BEST 'ERGO' ?
Best Ergomatic Cabbed-Lorry Model? PART 14.Page 21.TRUCKNETUK.
LEYLAND 500-SERIES FIXEDHEAD HEADLESS WONDER DIESEL ENGINE - DR.ALBERT D.FOGG’S IDEA AND PROJECT.
Carryfast.
With respect,if you carefully read my Post No.10 and Post No.13 I actually state that,to avoid cylinder head gasket problems in the new 700-Series -11.4-litre diesel engine,Dr.Albert D.Fogg,Leyland’s Director of Engineering,strongly favoured a fixed cylinder head for this new engine :slight_smile:
Doug Jack,who worked for Leyland as a legal advisor and later became the Secretary of the Truck
and Bus Division,and who has written several books on Leyland motorcoaches and buses,has stated
that the fixedhead engine was Albert Fogg’s idea as was the 700 CID-11.4-litre capacity.
Albert Fogg joined Leyland in 1964,and became a board member in 1965,Dr-Ing Alfred Mueller left
Leyland in the early 1960s and had nothing to do with the 700-Series engine.Albert Fogg developed
this engine,and when the Leyland marketing men called for the engine to be reduced in capacity
to 8.2-litres because supposedly it was too heavy and too physically large,and had to weigh less
than 1000 Kgs :unamused: ,Albert Fogg walked out of Leyland! :exclamation: :laughing: He must have known that a 500 CID engine was just too small and was not fit for purpose to work in 32 ton GTW lorries :unamused: :slight_smile:
I also state in Part 10 that this sudden reduction in engine capacity resulted in quality control
problems in the production of these engines :unamused:
Tiptop495:
Hey, An AEC,Leyland baged??, Natural has always driven AEC’s, so it must be a late one, or a V8 ■■?. Do you see an engine hump■■?
Who knows more.
Compare with the mid-class Merc it is not much higher.
Bye Eric,
FOR AEC READ LEYLAND :unamused: :imp: :unamused: …LIKE HELL WE DID - NOT!!! :exclamation: :exclamation: :exclamation: :unamused: :unamused: :unamused: :smiley:
Tiptop495.
So far as is known,only one AEC Mandator V8 Rigid 4x2 Lorry was built,and this was operated by
Blanc & Paiche of Switzerland :slight_smile: So the Natural-operated lorry next to the Mercedes-Benz lorry
was a AEC Mandator 691/760 TG4R Ergomatic sleeper-cabbed,Covered Dropside or Fixedside-bodied,
Rigid 4x2 Lorry…parked next to it’s drawbar trailer? :question:
The reason why this A E C has the Leyland name and not the AEC marque was just very misguided
Leyland policy to name AEC,Guy,Scammell,etc,vehicles as “Leylands” in certain instances and/or markets :unamused: :unamused: :imp: Which shows a callous disregard and disrespect for the companies that made these vehicles,their dealers and their customers :unamused: :unamused: :imp: :imp: :unamused: - and this kind of ludicrous carry-on made people rightly turn away from Leyland and it’s products!!! :exclamation: :exclamation: :exclamation: :smiley:
When the British Army bought a batch of Scammell Crusaders,they were named “Leylands” :unamused: :imp:
But,as with the AEC marque,in my POST 12 of this thread,I will let the legendary Scammell
marque name and badge have the last say in this No.14 POST :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :-
VALKYRIE
thats a very boring film and I wonder why he did`nt just drive it in auto with all the stops and starts on that peice of road, fredm
Saviem:
If one wears a mid 60s hat, then the design ethos of the 500 series was totally correct. Net installed weight, bhp output, overall size of the package.
