Trucks, tracks, tall tales and true from all over the world
cont. This is where i ended up thinking i was going to be a driver for my whole life -reality had arrived,
After the stores week I had to get to know the sequence of how the engine block got to the build station that was called a “cell”
First it was [the machined engine block] put through a pressure wash, then after it was what was called “ de burred ” that was two men with wire brushes and reels of emery paper, [abrasive paper just like sandpaper ]but just for metal and castings, and they had to get everything on that engine block smooth as silk inside all the crevices and journals, they had long brushes [like baby bottle cleaners] everything they needed to get it perfect ,so it would pass a microscopist inspection,by eagle eyed inspectors that was their job.
They used a big roll over machine , it does what is said, to inspect .it was firmly clamped in the roll over machine.
Once the block as been passed A1 the de burr men then had to fit in the main bearings caps ,they held in the crank shaft the .part that actual made the engine pistons work as the were bolted on to the crank-shaft with massive bolts ,and torqued up with a [special torque wrench] =a very large spanner 4 foot long ,at the end [just like a socket set you would use for home mechanics ] you put adaptable heads that fitted the size of bolt you were tightening up, there was a screw device on the end of the spanner that you could set the amount of poundage, [pressure] you wanted the bolts tightened up to .[it had to be right written down in the build sheet] once that had been achieved the spanner would not move. it made a cracking noise .so you knew the pressure had been reached,and that went for all the nuts on bolts throughout all the engine build.
so the main bearing caps held in the main crank shaft and they would stamp on the bottom of the casting, that was shining bright, a number that followed the block all through its construction the main part of the engineering masterpiece. Then it was now ready for the engine builders [mechanics] to do their work. They would have all relevant paper work and collect the block that was on a stand made to take all the weight when finished, the stand was fitted to a steel flat sheet ,as thick as a kit- kat bar , and it floated just like a air bed - hover craft ,and would be moved wherever need by a air umbilical air hose, very clever, into their cell. inside these cells there were perforated metal sheet sides that would take plastic bins that held all kinds of bolts and nuts screws that they needed to build the engine and to attach all the ancillary parts that made the engine up,in fact the cells were stacked out with boxes of bolts .
The same 6 men ,3 shifts, would stay in the same cell for the one engine .so you would think that they had all the ancillary material they needed ,but they did not ,as they would not stop to look around there cells or the other ones ,so they would then go to the stores and loose time waiting for bolts [whatever] that they already had and not bothered to look for so it was down to me to try to stop the men from going to the stores. my job was to be the unpopular redistribution man to stop the men from wasting time at the stores .
Though it was never put to me that was what the foremen wanted to happen to boost production up
it soon came apparent that was what it was about ,they new how much material was out on the shop floor that the men were to use but the output of the engines did not add up ,with the material issued. This was the very first time I had seen a computer,as I was allowed in the stores,i was given a free reign and I was shown how to add or subtract from the stores computer what I wanted or returned .I now realise that all the computer was only a stores program but then it was a magical piece of equipment.
I will be completely honest the actual trying to remember all the numbers of the bolts, washers, I thought no way in this world will I be able to cope with the new challenge ,also the very bright strip lighting was given me massive headaches ,it was as if why am I doing this, also massive diet, blood pressure,and the normal living .it thought [zb] this im off, my normal way of dealing with any thing I thought I need not do[ but I did not realise it than now later I can see it clearly]
I have always said I do not like challenges, like mountaineers ,runners, I have never been competitive I could not give a [zb] if I won or lost ,darts,anything, through out my life, however now looking back that is all I used to do myself ,and that in the build shop ,was one big challenge although I never looked at it like one ,i just thought get back to driving ,who needs nuts and bolts [zb] the factory.
However no driving jobs were available at that time so I had to get on with it and try to make it work strip lights as well.
It probably took about 3 months of moving all kinds of material around, and knowing how many actual pieces of the smallest to the largest engine needed for the men needed to make up the engine ,i did not know it all by any means ,however I used to be able to look at the work production sheet the men /women used and could see what was needed to a layman, I did have a few bust up with certain men about me taking any type of material out of the cell they were working and redistributing it around as if it was theirs .i used to say it was my job nothing personal , they got it in the end by a strange way. i did make the foremen aware of the situation ,but there is always one.
I had now got the bolt numbers in my head ,i also used the fork lift to get all the fly wheels down from the high racks for the men, I was learning more about the engines all the time however if you have never been trained from the very start of anything ,basic at the bottom you cannot fully pick the technical part up with out proper training,and that goes for anything .
I now had the sequence of the build in my head ,as I had watched it enough,getting to know how to sweat the gears on the end s of the cam-shaft also [there were small high power ovens in the cells to heat the gears up hot to be sweated on the ends ] however getting the right key that went onto the end was the hard bit that I would not be able to do right ].also the engine timing by the gearing inside the front plate.
Their was in actual fact so many small but important things to be done on the engine ,and to be sure that it was right would and could only be done by a trained mechanic .i doubt I would have got it right. So I new i had got about as far as I would be able to go within the build system and I would be a material handler , no problem,but I still kept going to the open door
peggydeckboy
SENIOR MEMBER
The economic climate within the country was not that good and it seemed as if the work was slowing down, I would notice that not so many engines where ready for completion ,and iused to go in to work for some shifts and have absolutely nothing to do, maybe I had done such a good job and done myself out of work.? I could walk around all shift with a empty box and no one would ask me what are you doing.
It got as on nights there was nothing at all to do ,only find a place within the stores and doss down for a few hours, something was going on and no one was saying yet,but it arrived one shift we were there , a notice was on the board stating that, low demand for engines was hitting the world demand for engines being a American firm they meant world wide, they would have to cut back with staff from all departments ,and it listed how many from where and it was last in first out,so as I was technically from the stores it looked as I was zbked, and as it turned out I was .
However the good news was that they were going to pay a minimum redundancy package going in 3 year stages [1month employment or 3 years you would get the same ] and up it went. I did not need to apply I was out ,but the cash deal was good however you would not get unemployment benefit for [I think it was 6 weeks] so off I went .and now to think about my future again.
Shift work ,i did not mind it at all as you got a premium payment so that made up for the inconvenience so I would look around for factory work within my area for a time. that was like trying to find rocking horse [zb]. So it was going to be back to the lorry,s or dole.
I phoned for van jobs,lorry jobs anything in the end I got a interview about 10 miles away at a crisps factory in long Buck,by at “Golden wonder crisps” after the interview I was told that I had the job , Monday on days doing delivers to their warehouses [inter factory work] just what I needed]
I thought [not] as it was C licence work, own account meaning that it was a factory that operated their own lorry ,s also manufacturing production of crisps,and other products.
So the lorry,s were just another department and it could be organised and operated by a complete “numb nuts”.Not run as a haulage company, they were only legally allowed to haul there own goods or goods needed in the manufacture of their goods. That meant as a driver you never had a proper transport manager each shift foreman run the transport they needed,I new it was going to be a fiasco ,i had not forgotten any of the rules, it was not long before I found out the men running the transport did not know any .
There were other drivers there they had been there years so I was put on the shunting from one factory to another about 30 miles away. While they did deliver work to wholesalers.
It was not long before I found that the shunter unit I was driving was basically I wrote a defect sheet out and handed it in to the foreman, well he had never seen one as long before,so down came a manager, to sort me out-ish after I had listen to him all I said was oh, if you do not want defects you should have proper legal lorry,s and said ok if I kill you kids it is ok then he then got it and said yes we will sort it out .
mean while drive this other unit. Yes ,no problem, well that was worse, brakes -■■■■■■ , electrics [zb], no mud guards, it was a disaster and I thought is there something wrong with me or what .off I go again defect sheet ,in the meantime one of the regular drivers arrived back with his lorry I was told to use that ,fair enough. off I go to do my shunting local ,well [zb] me the speedometer in this lorry was not working. I should have turned around and gone back but I thought I just do one trip .
If I would have been caught speeding it would have been down to me, and you imagine explaining to the police why you are driving without a speedometer ,do not even think about it,
back I go, and the driver is still there so the conversation went like this
,excuse me “drive”[that is what other drivers call another driver if you do not know them]
i asked him did you know about the defect on your [ motor] =lorry,
what defect
oh I just went to market harbour and I noticed as soon as I was on the road after I put my tachograph in the speedometer is zb
no it was ok with me he said
I said o k show me your tachograph then, your making out as if it was me.
zb OFF WHO DO YOU THINK YOU ARE YOUR ONLY A TEMP .
What ,a temp .i was told I was permanent ,so the bells were ringing ,i said ok, get the boss down who can deal with this, so down the chap came and said what is the problem to the other driver,
I said it is me ,not him. and I told him ,that he allowed me to go out of the yard with a speedometer not working without saying, and he will not show me his tachograph, so the chap said why should he, so I said you will see that he has been driving without a speedometer all day.
show the boss then I said The bos said to me I think you better go home and ring later .
I said if you think your going zb me over ,over this ,I am going straight to the ministry of transport, and then you will be zb not me. The head ministry of transport enforcement officer [I know lives in the village I do]we drink together]white lie ,will get to know about how you run defect lorry,s and make the drivers do it with total disregarded for road safety. I still had my old transport [nothing illegal] head on
Towards home , I thought I cannot believe this ,as I had to go through the town ,I better get this sorted for my benefit maybe later on, I drop into the job centre and ask for a interview ,and I get one, and explain what has happened, in case it would affect a dole claim if it had come to that and if they ask what happened as leaving a job would affect your entitlements for the out of work money, also that was me out of the crisps.
I rang up the next day ,no surprise, I was not needed but they would pay me the week, sas they had my p45, I wanted that back I had calmed down and I thought ,do I want a lot of trouble going to the ministry no I do not ,so let them run like that I know I will not .
Back to the local papers, and telephone book looking at haulage companies ,i did ring S T CHALLIS. However they had nothing at the time but they took my number ,so if they had a days casual and I was available. They had branched out in to the general haulage now and very little cattle transport .
I went around local building site for any casual labour, carrying bricks ,concrete, digging anything what I forgot was I had been mollycoddled within a factory ,my hands were as soft as butter and I had not done any hard work for a couple of years physical y I was not ready for the harsh working environment of building sites ,so I was kidding myself ,also I had no rough old clothes that could be ruined in a day. so I now had talked my self out of it, and I gave up looking. My one asset was I had a car and I would travel to a driving job if possible ,and if it was a long way from home for a daily run I would stay the week ,[where ever] if no nights out were with a job.
I drew a circle on a road map , the map was out of a A A road hand book, my village in the centre and I thought about a 40 mile radius . That incorporated a hell of a area and distance , i thought god no that is to far ,it stretched way to far , you would not work as far as that, o I cut it down to 30
and that was a big area,i picked out the towns, noted them down then thought how am I going to find road haulage company’s if I do not know them. [never thought of that] next move ,that evening I went to the pub and waited to see if the ministry man came in for a beer he would know all the company’s around and hope I strike gold.
No, he did not turn up however,another friend came in and we got talking as you do and he worked in Northampton at a British Timken Factory world wide roller bearing manufactures ,and his hobby was model lorry,s [now trucks] he started telling me about the new firm started up in Northampton near where he was working. And he was going on about these brand new trucks ,large boxed type trailers, paint work like he had never seen, I said [zb],no he said it is true they are brand new A reg DAF,S what the zb is a DAF I ,he told me they were from HOLLAND.
They were getting into the English road haulage market with sleeper cabs. He said he would find out more in his next dinner hour and give me the thumbs up with information
True to his word he went wandering over ,got chatting to a fork lift driver ,and pumped him for information, and come back with it he told me that night , that was me I was going to Northampton to see what was going on .
I must just say at this point of time I had what was called a full set, a massive red beard and sideburns. A slightly twisted moustache all red/ginger, all my head hair was auburn/black. I did not think anything of it but I was told later [once seen not forgotten ] the beard.
As I turned into the place where this company was, there was no lorry,s at all no sign of lorry paraphernalia I thought maybe they just delivered and then went else where . It put me off for a minute . I turned away and parked up and waited to see if anything happened at the unit /warehouse, i was not disappointed after a while I heard this lorry turn in to the unit area and there it was a [massive top line sleeper cab]i was told later.
Jesus I had never seen such a lorry before .it was jaw dropping,you could say .it swung [turned] in ,screwed round all the 6 rear axles tyres squealing rubber on concrete, I noticed it had two fuel tanks and they were big ,I mean large double capacity more than I had ever seen,before and the polished cab was unreal , also a massive engine on the front of the trailer belching out exhaust ,the trailer had a very neat paint job a just massive blue lines reading ROKOLD. The whole length of the 40 foot trailer 13.6 meters.
I made my move to go to the office,little did I realise they were all running late ,in a panic ,could they be bothered with job seekers, So there was me ringing the door intercom to try to talk to anyone,i said my name and the reply was “yeh what can I do for you” I said I am looking for a job .the reply was ,go down the job centre we take all packers on from there, I replied, I am a lorry driver.! O hh hang on you want Mr WEBB ,right where his he, he,is round the back of the trailer, And off I go round the trailer rear and inside there are 3 men moving boxes making lots of noise ,and cursing I thought I better just step back a bit and wait, that would be my best move,
,as I did I heard “Hello can I help you!”i turned and said yes please I am looking for Mr WEBB ,yes that is me what is the problem,!no, nothing, I told you might be looking for a driver,are you from the agency no I replied, then give me a hour ok ,I have got to move this lot, he said
ohh right,can I give you a hand I have nothing to do, I said er, no your fine but thanks.
When he had finished I went into the office ,and did the usual full job history, discharge book as well .and hope it was enough.
It turned out in 2 days time they were interviewing men or women for a driving job and they were filled with allocated places. And they did not have enough time for any more, I asked if any jobs going loading lorries or helping out as I needed a job. Well he said that as we ROKOLD only deal with the transport ,all the others are from a agency, so that was that ,but he said give me your phone number , [home number mobiles had not yet come out] and if there is time I will call you to come for a driving test on Friday. at lest a maybe .
Thurs 8 o clock at night Mr WEEB rang me ,be in for 2 pm Friday for a test. i got there early i parked in the garage next door out of sight to see what was going on test wise , I could not see any lorry , so it must be on test and later the same lorry came in the yard, and did a sharp u,turn and made the trailer tyres scream in pain as a lot of rubber would have been taken off the tyre tread, not the way to do it…
My time came I went to see MR WEBB and as i pressed the intercom a little man came out of the office never spoke and went to a car .MR WEBB welcomed me with a handshake [unusual ] then for a interview then told me some one could not make it ,so I had got a place ,he then went in great detail to Explain what the job entailed .I was told they did the haulage for a company that supplied supermarkets there were no big depots then, like now days called HUBS that all supermarkets have now for all their food distribution
All kinds of fruit and vegetables, from all over the world. they are collected from the airports wherever they arrive at
also produce was delivered here at NORTHAMPTON to be pre packed for all the main supermarkets then it was Sainsbury Littlewoods, Tesco, Waitrose, that was who they pre packed for then and the company was called Van-Heijningen .the biggest tomato producers in Europe
Rokold were the haulage contractors and the Van Heijningen were growers and the main suppliers a lot of the drivers who did Rokold work were owner drivers with their own tractor units .Rokold only had 4/5 of their own lorries and two were shared between god knows how many drivers as a lot were casual ,however if I got the job I would be permanent on a 3 months basis , as they were building up the company,there was a lot more about the job than I was told .
Mr WEBB, asked for my licence, excreta then went for a driving test. In this zb great big new lorry 3 steps up in to the cab ,it was impressive, I did ask before we left, as everything been checked ,fuel ,lights, tyres, oil water,and I asked for a tachograph , I think he was a bit surprised, as we were only going around town, but he waived it and said it was ok ,so off I go it had straight 6 gear box with a splitter for each gear so in theory you had 18 gears,however no point in using any except the main H pattern 6 gears, unless heavy loaded …
.also it had a exhaust brake ,consisting of a button on the floor by your right foot to be depressed when needed when in gear to ease the using of your brakes In the normal way ,what it did was put a shut off valve on ,inside the exhaust pipe from the engine slowing the pistons down [exhaust braking]. All new to me i had never heard of it or seen one before as it was getting on for 18 months since i was made redundant and not driven However I knew about them, I went and found out about D A F trucks from a fitter friend I had who knew about most commercial lorry s.
I did not use exhaust ,when I arrived back at the yard I did not screw the trailer round i did like a 3 point turn and backed it in. and that was that, I will let you know he said it was up to his boss and him off I go home and wait.
It was a Sunday around 2 o clock the phone rang, it was Alan he said you have got the job ,sorry for the delay, Would you be in for 6 0 clock Monday evening ,
This was after having a driving test on the previous Friday in a new 33 daf 40 foot refridged trailer I had never seen a truck and trailer like it before the last truck I drove was a seddon or crusader I have forgotten which with a flat bed 40 foot trailer I am not sure now it is a long time ago 37 years however I was very pleased to just even sit in it let alone drive it.
Also bring your sleeping bag he said ,we also like all the drivers to have their passports with them at all times luckily i had a passport, why do I need a passport [no computers then or else i could have goggled Rokold.] the only knowledge I had of the company was that they delivered mainly tomatoes and fruit to supermarkets I would have to wait until Monday night.
It was a 22 mile drive, back roads to Northampton from my village slower drive than the main road ,but shorter distance ,less petrol the time came, do I take sandwiches also a flask? i have not that much cash ,yes I did and sleeping bag ,pillow ,wash bag. Just in case
At the depot a older D A F A 2800 model, small cab sleeper 2 bunks, all though it had 3 axles the same colour as the other i walked around the back of the trailer Alan is in the back of the trailer pushing up pallets to the front with a driver i assume Alan turns and comes to greet me ready to shake my hand I had only seen him 3 days before he said his greeting then said for me to jump on up into the trailer , not the easiest thing to do but with some scrabbling i manage it, usually they use the fork lift
He then introduced me to Tom who was the driver of the lorry and he would be showing me the ropes, however I could tell that Tom did not want to know however he shook my hand another pallet arrived we then all 3 of us pushed it in to position the trailer was getting full what look like all kinds of vegetables after a time the trailer was loaded, we all jumped down then the last two pallets were pushed on with not a lot of room to spare for the trailer doors to be closed ,Tom shut the doors , went to the front of the trailer and started the engine for the fridge that kept all the produce inside the trailer at the required temperature . [Another new thing for me to learn]
In the office with Alan he took my p45 and then told me about the duties and hours and pay, that it was as position for 3 months that could lead up to permanent however they as a company use mostly owner drivers to do the majority of work ,and that the company only have 4/5 lorries of their own and they are utilised by casual drivers[part time firemen] to cover a lot of their work however i would work sometimes 5 days or even 3 days whatever and the monthly salary would be the same do not worry if you have days not at work. i found out later you make up for it they gave you £50 for expensive s for anything you had to pay for while on Rokold work, also if you had a night out, that would be paid in to your wages tax free.
Alan said if the company got really busy they would hire another tractor unit as they have just got a new job delivering to a super market and will need me. also that they do European work when required and that could be without notice, however I would be shown the procedures by going out with another driver first, it would be with a owner driver, it looked promising for me .
If the truth was known then I should have got out , gone home and forget it, I did not ,and ended up driving about 21 years on the continental until 2002/3 but I did not know it then
It was a new challenge and 100% different from the road haulage that I was used to i would give it a go ,TOM, was all right ,but I do understand now, then I did not, that it was a pain in the arse having a driver with you let alone a new one like me ,at least we both smoked so that was all right.
We leave the yard already running late for a booking to unload at Hemel Hemp-stead
it was a 1,1/2 hours drive the company being delivered to were strict on getting on time for booking time! 10 o clock at night , apparently it is going to be a different world I am embarking on Tom was pushing the older D A F to its limits no 58 mph then on the Motorway
We got to the delivery, watching the procedures it was all new to me the pallets were tight loaded to the back doors, you would not be able to back the articulated lorry down[on a slope] to get backed on to a unloading bay, you had a problem ,a ramp inside would not come down, that allowed the people inside to move in and out of the trailer to unload, you had to pull the lorry off the unloading bay, back to where you started from, then go into the warehouse and ask if they would use the outside fork lift truck to take the back two pallets off, then you would be able to do the original move again, if! you could find the fork lift driver ,he was not obliged to do it he would for a small price He would take the 2 back pallets off and deposit them inside the warehouse via the door you should have been backed on.
First lesson learnt do not leave the base if the pallets are rammed up to the back trailer doors, and make sure there is a restraining strap around them. ,why did we leave like it then ,Tom had got the hump ,and he forgotten
While all this is going on, other lorry’s are coming in the area where we are trying to get unloaded outside, and one is trying toback in on to the bay where we were ,however this chap wanted to go where we wanted to go, he must have thought we had just come off the unloading dock finished.
,Jesus I kept back and letTom deal with it i found out he had a very usefully tongue on him ,and would not back down eventually we get away and head down into London we had got, Samples to Baker street.
Kings Cross Rail Station in Baker Street, LONDON is nearly opposite Sainsbury’s head office the boxes are samples, of all the fruit and vegetables the company has imported trying to sell to Sainsbury, they are for their quality control, to either accept or reject,apparently that is the way they have been doing it for years the only problem is that we were on the wrong side of the road to the offices we had to drive on, find a place to turn around Tom had done it lots of time before so it was ok. He then drove to outside the office doors, you just leave the boxes in the door foyer with a lot of other goods you do not get it signed for, you we have to drive back around again the wrong way you want to go as our next deliver is Spitafields market in the city
Once outside the Spitfields market.over the years i had been past the market numerous times,however never been to a market in fact i had not been to any fruit market before,we used to park around the corner on the what is now a brewery was a round about in the 1970s near tower bridge… it was built for horse and carts, a mass of wire cages that people had all there produce in called stands only delivery drivers and the odd fork lift man were around there were only a few fork lift drivers around ,Tom told me when at Spit fields Market ,stay outside, unless you have more than 4 pallets ,as that was the limit the fork truck drivers would take off your lorry outside to go inside for one customer , if once in there you will not get out until all the lorries in front of you are unloaded a working area for hand carts
I was forever gratefully for Toms knowledge that night believe me. you went and found the forklift driver told him who you were delivering to how many pallets and where you were parked give him the £5 if you were on your own how do you know the fork lift driver will take the pallets to the proper customer who will not be there ,the fork lift drivers have the keys to the lock ups you have to trust them.years later at Liverpool marketthat was the last thing you did trust them.
