muckles:
muckles:
Please can you tell me which of the modern European AMT heavy truck boxes they have turned the Auto mode off and just left it running on manual?
I’d guessed that you’d have realised that was my point.IE the road safety question,in pandering to the habits of ‘drivers’,who’s idea of a skilled approach to hazards and obstacles is brake and go with the definition of brake meaning as late as possible with brake temperatures and entry speeds to match.
In other words you were spouting more guff, you knew nothing about.
As I said full auto gear selection provision panders to the type of steering wheel attendant who’ll happily use novice car type braking points and technique and resulting entry speeds to take a heavy truck into a roundabout for example.On the basis of a brake and go approach.
The fact that autos enable drivers of a lower competence to operate, does not automatically make every driver who actually uses an auto incompetent, or make autos something that a self-respecting competent driver would want to avoid using.
One can still drive a manual like a madman.
The argument that manuals impose some sort of discipline is a weak argument. Otherwise, synchromesh boxes would also be a tool of the devil, allowing lazy, flexible gearchanges compared to good ole crash boxes. And late model crash boxes would be far too sloppy, compared to pre-war gearboxes. And why have a starter motor, when a hand crank only encourages sloppy drivers to stall often and without penalty? Why have motorised windscreen wipers, when a hand crank separates the men from the boys in rainy weather?
All these backward technologies do is impose a higher workload on the driver, and a more rigid physical routine at the controls which is less amenable to the reality of what is actually happening on the road and less amenable to correcting one’s own occasional mistakes.
Auto gearboxes are at the stage where they are more or less as good as manual selection - and they retain the ability to manually select on the off chance the driver begs to differ.
When I have overridden the auto, it is normally because I’m in a restless mood and want to pre-empt it’s otherwise adequate handling of the gears and thrash every possible advantage out of the engine (such as downshifting before an uphill stretch, rather than allowing the auto to do so once already into the hill).
If I’d just left the controls alone, there would be no appreciable difference in the outcome, other than maybe a couple of mph difference over a couple of minutes - and those sorts of margins shouldn’t bear on the minds of safe, sensible drivers, particularly when the proposed alternative is to handle every declutch and gear change for one’s self.
For the competent driver, a manual gearbox is simply extra work - work that is itself prone to mistakes, and is no longer necessary.