Where was the logic in spending loads of Leyland’s budget on an engine design of less than 9 litres to run for use in top weight trucks bearing in mind that the design criterea is documented as including the long haul uk and euro export markets.When even by the 1960’s standards something of the capacity of the AV690 was ( rightly ) considered as being needed just to provide a satisfactory engine for the Green Line Routemaster buses. :confused:
youtube.com/watch?v=2q10L2TW2CA
Bearing in mind that the idea also seems to have caused at least one of AEC’s engineers to have walked away for exactly the reasons which I’m saying,in that even AEC’s original fixed head idea,was meant to have a lot larger capacity because of the simple reason that the only way that you’ll get a reasonable output from a small capacity engine is to run it at higher speeds.Which is the last thing that’s needed for a top weight truck.In this case it seems obvious that the idea was put forward by a German engineer when development of the TL12 seemed to be an obviously superior basis for the stated design aims.The future development of which would obviously be compromised if funds were diverted into develpment and production of the 500 instead.It seems obvious that if Leyland’s in house engine development was to have the slightest chance of remaining competitive it was development of the TL12 which provided the only credible possibility of meeting all the aims required of the 500.Just to prove that both AEC’s engineers ( an my ) thinking is correct,the small capacity,highly stressed,high speed engine idea was tried by Volvo and DAF in the F7 and the 2300/2500 for top weight use.But the idea eventually failed and fell by the wayside when operators realised that it doesn’t work in the real world even in the lower weight ranges as low as 16 tonners let alone max weight trucks.
Although even in that case the question why remains,when Rolls and ■■■■■■■ could provide proven alternatives without needing any money for development of an in house engine.Which is just what history proved in the case of the Crusader and the the T45 anyway. :confused:
[zb]
anorak:
gingerfold:
Who is this German engine designer we keep reading about?
He crops up in here:
mk-marketing.eu/Publications … ionM-E.pdf
The author of that report has done other work, which has been used to good effect on this forum in the past. This one, while full of apparently well-researched detail, seems a bit confused in its deductions. I will have to read it again, properly, before I am accused of the same!
{/quote]
Thanks for the link. I will read it over the weekend. All I will say if it is by Mike Knowles…, well,this man is well known in certain circles for opinions and views that are eccentric to say the least.
VALKYRIE:
AEC SUPER MANDATOR V8 3VTG CONCEPT-PROJECT-PROTOTYPE 6x4 TRACTIVE UNIT.
Albert Fogg’s AEC Super Mandator V8 3VTG High Tower 6x4 Tractive Unit,which looked like a Peterbilt High Tower COE,and was also in the same idiom as an Australian Atkinson High Tower COE,
was designed for better engine cooling,better driver comfort and high power for long distance
heavy duty freight trunking,and would have been for sale in British,European,Australian,New Zealand and other markets - as I said my PART 4:AEC and Albert Fogg were wisely doing a Volvo F88-F89! :exclamation: :smiley:
VALKYRIE
Hi Valkyrie. Is there any evidence that the 1968 3VTG was aimed at the GB/European market? The prototype we have seen does not look like a European vehicle- surely, if the intention was to market it in Europe, it would have had European styling? The split windscreen and simple vertical radiator grille may have appealed to US truck fanatics, but they would have been ridiculed in countries which had a preference for the likes of the Scania LB, DAF 2600, Berliet TR300 and Leyland Ergo. I still think that it is more likely that it was the prototype for the “Easy Build” cab mentioned in the 1971 Leyland/AEC strategy document, although I would like to see some documentary evidence of what its actual purpose was.
Regarding the Leyland rationalisation programme, multi-marque mergers were not typical in the 1960s. There was a proliferation of manufacturers then, acquisitions and mergers were happening all over Europe and the normal theme was to kill off the weaker brands. Nowadays, in a market dominated by a few huge companies, there is a desire to reverse this trend, by artificially creating “choice”, hence the various Audi/VW car marques all sharing the same engineering. In lorries, Volvo is adopting this same strategy, by continuing the Renault brand.
Examples of Leyland-style acquisitions killing off acquired brands:
Mercedes- Hanomag and Henschel.
MAN- Büssing, ÖAF, Graf & Stift.
Saviem- Somua, Latil.
Renault- Saviem and Berliet.
Iveco- Magirus, OM, Lancia, Unic and, eventually, Fiat.
Leyland’s treatment of AEC does, with hindsight, appear hamfisted and destructive- the neglect of AEC’s opportunities in Belgium, France and South America has been mentioned in this thread and seems ludicrous now. I can only speculate that it was a continuation of Donald Stokes’ desire to leave the European markets to their own devices. It seems that he wanted to force this policy onto the managers of AEC, and did so in a comically brutal way. Does anyone have any documents referring to these early 1960s decisions?
