Bking:
As its an Iveco they are probably oil resovoirs for the wheel bearings.
They run in engine oil not grease so probably on long distance trucks they monitor the hub oil level.Cant see how you would monitor tyre pressure from the hub.Most tyre monitors use radio transmitters in the valve stem.
What an absolute load of total ■■■■■■■■.
No more than saying they are for inflating the tyres, though I cannot see how the engine oil would get to the trailer hubs…
Bking:
So Iveco dont run front hubs in engine oil!Check out the old Eurostar with the sight glass.
Shows what you know a hole
Bking:
You beat me to it,better to say nothing and be thought a fool than to open your mouth and confirm it
Bking:
Shows how dumb the fekers are that drive the trucks if they need a “warning” light in the cab to tell them they got a puncture.
F/ing morons.
I’d say it’s pretty moronic not to acknowledge the fact that the pressure in a tyre changes significantly with the outside temperature, thus the need to inflate or deflate them accordingly. but you got to say something bad about somebody to make your own existence a bit better, so good for you
