wire:
When i first arrived here i was on flat deck work and i used to wonder why i was struggling with tarps when a tilt or Euroliner would have been better but then i realized that most trailers don’t have chassis. I pull a reefer now and if i had a picture to hand i could show you that the body of the trailer actually is the only thing to it.
That’s quite surprising. How rigid that kind of structure is? What I mean with this is that how easily they twist when laden and driving over uneven surfaces and does that structure maintain it’s rigidity as trailer ages?
newmercman:
Think about this, Scandinavia has some pretty extreme weather, the roads are not exactly flat either & they run at 62.5ton with a 6x2 configuration, why then do we need double drive at almost half the weight? The answer is, we don’t, but that’s the way it’s always been done so that’s the way it always will be.
Well, actually I think it’s legally 60 tonnes both in Finland and Sweden, but at least here (Finland) you can be somewhat reliable that you wont get done for weighing 62.5 tonnes. But for the 6x2 vs. 6x4 debate that is irrelevant and even Finland isn’t very flat when that weight is pulled by 420 hp to 500 hp lorry which often is the case. There are more hills on northern parts of Finland and Sweden and despite that 6x4 is very rare on a freight hauling lorry as, like you mentioned, 6x4 isn’t needed when driving mostly on firm surfaces.
Lets take three lorries into consideration (let that be artics, wagon and drags or rigids as it doesn’t really matter). One of them is 4x2, one is 6x2 (tag axle, not midlift) and one 6x4 and they all are loaded so that weight on rear axle(s) is maximum allowed weight and, for the sake of the argument, let that be 9 ton on a drive axle and 18 ton on a rear axles. Next lets assume firm ground, like ice or packed snow on asphalt, which is so slippery that 4x2 can barely get moving and 6x2 can’t as one extra axle gives enough drag to get drive axle spinning despite both of them having same weight on a single drive axle. Like you probably know, 6x2 can get moving by dumping air or lifting tag axle up. 6x4 probably can get moving, as it has same weight on both drive axles as 4x2 lorry.
Now lets make conditions bit worse so that 4x2 can’t get moving anymore. As 4x2 has has same weight on drive axle than 6x4 has on both drive axles, it means that also 6x4 can’t get moving any more, but 6x2 can still get moving by dumping air or lifting tag up. Now why is that so? It’s because even lack of driver acceptance can’t outweight physics
In a short, a force which drive axle can transfer into the ground is directly proportional to the weight on the drive axle, meaning more weight you have on a single drive axle more grip you have (if friction coefficient between tyre and ground stays same). This means that when you lift tag axle up with 6x2 you transfer more weight on a single drive axle and this allows you to transfer more force to the ground opposed to 6x4 or 4x2 lorries. Actually I think that at least in Europe most 4x2 can transfer more force to the ground per single drive axle than 6x4’s can. If I recall correctly in Finland maximum weight on a single drive axle is 11.5 tonnes and 18 tonnes for two rear axles (19 t with road friendly suspension) and that equation gives you only 9 tonnes per drive axle on 6x4!
Now keep in mind this is just a coarse approximation, but as long as ground is firm, tyres are good AND you can lift free rolling axle up you’ll get more grip with 6x2 at slow speeds than you’ll get with 6x4. Grip is also increased with 6x2 midlift but with tag axle increase is much more dramatic. When ground is soft 6x4 is often superior as there are also other contributing factors than just the ability to transfer more force into the ground.
As a comment for those who are still thinking that 6x4 is superior to 6x2 on snowy hills: think about Norway. There definitely are small and winding roads climbing up the mountains and they have fair share of snow too and most of the Norwegian lorries are 6x2’s with tag axles which will raise from the ground almost despite the load. I know that at least Volvo has special Norway-suspension available which is rated for something like 19 tonnes on a single drive axle. I’m not sure about the exact amount, but I was like when a fitter talked me about it at Volvo carage some years ago.
