Using 12v devices in 24 v socket
bjd:
whats the na and n markings for ?
A = Apple
NA = Not Apple
I have no problems with using either ports with my satnav, samsung phone or anything else I throw at it, but I am guessing with an apple device like iPhone/iPad you will need to use the A ports
bjd:
trubster:
I use one of these
amazon.co.uk/gp/product/B00IL1DJCQ
£11.99 with free delivery
It runs off 24 volts or 12, no faffing about with multiple sockets/plugs/adapters.
Very handy, it charges my phone up at 2 amps which the cheap chargers fail to do, why 5 ports? I use it to charge the TomTom, Phone, eCig, Handsfree kit and tablet if parked up watching TV.
whats the na and a markings for ?
Reading the listing, one is for Apple and the other for non-Apple…
I need to convert one cigartte lighter socket into two or three as I would want to charge my cooler and sat nav or phone at the same time.
Would this device be good enough?
amazon.co.uk/Cigarette-Split … _cp_auto_0
if not , what would chaps recommend?
what about this Hella plug to double lighter socket?
amazon.co.uk/Hella-Double-Li … or+12v+24v
There is also this:
amazon.co.uk/WAY-CIGARETTE-L … 2NQ8R6FSVF
Reviews are not very encouraging , they do not last long.
Has anyone any solid device to recommend?
What’s the difference between this Hella one and other ones?
I’ve got one of those Hella to cig lighter doublers for when I have to take another motor out.
It’s perfectly adequate, just not very tidy, and you have to keep an eye on gravity/vibration not working the plugs out.
In mine I just chopped the cig lighter plug off a 4 way (screwed to the dash) and swapped it for a hella plug. Got 2 of those double USB sockets in it for my phone, DAB radio, wifi dongle and tablet, then my satnav and coolbox go into the other 2.
Works a treat. Only put the hella plug on as the socket is more out of the way, and it’s a constant live, not ignition controlled.
trubster:
I use one of these
yes that looks really good mate
but before i order it can we just confirm 1 or 2 things
so i just plug it into the 24v cigar lighter socket in the cap and i can then plug 4 12v charger/devices into the 4 usb sockets
and they will work without any problem
or as i have no apple products does it mean i can only use the 2 not apple usb sockets
and i dont need a voltage dropper thing either
villa:
trubster:
I use one of these
Yes it will plug straight into a 12 or 24 socket.
You can plug up to 5 items in at one time, no problem.
The apple bit is down to a problem with Apple devices saying ‘Not Charging’ whilst plugged in… You can use any of the ports with none apple devices.
Amazon do let you return ‘Fulfilled by Amazon’ items free if you are not happy with them… Have a go. (just don’t be tempted with the prime offer if you are likely to forget cancelled it.
trubster:
villa:
trubster:
I use one of these
thanks mate i am just about to order it but can i just ask one more thing
i use a 12v fm transmitter to play my music through cab speakers
my 12v fm transmitter will not work at all on the 24v socket
so if i buy this will my fm transmitter work when plugged into one of the 4 ubs sockets that are then plugged into the 24v cigar lighter socket
Amerson prime yeh i got caught with that only noticed when they debited my acc. but i made a fuss as i only used it twice and got my money refunded
villa:
If the FM Transmitter is powered by USB? I haven’t seen one before, but if it is then it will work as the USB port outputs 5V regardless of 12 or 24V Input
bjd:
Some love it, some hate it. I love it, I can order up to about 6pm for free next day delivery, get 20% off nappies, 15% off regular bulky grocery items and Lovefilm (Amazon instant video). I am paying £49 per year (£79 for New Members AFAIK) for this and next year so I am happy with what I get.
If only I could ban Mrs Trubs from Amazon. I wake up to more and more “Your parcel is on its way” E-Mails :smiley: :smiley: :smiley:
dont let her on the net make mines a bit like that with e bay
Manc:
lankyphil:
Check your charger. A lot actually say that you can use them on 24V… It’s the input part of the ratings sticker (if it’s got one mind you). When I first started driving I panicked cos I had me birds sat nav and I thought the charger wouldn’t work or it would get fried, but that said it could take a 24V input. Since then I’ve used my phone charger in the cab and it doesn’t hurt it. it actually charges my phone faster too…
Hi
I am new to the forum.
I am a LGV driver.
Has anyone else used the 24 v cigar point in the LGV to charge thier mobile or satnav successfully?
Has anyone used the following web site: roadking.co.uk
Has anyone purchased the following, if so, does it work?
roadking.co.uk/24v-12v-dropp … 4-12v.html
Cheers
Thanks for the replies
I have a Snooper S1000 satnav and Snooper have just confirmed this will run off 12V & 24V
Makes no difference the chargers are transformers (step down to 5 volts) and have there own current/voltage limiting circuits.
Bloody hell, have you not looked at the rest of this thread. Some of the voltage regulator transistors will work with a 12v input, some with 24 etc. If you put 24, or more likely 28v into a 12v rated transistor, it will over heat. I’ve seen this happen with an LM317 type transistor and it doesn’t take long to get hot.
So NO, they’re not all the same circuits inside !
villa:
trubster:
I use one of these
Read this and ordered one as mine died. Great bit of kit. Well impressed. Thanks for tip