Dont know if anyone else has mentioned it but there has been a lot of talk if cooling issues with various ergo models so was that one of the reasons behind the fixed head engine design to eliminate head gasket failiure.
I know time and technology moves in but if you look at the the current iveco engines although its a pretty conventional design they make a lot of power from a relativly small engine size.
Looking back at the whole bl group there were lots of good ideas that other vehicle makers have devolped in to what we take for granted today.
VALKYRIE:
Carryfast.
VALKYRIE
I’m not sure of the exact time line which you’re referring to there.I’ve based my comments concerning Dr Mueller’s involvement in the 500 on the report which I posted referring to Dr Mueller’s involvement in the decision to use the 500 engine size ( as opposed to Dr Fogg’s obviously good engineering sense in wanting a larger capacity ) which certainly seems to have taken place based on Dr Mueller’s say so according to the part of the report which says that there was ‘an interruption’ in the 500 project as of 1964 due to the death of Sir Henry Spurrier.It then goes on to say that the design aims of the 500 engine were to power max weight trucks employed on long haul uk and european,specifically and probably more than co incidentally ‘‘the autobahns of peacetime Germany’’ ,work ‘using an engine of 8 litres to do the work of at least the 680’ :open_mouth: ( which of course contradicts all known/established engineering principles of the best way to make a fuel efficient,productive,heavy truck,or even long/medium haul bus,engine at that time and to date ).
Now comes the interesting bit.According to the report Spurrier was obviously at ‘that’ stage and at ‘that’ time working under the ‘advice’ of Dr Mueller while it’s also obvious that Dr Mueller was involved in the idea of using the Jumo aircraft diesel engine in the Chieftan tank project.All of which,therefore,obviously took place during Dr Mueller’s time at Leyland.While as I’ve said the debacles concerning the results,of using an obviously too small engine in the case of the design aims of the 500,and an already known to be an unreliable dog of a German aircraft diesel engine in the Chieftain cost Leyland loads a money in having to ( try to ) fix them and both,more than co incidentally,being able to be traced back to Dr Mueller’s involvement.
As for Dr Fogg’s idea,of a reasonably sized,fixed head design who knows but history seems to show that the TL12 and even better Rolls and ■■■■■■■ products probably had the idea beat,on the same basis that bigger is better for reliability and high torque outputs.Unless there are some fuel consumption,dyno figures and durability test results for the 700 fixed head prototypes which would show otherwise. :bulb: :wink:
AS for Scammell v AEC I think Watford had Southall beaten simply on that flexibility in thinking concerning the use of outsourced componentry like engines as and when required.It’s just a shame that the two operations weren’t merged and then kept independent and seperate from Leyland. :wink: :frowning:
it,s your own fault carryfast,you have put the marathon so down,so now im very fachinated of it,cheers benkku
bma.finland:
Only one little problem here bma.,Carryfast couldn’t drive a Marathon,he could only sit on the passenger seat with a plastic steering wheel stuck on the dash in fron’t of him while making a noise like a Bedford TK 4cyl !!Skol,Dennis.
bma.finland:
Are you sure Dennis that he would have the sence to imitate a proper driver, I don’t think so, Going off his past comments, Regards Larry.
Lawrence Dunbar:
bma.finland:
:smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: ,maybe a flapper in the bicycle wheel in shorties is the experiens of heavy haulage ?
Rock On BMA Your a gem , Regards Larry.
gingerfold:
[zb]
anorak:
… All I will say if it is by Mike Knowles…, well,this man is well known in certain circles for opinions and views that are eccentric to say the least.
:laughing: The link to that MK report was originally provided by Carryfast. Hmmm… No, it can’t be…
bma.finland:
Lawrence Dunbar:
bma.finland:
Now then bma. how did you know that “Carryfast” was a member of the Leatherhead Wheelers Club ? Well,“Carryfast’s” cycle has to be a three wheeler one because he has never mastered the art of riding a two wheeler. :laughing: :laughing: :laughing: :laughing: :laughing: Cheers Dennis.
