place between AEC and Leyland,concerning the 500 ci headless engine v the 700 ci one,seems to miss the documented reports that the Leyland 500 engine project ( as opposed to the AEC 700 project ) seems to have been on the drawing board at Leyland under the direction of Spurrier and Mueller ‘before’ the appointment of Dr Fogg at AEC :question: . :confused:
In which case the two ideas,although sharing the fixed head idea,were in all other respects different designs from different designers with the Leyland 500 engine idea ‘pre dating’ the AEC 700 one.IE The Leyland 500 engine was reportedly attributable to Spurrier and Mueller sometime before 1964 ( by all accounts 1960 ) whereas the AEC 700 fixed head was attributable to Dr Fogg obviously after his appointment at AEC :question: . :bulb:
In which case that can only mean that what followed was an argument between Leyland’s management and AEC’s management concerning ‘which’,of the ‘two’ ‘different’ types,of fixed head engine,should be used and according to the documented report must have been around 1966 when the Leyland 500 design idea was reportedly ‘re introduced’ ‘after’ it’s apparent ‘stalling’/interruption owing to Spurrier’s demise.
Which,of course,would have meant that the argument wasn’t about ‘reducing’ the size of the 700 at all.It was actually more a case of wether to use the larger AEC design of Dr Fogg’s ‘or’ the ‘different’ smaller design of Spurrier and Mueller. :bulb: That version of events fits in with my view that this was an act of incompetence at best,or industrial vandalism at worst,by Mueller,who was reportedly advising Spurrier.Which Leyland’s management then stupidly later nodded through because it seemed like a cheaper alternative to the bean counters than developing and producing Dr Fogg’s larger 700 idea :question: .Which assuming it was an act of industrial vandalism would probably habe been the outcome which Mueller was betting on when he advised Spurrier to go for such a stupidly small engine size to meet such a large design criterea.Added to which seems to be the other Leyland engine debacle concerning the L60 military order which again is documented as being another of Leyland’s engine designs with Mueller’s involvement.All of which seems more than just a co incidence.
You recon he was a secret agent for mercedes and man to weaken the british truck builders.
kr79:
Ha ha mission accomplished :wink:
