Another pic of Paul’s fresh moter.
Truck Net member gah1950 bringing a portable crusher into the Strinds/Dolyhir quarries this evening.
Smaller pic to get Graham’s big Scania on the screen.
Gross weight of this outfit is approximately 125 tonnes.
hiya,
Dave do me a favour and ask the driver of this motor if i can have a little go, just for old times sake, “you know what i mean Harry”.
thanks harry long retired
Graham’s Scania V8 620BHP moter parked, awaiting further instructions from the quarry management.
harry_gill:
hiya,
Hi Harry,
He is on these threads. Had a chat with him while he was waiting to park the outfit,he was good enough to ring me and tell me that he was coming up this way. That quarry is only 5 minutes away by vehicle from our place.
Graham’s Scania with Nooteboom trailer and bogie, with the Locotrack onboard parked at Dolyhir.
I remember when the crushers were on a trailer chassis and if you did not have the brakes adjusted before you moved them you would have a very scarey journey :laughing: that was a long time ago.
sammyopisite:
Hi Johnnie,
I remeber Nash Rocks who had the quarry that the pics of Graham’s moter was taken.They had a mobile crusher called Goliath which they move from that quarry to another about four miles away,it weighed 80 ton as far as I know,they pulled it with a loading shovel with another pushing from behind. Once in place it was static,whereas the one on the lowloader is on tracks and is fed by a 360% machine and moved quite often.
Steering axle’s on the bogie.
Closer look at the crusher,also the rear steer axle’son the trailer.
View from the nearside including the rear steer axle’s.
Side view shows how long this load is!!!
Graham reversing the combination back to have a sweep into his parking place.
Awaiting orders for parking.
A similar machine to the one Graham had onboard,at work.
sammyopisite:
Hi Johnnie,
Hi Dave in the prehistoric days they were built on a trailer with king pin at front 3 to 4 axles all twins you just went with unit and coupled up to them but with the weight the brakes were iffy
cheers Johnnie
sammyopisite:
sammyopisite:
Hi Johnnie,
cheers Johnnie
Hi Johnne,
The last time Nash moved theirs,was in the 80’s,it was used when Leominster bypass was built. I have a pic which I posted previously. I will dig it out and stick it on again.