Once done there .we then went to the worlds most smallest zb ing market in LONDON called THE BOROUGH just over London bridge inside there is a working open all hours pub, just in side the market ,and what a place, I followed Toms every move and learned that they use the same wholesaler every time ,and they had their own fork lift driver, and you were not allowed to touch any produce on your lorry at all ,they had what was called Porters .and they organised you ,t after they had seen your delivery notes,
Another load of the laziest ba–ards you ever met ,though you never had to pay them. not on a week day, however as I learnt later ,when you went to deliver on a Sunday night there was not the slightest sign of man or beast to be seen .WITH one fork lift left out in the square [yes all you old market men will remember]. for all the drivers to unload their self’s, pure nightmare it was a one way system very tight trying to get passed other trucks,
it was about 3 am by now or later ,we set off for the next Market New COVENT GARDEN nine elms just passed Vauxhall bridge, tom let me drive i found out later on that he had been up and working since 6 am the Monday it was now TUESDAY into the Market you have to pay a entrance fee to get in [all lorry s] Tom shows me where to go they have a regular customer it is all undercover.
We are parked in the inside of the market, all the stalls are starting to get ready for opening, once our rear doors, are open the fridge is switched off a pallet truck is put upon the trailer, I follow it up and start pulling the pallets back to be taken away ,the pallets have a big paper label on with the name of the customer ,you stop as the name changed ,tom said stay up there there are a few pallets to go back on, I pushed the pallets up to the others then told to come down after the pallet truck has been lifted off. i have no idea what is going on and do I care no.
By this time we have left the market, I am driving and Tom tells me to head for HESTON by Heathrow airport and wake him up when I see the sign post for the market, it is if I am driving on my own at last. He is soon asleep i am driving past Harrods I had never been this way for years i woke tom up ,he jumps up, tom we are at the market.
Once at the gate the guard ask where is my delivery how many pallets, Tom shouts 4 only, to some name, and we go right around the market to about the last [pitch] and park up, tom jumped out [soon recovered]said to me open the trailer doors and a fork lift will be right here.
I pulled all the remaining pallets to the rear of the trailer and the fork truck takes them away, we were empty, it was by now 6 am and the market traders were streaming in ,tom came back checked the back doors and said to me quick as you can drive out of the market and head for home.
Once out of the mad house Tom told me it was a regular thing for whoever delivered to their regular Covent garden customer would load up any pallets they had and deliver to the Heston market for them as they would go to the same trader as we were delivering to.
Tom told me what the market traders do when they receive full pallets of any produce especially from europe,not all he said but the majority .they have a practice called “milking” whatever fruit it is, they have one man in the back of the store and he will take every box on that pallet off, take a few of the produce out of it and put it on to another pallet no one never knows the difference if its strawberries two or three out of every punnet soon mounts up by the end of the night out of ten full pallets they would have made at lest one full pallet for themselfs to sell.
Taking apples out of the cardboard boxes that were used world wide ,they would lift the box upside down so as you have the bottom of the carton facing you,then pull the inside carton out of the outer one ,that the tray you lift out then you get to the apples, they lift the full tray out, then get the cardboard inner and push it back down the inside , it is tight because of the air pressure ,once it is back looking like a box of apples, turn it back and open the top proply and you would never know the apples are there on the top, the bottom layer gone ,that is true .
The regulations were/are always interpreted in different ways at different company s.
Drivers were/are their worst enemy’ when braking the law. the old adage was if you confronted a driver and ask "why did you do this or that "it was for my own benefit,. .the biggest load of tosh ever. but every one to his own i was no better some times
It was worse than a minefield. if it suited you as a driver you did it [right or wrong]we used to exploit our self s sometimes for company glory, bragging rites various reasons to be talked about status .and best of all of all never stop moaning about it. and never tell the truth. .lying you were skilled at .because a transport office wherever you worked would never every tell you the full story or the truth. it took me years to learn it ,not quite all, but a lot, you learned something new every day however more later I have jumped the gun, as I have only just done my first run.
I had the phone call Wednesday would I be at work for 1 pm .
I put the same gear in my car and got there for 1 pm a daf truck was standing there in the loading bay with its refrigerated unit roaring away I later found out it takes a while for the fridge unit to cool the goods down to the required temperature also they would have been kept in a cold room before being loaded the goods inside should be kept at +3/4 for fruit and veg so I was told
They would have a quality control person checking all the goods at all the delivery places after time I found that if a supermarket warehouse excepting products for redistribution and they had got to much of the product ,hey would reject produce that is why the refrigerated unit on the trailer is running hours before you leave as to get the produce down to the accepted temperature .[very important] then it did not mean so much ,as I was not really aware of the importance ,but I would soon learn…
I went into the office to see Alan ,also there was another man I had seen briefly when i was at the interview he said to me yes can I help you ,i replied i would like to MR Webb please why do you want to see Mr webb he said I told him who I was, just hold on a minute ,he said ,and off he goes.
After a time Alan comes in and said to me look Vic! i am really sorry but I should have employed another" man" not you!and the boss, who you have just seen , is fuming at me because he wanted a younger man, than you well I was 38 a bit later to start the work they were doing
He asked me to go and have a coffee elsewhere give him half a hour and then come back, I went. When i got back it had all been sorted, your job is safe ,in comes the boss another handshake , and welcomed me into the company I could not get used to the handshakes ,we never do it as normal ,it must be a european fad ,
They gave me the keys to the truck, also the delivery notes for the supermarket depot delivery warehouse, after a bit of a run around ,when i think back" i do not think i ever owned a map of ENGLAND ",i got there in the end, never get it right first time or even second.
I queue up, behind other lorry s waiting all with their fridges roaring away I looked at the temperature gauge is hovering on + 4 that was right I hoped ,that is what i was told ,I walked up to the outside security office with my delivery notes, handed them in, I came down to earth with a great bang You are late !you have missed your delivery slot
No one told me it should have been 3 pm all I could do was wait the security chap said they would see when they could get me in ,it maybe 7ish o clock tonight I was surprised how calm i was as years ago if someone had said that they would have had both barrels.
Eventually I got told where to go to get unloaded I switched the fridge off no taking keys in to the office then after time the movement stopped so I assumed I was empty I walked up to their office and they said it was all ok and unloaded and the empties are on the front i pulled off the unloading bay closed the doors back in to the office to collect the signed delivery notes everything was ok, I pulled out of the yard, and made my way back to the depot, on the drive back I was wondering how long has work like this been around, nice and clean no hard work it was better than general haulage just driving however the hours and times are not what I was used to do but I thought if I can do shift work this is a piece of ■■■■
Back at the yard, it was not really a yard it was a very large square surrounded by lock up units i parked up ,all the warehouses were in darkness I went to my car, and drove home on deserted back roads it was a 21 mile trip one way.normal for us yokules .
Work seemed to pick up as it was nearly every night I would be doing a market run or a late supermarket, I got to meet and see the other driver s and the owner drivers all the owner drivers were all clean and smart, the same as their tractor units
Refrigerated companies were driving to most European countries, regular runs to Spain France ITALY and bringing all kinds of fresh and frozen goods back to the u k i had no idea trucks were doing food transport work, if you were not involved you would not know, I did not know of any refrigerated company within the area I lived,
The company seemed to me to have quite a lot of new trailers but not with the name painted on them ,after a time i got to know that they were all hired from a big trailer rent company all this was new to me, some of the tractor units were the same It meant in company terms they did not own all the fleet no concern of mine, this was a completely new idea to me, a lot of the owner drivers were doing the same, hiring trailers and tractor units.
Work seemed to be very busy, a lot of the evening or whole nights work, it got me learning more about markets and the way they worked, I have been in Covent garden unloading and I would see another Rokold trailer ,unloading ,naturally i would go over to see who it was it was never any one i knew, it would be another owner driver.
I was asked to be in for 5 pm and bring your sleeping bag ,and passport
I parked my car Alan was in the yard ,he was always grinning in a good way, he said to me, when you get back later there will be a owner driver here about 9 pm you are to go with him on a trip to Holland, he will not go without you you have a short run tonight!
It was, the driver peter he seemed fine, he explained it all, where we were going ,it sounded unbelievable at the time ,it was for me ,we did the tacographs i said what about the 4 hours i have done on this disk, he said ohh just put it away, no one will worry about a quick trip you have just done ,you have not been stopped have you ,no! I replied ,he said it will be fine forget it and i did, the first time i had done anything illegal with a tacograph I was thinking how I reacted at the crisp factory for going without a speedometer ,kettle pot black ,I certainly had changed for the better who knows.
After a deliver to Hemel Hempstead we lost about 2 hours then one delivery into Covent garden market, then on top Heston we were empty but the time was ticking on ,we started to make our way down to Dover for shipping out on the Townsend Thorsten Zeebrugge ferry.
It was late, or early ,when we pulled into a lay by and he said its time for asleep the cab had two bunks, normal in most lorry s that did European trips now It seem like after 5 minutes and peter was up and woke me as well he had the small gas cylinder stove with a kettle boiling, on small wooden shaped shelf that fitted on the dash board, i was completely amazed ,unbelievable he said i only have coffee, but two cups that is fine i said bursting for the toilet, looks like a Lennie, but not on the wheels.
He also had a small type of round mesh with a wooden handle and was toasting bread if you can do yourself tea ,coffee and toast ,what more do you want ,you can buy the toaster today called a DEFUSER. after having the snack/breakfast he told me this is how you live in your truck once abroad you look after yourself as much as you like and you use all facilities provided by factory’s borders, service stations wherever you can, also always remember that it is you that is the foreign visitor in another country .and if you respect that this job is good.
I did ask about the tacograph card and he said we are starting fresh from where we are now and he took the two tacograph discs out of the tacograph head and tore them up he said if you do not get a police check through the night, then no one else is checking lorries or so everyone thought
Who knows what you are doing, where he booked off on his previous card I have no idea i did not ask i was a second driver he said he would just use his tacograph card and use mine later if needed to get back to Dover or, wherever, that meant we now had 15 hours to do or 22 hours if he used me as second driver to get back to a port for the ferry back to England.
On arrival at Dover i am all eyes I was going to start writing all that was done [procedure] when with a empty trailer you are shipping out.
SHIPPING OUT
First paper or booklet you needed was a TRAILER GARNET that is the trailers own passport. it is a customs required document for all Country’s in Europe the chassis number is used as well as whatever number the company uses for their own purpose and it cannot be changed, also on the trailers front are two photographs of the trailer in sealed plastic holders however never needed in England all foreign lorries driving in the U.K .needed them i must point out at that time in the 1980 s EUROPEAN lorries also driving over in the U. K. was very limited. Quite a lot of European trailers were shipped over on the ferry to be hauled by UK drivers.
At the ticket office, passports were shown to them two driver’s one lorry, apparently when the ticket was booked,
Two drivers were mentioned however they still wanted conformation. that practice was in still force all the years i crossed the channel from whatever port and country a named passenger or for a second drivers ticket to stop people even then bringing any one to the UK, or out, if there was any problems with the police ,immigration and trying to get in the country the fall back was the Ferry company they were held responsible.
Even back then there were concerns about illegal’s
As we were empty on the dock you let the parking marshal see your tickets and he would put you in the right loading queue ready for the ship.
On the ferry you parked where you were directed to ,the crew or dockworkers proceeded to put their chains on the front of the cab and the rear of the trailer lorry to the deck to stop any movement, we managed to get out of the cab it is very tight to the next truck, walking up steel stairs to the drivers compartments, and restaurant i never ever thought i would set foot on a ship again ever. just being there brought a lot of memories but I did not let on to peter he would not a given a rats arse anyway.
It did not take long to get on with him a all round nice chap around the table eating he never stopped talking. where he had been, what he did, other drivers were all ears later we went to our cabins to sleep for 3 hours ish how bad was that, and getting paid for it, that was the way you had to look at it
.I could not believe that for years some drivers had had jobs like I was now seeing not like i used to do, a lot of the drivers on the ferry were young men. Well good luck to them i was envious of them that is all they new ,i expect it was the luck of the draw where you lived and the company you worked for.
And then duty free,what a bonus. But peter did tell me
be careful how many cigarettes you buy as you are only allowed 200 hundred that is the U K. limit
also you can buy them on the trip home, a call over the ships T ANNOY “all drivers proceed to the lorries.
On the lorry deck there seemed a lot of lorries to the amount of drivers who went up into the passenger area I mentioned it to Pete he said a lot of the men .do not leave their cabs they get in there own bunk and get to sleep quicker, also if there is a snorer in the same cabin you might just as well give up. also you get longer in bed.
It did after time turn out to be a practice that all shipping companies on all routes stopped drivers doing as a non practice to be used after the 1987 disaster at Zeebrugge ,in fact all drivers had to report with ticket to the stewards office .as the loss of drivers life s trapped in the cabs was very high .however `that was to come later.
We start winding our way out of the ships bowl’s and into the ■■■■■■■ rain in a very orderly queue. , all lorries from different countries i had never seen so many ,Peter telling me who was from where etc.
When we eventually got parked up outside the customs and immigration office ,all in one it was like a football crowd coming out of a match. no order at all I stayed with Pete and no one was saying anything to each other, it was strange
I got my passport stamped .they do not bother now they did then,
First stop Pete said was diesel .it was the second cheapest in the Euro union Luxembourg was the cheapest and it still is to this very day.
He would not let me drive until i had got used to being the different side of the road
after around 10 minutes we were at the first garage, it was packed with nearly all the lorries off the ferry we queued again i can see now why the big rush to get first was to get to the diesel stop first.
After years ,i had got it all sussed out driving down to Dover the more lorries you overtook I hoped they would be behind you whatever queue in the dock you took I would more or less know if they were going for the Zeebrugge or Calais ,as the same companies usually kept to their regular trips to the same countries.
I hoped I would always be in front of them and be at the diesel tank stop in ZEEBRUGGE before them, how ?because you would be in front of them in the queue at Dover and get on the ferry earlier than them, and we were mostly empty going in to Zeebrugge so quick customs at Dover, and better position on the ferry for getting off ,it took me two trips on my own to realise the later you are for the ferry you get on last then you are first off. and first to the diesel…
It was the practice of all the different nationality’s while filling up was to have no sense of hurry at all ,they were like mad men to get to the diesel then once there they would put the fill up hose in the tank,[automatic fuel cut off]into the garage shop that had chairs, table, and free coffee and not a care in the world i expect it was something I would have to get used to but I never did .
We were there around a hour mind you Pete was as bad as the others once at the diesel tank, he was then speaking in pidgin English they were all shaking hands,if they knew one person, and if you were near you all got a handshake .that was very new and unusual to me well different,being English how many times in your life do you shake hands, very little it was a new form of greeting i would become very at ease with after time.
All I could hear was lots of then unintelligible to me talk.it was if I had been transported to another world, however after time i found that the Belgians, and the French used a lot of the same words in their greetings language, also handshakes.
The amount of different brands of foreign cigarettes also tobacco and the smells mixed in with coffee and body odder from the drivers unwashed clothes ,lots of different types of biscuits, chocolate sweets in the shop all types of lorry stuff i had never seen before flags and banners from the ceiling i think i enjoyed that very first time in the Total garage after years i got to know the boss ,but was never one to pass a lot of time there, fuel up, in and out.
.One thing did catch my eye was like the small well made wooden very neat table top ,that would fit around the inside of the windscreen like a small writing desk with little small draws ,for all the pens on the passenger side of the cab i thought how good a idea. they were labelled up for all the European makes of lorry cabs.[[little did I know then that I would know more about them] also the man who made them and deliver them to that same garage…
There seemed to be no rush what I learnt years later that a lot of the foreign drivers would wait there for loading instructions also a lot of English drivers adapted the i will stay here for a time
get going when I am ready! no sense of hurry I could then see that Peter was blending in,?
When at last we made a attempt to get moving, the tanks were full of diesel all so the tank under the trailer that runs the fridge engine ,that uses RED diesel even cheaper than England, as that diesel is tax exempt in England for Agriculture use only ,however it was used by hauliers using refrigerated trailers, as no direct profit is made from it…[more on diesel later]
Once clear of Zeebrugge ,you do not drive through the actual town, i was learning all the different signs ,road marking and of course wrong side of the road ,however it did not seem normal, well it was .Pete made a point for me to keep well sat back in my seat as not to block his view from the inside mirror .as that was his now important mirror for all his overtaking if he needed to
The direction signs I were seeing were way far beyond the distance from where we going.i thought we were going into Holland i had no idea of where we were Pete had no map he knew the road and did not need one ,we soon turned off the main highway [like our Motorways] it was as flat as a air port runway we headed for Antwerp.i did notice that on top of the road signs there was a large green E number I found out later the E number on the signs are main transit through routes to all countries throughout Europe…
We passed a most famous truck stop with EUROPEAN DRIVERS called Lokern .on the way out of Belgium towards the Dutch border The Border it was just like a pull in lay by with a few brick huts [agents offices] customs passport control, surrounded by fields and ditches full of smelly water.
I followed Pete into a transit type large hall with lots of open type rooms with uniformed female and male .customs. immigration, Police all lounging around, all with a side arm, not very busy, so Pete told me the procedures of entering Holland and what form to fill in, who to go to first then it followed on. He said nearly all borders work on the same principle. Police ,Immigration, Customs.
If you were loaded, and delivering into Holland you had to use a AGENT to process your paper work a few years later on they used a type of T2L customs paper for the Benelux if i remember correct ,maybe not ?
Roklod company used the same AGENT at all Benelux Borders, if needed ,however nearly all customs was done on the customers premises that means that there is a automatic payment account. We were empty it was quick and straight forward keeping well back in my seat as the were cars travelling fast along the road ,so Pete could see.
He told me that we had not far to travel i was rather disappointment i would have like to have gone for miles we did cross one massive bridge over like a lake,/inland sea, the signposts coming up said to Arnhem ,the 2nd world war battle for the bridges it looked as if we were going near there
That kept me busy writing place names down. for future reference, we turned off the duel carriage way on the a narrow country road just wide enough for a truck to pass each other one wrong move and you would be off the road there were hardly any trees no hedges all dykes, or canals Holland is known for bikes also very tall people ,i can see why now,all the cycling everywhere, it was very rural and flat.
We arrived at our collection point all brick block paved with flat sandy earth round the edges of the hard standing, you could see the indentations in the floor, where the lorries have backed on to loading bays overtime it was stable ground.different to a lot of our transport yards at home some are like bloody flanders.
The time was getting on and i was surprised we would be loading at that time ,however we were on the continent and their work time patterns were different to ours as years went by ,factory’s in the U. K did introduce continental work patterns much to the disappointment of the unions.
Pete seemed well known at the cold store ,a store holding all kinds of deep frozen foods at temperatures minus -25 we were and loading vegetables they were ready on pallets,that was unusual pete told me,lots of handball places still around and use conveyor belts to get the boxes or sacks to the front then they draw back asc the product goes on ,well you all new that ,sorry if im sucking eggs. i was told we would not be long here loading peter asked would i like a coffee in the mess room, with some other Dutchmen after another round of handshakes black coffee out of a massive pump flask i had never seen one before also a tin of carnation condensed milk ,nice and creamy also a big jar of sugar on the table the smell of all the tobaccos was ,intoxicating I loved it.
I could see through the widow alot of workers with white coats and head scarf’s good looking warm boots on , you could not tell whether they were male or female they were sorting and packing chips on a conveyor belt it looked cold in there .
That was not the storage freezer just a packing line also a stand on riding,type of pallet /fork lift they were using to load our trailer it was long enough it lifted two full pallets another first,the men were whizzing around with a loaded pallets on the front they were standing on the back with a ,like bicycle handlebar steering it.l ots of factory s just about have a fork lift and all loading is done by hand .[not now, after 1990s ]we got modern.
I went and found Pete back at the coffee area,he told me that we were not allowed in the loading area, in some factories you had to stay in your cab in 2013 you have to hand your keys in to a office ,[so I am told].
We are loaded we are told to pull of the loading bay Peter lets me do it and he closed the doors. W they are closed I drive round to the front of the building i park up Peter shows me how to work the refrigerated unit, all the dials and different functions i thought we have been sat around he could have given me the full tour of the fridge engine,maybe he did not want me to know to much yet?
I get the basic of the fridge control workings in to office and get the papers for the load and a very important paper called a C .M. R they were held by the agent normally given to the driver by the transport office completed of you filled it in yourself or the company you were loading from filled it in especially fresh meat transport that information came to me much later on]
The C.M.R. is the drivers load travel document with the load it has all relevant on in-formation typed or hand written on it, about 30 sections ,and it was never used in England for deliveries ,unless like us delivering to England from Europe, the traileris sealed up by the customs man,[ all the factory s in Holland, Belgium, have a designated customs officer at the factory ] so i was told, also the Benelux Country, s never bothered with the trailer garnet ,we were ready for the off .
Pete got in the drivers side of the cab i wondered if I would get a drive, he said we will get back to the border do the customs ,and then i could drive when we leave the customs it was all finished for the Dutch side ,all was required at the border was a entry stamp into Belgium and we would be on our way back to a ferry which ferry port, I had no idea.
We were clear of the customs area he drove along for a time , then stopped, Pete got out and said your turn to drive just keep a good lookout in you nearside mirror and keep in lane he said when you see the sign for Ostend turn on to that road do not follow the Brussels sign please, he then goes and lies down on the bottom bunk and leaves me to it
I noticed straight away how heavy trailer seemed to be,although the tractor unit was more than able to cope with the weight, I just drove on, however i was thinking how many more hours are we going to be working?
We have had two small breaks one for 7 hours before the ferry ,then on the ferry 4/5 hours we had been working since 5pm on the Monday evening ,it was now 8/9 pm Tuesday evening, and we were not yet finished yet, on duty for 28 hours with a 11 break I thought if this is what they do to get around Europe I will have to give it a try it was certainly different from cattle trucks or dock work, clean work ,cheap ■■■■, just see how it goes…
As we neared the road junction for the turnoff i gave Pete a call, we were on the road to Ostend he started to move around he said just follow the Ost-end sign, and give me a shout when you start to get near the town you will see all the lights in the distance, and you will come to a service station as soon as you get in to the outskirts. it is the only one.
peggydeckboy
SENIOR MEMBER
Top
Re: MY driving and work history from 1980
Postby peggydeckboy » Wed Feb 28, 2018 3:11 pm
I pulled in the parking area a few lorries were parked up. Pete slowly got up once, he told me the options we had, of what to do now, I asked what he meant, he said the Zeebrugge would have gone by the time we had got there, not another sailing until the morning, the Ostend ferry goes at ,0230 ish Ostend it is ,he lets me drive I did see the signs to the ferry port clearly signposted through the town, to the port “called Haven” as we arrive at the gate Pete told me what to say ,we park up go into the ticket office, Pete tells the staff that he would like a Plug in on the ferry I have no idea what he was on about ,i would find out later ,we collect our tickets, go to the loading bays and for loading on the ship and wait
When you want the refrigerated unit on the trailer to keep going to keep the temperature correct while you are on the ferry ,you switch off the diesel engine,and switch the system to run on electrics, you then plug into a electrical socket at the bottom of the engine with a electrical cable supplied by the ship into the ships electrical system .
The ships run on a DC system not like our houses that are AC.How it all works i am not sure when the cable [ just like the caravan 3 pin system] is connected you have to be in attendance with the ships electrician, as you! have to make sure that the fan working from the fridge engine is on the right phase, that it is sucking in air to cool and work the fridge and not blowing out i.e. sucking the cold air out from the inside of the trailer and blowing the minus-24 air out
,It was a common occurrence if not checked. all you did was to stand at the front ,of the trailer fridge unit and throw a piece of tissue paper up to the front grill air intake if it sticks to the front all was well it if blew away you had a problem.[i got to know all this later on].that is why you had to wait for the electrician, that took time for them to arrive you could be first on the ferry but the last to go up for food or a bed.waiting for a electrician…
If the fridges were left to run on diesel, diesel fumes would eventually leave the bottom decks and creep up to the others decks also the the noise, fumes if any drivers are sleeping in their cabs another option was to turn the fridge off ,and take a chance that the frozen goods temperature did not drop to much, if you had a long distance to travel after leaving Dover the temperature would soon get to the required one [years later they starting building temperature graphs in to the front of the trailer.
You were unable to open the trailer back doors to check the produce temperature as the customs seal was not undone until at the delivery, or if you had a customs check in Dover ,that was frequent , they would reseal the trailer and mark the C .M. R. as resealed it was not unusual for the customs to be at Cold Stores around the country and to be checking all European imported goods also door seals were in tact.also to check for hidden contraband ,cigarettes, tobacco ,wine or spirits,yes ,smuggling was going on trucks well before the boom once the border controls went down ,even before the beer boom in calais .the beer was in grates and the empty bottles were returned to some brewers ,i can remember going to the brewery i think it was [stella] in belgium to get the take -away.
We eventuality get to a cabin with 4 bunks, after a meal We are no sooner in a bunk then we are being roused by the banging of doors, drivers getting up then in to the drivers room for yet something to eat and coffee ,god ,not more coffee, it is all like a nonstop a real adventure for me ,it is something had no idea at all existed [the work]it was just like being back at sea all the unusual hours ,coffee and food at odd hours. this is a different life it is not a job, it was not what you call a regular, package, and I sort of liked it, out of the ordinary I expect that sort of sums me up I do not like being put in to boxes, if that makes sense.
Drivers are called over the tannoy to proceed to their lorry’s, do not start you engine until told to by the ships crew when the doors are opened,all the foreigners under stood that, [not] the diesel fumes were terrible by the time we got down to the trucks the ferry had not berthed yet and the doors were not opened.
Pete pulled the electrical lead out and switched the fridge back to diesel, but did not start it up .that would wait until we were out side from the ferry, as the fridge used red diesel that gives out so much black smoke when started it is like a chimney on fire.
It think we must have had about 3 hours in bed, it was all a new way of working ,that was sure.
Peter drove off the ferry you then go through numerous checks. Border control ,customs. asking questions what country have you come from ,where did you load, what did you take out, when did you leave England, all relevant i expect ,even back then it was impossible to bring anyone into England with out anyone knowing,as you pulled up in front of the customs people and while you were inside doing the customs, there were customs men looking in your cab or around the truck for any contraband, 200 cigarettes ,and 1 bottle of spirits, 6 bottles of wine that was it your allowance,any anything else you should not have, ■■■■ was a problem.
Once i got more experienced i found out that problems escalate if you are not truthful to customs if you get caught with extra cigarettes and not declared them and do not want to pay the duty, you are subjected ,well the lorry is what they call [impounded] that means your load does not get customs cleared until the whole load or part is taken and inspected on a loading bay by them. it was known to take hours, sometimes,if it was caused by you, the drivers fault for smuggling ■■■■ ,you were in deep [zb] with any boss as you would more than likely loose a delivery time and date.
It did not happen to me ,some it did who thought they were clever and greedy,most drivers i knew would not let on if they had extra ■■■■ or spirits,“over time” i knew lots did because you would get pestered where ever you went to deliver,by the fork lift drivers like bloody seagulls,take anything…
Once clear of that we parked up, then you had to go and put you custom papers into a clearing office ,that was run by the clearing agents, however theses were only [runners]working for the agents that were at the other end of the dock, it was them who took your paper work down to them, they would do all the import clearances needed ,it could take 1 to 4 hour or for some half a day or more.
The clearing of paper work for any load is the payment of any duties needed to be paid by the importer for importing most companies use the agents who serve them best, the agents hold a monetary fund to pay the duties ,the money sometimes get used up before the end of each month, and that causes delays for goods to get customs cleared allowing the lorry to go to the delivery.after all the effort you put in to get the load back to a port so as you can meet a delivery time ,was a waste of your time, again i found that out later.
It is now about 8 am with the hour turned back from continental time, your tachograph stays at UK time at all times time for another sleep ,we had had about 3 hours rest the agents runners knocks your door if your load is cleared so you can get your pass to exit the dock you have to go and get some stamps on your paper work from the dock board to let you out the gate, no stamps =no exit.[[stamps=franks like the post office use] not postage stamps…
Peter was doing some routine lorry checks before going out of the dock on to the roads ,oil, tyres, lights ,flashers ,making sure the fridge has diesel, and nothing hanging off, he told me if you go out of the main gate at Dover on the A2 towards LONDON there are always Ministry of Transport checks along that road, if your Tacographs are suspect[I am sure ours were ] you can or could go out to Folkestone and take a chance, there are not as many lay-bys to be pulled over along that road ,all though Folkestone was a busy cross channel port as well.
We were ready to leave and left Dover behind, the time in my body clock was utterly upside down but it was getting near 12 noon and we were going back via Northampton ,as someone else was going to deliver for Pete while he went home
It was about 5/6pm in the afternoon when we arrived back at the depot, i met another driver ,he did not look old enough to drive ,obviously he was ,I collected my gear said my goodbys and make tracks for home I have just had. about 48 hours on duty.
Life and work went on not a lot of fruit market runs for me it seemed to be supermarket delivers in different in lorries it was working all right however i did seem to be getting the Sunday run on a regular basis that however i was getting into the rhythm of not thinking what day it was ,a Sunday could be the same as a Wednesday , the pay was the same, no extra for weekends and i excepted that as now normal, the same as the others that were not owner drivers but like me
There were stories going around by about different drivers by other drivers what they had done or not in different countries where they collected or delivered goods all stories One Sunday at Northampton there was a left hand drive D A F English number plates i had never seen anything like it, the driver was about my age well dressed as if on holiday he had brought a full load of veg from Spain.[little did I know then] we got chatting after the handshakes he was the longest serving driver and a employee like me, the lorry was Rokolds it was a high line space cab perfect inside, i did sit in it it felt funny left hand drive ,he did say that he was the only driver of that unit but sometimes when needed it was used by others just to do short jobs[GOD FORBID] I thought it must take years to get used to that.[left hand drive] deja-vu.
My load was ready I leave to do the delivering ,it was a supermarket run it went as normal, no problems I drove back to the yard later I parked up and went home.
Around 11 am, i get up and go downstairs to answer the phone, i knew who it would be ,and I was right it was Alan, could I be at Northampton by 2 o clock, with my gear without hesitation i said yes ,I had realised if I show willing ,things would be good for me and I might progress on to the Continental work eventually .
When I arrived Peter was there it seemed as if he was waiting for me but there was no lorry there ,none anywhere, only a old white Volvo car.
The script[story] was we were both going in the car[the company drivers runabout] to a place called Lamberhurst in Sussex ,where Peters truck was being loaded and it needed 2 drivers as it was a urgent load, we set off to go down the M1 Motorway we are going up the small hill outside NORTHAMPTON the car starts chugging ,spluttering, very much as if it is running out of petrol, we have left the yard next door to a petrol station, there should be a petrol can in the back, Peter said, !yes there was ,it is empty. we are now stuck, pushed for time, out of petrol,
Peter walks to motorway emergency phone box, to ask for a call to be relayed to the office for Alan at the yard ask him to bring us some petrol.
While we are waiting Pete then told me the story of this VOLVO drivers runabout company car
When drivers are due a proper legal break [rest]or want 2 days off for any reason and they are loading a Export load and it is their own lorry, or a company lorry ,a spare driver such as what I am will go wherever the lorry is ,take over the truck ,and the original driver goes off home in the car then the system is reversed when the truck is loaded and the driver goes back to his loaded truck in the car ,and then the question of petrol arises.
Company men like me who use the car, put the petrol on their expense sheet , and get reimbursed the money ,however owner drivers that use it like Peter ,have to stand the cost themselves as the bonus for them is that they are getting there lorry loaded the company Peter should have filled the car up but did not the who will pay for the petrol Peter was given some money to fill the car up on the company he had forgotten.
Petrol was brought out to us by a driver after a phone call from the emergency box on the side of the motorway to the office enough to get us to the service area.
peggydeckboy
SENIOR MEMBER
Top
Postby peggydeckboy » Wed Feb 28, 2018 6:42 pm
We got to our destination a abattoir in a village on the main road to the south coast if you were to blink you would have missed the entrance i was pleased i was taken there and not had to look for it You drove in to the yard in-between two houses enough room for a lorry.a few houses built close around it, seemed a strange place for a abattoir to be
Once there it was a very large establishment two trailers parked up close on the loading bay and the fridge units were roaring away, Peter was met by another of Roklolds drivers i had not met ,he been loading the trailer ,well ,not actually fiscally, but in charge of the movement when required he told us that that it was not finished loading yet, they had to wait until the temperature of the lamb carcasses had reached to +2/3 in the chill rooms inside the abattoir, and then the vets would release them for loading ,could be a while he said.
The Script was for the driver to take the car and go home ,or he might have to drive somewhere else to relive another driver who needed to go home? It was now about 6 o-clock in the evening, the driver had left Pete put his gear in to the cab and he brewed a cup of tea up as he said the small canteen would be closed here.
I would get to know this abattoir very well in the future Peter then asked me if I would like to walk around the abattoir, i declined and he sort of said ,what is it do you not like Animals that are about to be slaughtered are you squeamish. i laughed ,and proceeded to tell him about my butcher boy work when not at school working down the local abattoir, and all my cattle truck days, that sorted that, he never said any more about it.
The plan was we were going the port of Ramsgate to Dunkirk we had deliverers in Belgian and then one in Koln Germany we had to have the tacographs right as we could get a check at the German boarder at [Aachen] and if they were not correct we would be in trouble.
We did not put tachographs in until we were ready to leave, for the reason it would give us 22 hours to get the job done [we hope]and not lose time .
He did tell me this job we were doing was very hard, pushing for time and it was the first time that they let a novice like me double man driving Peter did tell me both bosses asked him how I had been on the other trip he told the truth and said I was keen to learn .
It must have been around 8 pm when we pulled of the loading bay, got vet sealed up and made our way ,i was told it was best if i got most of the England driving done as once in Europe it would be on some back roads that could be tricky, my first taste of driving 20 tons of hanging meat, he told me i would get the feel of it once I got going and the sensation of being pushed when slowing down and the corners was tricky a long way off the old cattle truck days if you want shunting about they were the lorries to drive nearly as bad a tankers pushing ,so i was told however i never drove liquid tankers…
If you look at a map of Sussex ,you will see Lamberhurst and country roads over to Ramsgate via the narrowest villages you could find the most narrowest place ever I was a bit tongue in cheek for a start, it was a test really to see if I could handle it. one village called sissinghurst had the worst double bends ever.
It was getting on for midnight when we pulled into the dock and the Ferry line was called SALLY LINE we did the export checks that was new to me, I was all eyes watching the different procedures. once on the ferry peter never bothered with a plug in he said no sooner have you had your food it would be docking.
The food was really good steaks ,sausage, veg chips,[trouble was over the years the menu never changed ] also “sweets”[puddings ] all hours of the night and day, we really tucked in as i had not eaten much all day they also let you take bread and make sausage sandwiches for later ,there were not a lot of trucks on board some were very regulars on this run .
The reason we used this route was that you did not need a French Permit to use this route as it was called a FREE ZONE a very short coast journey from France to Belgian the place was called Hadenkirk.
Once off the ferry, limited controls,in and out of the BELGIAN CUSTOMS and away we went,pete was driving we were heading for Brussels eventually but going to a place called Kortrijk our first delivery, the roads were very quite, and once off the duel track we were now into very narrow country roads that were bordered by like water dykes ,each side no margin for error. it was pitch black except ,for the truck lights.
We seemed to be skirting a town and sort of looking for a entrance in to a housing estate,as i could see the outline of house plus the odd street light,then we were in like a small village, he pulled up outside a butchers shop , a large person standing outside with a white apron on he looked as if was covered in blood the fridge unit blaring away, just what you wanted in a housing estate, Pete jumped out of the drivers seat, shut the fridge off , but kept the truck running as we needed lights for inside the trailer .
I was Puzzled as what was going on, once the butcher had broken the seal on the back door, and opened it he kept the seal , he had some whits coats with him ,i knew then what the coats were for, we had to get up and pass the meat ,first time for everything, i could not believe what we were doing ,i kept quiet ,and followed what Pete was doing.i had never seen so many lambs in my life, they were 3 high from the hook to the floor, as they were attached to strings hanging down.
We knew when we had to stop passing the meat down as the abattoir had tied a string, around the next delivery you new when to stop ,well Pete knew , and i did now [learning].The unloading finished, we went into his house well it was a small abattoir we washed our hands they were covered in grease ,and given some horrible Luke warm Belgian coffee ,i have never liked black coffee ,is it in our English nature to drink coffee black no!!
All ready to go, after driving out of the village area we picked up a signpost for Brussels, it was starting to get light , I said i could eat something to Pete and he assured me when we get to the next place it is a proper meat factory we would eat then also maybe get 2 hours sleep, just what I needed.
What I can say about the Europe roads they are well signposted ,as you approach BRUSSELS it tells you the way to go for GERMANY, LUXEMBOURG, and all kinds of different new names of places i had never heard of 3 lane roads and they are not like our motorways people are changing lanes ,overtaking and undertaking it is normal.
After we went around a roundabout about as big as a football pitch, we were heading out back to the duel road, this delivery was on a slope,talk about awkward,it sometimes makes you wonder ,who comes up with ideas ,lets build a factory where no one can get in without difficulty.
once Peter had backed up to the factory doors for the meat to be unloaded, you opened the trailer doors once you were backed on to the unloading bay the opening was so wide the doors opened inside the factory , ground had such a slope on it there was no way you would stay in a bunk, let alone sleep.
I realised later that Pete knew that we would not get a sleep but try to doze off in the seats. he never said ,we went to a hot dog type shop that sold takeaway sandwiches /hot dog type called a frickadella we sat uncomfortable in our seats with feet on the dashboard /windscreen eating I am hoping doze off a, but the rocking of the unloading movement in the trailer plus the workers noise I gave up.
Once unloaded the c.m.r. signed ,they shut the back doors peter let me pull off of the loading bay Peter never got out to check anything i put the fridge back on he said to me ,you drive, he gave me directions and instructions then promptly lay on his bunk i am glad he did as it gave me the sense of being by myself it did not bother me I was still full of it ,me driving in Europe, unbelievable.
We were headed for a place called Liege the last town /city on the way to the German boarder it was our last Delivery in Belgium, he told me to go to the 3 rd turn off [city centre] in Flemish, he said you will go down this massive hill, be careful, other traffic will try to push you faster than you want to go, but keep slow ,that is what I did, when I got there the hill was massive ,the odd truck went past and blew its horn in disgust at my speed, the weight of the meat that was left on, how much I have no idea but I could feel it was pushing us down the hill without much effort from the engine.
Before going over the motorway /canal bridge i was to a turn off half way down the hill follow the city signs ,we were running alongside a river or canal, i gave Pete call I did not want to get to a junction and have to make a decision which way to go he rolled out of the bottom bunk, looked and said carry on ,he seemed not to happy, perhaps he was tired because I was getting to the stage of thinking zb this for a job.
After time we arrived at a industrial area the unloading place just like a warehouse, peter told me the way to go all theses meat factories looked the same i pulled up in to the marked parking bays and waited for peter to get sorted, he said he needed a coffee, we both walked in to the reception area ,peter gave the papers to the girls and she said in broken English the coffee is through there, peter already new, he had got that old glint in his eyes a bit of a ladies man .
Once the coffee was done a man in a white coat came out to peter and greeted him with a hand shake also one for me and said to back on to a loading bay for unloading ,I opened the trailer doors ,and we seemed to have gained more meat than we had before Pete walked round to the back and started the handshake routine some men looking out of the unloading bay ,they all seemed to know him he said to me go and have a lay down we might be here a while .i did not need telling twice.
It felt as if I had been asleep about 5 minutes I was woken up by the engine starting, Peter said we have now go to the Belgian customs to get sealed up for going into Germany, all new procedures for me learn, I did ask about the extra meat we had on from Brussels to Liege and was told it was a regular thing ,that was in -fact illegal for a English truck to do internal delivers within any country but your own country, that also applies to any foreign truck in any foreign country. [No internal work done at all ].but people knew no one is going to check. it was all the same company we were delivering to ,peter said to me how did you know you never seen the inside of the trailer at the last place i said i could feel the weight when going down the few hills.
Not doing internal work in other countries is supposed to protected your own home haulage market ,who wants a foreigner doing our work. The Belgians did not give two monkeys The practice of doing that internal haulage is called [CABOTAGE] that was in the customs era now , since borders are open anything goes in 2014. trucks can go anywhere and load anything.
The Belgian customs post/compound was on the same estate we did not have to wait long at all peter went in to the office they came out and sealed the trailer up,I have no idea what paper work was needed we left for the border
As we approach the turn off for trucks at the border ,after going up this massive hill, we had to go off into a parking area that was full of foreigners trucks ,Peter then went on to explain what was to happen next, a GERMAN PERMIT that was to be stamped, we had to make a fuel declaration 200 litres only allowed in the country then passports, then go to a agent to clear the customs forms T2 forms from Dover i had never in my life seen anything like it
Pete took me to a hut and had a coffee and bratwurst sausage and mustard in a crispy roll,lots of different cigarette smoke ,and language After about 1 hour Pete said lets go and see if we are cleared from the customs, if you have fresh meat of any kind you are told to leave the parking area with all the paper work given back to to you by the Agent ,and leave by a back road and proceed to the German veterinary for them to inspect the meat, and get clearance to leave for your delivery
God knows what was happening with the tacographs. Who was driving etc Pete was switching the mode switch around all the time he was obviously on top of it we were following a sign that said [schlachthof] that was abattoir, we were far away from the motorway in the town of old Aachen, Aachen was one of the first towns to be conquered by the British army in 1944/5.
Once cleared by the veterinary who thoroughly check the meat I was told we were to back on to a unloading bay so they could walk into the trailer ,i stopped in the cab ,Pete waited by the loading bay [ or dock] eventually we were cleared to go ,to Koln,to the meat market called the Grober market.
I was driving Pete knew the way I had no idea where we were going however it was all going in my head what I could see to remember for maybe future reference, I had completely given up on the time, and how much rest we have
Peter told me we will come up and cross 2 rivers then we follow the signs for the zoo, and that takes us to the market for unloading.
After time we arrived at the Grober market it was like a very large square surrounded by a platform type of buildings like a railway platform they all had their names above the units Peter told me which one to back up to, he opened the trailer doors, switched the fridge off and i backed up on his instruction on to their ramp/unloading bay ,and that was it, i thought what a day.
,Peter was inside having a coffee with someone and I could feel the movement of men walking in the trailer unloading, a feeling of tiredness seemed to come over me ready for some proper sleep.
Next thing I know we are moving again, i must have dropped off like a stone ,I asked Peter where are we what are we doing ,when do we sleep, all in one go the answer was we will just get out of Germany ,then park at the next service station ,we are loading in Holland in the morning.
However we have to wash the trailer out before we can do anything else but we will sort that out after a sleep .the inside of the trailer is covered in blood and snot and grease from the meat rubbing along the trailer walls we arrive again at the customs at Aachen and we still have to go to all the small offices for a stamp on our pieces of paper and the diesel paper called a lufzettle it is not as easy and as quick as that to transit but easier than being loaded[spelling not correct]
We now make for the first service station in holland near Maastricht and sleep, it did not take long ,once there in that top bunk like a rat up drain ,I let Pete worry about the waking up time.
It seemed like a very short time before i was being woken up and i could hear the kettle making a noise on the small gas prim-us stove Pete ,said welcome back to the living we cannot be long as we have to wash the trailer out and be loading today
I had no idea at all what Pete had done about the Tacographs I was not bothered a far as anyone would know we had not been in to Germany, in fact if we do not get stopped in Holland or Belgian we have not been anywhere as far as the Macrographs are concerned, he obviously knows how to fiddle them to his and the companies advantage they must know I hope he will show me what to do
The service stations in Holland supply more services than just fuel,[naughty] you can get the use of a high power jet wash to wash the inside of a trailer out so all traces of meat are gone and ready for another load, payment by us was by a credit card called a D.K.V. card ,it is renown all through Europe within the transport industry you can get anything with it I mean anything ,even in red light districts the card is taken ,like a transport only Visa it was the first time i had seen or heard of it, you get issued it only to be used when necessary by the company.
,Peter went into the payment office and came out with some tokens to put into the wash machine and he said we have 10 minutes of hot water and power the hose was the longest i had seen ,my god these foreigners do not need any lessons in doing the job correct.
Next thing Peter comes around from the cab side lockers with Wellingtons a pair of water proof leggings and a long raincoat/souwester jacket i was amazed, how much more am I going to learn, it seems as if you have to be very self-sufficient.
His water proofs were just what was needed and he did a complete through wash of the inside of the fridge it was perfect in side ,no trace of meat at all and as the lambs had been hung on string and not directly on the meat hooks they were clean. He dropped the air bags on the trailer so the water ran out of the trailer all the time
Once done he quickly went over his tractor unit with the hose before the time went out, and we were done, en-route to where I did not know.
We went in to the coffee shop and had a machine coffee, not bad ,a cup of tea for me would have been better, Pete asked to use the phone ,and that was a yes they passed him the phone from the office, another !i cannot believe it they let him use their phone, never in England would that ever happen, everything i have seen up to yet has opened my eyes.
Peter comes back with loading instructions ,we are to go towards the place we loaded at before, and load near there today Peter told me that going back into Holland to load once unloaded in KOLN is normal you always ring from here to get final instructions
I have no idea how far it is we do not have a map but Pete knows the way he lets me drive he dozes off, but he tells me which way to head for and just keep following the signposts until we get there or you have to have a break after 4 ½ hours [ that was joke]
We got to the outskirts of the town where we will be loading from and signpost directions to the factory gate ,the factory had a massive turning area for the trucks for backing down to a ramp onto a loading bay, I parked up, peter went in to the office came out and told me to back on to a bay as loading would start straight away, a pallet load of frozen chips we would not be long and the front pallets were smalls so they would fit under the meat hooks and the rear ones would make up the extra.
In no time we were loaded, custom sealed at the factory, customs paper from their own customs from the office paper work in order, next stop a ferry time has flown from when i got up at 11 am Tuesday morning it was now Thursday with no proper rest and now off again to a ferry, Peter thinks we will miss the late Zeebrugge to Ostend again
God knows what he is doing with the tachographs but i am sure he knows the fridge was set at -25 and roaring away ,however Pete said they were good at where we have just loaded and their product is always down to the correct temperature.
Out from the village we were on to the road that will take us to the boarder for Belgium customs we parked up at the border i asked Peter if I could go and produce the paper work and get the feel of it ,and yes it was fine i went into the large foyer and could see only one office open with a sign doune above the open door, I knocked walked in was met by a grunt, that passed as hello [I think] passed the paper work over to the uniform/gun holstered ,no idea what was said a couple of stamps later on the paper work, i was outside, they walked out to check the door seal ,he walked away another spoken word ,i was back into the cab, and peter told me that it was very rare to have any problems with the Dutch or Belgium’s authority.
I tried routine I was pleased with that i carried on driving to Ostend, I drove all the way up to the dock gate, and booked us in to the ferry terminal, apparently we were not booked for a ferry now but a later one, but we would get on this one as Roklod was a good customer so the women told me just go and park .
The ferry crossing was the same routine as before off the ferry at Dover the routine was the same as last week it sort of seemed all right to be working all these strange hours as everyone else was doing the same all though not many English drivers were on the ferry.
Once cleared by the customs, the agents runners brought the papers to us we had to get the dock clearance paper from the harbour board we are ready to leave Dover ,Peter said we had to go to FrigoScania at Kings Lynn a cold store that stored and processed and distributed all frozen products from all Europe and was used by super markets for storage also they work 24 hours shifts there unloading and loading throughout the day and night.
I was now getting a good idea of what this job in tailed, the load was the priority ,driver second, and you had to be prepared to do as the office told you or you would not last, i can see the importance of the owner drivers within a company ,however they want their own drivers to be exactly the same.
I have two choices Stay or leave the job it seemed just for me i liked the running around different countries and the unsocial sleeping times, the general way you were left to get on with the job and be left alone .
I know the hour pay ratio was not that good however we were on a salary, so hopefully yes maybe in the middle of the week, you would get more time at home, it would be worth a try if I get offered a job on European.
We made good time i drove ,Peter said it would keep him clear to ship out again if I used my Tachograph not double manned if we were stopped by the police or ministry of transport ,the plan was i had just arrived by car into Dover to take this lorry to unload and drop the driver [PETE]off at his house and I was to carry on and get it unloaded and back to base
We arrived at the cold store no problems on the way peter told me to drive on to a weigh bridge and the gross weight is recorded it is at the gate house so you have no option you have to weigh in when you finish you have to go back on to the bridge to get your tare weight ,then the load weight is taken from the gross and then you have the weight of the load, as you could have the right number of boxes but not the correct weight.
We were told we had a booking that night so park up and wait. Pete looked a bit sheepish we could have gone to Northampton i am sure he knew when the delivery was, but he is in charge of the truck if I was not with him he would have done exactly the same I said ,good have another sleep, there were lots of other trucks parked up the noise of the fridges roaring away was tremendous, but no one seemed to care at all ,and I was getting used to the noise as well.
While waiting the a unloader came and took the seal of the back doors and climbed in as far as he could go and collected 1 box of goods, he could go and check that the correct temperature had been kept and the product was the right temperature.
Before we fell asleep we got some door knocking from workers asking if we had any duty free to sell, cigarettes ,or spirits wine anything cheap ,Pete told me more about the selling of any goods at most of the cold stores you would go to .he said, what you do is let the fork lift drivers have first choice of anything you may have, they will ask you if you are going back to Europe it was a regular run for Rokold trucks.sometimes you will go back empty from Kings Lynn to Dover to load the next day in Belgium or Holland then straight back to Kings Lynn they would put a order in if [1] you have the cash to buy goods, and [2] do you want to bring in more than your allowance [3] if you are caught by a customs officer anywhere and you are selling duty free goods you are in deep it was up to you.
As it was, i was not interested as I had no control of what i did ,also Pete would not commit himself, as he did not know what he would be doing next ,if he did he would not tell me, as I expect he will be glad to get rid of me,and I do not blame him I would not fancy having a second driver with me however if the bosses say you will ,you will it is their truck.
After getting unloaded, and the trailer swept out and weighed [by me ] we made our way back to the depot . One thing Pete impressed on me was to make sure that when you collect your c.m.r note up from the office when the unloading is finished make sure they do not write any remarks on the paper work as that c m r is a legal
After my European trip, work seemed to by very quiet not that many night runs and no market runs at all just the supermarket work and loads seemed a lot less than before, however I just enjoyed the time off as i knew when the time come it would be longer hours than normal!.
On one run to a supermarket I was told that I had to have the night out and collect some pallets in the morning, yes fine by me, i was now used to doing as I was told ,i did not like it, but there has to be bosses.
As it was i had no idea what was going to happened next, I was loaded i needed to ring the office to see if the pallets were for home base or Oxford I was told to bring them back to the Northampton yard as quick as I could Mr East wants to see me, i thought another trip over the water.
Once in the yard ,i parked up ,went in to the office and asked for Mr East ,i was told to go in to his office, he stood up shook my hand ,and said Vic I am sorry we are going to let you go, work has got bad and there is not enough for all the men last in first out.
He said we may have got you some work with a local contractor, he gave me the details ,sorted my wages out ,said if an thing comes up again he would call me ,that was me finished at Northampton and that was that ,i said my goodbye to Alan he said sorry I went to find my new employee ,i hoped.
The new employer lived and worked at Milton just outside Northampton, i rang him up and he told me to meet him at the Ipec depot ,he gave me the address of the depot that I eventually found ,after getting through security, i was told where to go to meet he had a small office at the end of a loading bay, that had about 20 trailers parked on it.
The job was first to be shunting the trailers on and off the loading bay, as a contractor for the company running the job Ipec that turned in to T.N.T the parcel and goods distribution.After time, also when required i will have to drive a trailer up to the Glasgow depot, that would be a night job once there you go into a bed and breakfast in Glasgow while the lorry and trailer is taken around Scotland all the delivers done ,it is reloaded back up for you to run back down to Northampton through the night, you get back to Northampton park it up in the depot you go home. If you are required for the next night we ring you by 2 pm to let you know.
That sounded good, the money was Tax free ,that meant you had to do the tax yourself.[self employed] also he subcontracted some containers runs from Felixstowe, to anywhere it was a job I would go for it i started the next day ,at lest i understood what the job was and you got told what to do
I was busy more container deliveries than work in the depot i think the depot work was a untruth to get me to work for him I asked for night out money of £15 cash he was not pleased It was the money or I am going he said he will pay it but put it in the check at the end of the week i would have rather had the cash ,he has not been used to deal with someone who knew what they were doing as he had two other units and they were young bucks I doubt he paid the drivers any extra…
The man I worked for was a ex middle east driver, photographs all around ,early 1970s he must have been very young however most men that did that work deserved all they had made out of the jobs it was not for everyone.
HE kept me busy for a few weeks I had not done any Glasgow trips yet, I had met the other drivers and they seemed to be sharing it ,while i did the longer hours for the same money i thought it was time I had a piece of the cake i asked the boss when was I going to get a shot at the Glasgow run ,he seemed a bit put out ,I told him No Scotland trips and I ma off! hang on a minute he said you are down for the Sunday night run ,was he telling the truth or I was down for the job ,he said you are on the job all next week, I will stay then and that was the start of another fine mess.
The tractor units we used were from MANN HIRE and they were flying machines 70 mph was the normal speed once on the Motorway well if you did not get caught. You left Northampton you drove for 4 and half hours had 45 minutes break then another 4 ½ drive and you would be in Bellshill Glasgow that was how fast them trucks were, ,in the day time you would not have done it ,even in 10 hours however at night, unbelievable distances were covered the trucks had the power as if you were driving a car, you could accelerate just like a car even with a full load quite however they were never heavy ,remarkable even now when I think about it, in actual fact when i do it was so, so, dangerous I shudder. however once again by luck I came off all right
Once in Glasgow you would leave the truck in the IPEC yard and a man would take you up to your bed and breakfast ,in a van, you would have have a breakfast ,then bed, he would collect you again at 6 o clock at night, you had no dinner there ,after the first time I soon got myself organised when home I brought a small gas cooker, pan and tins of food, and cooked it in there rest room when I was back there it caused quite a show as they had never seen a driver cook before .not as I was experienced, I got the idea off of Pete ,never go hungry when you can do it yourself…
I started to get used to the pattern of work on the Glasgow run I stated having the run very regular I think there was a change of drivers it was a sort of fill in job.
I did have a small issue as we were only working in total driving 9 hours the boss wanted us to do some more work when we got back to Northampton, small local work just to fill the hours in as we got paid a rate ,night or day and the hours were never defined I think he thought we were getting away with money for no work, I did what he asked ,then went home to bed later than usual.
One evening just before I was leaving Glasgow the boss phoned me through TNT office and said when I get back to Northampton ,drop the trailer at the depot then pick another trailer up and go and deliver it to the car factory in Luton. Vauxhall. i was not happy years I had done a few years in and out of car factories not the best of place to be in with a truck
When I eventually arrived at the car factory the parts I had on the trailer were marked urgent production line,i was told to park up and would be called in when they were ready i knew from previous car factory experience that once you got into the queue going around the production area that was you basically stuffed, end of it is like going around a supermarket following 2 mobile scooters ,with people who cannot drive.
After god knows how many hours i am still at Luton ,it was getting that i would not have time to drive back, there and then I made my mind up that was me finished when I get back , no way to ring anyone up no public phones within the factory for drivers use
When I eventually got unloaded and out of the factory I was on my way nonstop straight to the depot, i was met by the boss, all full of sorry, i did not realise they said it was urgent ,i said no problem ,get some other mug, bye that is me done, he protested look I gave you a job a favour for Mr East ,i replied you get Mr East to come and do it then.
I went to the nearest phone box and rang Roklold at the depot at Oxford and told them what I had done ,and said thanks for the job, and whenever they want me ring at home
Now started another episode of driver without a job, i first called in at S. T Challis as it was on the way home and explained my situation and could they help, they would ring, never did, I had to look further from home in the local paper for Banbury drivers wanted at Aylesbury ,that was nearly 35 miles away, however i thought i would ring, and asked for a interview, it was in a village called Aston Clinton, did not mean nothing to me ,i was given Friday for a interview in two days time, i have no idea what sort of work they do or anything but I had seen the lorries around and no way of finding out .
I arrived at the village and found the yard I drove in and looked around for a parking place, found a visitors one and parked. Little did I know that I was being observed to see where I left my car.
I reported to the office explained who i was and was told to sit and wait. I had dressed
with some smart clothes and a tie, a bit over the top for a drivers job but I wanted work .I was shown into a office and a youngish man sat at a desk very smartly dressed, he did not get up just looked ,and there was a chair pulled out my side, but I did not sit I just stood there.
He then said who he was ,and what did i want, i said a driving job if they have any vacancies, I had read from the newspaper advert he then said that advert should not have gone that far out to BANBURY as they only recruit from the local area ,where have you been working I said I can give you my full working record since i left school, and got out my discharge book with various bits of paper and certificates also my HGV driving licence, he said you have a class one licence ,all self explanatory
I told him everything from school until that day. while I was in mid flow a older man come in to the room. also very well dressed and sat on the edge of the desk ,never said a word i was still standing up I did sit down when I filled in the application form
When I had finished talking the other man Mr Fowler ,the boss said we never employ any men who do not live within a 10 mile radius from Aylesbury however if you can start tomorrow we will overlook that rule that was me at Aston Clinton Haulage, A. C .H.
I had to be at the yard for 6 am to start then take it from there it was a good 40 minutes drive from home on back roads, after a short time started to try other routes, but it was nearly always the same time of travelling.
The work was varied from local shunting to unloading in the yard ,and loading boxes of cereal for delivery, then delivering it you had no time at all, but I stuck with it, they were very long hours if I had known more then I would have stopped in the yard the odd night and slept in a cab ,with no pay it would have made life a lot easier ,as all the trucks they ran were sleeper cabs.ll on European haulage.
The drivers that were on European I did not see much of the trucks would be in the yard then gone again .
The son David who interviewed me was what you called unfair, thoughtless but that was his way, and people accepted it, me also, as I thought i would get on European, have a truck of my own and get some good work even with my limited European experience
Sadly it was not to be, i had to leave, the travelling to far every day and expenses petrol . i had to do it right and not just finish one day i got half way to Aylesbury stopped in a village ,and rang the office told the yard Forman my car has broken down the engine failed i could not make it in and gave them the local phone box number so they could ring me back.[ no mobile then].
After time Dennis David’s assistant, rang the call box back, and said if you cannot get in you are no good for us you will have to finish, I made a bit of a fuss but said fine and would you send my wages and p 45 and that was that .It was what i wanted to happen in case ever wanted to go back in the future .
I arrived home, my car was working o k i decided to go around the local transport firms they were like “rocking horse [zb]” it had to be labouring on building sites wherever I could get the odd days work one site near home the footings were in and concrete had been poured the breeze blocks were stacked a way away from where they should have been ,my job ,take them over for the bricklayers ,what they did not say were the blocks were concrete ,my god in mud a rain I earned every penny my Welles were so heavy I had a job to lift my feet let alone blocks two days I lasted I was shattered,
It was back to the scrap man tony, always good for a few bob if you did not ask, being adaptable money was manageable. However I knew we could not carry on like this you need a steady job
.Life was plodding on ,getting myself resigned to being labourer out of the blue my wife gets a urgent phone call from no other than Mr East, from the depot in Oxford, asking where, and what was I doing,and asked would I ring as soon as possible, urgent. It was 7 o clock at night when spoke to mr EAST.
What had happened Tom ,the first driver i went with had ,had a brain haemorrhage and passed away he was on the service station by Liverpool ,the trailer had been taken away to be unloaded however ,the unit was still on the service station the keys were in the mangers office was the any chance I could go up with another driver and bring the tractor and the trailer back down to Oxford some other company is unloading the trailer.
The lorry was leaving at 8 am in the morning to get you to Liverpool later in the day are you able to go with it ,also we now need a relief driver if I wanted the job it was mine on Rokold not the other company j.c.s. at Northampton Rokold on a regular basis
It was a chance for me not to be missed it could be the break for me to get into European work I accepted the offer .without hesitation
I left home at 6 am to get to Oxford before 8 am good job i did as the driver had slept overnight at the depot and was ready to leave when I arrived, after a very quick hello in the office the truck was fired up we were ready to leave.another new episode is maybe going to start .
We made our way to the Liverpool area i found out a lot more about the job ,some bits were good ,others I knew about the hours the driver who was Toms friend, also from Northampton still could not believe Toms death, it only happened yesterday, it was shock all round to them all , well not for me, but sad as he left a wife and children i think.
On the service station the unit was parked in a corner we did a walk around all the wheels were still there, i went to collect the truck keys from a office in the service station ,they knew my name but wanted some ID, my passport was good enough, i rang the office told them the unit was ok my instructions were to pick the trailer up at Trafford park Manchester at a refrigerated depot ,I was told check it over for any damage in the outside and inside, count the meat hooks that were hanging on the rails at the front, check tyres ,any fuel in the fridge . All the trucks paper work was still in the cab folder also the D.K.V. CARD and fuel card.
Also to record the hours recorded on the fridge, a dial on the front cover, gives the hours the fridge has been run, make sure all the lights were working, as people will steal the lenses and bulbs, yes, the bulbs. When that was done I rang the office and they said make your way to Dover and ring first thing in the morning from there. i knew it would be late by the time I got there.
I never put a tachograph card in until I left Manchester I had plenty of time ,I thought I had.
I made it to the last service station, on the A2 Farthing Corner, before Dover and had a break, by the time I got into Dover and parked outside the Agents office ,went in ,and the [zb] had hit the fan what I was not told i was booked on the 6 am crossing to Zeebrugge when I had phoned from Manchester [no cab or mobile phones] they had expected my to drive into Dover gone in to the Agents ,they would have given me my loading instructions but I did not know
Parking up where I did and i could have booked off once inside Dover, and by the time I had got off in Zeebrugge I would have had the proper break, also I would have had lots of broken sleep.! Moving on to the ferry etc I had no a clue that was what I should have done .i made what was called a “RICKET”
I rang the office to explained that I had been up since 5 am that morning they more of less said it was their fault but told me if you ever have to get to Dover you must try to get there, as there is always a reason why, I was not experienced at the European way of working yet.
I was on the next ferry I did not have enough money even for some duty free ■■■■ I had forgotten about cash to be honest I did not need any until I got back to Dover i booked into my cabin and had a meal at least that was all free, time to go to bed for about 3 hours, why not ,” a lie down is better than a sit down ,a sit down is better than a stand” you never knew who your cabin mates were as Pete told me, get to bed first top bunk and hope the others do not snore.
Once I had driven off the ferry the routine started as I remembered,it all went well ,even the fuelling up as the credit card all worked on the same pin number so long as you knew it ,I did not ,but Tom had it written down in the trucks book of paper workalso the office had told me,I was soon filled right up the fridge diesel was ok no coffee or sitting around and talking round the table for me in fact over the years to come I never did as I could not drink the coffee.
The loading place was the same one as before when I was with Peter I felt very confident that it would all be ok without any hassle I found driving on the other side strange at first but you cannot really go wrong you just follow the traffic, and you know when you get some confidence you stop gripping the wheel and maybe drop the window and light a ■■■, however there is always something to bring you back to earth very quickly if you start to drift over the lane you soon get a blast from someone’s horn, and my are “they loud” “I got to bloody detest air horns also the blowers.
The traffic coming on your side seem to want to push you out of the lane your are in ,if you have not got eyes on the offside mirror you soon have some trouble I must admit I said a lot of zb meees
I was so busy concentrating on what I was doing before I knew it I had sailed past the customs post as you have to go in to a lay by to do paper work but being empty I just cruised on thank god we did not have to have stamps on any paper work “good old Benelux ”it is not like other places where the barriers are across the road free movement.
After following signs and my memory of places it was not too long before I started to recognise where I was by the factories getting there was good I felt as I had at lest done something correct however lots of time to zb up
I was soon at the factory gates what a feeling of relief I have to pinch myself to think where I was with no money as such,i parked up walked in to the loading office,a Dutch man said in perfect English, hello you are late your load has been given to another driver you will have to wait they were not nasty they knew when I would be arriving I would put money on the office told them
What could I say but ok thank you [ any chancy of a sandwich] he said you can put the fridge on ,bloody hell I had forgot about the fridge ,that was me concentrating on what I was doing finding the place I bet he knew it was my first load by myself it did not matter what age you are ,there is always a first time for lots of things new, the office must have told him.
I never said another word fired the fridge up after a few minutes she was going barmy just roaring away with nothing to freeze only the air, it did not seem long ,when a loud banging was on the door and shouting for me to back on to the loading bay i opened the rear doors , shut- the fridge down, I had forgotten the first rule get the fridge temperature down as low as possible, if loading frozen it will never get to minus -20 as there is not product in the trailer to hold the temperature. But it helps once loaded as it is cold in the loading area.
Once frozen goods are in the trailer and the trailer is all ready cold it will soon be down to-2I i learned another thing, other people do not like to see you go and lie on the bunk and read a book “over time” I learnt it really ■■■■■■ other people off especially if you have had a disagreement with them and it was your fault, you have shown that it does not bother you at all .
Once loaded 19 pallets i was told to pull off the loading bay closed up the doors I went to collect my paper work from the office ,the customs will seal the back doors, and i was ready to go I did stop and think have i done all the right things ,I checked both diesel tanks. Fridge running ok god knows what I would do if the fridge stops I have not been told yet i must put that on a list of to” ask instructions” if a fridge breakdown occurs.
I made my way to the Belgium border I had no problems it all went well then on to a ferry port ,I had forgotten to ask what ferry to go back on,[zb]i stopped ,I looked at what the T2 customs form said ,and it was Ostend,
I now knew the office must have told the exporter that was my port of exit. I made my way there without any problems it was easy to find, the port as the signs were very good you just followed the sign with a ship on and it took you straight to the port gate as I had done before ,I completed all the paper work ,also asked for “a plug in” then went and queued up with all the other trucks, that was not hard to accomplish, as I had been shown before what to do if I had not It would have been a different story
Once on the ferry I asked the crew for a electrical” plug in” I was told yes o,k but wait for the ships electrician that is what I did however he came and sorted the plug in it worked the correct way it sucked in air and not blow it out ,eventually I got to the accommodation had some food then down to the cabins for a sleep, the cabins were located as if they were right down besides the engine
Lots of noise drivers coughing it sounded like a cattle market,
It was time to get up when someone was banging on the door i got up and dressed I did notice most of the drivers getting out of their bunks had slept in their clothes i followed the herd up to the coffee, tea and ■■■ bar, also more food to be had it seemed only 5 minutes before that i was eating, they all seemed to get stuck in, hard boiled eggs and some fatty looking round sausage and coffee , it seemed to me as if coffee was the same, for the Europeans as we have our regular tea at home
The announcement came over the tannoy, all lorry drivers to the car deck, do not start your engines please until told to by the staff, by the time I got down to the truck ,the rear door to leave the ferry was still closed and all these foreign drivers had the engines all ready roaring away it was choking, and they had no idea what pollution they were causing. some of the drivers had already taken the chains off their trucks before the dock workers got on board ,they must have known the system I did not, yet I pulled the electric plug from the fridge rolled it back up and left it,i switched the fridge to diesel but did not fire it up until I stopped for the customs.
