Danj
Every CPC Mod 4 test will include the following 2 questions. Below are both the questions and definative answers to both:-
LGV MOD 4
Section 4 - Ability to assess emergency situations
This question is on all 8 papers
(Q) Show me how you would enter the vehicle safely, and then show me all of the precautions you would take before starting the engine. b) You are now parked on the left on a busy main road. Please show me how you would leave your vehicle safely.
Open drivers door fully and use both grab rails to enter cab making sure that all steps are used (worth 5 marks)
Close door set seat position, set mirrors, check parking brake and gear lever (worth 5 marks)
Ensure that the vehicle is secure, stop engine and before opening door check all round for safety (worth 5 marks)
Turn round and use both grab rails making sure that all steps are used to exit the vehicle (worth 5 marks)
LGV MOD 4
Section 5 - Ability to prevent physical risk
(Q)
From the driver’s seat and externally, show me and explain the daily safety check you would make to this vehicle before driving on the road
Brakes (pull forward slowly and apply the brakes)
Lights (turn on all lights inc rear fog light but ask examiner to confirm brake lights work )
Tyres (as per mod 3 vehicle safety question) except add checking for foreign objects getting stuck between rear twin tyres)
Wipers/washers (as per mod 3 question)
Horn (forget this and you deserve a retest)
Mirrors (see above)
Speedometer/Tachograph (explain that you would insert digi card or tacho disk. No need to expand)
Reflectors/number plates (say you would check they are clean and visible)
Exhaust systems start engine then get out. (the only time you leave the vehicle with engine runnng). Look for excessive smoke or noise
Speed limiter setting show 90km limiter sticker and confirm to examiner that the limiter has been checked
If you give the above answers you will get 20% on each question. Hope this helped
Regards
John