VALKYRIE:
Scammell v AEC ■■? Where did that come from ,Scammell never used the ergo cab ,they produced a tractor unit for BRS and the Army and were basically a specialist builder .AEC were a lorry and bus producer who manufactured from scratch the complete vehicle .The Crusader cab was the crude motor panels cab the Routeman had the bone shaker fiberglass cab , but they did fit the Detroit in some tractors so this could be the reason they had AEC beaten ,(whatever that means ).2 totally different manufacturers
What does the initials CF Realley stand for or mean, In my younger days days in the haulage Industry It would have meant Cr–y F—ker, But of course that was then , Nowadays it would be in BOLD PRINT If one was like that,Regards Larry.
bma.finland:
Lawrence Dunbar:
bma.finland:
yee but ekers in the frontwhel,flap flap flap :smiley: :smiley: :smiley: skål lager is dilight to night ,cheers benkku
ramone:
VALKYRIE:
If you’d have read the post I said that it was Scammell’s ideas on the use of outsourced componentry like engines which was it’s main strength over AEC’s and Leyland’s over dependence on use of their in house engine supplies all of which were compromised by lack of funds to develop them and/or suicidal design ideas at least in the case of the 500.
The Crusader was used by many different types of customers not just the army and BRS while those two large customers just prove that it was built to satisfy all levels of the market from general haulage fleet work to heavy haulage including military applications.While I’m sure that probably more of those customers were happier with a 280 or 305 Rolls powered Crusader than an ERGO/Marathon with any of it’s Leyland or AEC supplied engine otions.Especially the V8 or the 500.With warranty costs to prove it. :unamused:
No surprise that Leyland then eventually learn’t what Scammell already knew in the case of ditching the in house engine idea and outsourcing it’s engine requirements to Rolls and ■■■■■■■ in the case of the T45. :bulb: :wink:
As for the Crusader cab v the ERGO as I’ve said the final generation fixed cab on the Crusader seems to have been better in most respects than the first generation,underdeveloped,cheap job of the ERGO and Marathon.When what was needed was something along the lines of the tilt cab development of the Merc LP,which was introduced not long after the ERGO,given the luxury of a Mercedes type development budget not a Leyland one of course.
Daimler-Benz (Mercedes) were five years behind Leyland wid a tilt kabine , and only the big V 1632 /1932 had the tilt version , the others LP/S 1418 ,1924 ect ect straight six had NO TILT ,replaced by nue -generation mid 70s , Leyland could see fuel economy was future , Volvo made a 6.7 liter to work upp to 40 ton ! ,the 8 liter Leyland was free revving and the larger the engine the more power and fuel is lost just to turn it over before pulling the load , Gardner showed how large engines can be next to useless on the road , where is ■■■■■■■■ now? they had a 14 liter bad on fuel , made 10 liter for next generation , Rolls eagle was large and crap , Scammell used Leyland motors of course after takeover but offered Gardner and l ater Rolls for more power option , Guy Big J was a huge seller in UK so money to be made from normal size day kab thing up to 220 HP , 510 Leyland was to go to around 350 -400HP if developed all the way , in 1960s Scania was saying no more than 350 would be needed up to 1985 , who could tell the future ? weights and speeds on hills going up so much , but relativly small turbo intercooled motors wid large output is the way
Best Ergomatic Cabbed-Lorry Model? PART 15.Page 21.TRUCKNETUK.
LEYLAND 700-SERIES FIXEDHEAD HEADLESS WONDER DIESEL ENGINE - DR.ALBERT D.FOGG’S IDEA AND PROJECT.
Carryfast.
I draw your attention to what Gingerfold has correctly said about Michael Knowles:-
“Thanks for the link. I will read it over the weekend. All I will say if it is by Mike Knowles…, well,this man is well known in certain circles for opinions and views that are eccentric to say the least.Gingerfold.”
And this is what I said in regard to Michael Knowles in my POST 13 of this thread:-
VALKYRIE,“But Michael Knowles seems to be obsessed with feet,inches,fractions,meters,centimeters,milimeters,
fixings and fastenings in the British Commercial Vehicle Industry,and has had several articles
published on this overall subject,namely The Metrication of the British Commercial Vehicle
Industry,in various publications,including the HISTORIC COMMERCIAL VEHICLE SOCIETY’S Historic Commercial Magazine.