The procedure once in Dover was still clear in my head I remember what to do regarding papers and customs i did all the right things i parked up .put my paper work in the agents box ,wrote on it where I was parked, and smartly went back to the truck and got into bed again.
Next thing I know there is rapping on the cab door, i jumped up pulled the curtain back and there was one of our drivers there hanging off the wing mirror with his arms, shaking the cab shouting something, I was not best pleased.
I got dressed opened the door and said nothing about the shaking of the cab ,however over time men I worked with knew not to shake the cab nothing worse ,the first thing he said are we cleared, what! I said, I have not long got in bed, he said he would go and collect the paper work I gave him the pass paper to get the exit stamp
He came back and said it has been cleared 1 hour-ago I said I have only been here 3 hours and not had my full break, he replied, that he was driving the truck I was to be the passenger, ok that made sense. well sort of until I thought about it. it did not matter any-more how much rest or sleep i have
I asked the driver how he got here and he said he came down last night with another of our drivers and went in to a bed and breakfast he got up this morning as he will deliver the load ,and take me back because the office knew I would not be able to drive for some time as my break hours .
It made sense ,as the load would be delivered, we arrived at a cold store at FRIMLY, i was off duty in the passenger seat basically it does not matter where you take your off duty break so long as you are not working
A few years later it was considered by the ministry that if you were in a company vehicle you “were” classed as on duty,” but that was much later in the 1990 s in actual fact if you were driving a company car to or from work of to relive another driver you were technically on duty, however who knew unless you had a accident in that car.
At Bejams Frimly, after a short time we were told to back on to the loading bay ,you got a green light when you were safely backed on to the loading bay you see it in your mirror you could not miss it to tell you that you were on the bay you would then feel the ramp inside the warehouse drop down on to the deck of the trailer they could start unloading.
First the quality control would take off the first 6 pallets then on the they would open the boxes to check for the correct temperature of the product and it had to be between minus-18 and -22 ,they would take all the boxes of the pallet and check the very bottom ones, just to make sure that the chips had been loaded at the correct temperature
After the unloading all was correct ,the load count and the temperature we pulled out of the yard making our way to the M3 where now for me i asked, we are going to Bedford for a truck and trailer service We arrived at Bedford, and the trailer was dropped in a service bay ,and the unit taken for a service next door, i was taken to see the boss of the workshops, and he asked if there were any outstanding faults on the truck or trailer ,i did say some of the tyres on the trailer were a bit short of rubber meaning the tread was low by my sight all the other gauges on the unit were working oil and water was good ,there was no more to say,I had only had the truck for 36 hours ish I was given the keys to the car I had to go home in and that was it,
I was away to go home it was the same old Volvo first thing was I checked the petrol, and it was nearly empty, what a surprise, why would drivers leave a car with hardly any petrol in thank fully a garage was close by,when I got home there was a telephone message written down by my wife for me to phone the office they never left you alone for any length of time it was something I was going to have to get used to
When I booked off in Dover as far as the office were concerned my time off stated from then, that meant by the time I had got home I was on my day off already or as near to dam it. My instructions from the office I had to be down in Lamberhust for 5 pm the next day and deliver a load of lambs the same run I had done with Pete before, on my own ,are you ok with that they said I remember feeling pleased with myself as they were trusting me with a Export load for the first time.
I would not be putting in a tacograph until I leave the loading place that I had one night at home as had to leave by 1300 however it looked as if I had had 48 hours off as far as my tacographs will show.
After a good drive to Lamberhurst ,i arrived in plenty of time, and I had brought a small gas burner and some food ,saucepan, tea ,excreta, just to keep me going and from spending any money on foreign food, the more I did not spend the more for me, well that was the thought .I had not got round to finding a toaster, but I would.
The unit was the one I had driven the day before 2800 DAF, after the service the driver was already ther he wanted to get off home I did ask him why he was not doing the job instead of me ,he gave me some story about his wife I left it at that, it was nothing to do with me ,he told me the trailer was ¾ loaded and the last lot would be soon loaded when the lambs are down to their required transit temperature the fridge was working hard but the rear doors were open to the abattoir.
What I did not know was one of drivers from the abattoirs own trucks was also going down to the docks on a export load he was going direct delivery at Liege and then into Germany i was to follow him down to Dover the ship over to Calais [F] and follow him through to Belguim then we would go our different ways, this was new to me ,apparently all things change when meat is involved ,the office knew what was happening I had no idea
I was to pick a French permit up from the agent in Dover ,and the driver was going to show me the route out of Calais, and how to go through the customs at Calais all straight forward well it is supposed to be.
We were ready to go and he said we were going the back roads down to FOLKSTONE, then on to Dover I did not have a map with me it was a switch back ride ,where we went I did not know I did not let his rear lights out of my sight, he warned me that when you get to Folkestone we will go up this very steep hill if it is wet and you miss a gear near at the top you will be stuck, as the steepness of the hill lets all the weight of the lambs hang back at angle ,taking your traction away from your drive wheels as if you are skidding on ice
We parked outside the agents after booking in to the ferry office for our tickets and i collected the paper work for me and a permit for transit of France we drove round to the customs ,this time we had to queue up to go into the customs sheds for a seal check the fridge’s were making hell of a noise under the canopy so we switched them off , a port health check, ]MAFF],to make sure we were veterinary sealed up ,we had queued up the stairs for the customs paper work to be checked lots of banter on them stairs but not from me I did not know any one.
That all done we queued up for the next ferry to Calais, they were every 2 hours ish leaving Dover we were loaded on to the ferry we had to ask for a Electric Plug as no diesel engines were allowed to be run, once that was sorted and it was working the correct way we made our way up stairs for food in the drivers lounge.
We were on Sea-link ferries and the food was good Jimmy asked if I had any French money at all, and no i did not,he said we would need at least 5 French Francs for the customs as you go out of the gate for the bung, for the excess diesel we had, you are only allowed 200 litres in France.
I changed £10 sterling and received just over 10 Francs Jimmy told me do not give that much you must change it as they would take it all that i am learning more ,we talked about my delivers and he told me about the Belgian border so as i was sure where to go he was a great help i did remember when i was there with peter i would have been struggling without the recap, but that is why they sent me with him.
Once the ferry docked we were about the last to get off we unplugged the electrical cable ourselves switched the fridge to diesel,there was a massive queue waiting to get out of the dock after the customs.
Once in the customs hall I just followed what jim said and I did not speak, there was no need to, the customs men all looked the same in massive coats stinking of French ■■■■,and laughter they were in charge ,after the stamp on the permit backing paper Jim said he hoped they would stamp that, and not the actual permit as it could be used again I will explain later
I watched as the trucks drove up to the last barrier where you gave them the money ,[they called it coffee] the man jumped up onto the step hung on the mirror arm and looked at the fuel gauge on the dash board to see what it read ,full, or half full they still had the coffee money whatever, and when it was my turn I drove up, stopped, and he got on the step looked in the cab and took the 5 francs.■■■ was a long queue driving out of a part of CALAIS TOWN
That was my first of many giving of French francs to the customs men, only in Calais no other French port bothered with the fuel coming in to the country they were the French Mafia that practice carried on until the customs frontier controls finished in the 1990s.
Once clear, before I was let loose on my own Jim gave me my last instructions we crossed the same border in to Belgium as when I was on the other ferry, not to far away however I had to clear the customs there as it was my final boarder of destination, but Jimmy was there so it went well.
AT all the deliverers they will be waiting for me they will soon be out as they were local Butchers shops, in towns this was a regular run.
I found the first delivery more by luck than judgement however I had remembered the name of the first town we delivered to when I was with Peter what a stroke of luck,once they had their meat I would be taken to the next delivery by following a car, I think this job must have been another test as it was nonstop full-go.
,At the first delivery one man jumped up on the back of the trailer to take the lambs of the hooks and pass them down i was given a white coat, to get up and do the same, as two men were on the road taking the meat inside, no lay down on the bunk, and that was the pattern of the nights work,
i had lost track of time.
I ended up somewhere near Brussels Airport with a empty trailer the inside needed a wash out, that was my next move find a truck stop with a high power hose, it was normal in Belgium as they seem to think of everything, Jim did tell me that I should ring the office by 11am our time and get loading instruction, so sleep was the second priority.
I did find a truck wash .no soap just cold water but very powerful it did get most of the fat off the walls of the trailer although I did have to use a plastic ice scrapper [brought from the shop in the service station that was my 5 French francs gone] apparently the use any currency in Belgian
The office told me I was loading tonight not far from the in Belgium, make my way there, as the load was ready a full load of frozen vegetables ,after 3 hours in the bunk I got up , went in the services brought a hot –dog [frickadela] with the French they even took coins, I found that unusual however I had no idea. all new to me
I was ready to leave, heading towards Antwerp you will pick up the signs for IPERS the office had given me directions, on the narrow roads some of the back roads were cobble I was told the road eventually you would drive in to a factory AS EASY AS THAT [NO]eventually after a few turn abounds i picked up the signs for the company in large compound ,other trucks were there, I parked up, went into the office they knew who I was loading for, I was given a loading bay number to back on, I had forgotten to have the fridge running again.
Wait in your cab ,or in the rest room here as the load is handball [meaning not on pallets ,in paper sacks it will be a while before it is finished they would knock the cab when it is finished, it was time to get a brew of tea on then lie down and get some rest ,sleep.again.
After about 3hours and I was woken up ,and told to go to the office ,to collected my cmr andpaper work ,and customs paper, after I had pulled off the loading bay closed the rear doors ready for a customs seal ,i fired the fridge up set it at -25 they told me that the my office said I was to go to Zeebrugge for the late night ferry ,it was not far in distance to the ferry ,that was good and I would be able to fill up with diesel ,unbelievable but it all worked out. even for the ferry, and another time to get in the bunk I had already worked out that if you can get a lay down do it.
Once the ferry arrived it did not take long for the off load of trucks we were soon brought up from lanes for loading ,it is not straight forward ,as heavy lorries have to get put in different places, the loading ticket office know all the trucks weights when booking in .also I wanted a electrical plug in, so I seemed to be kept waiting to load with other fridge drivers as we were all on the same level where all the plug connections are or sometimes you go up the top deck with the hazardous loads it is open to the elements so you can leave your fridge running on its own ,once you are loaded and the dock staff chain the trucks down you go inside to get your bed number/cabin, no single berth, so you have 2 choices either go straight to bed or eat a dinner. Some drivers stay in their cabs .
For me it was a no brainier /bed, before the snoring started, and just hoped you did not get a cabin with foreigners.
All went well ,the crew wake you up in time for breakfast nice full English, then the unloading starts passport control/ customs, all done on the dock ,as before I parked up ,after driving around trying to find a space away from sleeping drivers [ some drivers used to close their curtains so as no fridges park near them and they would not be in their cabs]my paper work lodged at the dock agents in box i wrote on it the number of the lane I was parked back in the bunk again. I have started to realise that a lot of drivers have no time for fridge drivers on account of the noise.
After about 3 hours, I got dressed again, went and collected my paper work ,all cleared that allowed you out of the dock gate and on my way to kings Lynn again to get the load off loaded I knew it would take a while as it all had to be put on pallets ,a long job.
After getting parked up in the Frigoscania yard I report to the office and they told me to ring my office as soon as I can Once again I was told that a driver was coming in the car to relive me and I could go home and ring tomorrow it was a waiting game, the more time I spent here the less at home.
Another driver I did not know, arrived ,and I told him what was going on and that they would let him know when to get on to a unloading bay, and that was me, away, petrol check seemed ok, so home
Top
Re: MY driving and work history from 1980
Postby peggydeckboy » Sat Mar 03, 2018 7:27 pm
The next day from home, I phoned for instructions at dinner time to be told to go to Bedford service depot 7 o clock in the morning, I was to take the truck that was there to load a load of lambs from Canvins abattoir near Bedford and ring from there I thought another euro trip just what I need ther more experience I get the better for me
Before I arrived at the Abattoir I had the fridge going at +2 I looked in the back and it definitely wanted a good wash out before loading I have no idea where the trailer had been previous or who drove the unit .the inspection by canvins veterinary was the most through you could have, at lest the wash was very high power and hot ,if you washed the hooks first you would get soaked with the dripping I knew i would not be loaded for at lest 1 hour after ,it was a new trailer with the air bags suspension ,”very new” you let the rear down so the water ran out they had a large squeegee for removing the excess water from the floor, also you could do the trailer wall sides as well.
Directed on to a loading bay, loading started there was a never ending rocking around as the loaders were walking in and out of the trailer this abattoir only slaughtered lambs and ewes they also had their own trucks but only uk deliveries I was told.
The trailer was loaded I was told to start the fridge up ,at set it to +2 then pull off the bay close the it is some sight looking at maybe 3oo lambs all hanging from strings from the hooks nearly down to the deck a lot of food ,also a lot of swaying about if you start trying to move the truck around to quick,[believe me once you have had a scare you don’t want another]that was for me later.
The veterinary came in to the office gave the office whatever they needed to, the office filled their own c m r out for delivery all the paper work for the Dover agent named A.G. was in a envelope I asked to ring the office before I left the abattoir my instructions were to take the truck back to the Bedford garage, leave the truck ,the fridge going at the correct temperature ,the car would soon be there for me to go home again ,and the other driver would be taking the load,
That seemed for a while the pattern of work i was doing, unloading or loading for someone else and it was sort of getting to me ,i thought i was permanent and the 2800 daf was mine to drive apparently not
I asked to speak to the boss the office men tried to keep fobbing me off that he was never in the office ,I let it go for 2 weeks and one Friday I was home with the company car I rang the office they told me to come to oxford on Saturday he was there on Saturday morning in the yard ,well it was in a forest, called Tubny wood off the Swindon road out of Oxford, it had some hard standing for a few trailers and a wooden cabin type office .I spoke to the boss and asked if I could have a truck of my own soon or I will be looking for another job I have been doing the relive for about a year, with the occasional run abroad I would like European on a more permant basis please.
I was told they would be getting another hire truck a new Scania i would be driving it on a permanent basis in 2 weeks, however it would be on European work and I would have to do the same as the others and go anywhere I was told, if I could not do it they would have to let me go .a catch 22. Situation.
It could be 3 weeks away at a time, i knew some of the other men were very rarely home for long as the export and import ruled, it was a no brainier i asked to phone my wife to see what she thought I could do it or leave and go to nothing as the work driving was very limited around my area
also at that time obliviously I wanted to do it anyway however not my own decision we decided to do it and take a chance i suspect my wife relented as she knew I wanted to do it also the monthly check was there and that was important it was no different than a man being in the services or at sea however I did have a choice and I made it I do not think I moaned about the job at all as I knew what I was getting in to.
The 2 weeks went into 3 and I was getting slightly cautious were they telling me the truth, when I did bump into other drivers they said yes the fitter at Bedford had been told another truck was coming and it was the first Scania not a D.AF I carried on as normal unloading other peoples loads day or night[ not at the same time].
One load comes to my mind that nearly came to my down fall while waiting for the scania also me getting to big for my boots ,it is funny how life puts you down to ground very easy.
I had the company car I had to go to Bedford to deliver this load of frozen goods at 12 midnight at Bejams frozen foods I knew it very well as a lot of our loads ended up there I knew some of the workers however it was different at night ,different people but they knew the company well [as regulars] we had no problem getting in past the security to get parked up at times it was very difficult to get on the premises ,if you were early, or late but Rokold seemed to. have a little priority
This trailer I collected was brand new it had a new system for the brakes called “progressive breaking” meaning when you put your foot on the brake pedal it sent air down the air line to the brakes on the 3 axles like normal the brakes did not all come on at the same time there was progressive breaking one would come on then another then the last one, so as there was no skidding, gently braking however it used the air in the system up quicker whenshunting in tight places the engine needed to be at a high revving speed to keep the air cylinders up to maximum pressure. I am no fitter I was told all this after.
When you were moving slowly shunting around using your brakes the air would be going out ,but the brakes would not be jammed on, one axles would stop you. I was told to go on to a loading bay, it was very tight there was a truck parked both sides for unloading after a lot of manoeuvring and shunting the rear of the trailer touched the loading bay-dock a green light would come on and that was you ,[you had opened the back doors before ] it was tight getting in as their own company trucks were parked everywhere where you wanted to be ,another driver got out of his cab and help me back up to the bay.
I was still chatting I jumped out of the cab with the deliver tickets walked up the 10 steps at the corner of the loading bay into the freezing warehouse, as you walk up the steps you are as high as the roofs of all the trailers parked on the loading bays so it looks like a flat field of roofs ,and all the fridges are off.
All the drivers ,some known and some strangers are drinking coffee and eating sandwiches, mostly homemade, the meal for the night workers does not start until 3 am in the subsided canteen ,I hope I get away before the workers eat as it all gets later and they get slower the longer they work.
The odd driver gets told he is finished, and new ones arrive, at last they call me to say all is good and the unloading is finished just wait for the empty pallets to be reloaded, off I go down the steps, talk to driver next door to me, jump in the cab, put the key in the ignition ,start the engine and let it tick over i jump out the cab again, say something to the driver again [being cocky I expect as I was unloaded before him] I make for the steps again in to the warehouse to see if the pallets are loaded ,and collect the paper work, I was told 2/3 minutes and they will be ready I waited like all the others do. they were that good at this particular delivery
At that moment I was a happy soon be away and home, i was given the paperwork CMR all signed correct I opened the door to go down the steps and looked over the trailer roofs again and there was a empty loading bay where I was parked, i thought well what a good chap ,the driver next to me he had pulled my truck off the unloading bay so as someone else can get in to the space
. That was what I thought.,as I got past the truck alongside the walkway it was quite as I got further round I could see the Rokold unit parked on a strange angle I thought oh no!he has hit another truck, as I run round the front of the Rokold cab it is empty!! no one is in it, I run back around the way I had just come and Jesus, the left hand side of my trailer door was stuck in to the mirror arm cab of the truck next to me, what has happened ,i run back to my driver’s side jump in the cab, and there is the evidence looking at me, the hand brake was not on!!!ohh no that is me stuffed. In the mean time out comes the driver who s cab I have just hit he is going he is going bananas
He said he had only just had it repaired “look mate its happened it is a accident I did it, sorry I turned to sharp” I will back up the truck and you hold the door open then I will park up over there and come back and sort it out what the blessing was the chap parked next door had gone to see another driver so no one knows what actual happened if the truck had not stopped and got caught up on his front, parked up were 3 trucks of Bejams units dead in line where it would have rolled into, now that would have been a major incident [ no health and safety yet]phew lucky or what.
What happened is that when I reached the loading dock doors and the green light came on just by luck or unlucky the air has all gone out of the air reservoirs connected to the trailer brakes and they are firmly on completely empty so it means that all the brakes on the 3 axles are on, I forget to put the hand brake on I was too busy talking!!
After I had sorted all the paper work out ,truck numbers names extra I had to go and tell the night foreman what I had done if they had a inquiry they would know. i eventually got away and made my way back to Bedford no damage to our truck and trailer I was a different person going back than when I was going there subdued
I parked back up at Bedford i wrote out all that had happened on the back of a envelope [a big brown one] and stuck it in the window also left a note for the the fitter if he would tell Mr East what i had written down I would ring the office after dinner, no more I could do I drove home and expect the sack, at least I had given the office a heads up if the other driver rang first thing ,they would know what had happened.
About 2 pm I made the dreaded telephone call asked for the boss, I was told he was out ,but not to worry the insurance would sort it out ,have the rest of the day off ring tomorrow i could not believe it just like that, all the thinking I was going to get the sack and that was that.
I rang the next day, all seemed ok I asked if Robin wanted to speak to me and the traffic manager so no, all ok here is what we want you to do, I think it was Wednesday[ not sure] I had to drive the car to Guildford and go to Steve Chitties abattoir there is a trailer that will be loaded with beef for Rungis, market Paris,
Jesus Christ, after what I did, they have given me a load that I have never done before , only briefly in France once, i have no idea what to do where to go, out of the pan into the fire .I thought it is a joke they know I have not taken a load of beef before, let alone deliver it, it is either a test to see what I do ,if I take it or not.
I arrive at the abattoir the other relief driver said thank god you have arrived, he thought he was going to have to go with the load and he had less experience than me, I thought well that is two of us but i never said a word,
The load had all been sealed up and he gave me the papers I put my gear in the cab checked all around checked both diesel tanks and the fridge was set at +1 the correct temperature, the engine was ticking over [normal sound] I did jump up on the rear of the unit to open the front of the fridge doors you have to slightly jack knife the unit so as the fridge doors can be opened to see the engine to check to see if the gas bubble was ok in its tube,if it is floating the gas is ok if the bubble sits on the bottom of the tube it is of of gas the fridge works but not correct ,all seemed good .
It was the new Scania basic white rental the cab was empty of any personal goods I made sure the company book was in it with all the relevant company credit cards for fuel etc I had my company cash float that they gave you, all was good the Scania was a low line cab 112 if I remember correctly I think it was a twin steer I made my way to Dover once through the ticket control i knew what agent to go to once there.
I had to park in the customs bay, under the canopy once I had the paper work I went to the agents they handed me a envelope with customs forms for me to produce ,also another one marked with my name and it said open in Paris with loading instructions after you are empty.
I found space for parking [customs] lots of other fridges there, roaring away, very noisy i queued up the stairs to present my paper work like the other drivers up the stairs, feeling a bit lost and apprehensive, a shout behind me called Rokold! i looked behind as you do ,another driver a few behind me said ,we are going to the same place ,i will see you on the ferry.
It turned out he had also loaded at the same place but left before me he knew that I was a first solo tripper as he was a sub contractor to Rokold they had told him, I was pleased he proceeded to give me as much information in a short time, however he did say that if we got split up he would wait for meat the last service station before the peage [toll both] he would then lead me through Paris, I said how will I know if it is the last one ,he said it will be chocker block with cars and lorries the service station is just as you see the toll booths. And it was as he said. manic, but that was just the start.
