New ps4 expected to be about 40w draw according to their website add 35 w for a 17" screen , so thats 3A ish at 24v. Allowing for generous invertor losses call it 5A total perhaps, thats a ■■■■ sight less than having to leave the sodding side lights on all night in the laybys that you are having to do now !!!
Play to your hearts content I would say as batteries must be at least 200ah even on a puddle jumper.
jediknight:
hi im very interested in doing the same using an inverter with xbox and small lcd tv using an inverter, question I have do you just use a multi plug adapter for both plugs of tv and xbox. cheers
Yes I use one of those multi socket extensions
Thetaff2:
PMSL!! And you know all about me then?? You tried it for a living and failed like you did at shunting trailers in tescos in goole…FYI 4 year apprenticeship in electrical and electronics,couldn’t sit my AM2 exam as the firm I was with went pop so I was rewiring houses at 17 years of age so that’s ■■■■■■ on your chips!
Like I said on site not sat at home looking in a book…Hope this helps but I doubt it as your so far up your own ■■■!!
LOL @ yet another jumped up sparky thinking he knows about electronics theory. You hardly need to be a rocket scientist to strip insulation off cables and shove the bare ends into a connector and tighten up the screw. Hell, you didn’t even get a qualification whereas I have BTEC HNC Electronics Engineering.
Rewiring houses at 17? At 17 years old I was working as a bench engineer for Euromax Electronics fault finding on arcade video game boards to component level.
Like I said, I’ve forgotten more than you ever know. Judging by the fact you believed that halfwit it would appear you’d have failed your AM2 if you ever sat it.
Conor:
my dad is big
thetaff2:
my dad is bigger
Conor:
No he isn’t
Just to bring this thread back to life…lol. is a 300w inverter enough for ps4 and 22 inch tv??
gurj254:
Get a 1500w big enough then to run microwave and coffee machine to then. Home from home
taffytrucker:
gurj254:
Just to bring this thread back to life…lol. is a 300w inverter enough for ps4 and 22 inch tv??Get a 1500w big enough then to run microwave and coffee machine to then. Home from home
I would get one of them but I need an anderson lead to connect to it…where can I get on of them from?
also what is the best way to mount tv in a scania?
Any leads you need should come in the box with it. As for mounting I don’t know I got a Peterbilt and keep it in a cupboard when not in use. Try speaking to the guys at CCC in Caerphilly they pretty good at stuff like this
I want to install an american style fridgefreezer and a washing machine in my truck, could i connect both to the 24v hella socket and then i want to wire up a microwave to the 12v cigarette lighter, should i put an inline fuse in first before switching them on. I appreciate your valued advice.
