newmercman:
We’ve been down this road many times, maybe I’m wasting my time, but I’m going to say it anyway. Over 300hp lorries were the exception in the 70s and early part of the 80s, by using the F12, 3300 etc as a comparison you are doing the apples to oranges thing again.
The bigger lorries on the road at the time of the T45 design were in the 250-300hp range and so that’s where the mainstay of the range should ideally be aimed. From there once the model is established you then bring out a range topper, just as the competition did. Again we’ll use Volvo as an example, first came the F88 and then the range topping F89, they did the same with the F10 and F12 to a lesser extent, mainly because they had already broken ground with the F89, so the F12 wasn’t such a major engineering project.
Unfortunately,as history proves,it doesn’t work like that.The truck that you’re designing in the 1970’s is the truck you’re going to need in the 1980’s.In all cases you allow for the max foreseeable design spec during production life then go back from that to suit demand for lower spec not vice versa.In which case I’d guess that ‘designing’ for at least 300 hp + in the early 1970’s,or even late 1960’s,was actually being conservative.Bearing in mind that the DKS and F12 were both well established in production during the 1970’s and power outputs were only going one way from that point.Hence Leyland being in the position of a supposed in house manufacturer without an in house engine.
The point in this case being what if neither Volvo or DAF had engines reliably capable of that benchmark,in the form of the 11.6 and TD 120,in their armoury,as of the 1970’s ?.
archive.commercialmotor.com/arti … 12-rockets
You do talk ■■■■■■■■, the F12 wasn’t launched until 1978, at the time it took part in a euro test in TRUCK and it was the most powerful lorry they had ever tested.
The UK was a 32ton market and despite years of threatening to implement a higher weight limit there was no indication that it would ever go up, so why on earth would anybody without a crystal ball design a range of lorries for a weight limit that never existed at the time?
You have to remember that the British market was the strongest in Europe, so Leyland would be foolish to concentrate on anything else. The importers may well have had more powerful lorries in their ranges, but they also had higher weight limits in their home markets that had to be serviced, if Sweden was 32ton and not 52ton, do you think that Volvo would’ve bothered with a 12litre engine? And even at 52ton they thought that 350-380hp was more than enough, as did Scania with their V8, even without a calculator you can figure that a 275hp TL12 at 32ton had a better power to weight ratio than a TD120 or DSC14 at 52tons.
You also keep banging on about Daf, well that only compounds your ignorance of the situation, the 2800 was nothing special at all, the cab was cramped, the driving position was horrible, like driving a Bedford TK, they couldn’t pull the skin off a rice pudding and they drank oil and leaked air like a sieve, they were also heavy and couldn’t legally couple to a 40’ trailer.
I used to run to Italy in a 2800 Daf and it was no better than a 1628 Merc or an F10 on the hilly bits, it certainly couldn’t live with a Transcon with a 335 ■■■■■■■ or an F12 or 141 and during the evenings I spent relaxing in a routiers with other drivers, not one of them ever brought up bore and stroke dimensions, so I guess that part of the equation was over our heads…
Seriously, you’re surpassing yourself on this thread, change the bloody record before the people with facts and considered opinions run away screaming from your incessant ramblings about bore and stroke and mega hp dream machines.