We both had plug ins on the ferry no beds on the Calais crossing there was a drivers restaurant drivers seemed to be more talkative than in cafes at home, over time it was a place I would avoid It was easier
It was only the second time I had been to France once off the ferry the mad rush up to the exit gate I noticed a lot of drivers did not lock their doors we produced to the customs the permit plus its backing paper to be stamped also the T2 forms all in order, we drive out towards the fuel checking customs man for his 5 franc bung it is like a slow snake all the traffic ,cars mostly gone in front all the lorries winding our way out of the Calais dock and through a part of the town as well as us going out on the same road as all the traffic going in to the dock it was very busy .it will be years later before CALAIS is like it is now in 2018 back to 1984/5
After getting clear of the houses we start to go down the main road in to PARIS the auto route has not arrived yet two way traffic ,I think it was PERONE area we got on to the pay road however I could well be wrong.Once I had got through collected a ticket it was all very new to me thank god I managed to keep up with the lorry I was following, it was the first time I had been around this area I was doing more looking around than I should have done.
Eventually we came to the pay booth I had changed some float money in to French francs as I was told I would, need a certain amount also for the return journey I do not remember how much it was but I got a lot of change from a 100 franc note.
I was told to keep up his arse do not let any lorries get in between us the first fascination was going under the airport runway and a aeroplane was going over the top I could not believe it I was astounded the traffic it was very busy it was unbelievable then I spotted a train it was the coaches for the orient express ,also the large overheads signs saying places I had never heard of
Paris city has 2 ring roads they are called [peripherque] one outer for all the transit traffic and a inner for local the outer has 4 lanes like a race track and that is what it is,as our trucks are right hand drive ,it was the only time it was to our advantage as the 4 lanes has no hard shoulder, masses of twists turns tunnels ,some dark some bright and all exits on the same road as the entrance and being on the right we always had a better view as to what was going on than the normal left hand drive.
After years of using that road I used to enjoy going round the peripherque all the exits are named as [a-port-de -lyon or similar ] it used to get really fast and dangerous as the French would never ever give way in their cars they would just keep going, what they did not know was we could see them in our driving mirrors, as being right hand drive not left sometimes they would have to go back ,the up to join the main road again because we/I would not let them in. as they could see they would go under the wheels they would just be hanging on their hooters ,and if you were left hand driver you would slow up and give way because you would not be able to see them.
That was the rule in the city [give way] to cars trying to get on to the main road from a minor road. it was only our ever victory over the French driver, it was even funnier if two of us truck were very close together. Sad but true all the bumps would be in the fast lane not ours all though it was a free way, we always stuck in the slow lane I will speak for myself.
I was given the insight of what to do and very pleased I was ,of having been given information, by the other driver he told me the Motorway signs are very different from ours in ENGLAND because they will show you mileage[in kilometres] and place names miles/kilometers away from where you are however they are excellent to follow if you are going long distance example signs showing all routes as if to give you the chance to turn around and go any direction.
What I am trying to say is that so as long you know your final destination you will never go wrong they all give you a Chance of turning around ,and when you enter France from other boarders Paris is always signed from wherever. Sign posts in to the Rungis market you see when you are right on it
now the nightmare does begin.
As Rungis is the biggest wholesale market of all the products imported into France by road
it is like its own city, with restaurants/bars buses ,we had to go and pay a entrance fee, at a barrier it was all very new. Once done at the barrier ,we went down to the customs parking bays, well !it was like the biggest area you could imagine all numbered with a letter then a numeral. I later over time, found that there were maps of the market in the bars but the locals did not need them.
I was taken up to the agents office about 5 floors up and presented the paperwork and we were both told we could be to late for to days market, meaning the customs had stopped clearing trucks for today [.clearing ]means processing the paper work and making sure all monies have been paid by the import
SOME ANCILLIRY INFORMATION MAYBE USEFULL I DO RELISE THAT DRIVERS WERE DOING HANGING MEAT LONG BEFORTE I STARTED THIS IS HOW I FOUND IT. ALSO MAYBE SOME READING THIS MAY NEVER HAVE SEEN A MEAT TRAILER.
MY HISTORY CARRYS ON AFTER THIS
In the trailers built before 1983/4 had just a fridge unit control box on the front side of the fridge and all the workings and blowers on the inside of the trailer if you looked in side the trailer from the back doors ,at the front you would have seen a metal blower fan unit sticking out, just about the size of a modern set of two Chester draws hanging down from the front sticking about 2 foot out ,meaning that you were not able to push pallets right to the front flat they would have to be half size, if you had boxes you would have to take half of the front pallet off in the trailer push the other to the front under the fridge blowers ,then try to re stack the taken off boxes around the blowers , the ones you were left with you would re-distribute on the pallets as they were in the trailer .meaning no matter how tired you were you had to be with the loading all the while.
The next awkward thing was the meat hooks, each fridge had meat hook rails but i had no idea how or when they were used and by what or why, i knew that there were about 330 ish meat hooks hanging down along 5 rails in the roof of the trailer, what was holding them up I do not know [I still wonder today what was unseen in the fridge roofs]
FRIDGE SIZE AND WEIGHTS.
The first fridges were on 2 axles,[4 wheels] on the rear a Fridge unit[ the cooling system] inside on the front . A steel ribbed floor , thick heavy doors and side walls,Overall weight with tractor 17.000k gs[17 tons]
around 19834/5 new ones arrived.=3 rear axles ,singular tyres ,refrigerated unit outside on the front, lightweight chassis, flat [not ribbed] chequered steel floors, visible screw heads,a thin steel holed strip attached to the side wall to put restraining bars in [ to hold loads back from falling] about 4 foot high off the floor .also later they built under slung boxes underneath the trailers to hold 24 empty pallets and the meat hooks in plastic boxes. and various other features as years went on and of course the lighter they weighed the better. in the end there was no chassis as of now ,very lightweight, that was the ultimate aim years ago lighter net weight higher pay load.
I AM GOING A BIT FORWARD IN MY STORY,HOWEVER IF I DESCRIBE THE USE OF THE FRIDGES,AND PRODUCTS WE /I CARRIED AND TRAILER DEVELOPMENT YOU WILL HAVE SOME IDEA ?
I will just start with the loading all meat was loaded, not by the driver at all it was done at the abattoirs by loader ,it was a very hard job ,you would not have wanted to have loaded meat then have to do your driving work like we used to do with bricks and cement it was all ways very clinical ,we had to wash the trailers out with high powered jet washes, and cleaner, either before arriving at the abattoir , or there ,also the temperature and to be cooled down in the trailer before loading as you backed on to a sealed loading bay, temperate controlled , next to the massive fridge s within the abattoir where all the meat is being cooled down in the fridges for loading , the trailers were meticulously inspected by [ 1] the VET, [2]A MINISTRY OF HEALTH INSPECTOR NOW [ M. A F. F] before any loading took place at all.
DIFFERENT MEATS EXPORTED][ I] CARRIED
BEEF=fore quarters [front legs /shoulders.[2]
Hind quarters [rear legs[ 2]…1animal could weight 1 ton [1000gks]
COW BEEF,= OLD MILKING COWS. AS ABOVE SLIGHTLY LIGHTER.
SHEEP,LAMBS= to FRANCE SWITZERLAND, BELGIUM .HOLLAND GERMANY. ITALY. GREECE.
EWES = MUTTON. LARGE for ITALY SPAIN. A very fatty product.
PIGS, FAT OLD SOWS,LARGE. For ITALY, SPAIN. GERMANY. FRANCE. a
PIGS=SMALLER =BACON,HAM. For SPAIN. ITALY ,AUSTRIA .FRANCE
BOAR MEAT, HAD TO BE TRANSPORT SEPARATIVE FROM ANY OTHER MEAT, AS VERY ODOROUS .Mostly loaded in Germany for ITALY
BULL MEAT=ALSO CARRIED ON ITS OWN. MOSTLY to Italy
SOME TIMES BOXES OF ALL GAME BIRDS, VERY LARGE AMOUNT OF WOOD -PIGEON fresh ALSO VENISON NOT HUNG UP BUT STACKED IT WAS FROZEN
IF YOU WERE LOADED FOR ITALY, FROM ANY COUNTRY YOU HAD TO LEAVE THE MIDDLE HANGING RAIL EMPTY,SO AS THE VETS COULD WALK ALL THE WAY DOWN THROUGH THE LOAD TO CHECK WHAT YOU HAD ON THE LORRY CORRESPONDED WITH THE PAPER WORK,THEY COULD HOLD YOU UP FOR HOURS.
It was because the way the meat markets were going if more imports were in the country, the local prices would be higher. Without imports it would not be only me waiting there would be up to 20/30 lorry s, waiting to unload all over a ITALY .however if you were in Transit ,going outside ITALY for delivering you would soon be out of the customs /vet .the Italians call their vets doctors.
We transported hanging meat to any country , also frozen meat some that was what was called INTERVENTION [remember the butter ,wine mountains] there was a meat mountain it all went abroad ,we never got the benefit of it, when ROMANIA was freed, we took loads of meat to GERMANY to cold stores close to the old east German boarder that was then transferred from the cold stores to the ROMANIANS very poor lorry s back to ROMANIA. when you saw what a sorry state the men [drivers ]were in and their lorries
CONTINUE OF MY HISTORY THE NEXT POST.
RUNGIS MARKET Paris
All we could do is just look at each other ,we could not do anything ,it was starting to getting light, and John the other driver said I know what is going on, the importer has got to much meat today and he cannot sell it so he is holding us back, he said it has happened before ,they always do it to the English, even if we had been earlier at midnight ,they know what is going on and you have not control, we just have to wait ,so he said let us walk around to where the meat is loaded at unloading shed numbered V2P.
That is a number I and many more will never forget if you have ever been to the dreaded Paris market V2P that our importers pitch for unloading, and when we got there, 3 trucks waiting to get unloaded, John ,new one of the drivers, he had been waiting for 2 hours he was not next, we had no chance to get unloaded today, we went to the agent and in their usually manner basically did not give one zb, I asked John what happens now ,he said he will ring the office on the night number tell him what is going on, and ring them later when they get in the office ,in the mean time ,go to bed.
Once the duty office man AT HOME rings the exporter ,to tell them what is going on, Rokold then talkto the Dover agent who processed the export paper work to check all that was in order ,also they are 24/7 and have French language speakers, they will ring the agent in Paris and get a update
,We are parked up and wait for the nights unloading to start, however the French will all ready have their nights schedule worked out it means that they will get to unload us when they can ,as we will be classed as extra loads as being custom cleared the meat we have in the trailer could have all ready been sold on to another buyer any where in France, but will they tell us ,no!.the scenario is ,one of us will unload in Paris and one will go else where
A delivery in or around Paris once we know, whose going we have to phone the night office [Rokolds] man again ,and let them know where and who is going We use a phone from in a cafeteria, in the market, the noise is horrendous, they are always full no matter what time, when the market is open. As you know the French are very loud the place is full of smoke, you pay the barman as the phone is on a meter. and you get a hand written receipt[which is normally altered to our advantage.
After sleeping it seemed for a short time there was knocking on my cab not the best way to be woken up ,it was John he said he had rang the office and it is all still the same as before you either unload in the market or go elsewhere and I must ring whatever time it is when I am empty,
That was it ,back for another sleep ,what with loads of noise and my fridge roaring away I was soon awake again so I decided to get up .
I found John next door also awake ,he decided we would take a walk around and get a coffee somewhere to kill the time, and it was a good time for me to try to get all the information I needed for France that I could it seemed to me as if he knew what he was doing, it worked out a good day from a bad one he said we must go back and try to sleep as we both could or would be working all through the night and maybe the next day he said you must keep your tachographs in order even here in the market as the police have full power in here.
Just before we went to bed again I asked John what to do about this envelope I had got and should I open it as I was not empty yet, he laughed and said what envelope ,I showed it to him ,and he opened it and laughed again and said you knob did no one tell you” I said what! And he replied it is a Spanish permit ,empty in and loaded out, “meaning I said” when you are empty from here you are to drive down to Spain for a collection load up and come back…zb me is that all I said Jesus how the zb am I supposed to do this when I have not done nothing much within Europe, and he replied now is your chance. End of…
And it gets better, they have been having problems at the FRENCH SPANISH border with the local Basque- Terrorists called ETA, where I have to go whoever unloads in or out of here and then head for Spain at least John has done it all before and gives me the rundown of what to do and what not, I write it all down ,and he did tell me all, well sort of.
I was supposed to go to sleep, no chance !I had to get this load out of the way, one thing ■■■■■■ me off ,the office knew and never said a word about the Spanish permit it was testing time again or they would not have given me a permit for Spain,although it was better this way to be thrown in the deep end and wait for the outcome. I expect some men would have said no to Spain…
John did give me a old AA map of his ,for all Europe, the old book type, it did give the main roads through- out Europe at least I was not blind, also he said wherever you unload if it is more than one abattoir ,you must not on any account leave the last premises without using their trailer washing facilities ,as you will never get a truck wash in Spain and the trailer must be spotless ,they will let you use the wash. on no account leave with out having thoroughly washed the trailer then run the fridge cold to keep a chill in it but not all the time…
Also money, he told me that I would need a small amount of Spanish currency only for myself for eating as Rokold has a account with the Agent in Irun the customs boarder post for trucks, for when you return to pay for the paper work.
I must have slept well as John was knocking on the cab door, once I was awake he said the customs and the doctor[ veterinary] only called that in Italy ,and France, [vets.]are ready to look at the load to check the temperature and that it is beef…and not some other meat[horse, donkey etc] once that completed they told us to wait for our papers. About 1 hour later the agent appeared ,no hurry, all the time in the world typical, zb you attitude. I was to deliver in Tours ,and John , had to deliver somewhere here in the market then elsewhere outside ,so we both had the rough end of the stick.
Good thing was it was a regular out of market delivery so thankfully John knew where it was ,and he gave me directions, well in the same area, that was a tremendous help as I would be right out of my comfort zone and driving with no idea where.
After I had eventually found my way out of the market a sort of idea where to go ,well the names of towns to follow, not good in the dark however hardly any traffic to worry about if I was to go the wrong way ,past the junction I needed to be at then that would be bad, luckily TOURS was up in the top order on the massive auto route signs, once I got on to the pay age[pay motorways ,dual track but not free] I was settling down ,bad sign, once you start to feel to comfortable ,I would guarantee something will go ■■■■ up… however this time I was wrong, and TOURS started to come into view ,it was light now, so I was looking ahead for industrial signs. Large chimneys, and factory’s, and the sign for Abattoir… in France it is the same as English well near enough.
Once the right sign was spotted off at the pay exit ,paid my money, and kept the ticket, and found the Abattoir after a few about turns I eventually pulled in to their yard, it was very quiet ,I now had to wait and see what type of reception I got, as I do not know if they were supposed to receive the meat the night before and god knows what they are told, by the agents in paris,
I try to find my way in, lucky the side door was open I went in with my ever magic paper the C.M.R and the Bon- de-reme, from PARIS, I was looking for the boss or “Chef “[chief]as the say in FRANCE,and I soon found him , a massive half chewed cigar with ash ,hanging from his mouth sleeves rolled up up ,blood and snot ,all over his apron a massive man in size, and a big Bonjour, Sava! From him and the same reply from me. [fluent in French speak now he eh, ]well he seemed pleased to see me ,made a change, so he showed me the loading bay at the back to back on to then made a sign ,as for me to go and sleep and I patted his watch and he held 3 fingers up, so that was 3 hours to unload and sleep for me,
I must have soon slept as the rule of thumb it takes a while, however the fridge is turned off, that has been going non stop since I left with the load from the abattoir in England ,it seemed a long time ago .
“THE BON-DE –REME THE pink piece of paper you need to travel out side the market to deliver else where ,in France is like a authorisation to do “cabotage” legally. where as a French truck should in theory be delivering the meat.”
After it seemed like 5 minutes the cab was being rocked, and the door knocked and shouts of guttural French ,so I assumed the load was off and I was needed to move off the bay ,with a quick jump out of the bunk ,clothes already on…the curtain pulled back and a large Frenchman hanging off the mirror arm ,and a foot on the step of the cab, telling me to move off the bay well I knew what he wanted ,[how do they keep that little ■■■ end in their mouths] just what you need when just woken up ,but I knew the best thing to do was start the engine ,pull the other curtain round ,so now a clear view in the mirrors, and pull away and that is what I did well away from the loading bay as other trucks were waiting to un -load…
All done ,C.M.R. Signed with a clear signature, and a company stamp, now I asked about the use of the wash for me to use lots of huffing and puffing, in the end the gesture I got was I was to pay for the hot wash ,and I gestured I would like a receipt, that was a strange look, from the boss however in the end it was all sorted [nothing seems to be easy and straight forward ]then it clicked, it is a foreign country, not home. I was learning every day.
The hot wash was the only way to get the fridge clean and get all the fat and grunge off the sides of the fridge walls if you like snot and grease bits of fat where all the meat carcasses have been swinging, for my first time I think I done good, as at least got my first unload without any major ■■■■ ups [yet]
I had to push all the meat hooks back to the front of the trailer as the were now all at the back, after the meat had been taken off also there is lot weight in all them meat hooks, they are held in place by small clips that have to be clipped down on the meat rails, or else they will be sliding up and down the trailer .and they needed washing. good job I had brought my wellies
Once finished I made a brew and a sandwich as the time was getting on and I had not eaten much in the last 24 hours, now I was ready for my first venture south it may not sound much to all the men who were already well established in European haulage and driving further, like to the East into commie block countries and into Russia ,but for me going into Spain from France on my own, yes empty I was quite pleased but all so a bit “apprehensive” of what zb ups I would put my self in, time would tell,I had got used to driving on the wrong side of the road ,but not got to cocky, because I know what will happen, ill lose concentration and zb up at lest I was driving with the window down that was a good sign. I made my way back on to the Auto route and made for Poitiers enroute Bordeaux .
.I was surprised on how flattish the country was around the area I was travelling, to be honest I had not got much idea on what to expect as far as the countryside would be like as I have never been bothered at all about areas of France, I will no doubt learn it time…
Time was ticking on and sticking to the speed limit I think was 86 ks or 90 was going a bit slow .I then tried to work out that when I got to the loading place, would I be in time to load in the day time .to be honest once I have had a break I will try to phone the office from a service station to find out.
After getting lots of change I telephoned the office number I got through they asked for the telephone and code box number and would ring me back, good plan.after time they did ,they new I was unloaded and had left Poitiers and told me that the cold store will load me when I get there ,they told me tp go past Pampalona follow the Madrid road out, and you will not miss the food factory it is on the main road [something] there is one of our subcontractors all-ready there ,waiting to load, and he will wait for you to take you back through the customs…that was the best news, Pamplona Madrid ,bloody hell.!!
I only had to get there now.
peggydeckboy
SENIOR MEMBER
I thought I would get past Bordeaux, but to be honest I did not have a clue, I had dumped the tachograph card that I used from Paris to Poitiers, and started afresh when I left Poitiers so I had about driving time left it was all hit and miss for me I did not really know what I was doing as regarding times and distances so I thought this was my best bet just crack on.
At last signs for Bordeaux it was starting to look like urban town all the house roofs were tiled terracotta, not like our flat tiled roofs at home god knows why I noticed that but I did, roads were starting to flow in to the main road the last thing I need is a bump, the drivers of cars seemed as mad as them in Paris perhaps it is a French thing being suicidal they had no fear of a 40 foot trailer.
I followed the route around the city, or it might have been through the city ,you followed the river and went past massive palace type buildings like our houses of parliament very touristy I thought this cannot be right had I taken the wrong road
I just carried on, eventually I emerged from the busy scuttling cars my analogy of French cars and drivers are like “bees trying to get back in to their hives” they seem to at the last minute know where they want go and they go for it, and throw caution to the wind ,”completely barmy” over the years my opinion did not change, however who was I to criticise.
Once I got away from the city traffic, it started to get quieter, time for me to be looking around, but not getting to flash ,I had got my elbow on the window edge, shirt sleeve rolled up trying to get a bit of sun the area was so flat it was unreal the fields stretched for miles and there were large water sprayers moving on their own I had never seen anything so large ,god knows what crops they were watering.
I soon found the service area, I was so very close to the boarder ,I walked up to the road and looked and it was about ½ a mile away. At least I had not been stopped by the French police today so that was a bonus all I had to do now was have a good break on the tachograph card, doubt if the Spanish were bothered ,but that I did not know ,yet.
I thought I would get up early ,and maybe it would not be busy, after tea and toast ,[my last English bread the margarine had melted like water,]also I had my very first visit of Mosquitoes during the clammy night, like a novice, as I was,I left the tops of the windows open to get some air in,Jesus what a bollock to drop all I remember is going slightly mad trying to kill the little [zb], what a waste of effort and time, I should have just laid in the sleeping bag head covered and tried to sleep .another lesson learned ,get some thin sheets and shut the windows…
So I was now ready to face my first boarder crossing ,slightly nervous if the truth be told, sI dropped down the big hill.in front of me was a massive piece of steel work that went right across the road with all kinds of different signs in FRENCH AND SPANISH b I knew I was to drive over to the right,to some offices [French customs and imagination, ]and they were just for the trucks that were empty and for Spanish trucks going wherever .There was no order in parking very few trucks nearly all Spanish,were just left where they where ,and you sort your self out.
So I gathered my Permits ,one French [to be stamped as exit] and the Spanish as entry and of course passport,For a time I just stood and looked at the windows within the building I could not read any of the signs, I just watched others as they walked in and there seemed to be a sequence of going from one to another .
. After a while I went to the first French office and give him the lot, not the right move,I remember him saying CMR, over again and again, so it then clicked ,he wants to see my CMR, from my delivers, I had not got it, so back to the truck got the CMR, and I took another CMR with me with no writing just the companies address on it,It was for me to use when I had loaded in Spain .
Back to the office the same man is not at the front working I had to give it to another man not the one I had seen before, so I pointed to the chap sat at the back and then pointed to the paper work, he said something to him ,they came to sort me out.
I did not, know what I was supposed to be doing, but he said something else, what I do not know, but next thing, he is out of the chair, then the office told me to follow him with hand gestures, and gestated where is the truck ,is hands were flapping like a swans wings , I pointed to it and went to the cab thinking he wanted to see in the cab, no wrong end, he wanted to look into the trailer to make sure ,it was empty,he then said to me “Vide” I had no idea what he meant, he then pointed up to the signs above the toll booths a picture of a lorry, with Vide in French ,and something else in Spanish.
