iy67:
Hello,
In it’s endeavour to do the right thing/increase ISO rating etc. your company decides to offer you some basic adr awareness training. It’s stuff you’ve never really given much thought about before as you’ve been carrying mixed items containing the odd box or ten of hazardous goods (solvents, lubricants, adhesives, aerosols, cylinders etc.) for as long as you can remember. So you sit through a brief 1hr lesson about limited quantities and small load exemptions and toddle out the door clutching an a4 summary of said lesson. Not long after (next day
), it’s all a bit of a blur again. Soon after, new procedures come into force by way of a DG manifest issued at the start of your shift which contains information relating to the 20, 333, 1000 limits for the transport categories (TC) like this-
branch quantity weight category total under threshold
1 4 25 3 100 YES
1 1 25 2 25 YES
2 1 25 2 25 YES
Hi iy67,
Firstly, I’ll start by telling you that a 1hr lesson to cover what you’ve said is IMHO woefully inadequate, so it’s no wonder that you’re left in a bit of a spin (other descriptions are available
) and therefore the company have got what they paid for, which is a great deal of confusion on your part.
From the info you’ve given in the table above, it is correct to say that the load is less than threshold.
iy67:
The quantities are normally as small as shown and you set off from base with your trusty 2kg fire extinguisher in order to make your deliveries and pick up returns to/from satellite branches all around the country. Now these returns might also contain DGs but there is no manifest for these. You have no idea about the UN numbers and what TC they would fall into anyway and couldn’t work out the totals even if you wanted to. So you might drop off 2 DG items at drop 1, 1 at drop 2 then collect 3 DG items at drop 2. And so on. As far as I’m aware these collections are also meant to be documented beforehand but never are so the totals are pretty much meaningless after the first delivery. As stated, considering you have no idea about the TC should any DGs remain at the collection points unless already sanctioned for collection with the proper calculations shown on your manifest?
You can rest easy now mate, because this isn’t your job if you are an employed driver.
This is very firmly the responsibility of the Carrier ( = the vehicle owner.)
They can delegate this to an employed driver, but it would need quite a shift in the way that they do things for that situation to have any chance of success. You’ve given a perfect example of what I mean, because there are collections to be done during your route. You are completely correct to say that the original plan therefore goes out of the window after the first collection.
iy67:
Example
You don’t even have any DGs this particular day and arrive at your delivery point, offload the goods and are about to collect the returns when you notice a 25l drum of UN 1993 N.O.S. which contains phosphate & ethanol (I think that’s what it contains, I can’t see the words properly) and has Class 3 flammable liquid and marine pollutant markings. As you have no idea about the TC should it be prudently left behind to allow you to seek advice and clarification? If it should be left behind what would be the consequences of collecting it a) knowingly and b) accidentally (eg. hidden in a cage so you couldn’t see it) then getting pulled on route and busted for carrying too much of a particular category?
As an employed driver… if your boss has told you that you can carry the stuff legally, then you’re good to go.
As a carrier, your boss has a legally inescapable duty to employ a properly qualified DGSA.
The company’s DGSA has a responsibility to monitor and advise the company. As a DGSA, my (free) advice to you/your boss is that the system at your company needs to be changed and there is a need for a review of staff training to take account of duties in connection with the carriage of dangerous goods.
What they’re doing is fine, but IMHO it’s the way that they’re doing it that needs changing. Otherwise, they will fall foul of what you fear if you get pulled. The outcome for you as an employed driver is that you will be issued with a prohibition, which is simply a minor inconvenience to you, but which can have a negative outcome on your boss’ ‘O’ licence at review and maybe his ISO.
iy67:
Could somebody also explain N.O.S. (not otherwise specified)?
Not Otherwise Specified (NOS) is a legal way of saying that the ‘stuff’ doesn’t have one of the legally required names in ADR’s dangerous goods list, or is a mixture of chemicals. As you’ve observed, the name(s) of one (or more) of the ingredients are shown as part of the Proper Shipping Name. (PSN.)
In many cases involving NOS, there are three versions of ‘stuff’ according to the level of danger EG: PGI, or PGII or PGIII.
Therefore, the ‘stuff’ could end up being in any of the five ADR Transport Categories, and there is the reason that an employed driver wouldn’t be able to know what’s what with it when it comes to whether it’s ‘in scope’ or not.
UN 1993 (the one you mentioned) is a great example, because there are three PGs for that one!!
iy67:
Finally, could somebody explain in simple terms the difference between limited quantities (LQ) and small load exemption (SLE). Is a LQ always a SLE and vice versa, a SLE always a LQ?
LQs are best thought of as the kind of dangerous goods that can be bought in a retail shop such as B&Q or a garden centre and packaged for retail sale over-the-counter. LQs are completely separate from any ‘small load’ considerations and can be carried without limit.
The small load exemption is completely separate from the LQ exemption, because that only applies when the dangerous goods are NOT packaged as LQs. As a rough guideline… anything bigger than 5L or 6Kg, or anything that doesn’t come as receptacles in a box (max 30Kg per box) or on small stretch wrapped trays (max 20Kg per tray) is NOT an LQ.
Anything that has this label does NOT count towards load calculation:
For me to give you any advice other than the very general advice above, I would need an extensive knowledge of what you’re expected to carry (how/where/when) and the way that the paperwork and returns are done.
I hope this helps, but I fear it might be insufficient.
