albion motors.
erfguy:
Pete I don’t know much about them but Gerald/leyland600 would know I think. Eddie.
Ta for reply Eddie
HD57,still alive,just…
My little Albion
oxo3:
My little Albion
What year was this one ■■, Regards Larry.
Lawrence Dunbar:
oxo3:
My little Albion
Is this a Homalloy cab ? Regards Larry.
Lawrence Dunbar:
Lawrence Dunbar:
oxo3:
My little Albion
Did Penmans of Dumfries ever build Albion cabs Larry ?
My little ft37 is 1957 with en287 Albion engine
Lawrence Dunbar:
Lawrence Dunbar:
oxo3:
My little Albion
Im not sure Dennis but J.R.Adams had two Albion 6 wheelers with the wrap round type windscreens and I was told the were built by a Dumfries Company, So It may have been Pennmans ■■, Regards LARRY.
My first lorry which, sadly, ended up as scrap was an Albion KS127, reg. no. BUS387 and chassis number 37322L. It was made in 1938 and originally sold as a 5000 gallon aluminium tanker to the Clyde Oil Extraction Company. Strangely, I saw 37325L at a Lincoln vintage show a few years ago.
The lorry had a four cylinder side valve petrol engine 5¾ inch stroke and 3¼ inch bore. It had no electric starter fitted and could only be started with the starting handle but it started every time even in the coldest weather.
dr1ver:
Hi dr1ver, sounds like the one I worked on 61ish did head gaskets for fun, white metal bearings to blue and scrape, typical old Albion Engine, happy memories.
Les.
It seems peculiar now but in those days engine reconditioning was regarded as just another item of servicing that was to be undertaken on a fairly regular basis. Sixty or so years on and we’ve come to expect engines to do five times as much mileage, haul five times as much weight and last forever- well, almost forever!
Retired Old ■■■■:
True that. I remember an old workmate who had been a fitter for Ellis’s Transport of Hartington, Derbyshire, before BRS took them over, and they ran Gardner engined ERF and Foden (their ERF four wheeler is actually pictured in the Pat Kennet World Book on ERF) and he said that every 50,000 miles the heads came off for decarbonising etc as a precaution. Even the Gardner LXB manual states to decarbonise every 48,0000 miles but I don’t think that happened much during the 1970’s/80’s!
Pete.
I don’t expect that many users of second-hand Gardners had ever seen an Instruction Manual! Fill it with fuel & oil and drive it 'til it stops.
This is worth a listening to by Albion fans:
youtube.com/watch?v=dzqNSAbE … bE7Fo#t=14
I must admit it made me go a little damp round the eyes!
I think the song would be even better if a video could be attached showing either video clips or still pictures of Albions (or both) if anyone has the knowhow to compile it.
Somebody was asking did Penman build Albion cabs yes they did. Eddie.
dr1ver:
Coincidence. My 1938 KL127 has a chassis number very near to those, (for security I won’t quote it on an open forum) and it’s been at Lincoln show. Like yours, it has only an “Armstrong” starter but I’ve never found it a problem in the 44 years I’ve had it. Those chassis numbers you quoted could be some way apart as Albion built batches of vehicles with the same number but a different suffix letter, so theoretically you could have 26 vehicles with the same number. As it happens my original buff logbook doesn’t show the letter on the end, just the number, and that was brought forward onto the V5 and then the V5C, so it’s possible DVLA may have more than one motor registered with the same chassis number.
Bernard
Retired Old ■■■■:
It seems peculiar now but in those days engine reconditioning was regarded as just another item of servicing that was to be undertaken on a fairly regular basis. Sixty or so years on and we’ve come to expect engines to do five times as much mileage, haul five times as much weight and last forever- well, almost forever![/quote
I’ve got the original drivers handbook and parts list for my lorry. The handbook tells me I should examine and if necessary regrind the valves every 5000 miles. The engine oil should be changed every 5000, together with dropping the sump to clean the gauze filter with paraffin and a stiff brush. The water should be drained if the vehicle is standing for more that 2-3 hours in frosty weather. Every 500 mils, oil gun on kingpins. Every 1000 miles oil gun on the rest of the ■■■■■■■ and oil can on all moving parts, brake and throttle linkages etc. Labour intensive but the parts look cheap to modern eyes. A few prices from the list, dated December 1936 but rubber-stamped “prices in this list subject to 15% increase” by time it was issued against my lorry in April 1938. How about Front spring complete £1.15.0. Radiator complete £15.0.0. Or if it’s only the top hose you need 6d. Fuel tank complete £5.10.0. Silencer complete £1.0.0. When it gets a bit worn you might need pistons, 12/9 each. Or a crankshaft £14.10.0. An exhaust valve would set you back a half-crown. Clutch linings 18/6 each, and rivets for them tuppence-halfpenny a dozen. I could go on but you get the idea. I’ve quoted in “proper” money as I’m sure you all know what I mean. :wink:
Bernard
Doesn’t seem possible, does it? I wonder how much fuel and drivers’ wages would have been in those days?
Happy New Year!
robert1952:
Happy New Year!
That must be the first factory built Albion sleeper cab to be seen!!!
David