We went back in ,he stamped the permit and ,passed it along to another uniformed man ,he stamped it ,looked at my Passport, unstamped he gave it back to me ,and that was that. .flipped his hand as if to say go on zb off.
I had realised I would have to do the same the same procedure once through the border with the Spanish I picked out the nearest entry type barrier to drive through ,it was opened the and I went in through to Spain, first time ever, well on land. The same procedure this side of the boarder
What I found out over the years trucks going into Spain were all ways loaded, very rare for a English truck to be EMPTY well I was I pulled over to the Spanish block of offices looked around and it seemed to be deserted ,it looked run down bare concrete walls open doors, scruffy curtains hanging ,different from the next door French. The EEC money had not started to make any difference yet to the country ,maybe the offices were last on their lists of next to do??
After time two uniformed men appeared ,■■■■ in the mouth ,stomachs bulging over the baggy trousers, they looked like well dressed bags of charity clothes in one, but they took the permit and passport ,stamped the permit, not the passport, and motioned me, with a flicker of the hand ,like the zb off gesture, to go to the truck , they slouched along besides me after they had put their hats on, I knew they wanted to look in the back ,I opened doors ,they check it was empty that done they gave me my passport and permit back ,they turned around ,and glided off not a care in the world.
So, now I was on my own in Spain n not really knowing where to go, the traffic was flowing quite fast, not very many trucks at all ,I was thinking there is something not right where are all the trucksbut that was just me.
I remembered John saying to me , come of the main road at the very first turn you come to just within the boarder area it is a gravel type road ,a fence all crushed down but take the road ,and it leads to a t junction ,and remember to watch for massive heavy trucks overtaking near the junction and then follow the signs for Pamplona also you will never have been on a road like it before, and my god he was 100% right, this was the main road
peggydeckboy
SENIOR MEMBER
Top
Postby peggydeckboy » Wed Mar 07, 2018 3:27 pm
Jesus it was a mass of sharp hairpin bends, the gradient was nothing I had ever seen before, absolutely unbelievable, the bends in the road were rutted where the weight of the trucks had lifted the road suffice in to gravel. the trye marks on the road were thick with rubber
The room when trucks were coming down at a snails pace was hardly any at all ,at least if they hit you we, as right hand drive were away from them, mind you that would be a lot of good rolling down a mountain side. There was a eating place, maybe it was half way up some trucks were parked up but no chance of me stopping. Later I did see some photographs of English trucks parked there right up to the cliff bank.
I was going up the mountains and did not know it ,talk about ■■■■ clenching ,I thought Jesus if I have to come back this way loaded, the brakes will not hold the truck I knew about the exhauster brake but I had never used it before , creeping down at nothing miles a hour, that was to come later.
After a time, wo hands gripped to the wheel I started to cut the corners going up I could see that no one was coming down it soon got me to the top ,a flatter area as high up you could go and able to see for miles. like looking over the whole of Spain, this road .I do now remember it so well that is why I can write a little about it when anything is a first.
Having got over the first hour I starting to make progress, and the driving through villages on a main road ,was like driving on B class roads back home it was only single track in places and a debatable 3 lane in others the passing of trucks coming the other way towards me was quite twitching, how many times I said [,zb me ]I would not hazard a guess, I can tell you I never once took both hands of that wheel, full of concentration, and no way did I overtake any trucks if there was a funeral procession I would have stayed way behind it.
I was making ground in distance, I had to be, it was time I had a brew, there were no lay bys just massive open areas of rutted grass, rocky ,pull off’s, the next one I pulled over ,it rocked the truck about as if it was a yacht at sea, thank god I was empty, as I am sure if I had meat on it could have rolled the truck over
another lesson learned…
I was starting to think, this driving in Spain was no joke if all the roads were like this [no autovia yet] as I got nearer towns I did not seem to be going down hill signposting this way to Pamplona. Hoping the roads were getting better, but I did not hold my breath, in the distance once you could see another town/city and plumes of drifting smoke or dirty chimneys the culprit came in to view
A lot of steel type foundries/factories were around the clue was trucks going the other way were 8 wheelers plus they had a dolly 1 axel, plus tri axles trailer a bit like the [Australian doubles] with god knows how many coils of wire on them, viewed as some were parked up but most were slowly moving along the engines were roaring you can tell after time, when a motor is heavy, and they were ,the engines were screaming they were going down the mountain where I had just come up,
Time was moving faster than I was and I was starting to get slightly anxious about how was I doing as I had no yard stick I just wanted to pick up the sign for Madrid from Pamplona I kept pinching my self I never in a million years thought I would be up in the Spanish mountain area looking for a bloody factory the road sides were like slag heaps from the pits ,it certainly gave the trucks a hammering with it was unrelenting, and I was empty.
Moving on, then at last [phew] the magic sign came up “Madrid” it was not a great tour around Pampolna but I did it ,[so what you may say,] when that safety blanket of being sure ,is not there and you are still not sure you are on the right road, it got a bit disconcerting ,well for me it did until that factory came in to view .[but never believe all you are told]there could have been another road out of the town to Mardrid
After a time I was beginning to doubt what I was told ,how close it should have been to the town/city had I got it wrong, the next place I can stop I will , I will show the address I had written down ,well the name of the factory and the village that the office had given me.
Another mistake!! I made, it was a small type fuel stop, 2 pumps little shack, I thought these will know ,so typical English,[ I kept forgetting where I was] I jumped out of the cab like always paper in hand , I rushed up to the door of the shack/ office, pushed it open ,then [zb] myself ,I had not only pushed the door open, and right behind it was this zb ing massive Alsatian dog. It was just starting to rise and pounce, at whoever dared to push the door open on him,
I started to pull the door shut, the dog was going ballistic, the owner was in slow motion rising from his desk, some type of words shouting, there was me closing the door while waving my piece of paper .
Thank god I closed the door, but the best yet ,it set another dog barking, that was round the back not chained up loose, I did not know just what I needed I only “wanted directions”, and all hell broke loose, I flew back to the cab in record time, jumped up ,got in shut the door and then [zb] myself again[not really]the dog was loose yapping/barking like a bloody banshee.
That was not to be my only frightening experience with dogs] I thought zb the directions I fired the engine up ,with a massive cloud of dust I roared away and thought ,zb the dust ,that was close, never go into a place again like that you, [zb].!
I was now calmer I was chain smoking now once myself down in the distance, I could see on the top of a hill it looked like a massive black bull, i thought what the [zb is that] and as I got closer it was the biggest hoarding you have ever seen it was a big as a house, well a outside wall size. Massive, as I got closer it was held up by limited scaffold poles, advertising brandy ,whatever, you could see it from miles away. After many other trips to Spain the [bull] was a main feature of the arrival and exit of many towns.
I was now starting to get a bit worried where is this [zb] factory,[so close to the road they said [you cannot miss it]. Wanna bet,. have I missed it??
I was now thinking, maybe there were 2 roads to Madrid from Pamplona I was going to stop and ask someone I had too just for that bit of reassuring that I was on the right road once you start thinking that you have gone wrong, although you do not know, you start looking for places to turn around if needed, and you start putting pressure on your self, but you do not realise it
.I was right and it was not long before that happened out in the distance a factory started to come into view .yes…thank zb for that .that was always the response to myself I just hoped it was the correct place there was a Rokold trailer parked up
It looked like a farm with massive greenhouses that was the best sight since sliced bread [the trailer]but no tractor unit on the front. I was so pleased that I had arrived. my first load from Spain…well later.
Once in the yard it looked like a desert, I slowly turned my truck around and parked next to the Rokold trailer. First thing I noticed were that the back doors were open and the fridge was not going, strange
I stopped the engine jumped out of the cab,and walked back to have a look the office had told me that the load was waiting for me we would leave together…strange.
I walked over to the office it was empty , back to the cab ,no one around. I did the favourite thing “put the kettle” on…after time I heard a lorry ,and it was the tractor unit,I was pleased to see someone, when he parked up he came round to me as I got out of the cab ,we introduced ourselves he was Roger a owner driver
He the told me what was going to happen and when Apparently the green beans are being picked to day from the fields ,processed tomorrow, bagged up in paper sacks, and loaded whenever they are ready. The load is not frozen but will be the time it gets back to the uk fingers crossed
My first question was why would the office tell me you are loaded and waiting for me to get here,…
He said,[the office] [1] they wanted you to get here so you would get enough break in on the Tachographs once loaded we are none stop-ISH to Kings Lynn cold store.[2] they did not know if you would get here or turn around and go home ,that has been done with other drivers, with other companies best to push you and see what happens…and you made it,i I will phone the office to tell them you are here.
I said what do you do now , as a contractor and the unit is his he does small maintenance, changes fuel filters etc, ,because he does not get the truck serviced like a company does, which is fair. also he said would I help him wind up the trailer brakes before we leave ,I did know how to do that task I told him but never bothered on here [yet] as they are supposed to get serviced. that was what we did also my trailer brakes as well and I can tell you, if we had not done it, I would have had problems going back down the mountain ,they needed attention being empty on the way here I did not notice…another lesson learned, get myself a good ring spanner and hammer .also some [Olives] for the air lines to make a tight connection ,no Olives no air lines .you could be stranded just for the lack of not having some[olives] not the eating type [for the non driving reader ] also two large open ended spanners or adjustable to fit the connector ends.also a ring spanner and a hammer for the brake arms under the trailer.
When we had finished Roger gave me a lot of useful information for when loading from [Pack houses.farms] the produce is never ready on time, just get used to sitting around maybe 2/3 days do not pester the office because they will know before you when you will load or so they say…
Make sure you have enough fridge diesel ,also diesel for the truck as it could be late night or early morning when you have to leave ,no set rules, you have enough food for yourself ,water bottled ,or from home in a water container with a plastic tap on the bottom, on no account use any Spanish water for anything ,not even cleaning your teeth, ,you will be ill.enough bread, tined food, whatever you like, packets of dried pasta etc,
Buy it from the supermarket back home, you will want, sun cream .mosquito bite cream, soap powder ,a bucket, a hat, flip flops, a wash leather , shorts, string ,pegs, headache tablets tablets for a upset stomach, plasters, a sharp knife ,cooking pot ,frying pan toaster .you have to be 100% self sufficient as you are on your own. And yes [I did carry all just mentioned for years] also helped other men out.As sometimes it could stretch in to 4/5 days waiting over a weekend especially in the south of Spain where most fruit, and vegetables are exported from.
If you buy vegetables, to cook up, wash them thoroughly with bottled or your UK water ,French water is ok ,but not for drinking. It seemed as if I was on a mission of survival, however if one man on all my driving career gave me the most sound advice and truth it was him he was spot on.
I passed the same information to many young men starting out ,however ,most liked to just go to bars and eat out, to lazy to do it ,but if you offered them a meal they would never refuse in all the years I did European I do not think I had more than a few meals in restaurants in all EUROPE wherever I went especially on the meat.
He was well travelled within Europe as a owner driver ,he went where the big money was supposed to be made …did they ever make money .
Loading the French green beans they were in large thick paper sacks it was a art in itself how the loaders alternated the rows they put very thin pallets on the floor,for the air flow then the sacks were laid long ways across the bed with a least a 2 inch gap between the sacks ,and the next row was reversed and so on and on so it had complete air flow from front to back of the trailer ,it was like a large honey comb, about 2 foot from the ceiling just under the air flow -trunking that took the air to all of the trailer, and the hope was that by the time the truck got to England the whole load would be FROZEN down to -20.
Once loaded the fridge thermostat was set at minus -25 the lowest it would go so it meant that the fridge engine was roaring away ,and it seemed it was no stop ,going through the fridge cycles in the end but the product was frozen and down to temperature I found out later you can bring the temperature down in degrees like minus 5 first then minus 10 then so on until the fridge gets down to the –minus you need over time it got to be a work of art
THIS information was told to me , and learned by me ,by experienced fridge drivers
especially loading warm fruit you are working on a fruit temperature of plus+ 15/18+ straight from the fields
once all the big cold/chill stores arrived the fruit is already down to the correct temperature ,built with EEC money
To get the temperature down to plus +3 first you hope can find/ have ,some sheets of cardboard handy from the store where you are and you cover the tops of the back pallets ,where the air flow is blasting out of the air trunking it will freeze the top layers of fruit if you do not start to bring the temperature down in degrees
IE how–you find out the LOAD temperature if you did not have [probes] [i did not then ]once loaded and doors closed, you fire the fridge up ,set the temperature control dial to the highest temperature +25 then wait until the fridge engine shuts down to tick over look at the dial see what it reads set the dial down to say+ 15 let it run, then do the same all day it will go through its cycles you may have to stop every 2 hours to check eventually the fridge will tickover at the temperature you want +3 for fruit…not melons[ a basic summary sorry if it is not 100%correct] but you get my drift back to the story.
The drive down the mountain was very slow and ■■■■ clenching at times, never before had I been subject to zb me going down hill I hope these brakes do not fail if they did that would be it it is so steep
I was following Roger down behind him , some places all i could see was the roof of his trailer with the step gradient and hair pin bends, the engine is screaming, using the exhaust brake
Spanish trucks up your arse like trying to push you on faster. after a while Roger pulled into -parking area ,one to let the engines cool down a bit and to let the traffic move on and for me to breath…they say the first time for everything is a bit hairy to me ,it was blimey I thought I could drive ,it appears we are only playing at it back home up and down the motorways theses old foreign boys have my respect
It was quite strange when we were parked I said to Roger I seem to have seen this place before , but I thought how come,he said it is a popular stop for the UK drivers going this route to Zaragoza Madrid route s Apparently the quickest but the hairiest ,he was not wrong there
.Once inside there are loads of photographs of English trucks on the wall and there are Rokolds trucks then it clicked in my head, Pete, on my very first trip was showing me photographs of him in Spain and I can now remember him saying how dangerous the road was.and here I was in the very place he had been Photographed.
I did not have anything to drink, brandy seemed to be the drink of the day everyone had a small glass with whatever else they had…not for me…it was only dinner time.
I have never liked trying to speak any foreign language at all, my English needs attention. people say over the years …[ohh ,they like it ,[the foreigners] if you try to speak their language,[ who says so]… as any foreigner ever said “well done ”you, you tried but [zb]it up. No! . After years of driving in Europe I am still the same,. just got on with it…with hand gestures. drawing bits on paper and you get on…look at the Italians .they [wave the arms] around, people think that is great I dont, stop bloody flapping around ,and stand bloody still.
They want my mum behind them she would tell them and she is 99. Haa she used to sew all my pockets up when I was a kid to make me walk straight “keep your hands out of them pockets and I used to have to sit on my hands when in a chair…how about that. Discipline, I grew up to hate it .but had to abide by it just like driving.
nce we had left the parking we had to get into the customs compound, we did not have to do [revision ]that is only for fresh produce Roger warned me in advance once parked that loads of men would come knocking on the cab doors looking official, saying [give me your papers] ignore them, they are only Agents runners, people touting for business to get your papers processed by the customs .they will go once you say [carlos]
He is the man who will come to you introduce himself and he will know you are new ,as he knows 100% all the drivers who work for Roklod and other well known firms running to Spain…and Roger was correct .also he will not forget your name and that was also correct over the years he would always greet you with the correct name, even if it had been months since you were there .good man to know…
I then realised that things were not that hard to do at borders posts ,if you got the right person who knows a little English .if you have to have customs papers made up. also the price is the same if you use the same company. I found out over time. when I used to hear men say [-yes I got myself cleared ]at so and so border, now I know [[zb]]everywhere Agents do the business in transit it is different you can do yourself but clearing[ no]. well as far as I know but I could be proved wrong…
After about 4 hours where every tom ■■■■ and harry have helped their selfs to the produce before it was sealed up, it seemed normal practice ,some with different uniforms some with different hats and some just bloody thieves
We were cleared to go, make tracks, out with the old tachograph and In with the new one ,the one we had used from the factory to here was thrown away, now it looked as if we have just started another days work “from a long rest ,who was to know, if we get stopped by the French police on our way back, it looked as if we have had a good long 3 days -ish rest .so long as I wrote down the mileage from where we were leaving from on the new tachograph
made sure that I put that mileage down on the one that I had finished ,to look like when I first arrived, we had been standing still. The law then was you had to show a tachograph card with a complete 24 hours ,no movement on at all, that was it …so long as the written mileage corresponded with the card you were starting with it was ok . There were no electronic methods of checking cards then it was really a free for all …now completely different ,for the better…
I just followed the back of Rogers truck ,what he did I did, I knew he would not be legal ,but he-ho needs must .I could not hang behind .I can now see why are paid a Monthly Salary
no way could you be paid hourly on this job, we get a daily tax cash allowance ie [night out money] but the company’s do not look it as that ,it is just a perk ,so they think ,however that is what makes the difference ,is it worth it.? So in theory we now had a 10 hour drive with one 45 minutes break to do , then park up for 9 hours rest.[sleep] Roger said we will be just south from Paris when we finish today.
I just kept up with him all the way, at times we were going over the FRENCH speed limit at that moment it did not bother me, because I was green at the job to be honest ,however I would learn another lesson.[not this trip]
Where we got to I could not tell you but I was glad to be finished, we checked our fridges ,[diesel and our trucks] and Roger said that we had enough to get fuel to, transit around Paris and fill up at a service station on the home run, apparently once the fridges had settled down and the temperature was getting colder inside they went into a slower ,mode and the fuel consumption was slower,[how I do not know ,it turned out to be [zb]]
It all worked out, after some tinned food [Rogers beans again] and good sleep even though the fridges are roaring way not 3 foot from the cab, you are so knackered ,you sleep. It was afternoon when we were ready to leave, Roger rang the office and gave a progress report, it looked as if we would be in Calais early morning .
The reason the office want to know where you are, they try to work out when you will be back in the UK it is so as they can book loads in to factory cold stores for unloading, they already have preliminary bookings [but do not tell you] they let you get on with it as they know you will, and want to go home for a couple of days you will go all out to get back to the ferry. The old ca rrot,…so long as you have had 9 hours rest ,you could break that rest by a movement on and off a ferry .
Mind you every one made their own rules up you would not get two drivers agree what was legal and what was not, also the companies they all wanted you to look legal and keep the cards straight however What you had done abroad was not there problem.
They new that every driver would do his utmost to get the job done and get back in fact a lot of drivers did not really want to be where they were, as if they wanted to be home before they had left… and the Europeans really did not give a [zb] legal wise so we were on a hiding for nothing
We arrived at the fuel stop after a hair raising trip around the Paris ring road we were about 4/5 hours from Calais we both had French sticks with a nice brie cheese ,and some [zb] coffee, I could not be bothered to brew up , that was the last time I did that!! I brewed up whenever now.
The service station was full of trucks from all euro countries , [well it would be ,]as I could see no other English trucks back then there were limited firms that actually did European it was NOT until the customs border post came down then every tom ,■■■■, and harry, got on the band wagon all the hassles had gone from the job but that was not for a few years yet…
Arrived in Calais ,no police stops ,or customs, it was not unusual to be stopped by the customs not the police just before you got in to the outskirts of Calais they would not open the doors but check trailer lockers /boxes also a cab check for wine and tobacco you may have come into France from Belgium via Lillie over time that happened a few times to me before the new roads were built
The customs exit procedures were done, then on to the ferry ,well to park up and wait, you had to be booked on by the company, not like now any ferry any time. Waiting at Calais was not long this time [only sea link and p,and o ] were running then from Dover to Calais.
At the booking office we had asked for electrical plug -ins they told us they have all been taken by other trucks, if we wanted we could wait for another ferry ,or switch them off, as the goods were frozen not fresh ,Roger said it would be all right that is what we did a meal on the ferry then to the duty free shop, I had enough money for 200 cigarettes no credit cards then for me .
We had a meal in the drivers lounge ready to get off. Once the ships tannoy told all passengers to go to the cars and trucks you realise how many people actually use the ferry After docking procedures, the ramp is put down , by the deck officer within the ship then you are told when to move towards for driving off, the lorries were already started up so lots of lovely diesel fumes for the ships crew, I had my window up once off the ramp you have a drive towards the immigration, and formal customs proceed ,when completed you are told to go the parking, most of the fridges all try to park together as the noise is horrendous .if the customs want to check your loads or your cab you are told where to park, near some unloading bays and wait [it is all done by walkie-talkie hand held radios] you are not privy to your papers can not be handed in to the Agents to start getting the customs clearance until you have been cleared once the inspection is over.
There is no guarantee when you will get told to back on to the unloading bay sometimes it takes hours, if they want the whole load taken off so they can look at the very front pallets, that is what is done.
However the unloading is done by the port dockworkers [shift work] so if you are unlucky you just as well go to bed and forget it day or night. believe me .this time on my first from Spain we were both lucky and not inspected but numerous times in my driving job Dover was a pain in the ■■■■. especially for load inspections the trouble was if one truck from the same company has been pulled and goods are found even just extra ■■■■ or spirits in the cab, or worse in trailer you can guarantee that company trucks will be looked at .i do remember being told that your job is driving, and the truck is mine it is not for any ones use to bring in contraband [smuggling no matter how small]
Especially if you have loaded in Spain or Portugal and come back into the country via Calais ,it is the longest way back [ road] to England from Spain ,the most used route is from Cherbourg to POOLE, or ST -malo to Portsmouth or even Le- harv,e to Portsmouth so the customs would quiz you why you come back the long way round .,and the usual answer was we were doing as we were told, however it was a smuggling route so they treated every one the same.
We were both customs cleared and ready to drive up to up to Kings Lynn to the Frigoscania -cold store one ,not that many in England, I think it was Thursday night ,we had a delivery time for 12 noon Friday, we made good time and arrived early ,booked in and told to park up, they would get us when they were ready, the local in house customs man broke the seals on the doors and the quality control took bags out of both trucks to check the temperature of the goods and the quality of the beans [French] it did not bother me, straight in to the bunk.
.After a time the door had the unwelcome raps, and shouts, normal.,…once semi awake curtain threw back a fork lift driver [fat [zb]] shouting bay number 2, they used to love waking drivers up, so I made a mental note I will never ever sell him any duty free ,ever if I ever get the money to buy extra as time went on I did, sometimes we would get a turn round either to load in the uk or stright back empty to Holland or Belgian for the frozen veg or chips
W hat I used to do was keep all the big manila envelopes used for paper work and wrap 200 ■■■■ in them and find a post office there are some around I would look for laybys near a village then park up run around and hopefully find a post office or where I was unloading, I always got them sent home to my wife ,the last thing you wanted to do was take them back out with you again, because when you come back in again on the ferry you would be over the limit if you brought some every trip
How they unload is they have a elevator.[a revolving track] pushed up to the open back doors ,and the bags/boxes are put on the track, sending them out of the truck to people loading them on pallets on the ground, then they are taken away when by forklift
Roger told me this where the selling of the duty free comes into its own ,no ■■■■ =slow unload…oh zb another lesson, this time Roger had sold his ,so it was o k, next time I will know, apparently most cold store and unloading warehouses work on the same principle with import loads, they know you will want to make some money some men had a good business going ,as I was to find out much later on.
