need help as fast as possible…been doing deliveries for a few days using analogue tachograph charts which were given to me at a previous work…but i have now run out and have 5 days work again from monday…where do i buy these charts from? i live near birmingham
bigbedda:
You don’t buy them the transport company you’re working for supplies them, in fact they have a legal obligation to do so.
When you go to work on Monday ask in the transport office for some charts and you should be given enough for the week, apart from the fact that you shouldn’t be supplying your own charts some companies don’t like you using charts that are different to the ones they supply.
thank you…at least I shouldn’t have to worry about having my own from now on then…just hope someone is there to give me some…past few days it has only been another driver there when i arrived
Also remember to ask for a spare too. If you’re doing 5 days you’ll need 6 discs.
you should get someone to check the charts are ok for use in the tacho you are using, the code and numbers need to match the listing on the unit, im sure someone could post a picture of a head sticker on the unit. I cant even manage an avatar.
m1cks:
care to explain why ![]()
green456:
m1cks:
If you’re doing 5 days you’ll need 6 discs.care to explain why
Because it’s always wise to have a spare chart.
green456:
m1cks:
Because you need a spare
