Just bought a 06 xf the mat in the drivers well is wet is this a windscreen issue or under the grill
barryclegg1:
Just bought a 06 xf the mat in the drivers well is wet is this a windscreen issue or under the grill![]()
Has it got sky lights? My mate had one that was a conversion from the small sidelights. It leaked one side like a sive
yes.will have a look at that, but cant see were the water is coming from. thanks
Do you need Tena Man?
your sharp
Wonder if that’s why folk keep calling me “prick”?
XF95 or XF105?
sunroof seals are prone to leaking at that age
what does the headlining look like?
also, could be the heater matrix leaking, on my Xf95, it leaked from behind the dash in to the drivers footwell
On mine its the aircon
Yep the drain tube under the grill is blocked and the water when the aircon defrosts has nowhere to go except the cab