Some of what he says in this report is wrong.For example,as I said in my PART No. 10 of this
thread:-
“The Leyland Group had cylinder head gasket problems with some of it’s AEC and Leyland
engines,but,although these blown gasket problems were largely cured,it was our old friend
Dr.Albert Fogg :slight_smile: that came up with the idea of using a fixed cylinder head for the new engine
range”.
So it wasn’t Dr.Mueller’s idea.”
So add the above two comments together,plus the other fact that Doug Jack is almost certainly
a more accurate and reliable historian and writer with more balanced views,and you must come
to the conclusion that it was Dr.Albert D.Fogg,Leyland’s Director of Engineering,who was
the mastermind of the Leyland 700-Series Fixedhead Headless Wonder Diesel Engine.
I said that Dr-Ing Alfred Mueller worked for Leyland until the early 1960s,Albert Fogg became
Leyland’s Director of Engineering in 1964 - Doug Jack said that Albert sometimes came up with
unconventional solutions to technical problems,and he somehow did not fully fit at Leyland.
Thus,bearing all that in mind,it isn’t really suprising that Albert came up with the Leyland
700-Series fixed cylinder head engine.
LEYLAND L60 TWO STROKE MULTI-FUEL TANK ENGINE.
As for the fascinating and MUSICAL Junkers aeroplane two stroke diesel engine-inspired
Leyland L60 19-Litre 6-cylinder Opposed Piston Two Stroke Multi-Fuel Engine for the Chieftain
Tanks,surely it was more reliable than it’s made out to be. It also offered a better power to weight ratio than a four-stroke engine - tanks are heavy,and the designers wanted to save weight,yet use a powerful engine that was light in weight,hence the Leyland L60 engine which was the ideal engine.
[ZB] Anorak.
This is what I said in my POST 4 in this thread:-
VALKYRIE,"
AEC 3VTG CONCEPT PROJECT LORRY.
As I said in my last post,the wise AEC 3VTG Concept Project Lorry was the wise and inspired idea
of the boss of AEC,Dr.Albert D.Fogg,who obviously wanted to copy Volvo with it’s refined
American-style F88-F89 lorry models,and produce a refined American-style AEC heavy lorry range :slight_smile:
And in the words of the great Barry Norman:“And why not”… :slight_smile: And why not indeed,because
other lorry manufacturers were doing the same thing :smiley:
The interior of the AEC 3VTG cab was well-appointed,with Bostrom Viking seats,a very
comprehensive instrument panel and good cross cab access. The lorry’s engine bay allowed more air
to circulate around the engine than with the Ergomatic Cab,and it’s AEC 801 Series V8 engine had
a much larger header tank,radiator and cooling fan than the AEC Mandator V8.
Albert Fogg wanted to produce a better cab than the Ergomatic,and he was well on the way in doing
this with his AEC 3VTG Lorry :smiley: He realised that the Ergomatic was not big enough,it produced
cooling problems for the engines,especially in the tropics,it had design flaws and,according to
Albert Fogg,it was not suitable for long distance motorway journeys. So entered the AEC 3VTG
Project-Concept-Prototype Heavy Lorry for all of the above reasons that I’ve listed :smiley:
But,as I’ve already stated,Leyland mismanagement very misguidedly scrapped the AEC 3VTG Programme
:unamused: …and by doing so,it was yet another long,long,sharp,sharp nail in the unholy coffin
of the British Leyland Motor Corporation! :exclamation: :unamused:
AEC 3VTG6RGAE 090 Mk1 Project-Concept-Prototype 6x4 Tractive Unit Specifications:-
Cab: Motor Panels Tilt Cab,modified.
Engine: AEC 801-Series-AVM8/801,13.1-Litre,V8 Diesel Engine,producing 272 BHP @ 2600 rpm,638 lbs
ft of torque @ 1400 rpm.
Gearbox:Leyland-Self Changing Gears -SCG Pneumocyclic 10-forward speed Splitter Semi-Automatic
Gearbox.
Rear driving axles: Leyland Group Hub Reduction Drive Axles.
Year:1968.
