audio aux in
Do renaults (premiums) have aux in somewhere in the cab? And other trucks in general?
Thinking of connexting my phobe to the cabs audio system to listen to my stuff, not that radio bs
The 14 plate DAF I drive has one, but the MAN I had before didn’t so I plugged a fm transmitter into my I-pod and did it that way. It’s not as good as an aux but it worked okay.
Best way is to get a good wireless speaker and use that,a Bose portable speaker is around £80 .
Fleet spec Renault Premiums don’t have an aux in socket. Only the higher spec models with the factory fitted Bluetooth head unit have an aux in.
Depends on the speck with anything . Remember nothing in this life is free
Most modern head units have a connection on the back for an aux input,
ebay.co.uk/itm/Latest-3-5mm- … SwuMFUaGe1
I cut the ■■■■■■■■ mine and fit a socket to it, and put it into a switch blank,
ebay.co.uk/itm/3-5mm-Mini-Ja … Swl9BWKMdw
Cost from Scania was £50 for the same thing.
Make sure the head unit has an aux on the source button, it may need activating in the menu settings
