Hi all im looking for the correct connection so that I can plug into the anderson connector on the back of my daf, run it into my cab and connect to my 24 v 300w oven.cheers.
If you are really determined to go down this route, all you need is another Anderson connector- they are both the same, no male & female.
Now wait for someone to let me know that I’m wrong.
Again!
jediknight:
Hiya …go on E bay plenty connectors starting at £3.49. the two ends are the same as my mate said.
John
You need one of these. Grey Anderson connector at one end and a heavy duty cigar socket at the other. Go to a truck components place to get the connections and about 2 metres cable and see if they will assemble it. I had mine put together at Lymm. The problem I had with this cable is that the socket does get very hot when the oven is switched on and it will drag alot of charge from the batteries.
3300John:
jediknight:
Hi all im looking for the correct connection so that I can plug into the anderson connector on the back of my daf, run it into my cab and connect to my 24 v 300w oven.cheers.Hiya …go on E bay plenty connectors starting at £3.49. the two ends are the same as my mate said.
John
That’s twice I’ve been correct this year- must be some sort of a record!
beanie:
Just run the engine whilst you’re cooking something. It’s easier to lose a drop of diesel than being stuck somewhere because your batteries are flat.