Not only was Dr.Albert D.Fogg the General Manager of AEC Ltd,he was a member of the board of the
British Leyland Motor Corporation,Deputy Managing Director of this corporation and Director of
Engineering of British Leyland. So his above various positions within British Leyland allowed him
a substantial amount of influence within British Leyland and at AEC,thus,the AEC 3VTG being
Albert Fogg’s pet project,he probably had every intention in eventually turning it in to a
production lorry to take on the likes of the Volvo F88-F89,Scania LB110,etc :slight_smile:
But of course,British Leyland mismanagement very misguidedly scrapped the 3VTG project :unamused:
,which proved to be fatal for British Leyland in the long - as did the scrapping of the AEC
marque!!! :exclamation: :exclamation: :exclamation: ."
I therefore based the following statement in my POST 13 on everthing that I had written in the above quote:-
VALKYRIE,"Albert Fogg’s AEC Super Mandator V8 3VTG High Tower 6x4 Tractive Unit,which looked like a Peterbilt High Tower COE,and was also in the same idiom as an Australian Atkinson High Tower COE,was designed for better engine cooling,better driver comfort and high power for long distance
F88-F89! :exclamation: :smiley: "
Since this was a prototype,and not a production example,it is fair to say that a production
version would have been moderately re-styled to look more English-European than American,while
also appealing to the Australian,New Zealand,etc,markets,who buy a lot of American heavy motor
trucks-lorries :smiley:
MULTI MARQUE MOTOR MANUFACTURERS - THERE IS NOTHING NEW UNDER THE SUN :smiley:
The General Motors Corporation was formed in 1908,which brought together famous American motorcar
marques,such as BUICK,CADILLAC,OLDSMOBILE,and later on CHEVROLET,LASALLE,PONTIAC,OAKLAND,HOLDEN,
OPEL,VAUXHALL,including CHEVROLET and GMC commercial vehicles,and so on.Many of these are still in business and are still owned by General Motors.
The White Motor Company of Cleveland,Ohio,USA,built up an empire on Leyland lines from the 1940s:
AUTOCAR,DIAMOND T,DIAMOND REO,EUCLID,REO,STERLING where all part of White.
Austin and Nuffield merged to form the British Motor Corporation - BMC in 1952,with MORRIS,
RILEY,MG,WOLSELEY,AUSTIN HEALEY,AUSTIN,VANDEN PLAS,METROPOLITAN,etc,under it’s control.
The Rootes Group consisted of HILLMAN,HUMBER,SINGER,SUNBEAM,SUNBEAM TALBOT,TALBOT Motorcars,
and COMMER,HARRINGTON,KARRIER,SUNBEAM,TILLINGS -STEVENS and VULCAN Commercial Vehicles,plus DODGE,with the Chryslertakeover of Rootes,joined the line up in 1964.
I could mention a few more pre-1960 motor vehicle groups that consisted of more than one marque.
As for the tragic deletion of the Bussing marque :unamused: ,a well-known manager of MAN said that MAN
should never have stopped making Bussings! :exclamation:
And in regard to IVECO,they very unfortunately dropped so many marques that they ended up
being the weakest European commercial vehicle manufacturer :unamused: …and they probably still are :unamused:
And here is a word of warning:-If some of the present European and Scandinavian commercial
vehicle makers vanish through mergers and takeovers :unamused: ,they will be replaced by Japanese,Russian
American,Chinese,etc, manufacturers! :exclamation: That is what happened to the British Commercial Vehicle Industry:British marques vanished :angry: :unamused: to be replaced by Scandinavian and European marques :slight_smile:
Tragic,scandalous and criminal! :exclamation: :unamused:
As with AEC and Scammell in some of my most recent posts,I’ll let yet another unfortunate
victim of Leyland mis-management have the last say in this POST 15:-The great Guy marque
with it’s wonderful American red indian mastcot badge and Feathers In Our Cap slogan :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :smiley: :-
VALKYRIE
Lilladan:
:open_mouth:
Yeah right which is why Volvo,DAF,Scania,Volvo,Mercedes and MAN have all limited their engine ranges to less than 10 litres capacity. :unamused: :laughing: :laughing:
So you obviously don’t understand what it takes to produce loads of torque which is what makes a truck engine efficient.Which probably explains why both customers and manufacturers gave up on trying to power wagons with small capacity gutless engines like the DAF 2300/2500,Volvo F7 or Scania 93. :unamused:
