Basic Manual Entry question
When you record a manual entry is the first line you enter the start time or the end time of the activity you want to record?
Thanks in advance.
I avoid manual entries like the plague. Probably best to find a “how to” guide on Youtube.
Jeffrey32:
Thanks in advance.
First line is the start time
Second line is the finish time
Jeffrey32:
Thanks in advance.
It’s the start time. You can’t change it anyway as the machine sets it at 1 minute after the finish time of the last recorded activity.
Sent from my VOG-L09 using Tapatalk
The lines you alter are the finish times of the activity (second line). The start time of each activity is either the time of the last withdrawal or the finish time of an activity line you have just entered. It will keep prompting for more lines until you are right up to the time you put the card in. You can always press back to alter a previous line, but once you have confirmed the entire manual entry, it is not possible to alter it.
https://www.youtube.com/watch?v=Ei4e4yu-YDM (Stoneridge)
https://www.youtube.com/watch?v=3Al6H0LuQBE (Siemens/VDO)
