Actrosman:
When i used to do the shunting after finishing my old run to Battersea at night, hardly any of the trailers that were dropped off during the day had the park brake applied. Do some people drop the legs, pull the lines and pin and hope that the trailer brakes will come on? How many of us have backed under one and give it a tug and found ourselves lumbering across the yard?
With airbrake systems this shouldn’t happen unless the shunt button has been used. Removing the red line will apply the service brakes on the trailer (not the same as the park brake). it shouldn’t then move anywhere until air is once again applied to the red line. The shunt button overides this unfortunately.
Out of the 5 cases I investigated they were all the same circumstance. Driver reversed under a parked trailer without having first checked the trailer park brake was on. Once the pin is in the 5th wheel jaws the tractor is now held by the braking effort of the trailer. it is now so easy to forget the tractor handbrake. Driver gets out, winds the legs up, gets on cat walk and starts connecting airlines etc. As soon as the red is connected the trailer brake release and the combination is free to roll in either direction.
Even if these drivers checked the trailer park brake - their next move would have been to go round and push the park brake control back in - and away it would have gone, possibly with the driver leaning underneath to the park brake control.
There is of course a possibility the air could be completely gone from the trailer and the tractor possibly low on pressure. red line applied and air starts to build in the trailer but the brakes don’t release straight away. Driver climbs down, walksround front of the tractor and by now the brakes are releasing with sufficient air pressure and he gets run over by his own unit.
When we first devised our hand brake alarm we actually had it working on the central locking as well. Handbrake off - doors locked. We decided in the end this was a safety issue as the driver could be trapped inside in the event of an accident and in the panick forget the handbrake was stopping him opening the door etc - so we ended on a flamin loud warning instead.
There are many ways of putting an interlock of some kind in but most could cause a potential breakdown if they imobilise the vehicle in some way. At least with the alarm if it goes faulty the driver can still move the vehicle allthough with an annoying alarm going off.
The other issue though - what happens when the alarm fails in silent mode - i.e. doesn’t sound. One driver actually told me he relied on the alarm as he often forgot the handbrake if his alarm stopped working he could then leave the handbrake off.
Something does need to be done within legislation for new tractors and trailers. yes there are auto trailer park brakes when the red line is disconnected, but that doesn’t fully solve the problem. At least for now some employers are addressing it.
Bit late for the chap at the beginning of this post which is very very sad.
pete
PS my car - an automatic - won’t release the drivers door lock unless it is in P or N but with the handbrake applied. That’d work!!
