hi guys, with the wealth of experience on here, i thought id ask before i went down the rabbit hole…
i have a ablue light on with the following code:
1694 Aftertreatment 1 Outlet NOx Aftertreatment 1 Outlet NOx Sensor - Data erratic, intermittent or incorrect.
is there a common failure i need to look at first before i start tracing harnesses and checking voltages?
thanks all
qwakers:
thanks all
The type of truck is immaterial, the codes for the Engine is what matters !!!
priglobalservices.com/post/ … ulty-codes
If you can borrow a code reader ? You can reset the code, which will terminate the problem. You can also try these remedies as published by ■■■■■■■■
f01.justanswer.com/NicholasM101 … 6-1694.pdf
However if the fault reoccurs it may need a Technician.