After a fare amount of time, we were both unloaded , the next instruction was to go home, for how long only time would tell., after a while doing the job permanently ,I used to find out it was not worth going home just for 1 night, it put my wife out of her routine no sooner were you home you had to leave again it caused more trouble, than the night at home was worth.
After time the driving laws changed and we had to have 36 hours off in one go ,so we did used to get home ,sometimes in the middle of the week however it was home ,also I had room to park not to far from my house. on waste ground
This time I had a 2 days also the truck at home I had a call saying that the truck would be loading at “Canvins ”Bedford a abattoir that was mostly for lambs and be there for 8 am ,the next day I knew that that would be a long job loading however you had to be there early so as the veterinary could pass the truck inside clean and ready to load, but you had to wash out first at the abattoir so it was a early start and be washed out ready…
.That Tachograph will go out of the window as I knew it would be late afternoon before I would be ready to leave and I did not know where the load was for once on the loading bay i was on the bunk for a sleep…I think it was about 1pm when the cab was shook and I jumped up, told to pull off the bay ready for the veterinary ,customs seal on the trailer rear doors.
After the paper work was sorted it was now after 3pm so in with a new Tachograph card with the name of the place I had left this morning so it looked as if I had just left home and the mileage
After the paper work was sorted the fridge nicely ticking over at +2 in with a new Tachograph card with the name of the place I had left this morning so it looked as if I had just left home and the mileage was about right.
It was the Belgian run, from a different supplier I thought thanks a lot I did no more and just got on with it and for once it all seemed to go the right way for me, I must be doing some thing right, some of the trips were getting routine a lot into Belgien for frozen vegetables all back to Frigoscasnia KINGS LYNN. You would be amazed of how much vegetable produce was exported from to England, I never did get that ,I expect it was cheaper
All the same procedures with the agents, customs ,and queuing for the ferry after the seal check,and off to ZEEBRUGE no matter what time it was there was always food on the ferry.Just something, nothing to do with my story …every time I was on either Townsend Zeebrugge ferry one of my old ship mates was a A.B deck hand on duty as quartermaster and never would have seen him. Well it was park up and eat and bed…
The trip went well the same as before, I was knackered as usual, and I was looking for a change of scenery. More FRANCE OR ITALY ,OR BEYOND I knew I was the new meat man however I did realise that I would like to go different places most of the time, story of my life…after time I did ask if ever the was a chance to do deliverers south, spread my wings…some of the young lads were content with the Benelux runs, not enough for me…so I had to wait …
It must have been a least 8 months ,I was clocking up lots of European work and getting in to the swing of things , more and more confidant with the work and different place most of the time ,lots of long days ,in fact mega days and it got as it was normal to be on the go 15+ hours a day not always driving but being around your truck and on duty or waiting for someone to turn up to takeover from you or vise -versa in fact it was never ending, I should have seen the light and pulled the plug then ,as me and others were getting as if we were owner drivers not working for a company, but that was the game . Say no more…
I think someone was sick and I was told to go to LAMBERHURST wash out and the next day load for a GENEVA run, well at least it was a change i had no idea my mission was to get as much info off who I could without sounding like complete novice, but in theory I was.
I hoped one of our drivers was loading there as well…
As luck would have it one of their own drivers was there so he briefed me on most not all of the trip to Swiss. I looked as if I had taken it all in ,what I did know about my self I would listen, but not listen, if that makes sense and as something unfolds that I have been told about it would come back to me as if a film is rollinbut I would never be able to recall anything once I had been told straight after.
However all that I have typed down and recalled and are recalling without any diary, is how my brain works…
There were more things the driver did not tell me he should have…once loaded, sealed up paperwork all sorted ,fridge running fine ,temperature correct + 1 to 3 …fridge tank half full of of diesel .all the lambs had been slaughtered the day before so they were well down to the proper travelling temperature ,away I went, when i left LAMBERHURST it was no easy driver down to FOLKSTONE then on to DOVER,
As soon as you left one village you would hit another in the SUSSEX countryside, one that you had to be on your A game was “Sissinghust “yes the famous place, the double z bend around the churchyard was a tester! After that all back lanes but you got used to it over time lots of trailer swaying as all the meat settled down swinging on the hooks , and you could guarantee that all the stops were put down.
When the meat is loaded the first lambs are put on the hooks through the sinew at the backs of their hind legs that are high to the trailer roof, then the next lamb on the same hook are hung down on string,and sometimes if I remember right then another on string so that means on one hook there could be 6 lambs 3 each side of the hook
When you have more then one delivery string is wrapped around the lambs on the hooks when the others before are taken off you then come to a load of string wrapped around the lambs you know it is another delivery .unless as sometime s it did happen that some string would brake and lambs would be on the floor,[not good] so then who s were they.?this delivery or another ,but they did stay most of the time where they dropped…so long as the customer signed the CMR correct I did not give a monkeys.
The trip from Calais ,down around Paris ,the clock ticking ,good fun around the ring road,out down towards Macon we used to park around this area a very short brake ,never once do I ever remember not being able to sleep ,waking up was the problem ,even with the fridge constant banging away, a nuisance to other drivers ,but I was used to it if it ever got turned off or a problem over the years I would be awake in a fla
nce awake and up out of the cab checked the trailer doors seal if that broken you would have to call the police ,fridge temperature, fridge diesel see no one had siphoned the fridge diesel, tyres all the checks you had to do it ,others may say ,no you did not, but yes with fridge work you did because any ■■■■ up and it was down to you. also you had your own reassurance that all was ok, when you checked it.
The actual freight customs clearance in GENEVE AIRPORT French side is accessed by a horrible road from FRANCE called to FERNY VOLLTER ,now there was a road ,it was the back and beyond…if I remember there was a town called ELOSIE .before or after the MONKEY HOUSE… RESTAURANT
I am not sure you made your way out of the town/village the road got narrow and I started to think ,this is not correct, but turning around was no way and I was told that is the way so on you go lots of ■■■■ being smoked. at the the end of the track/road you came upon a very small customs house and it was a house, small parking area on the verg rutted tracks where to park .once in the house permit stamped t form I think it was a T2 transit form.[not sure]or T1 for Swiss then on to clear the swiss veterinary you climbed a little higher and right in front of you was the GENEVA airport.
There were agents offices that I was told to use ,the swiss people in authority were not the most [have a nice day] kind of people in fact in fact arrogant ,bossy,well if you have dealt with them as drivers you know…after time I was put onto a inspection bay, vet inspected ,all cleared temperature ok,that was the main thing, ok to go
After you had paid the days road tax,15 swiss francs I f I am right, now that is not for 24hours that is up until 10pm when trucks stop…[well then it was] 15 francs was a good sum ,and I never used to have much foreign currency as I would self cater so I never needed much .
Once cleared I was told I could go to my first of many deliverers they pointed to the car park and said wait there and a car would come for you and follow it, nice one .
Once a car arrived , [ a white van] the drivers left arm waving out at me that ■■■■■■ me off straight away, not a word ,I would not have understood them so I followed him we arrived at a like public car park he parked me up and I thought right brew time, but they had different ideas this big fat cigar smoking chap got out ,massive gut, stupid hat, waving is arms about to the back doors ,he wanted me to open,[ yes ok ],there was no one around that if you have ever opened a fridge door and you are standing on the road looking up in to 300 lambs all hanging on strings it is some site and I how do they unload them they wont unload themselves.
I am puzzled ,another van rolled up then another then another it was like a white citron van convention, some with 2 people in some single they all have white abattoir coats on like a load of cricket umpires ,all got ■■■■ on and talking ,well shouting over one another looking at the lambs as if they had come from outer space . then they were pointing and looking at me .so! Me in my perfect English shouted what the f-ck are you are you lot at looking at
,Then the big guy suddenly spoke English and said C M Rs I knew I had a lot .so I gave them all .more chitter ,so after time one chap climbed up in to the back of the trailer lambs all around him and started to cut the strings from them lower once to make room at the back as he passed the lambs down to the other men and started to put them in their vans, I am stood there gob smacked in a car park…
That was only the start ,after time other men got up into the trailer and started to pass the lambs down ,the big guy had a tally card on the deck,[ mr checker ]asked me to switch the fridge off, that I did after I made it clear it was down to him at further drops…if the temperature was not right.
After time half the load was off and they had come to a load of strings around the lambs that told them that another deliverer was next .I shut the doors, start the fridge and follow the van man and the same happens again a car park…
Only 2 vans and 2 women driving them ,same white coats blooded so the must be butchers like the others so the big man comes knocks on the cab door holding a white coat, I get out and follow him to the back open the doors, after knocking the fridge off and go to get back into my cab, but he has different ideas ,he wants me to get into the fridge cut the lambs down and pass them down to the ladies waiting, what he did not realise I was the worst bloke that he could have asked to do that I went ballistic I f—ed him up hill and down dale
I still remember what I said =the richest country in Europe and you want me, a driver, to get in there and do some on else’s work …etc .etc blah blah I said I want a phone ,I closed the fridge doors up, and told him I want to speak to the agent and my office ,guns blazing.
He took me over to a bar spoke to the agent on the phone ,who then spoke to me and calmly said ,we have never had a problem before with all the other drivers, we have these loads every week, and the driver gets up and hands the lambs down he said that was part of the deal the man pays you at the end of the day, [are well] ,no one told me anything about this I reply d that is a bit different now
I said that should be ok then ,I was now fast backtracking if I caused a stink ,work could well be lost, so I know went on charm offensive ,[I was wrong again ].however I always have hated anyone being taken advantage of. So reluctantly I jumped up with my white coat on and did the job ,after about 4 more drops the trailer was empty and now my reward I thought I would get a nice wedge, 15 swss franc the tw-t gave me, he was all smiles, it only repaid the road tax say no more,
I realised this is how c licence company’s men,[own account] and owner drivers work, I had still got that old mentality from before, still in me one job and that was it but I was changing, now I had to ring the office, I knew the agents would have told Rokold what had happened so I knew I had to get in first to turn it around to my advantage, so rang the office and the receptionist answered and I asked to speak to MR EAST himself, so luckily he was there and I turned it around and said the traffic office failed to give me clear instruction what to expect in Swiss as I thought the man was trying it on himself -if I had known we had to get in the back and unload all the lambs that was ok however did that mean it was other duty,s on the tacho setting or what , I am now EMPTY, it worked… it turned out he did not know that was going on ,and he did not like it himself so it turned out good all round I never did that load again…however I did know that I must now do whatever asked within reason…
I washed out the trailer at village near Cluses that was lucky, thank god it was a hot wash I used the dkv card you would not belive how much lamb fat gets rubbed on to the side walls with all the movement because they are moving all the time with the natural road swaying then ,it did not bother me at all ,after cattle trucks it was a piece of ■■■■.
On towards Mt Blanc another first [flying blind] I came off the auto route at Cluses that was the customs post, cargo area transit area, get you T forms /Permits stamped area, eating, showering, etc if you wanted to gather information that was the place to wait OR NOT for me over the years NOT in and out. I was told to go into Cluses by our drivers before or else I would have flown past transit was quick if you could park up
It was a place after time I never much used. as we used to diesel up half way up the mountain ,IDS …after [I finished with fridges.].in the mean time I was still the novice/new boy but who knew, no one.
Once I had pumped a English drivers for advanced information ,I had not yet acquired…I left the compound area and felling more confident I struck off up to the mountain ,the ski slope was not yet finished it was under construction .
As I progressed up being empty I came across lorry s struggling at a slow pace, and to be honest I did not know if I should overtake or what ,as little traffic was coming down so after some very bad bends the road widened and I stuck my front end out all eyes on mirrors for cars or even another truck to take a chance.
All clear ,pull out ready to flip back in smartish all clear and away not a practice I was too keen on I drove on as I was nearly at the top I did see some trucks in the dstance stopped in a lay-by type place with a wooden hut i took no notice and went driving past I was not speeding next thing I hear is this almighty blast on a whistle I looked in my mirror and a police man was going mad waving, at me i pull over, good job I had the window down as I would had never heard him.
I managed to pull up and park on the gravel verge also a big ditch ,and he waved at me very nicely, like get the fu-- down here …the trucks I had passed before were not behind me and I managed to back the few meters on to the parking near the hut,
well I had no idea what was wrong it turned out it was the chemical stopping point for the mount blanc however all trucks had to stop and show the CMR to the police /customs…90 francs fine for my incompetence, the biggest mistake I ever made and now I have made it public it was about 1984/5 I think ,I have no diaries so it could have been earlier
That was the best learning thing that happened to me .also that was all of my French money
It took me a while to get over it money wise ,how would I get that back ,tell the truth and see what happens.
MOUNTBLANC TUNNEL ,well I had never come across anything so long as tunnels go ,made the Dartford a bit small ,once out of the brightness and fresh air into the tunnel the trucks coming the other way seemed awful close I was pleased to see the light at the end although there are lights in the tunnel I was to busy concentrating once through I stopped again and went into the customs etc I was told before what to do , I started off down into Italy [bloody hell] steep road sharp bends the scenery was a first, as it was still snow covered , I thought how do you go down here loaded.
I was so new ,a Dutch pig transporter came roaring past me blowing his air horn .so I thought right I will follow him my god he flew down and I did after him
Once we enter the compound at Aosta, as I was transit I was in the wrong lane but in the end it worked out ok after a walk around the compound I changed up some money, trying to not look new, I walked over to the exit to see what was going on I thought I might have sussed it out ,it was easy to get back to the traffic lights where you turned right for TORINO AND MILANO.
I did have a old map page rescued from someone ,not a full map enough I should have brought one from the compound but did not if I spotted a English truck in the service area and the curtains not drawn I would go and ask for more information I think in the end I was confusing myself .I had so many bits of paper with all kind of instructions .
I arrived at the outskirts of MILANO I passed santhia ,cariso the most well know truck stops /parks /eating houses for all non Italians even they used, them ,however at that point of time I had completely no idea what they were or took any notice I was to busy looking around thinking how did I get here and bloody rice paddy fields ,I was amazed I had no idea they grew rice in Italy I did not connect,[rice/pasta] they way the fields were ,some were flooded some were dry just like the far east films of rice paddy fields I expect American troops to pop up like Vietnam ,also where did they get the name[paddy!! Fields]from ,as we all know paddy is a christen name for men in Ireland a shortened name for Patrick I think.
I was expecting for all the country to be a mass of mountains that was my view because I did not know any difference as Aosta is surrounded by mountains but it does not take long to be on flat country
Iwent past about two service areas ,the mileage,[ kilometres] signs for Milano was getting closer also the traffic was building up, and I was starting to get slightly ,not worried but apprehensive trucks were flying past if I miss a turn that will me being zb, it was only me who did not real
Eventually the roads take you around the “tangenziale around Pero area the signs say BOLONGA ROME that made me feel a lot better to be honest it was quite straight forward ish follow the sign to Bolongna easy i was getting to confident I knew it was time to get my proper head on if I miss my turn off I have no idea if you can just come off theses roads and turn around like a round about I have not noticed like two bridges when going under a junction coming up,I will soon find out no doubt.
It was the main road south I mean all the way down this coast road goes all the way down past Bari .Brindisi on to Taranto if you needed to go that way, over the years I got to know that road like hundreds of other uk drivers for catching the Greek ferries ANCONA was not the route then.
However their driving skills ,believe me total confusion ,the Italians can make 3 go in to 2 in their driving however a after time I did get used to it and ignored all the horn blowing they were mad speeding
I did find my way you could not go wrong really but it was all new I did arrive at the loading place Faenza just above Forli something like that ,a peach and nectarine pack house, other UK and Irish fridges were there all rear doors open, drying and letting the air in to cool the fridge they were .all empty
At the office I left my CMR and went and joined the other drivers lots of leg pulling and banter ,I did listen a bit and found out some had been here for 2 days the weather had been to bad for the fruit to be picked.
Do I ring the office ,I asked the others how long to get loaded and they said it was normal when collecting fruit you could wait for at least 3/f the weather is not good once the fruit is in it the pack house it gets washed and sorted and packed in trays it did not look good there were at least 8 trucks waiting to load, the buyers in England want it like yesterday day, I rang the office after a performance getting to use a phone ,[you paid for the call] I just let them know what was happening ,good job I did ,they stopped another of our drivers coming here they told me , ring when you are loaded and ready to leave .
This is my first of many ,many, stops at pack houses. After many years I learned to forget the phone until you are ready to leave unless specifically told to ring
All loading went well lots of ladies in the back of the trailer with little wooden mallets it was all hand balled loaded no pallets and the ladies tapped all the wooden boxes up nice and tight it was a unusual sight
How they worked out to finish right at the back doors I will never know, I was told by another driver to put on top of the fruit ,where the trunking for the cold air from the fridge comes on to the load cardboard sheets, so after about being half loaded you had to be in the back of the trailer doing that as once finished you were unable to climb on the load, it was to stop the very first lot of cold air from the fridge freezing the back pallets as it would be roaring like made to try to pull the temperature down, I did not let on that I knew
Bring the temperature slowly by the control dial on the front of the trailer, I could bore you to death how you did this step by step, it was like using your central heating gauge at home gradually…once THE FRIDGE got to a normal fridge working noise not going daft you would be about right if you have never done it before it takes a while to get it done right ,it is not like the trailers you see at the supermarket depots just switch on and leave. There was a lot to it. other may not have know about.
The local custom clearance then up to AOSTA for the main clearance that would be the next day lots of roaring fridges getting the temperature down to the correct transit temperature
Later onthe fruit started to get palletised boxes were put into a chill store before loading however you cannot be sure as to every pallet loaded will be the correct temperature, what they do is send out the first pallets at the correct temp then the rest are warmer ,no loading docks, all are pushed in by pallet truck after being lifted up I learned all this over time ,not in the first trip. I was green. And soon learned
I did latch on to a owner driver who was subbing for Roklod and we had the same delivery so that was good, what he did I did however he kept jumping off the French auto routes me thinking this was a better way ,however he was saving money I did not realise that
. I was learning a different route .there was a different route around to miss Paris both ways I think they called it “THE HO CHE MIN I never used it it was mostly drivers saving a few shillings the office told me when I started there was a reason why the autoroutes were built use them…
.How he worked his tachograph i have no idea as mine was shot away it looked like a child had scribbled over it thankfully I did take it out a few times just to look at it ,we never got a pull In France next stop Calais
All went well shipped over to Dover ok custom cleared and away It sounds all nice and easy it was not ,my eyes were hanging out ,to be honest I was having serious doubts as do I want to carry on doing this job, stupid long hours we always seemed to be on the “hurry up”not getting paid for all the time you did, but accepting a salary i had to convince my self that the time off in the pack houses was” my” time and it was, however sit in the sun was all you could really do and hope you got enough time off at home to compensate ,the money was the same, the old carrot if its to hot in kitchen get out ,there was no one making me stay in the job, only me,was ,it better than being covered in cow [zb] ,yes.or shift work yes.did i enjoy it the work i do, yes.i am the best man in the world to think ,yes i/we will do something, then i can talk my self out of it, a good quality to have ,who knows,over years to come i certainly tested my self “press the self destruct button”
We both ended up tipping in a supermarket main distribution Harlow if I remember correct , sometimes there would be more than 2 trucks loading for the same people and from different pack house however you would have no idea ,that is why lots of drivers threw running legal out of the window, to get back to clear first and be first.
Trying to stay legal was getting a problem the bosses wanted good clean tacho cards but wanted you to be just like owner drivers ,because the firms were saying we do not pay speeding fines, they all said it but still wanted you to do it and we did like lemons, [off your own back] because you wanted to get home quicker. It will never change.
After time the work got varied you could never tell what and where you would be, doing any load you would get sent from the north to the south if you were needed ,sometimes I would wonder how on earth is this paying, not my concern you knew the loads would be regular ,lambs from the Midlands and the south
.Beef from Midlands ,west country, home counties .
.Pork Lincolnshire area regular work loading at abattoirs. How it was all decided who had what I have no idea.
We also had a lot of uk work cold store movements too much to go into detail however I did not like it at all, to me it was like van boy work the odd pallet here and there just like shop deliverer.
If your face was not the flavour of the month 2 weeks of uk work would sort you out, some liked it and some did not.like me Then out of the blue would come a cracking load ,and the office would make you think that they were saving it for you ,total ■■■■■■■■ I never refused any load ,how could you but some did…
We had a lot of dairy type connected work and it was very good, yogurt was very popular and of course the milk marketing board sourced the products from European country’s cheese also. As the trailers were now coming in with no meat rails and much lighter and able to get 20 pallets on the floor.
I am not sure when the lighter trailers came in I am sure someone will know ,later on they had no proper chassis ,who would believe that.
I was now a permanent Rokold driver also the fleet increased with drivers as well as kit, however it seemed as if there was always a driver or two without a truck, some drivers always had the same one, however a few of us seemed to have to share, ,not the best of worlds the main thing was once you had one keep it ,you could end up doing your job because you liked 3 to 4 weeks .
We did have some good work though we used to go all over EUROPE and back load in most of the country’s you were unloading in ,or sometimes you would transit 2or3 other country’s to get to your loading place you would go to many out of the way places
Wine collections from most of the wine regions in france ,you would have the address of the first collection given to you by the office mostly the biggest wine producer in the [VINE-DE-ROUTE] AREA that is what you would follow ,once at the first you would receive a massive “telex it looked bloody frightening a mass of names addresses number of cases ,to be collected then, when you got to the vineyard the count would be different more or less cases, there were at times as many of 15 collecting points along the vin-de-roue the tourist trail At each small village there could be .
Two collections, from vineyards the way in and out all meant for a horse and cart sometimes it was like going in to some ones garden ,not a new forty foot trailer I soon learned to do the walk in to the property first, go up to the big old doors ring the big bell and wait, sometimes a zb dog would come bounding round from the back some of the dogs learned English[ zboff] then the owner would arrive and go in to speaking FRENCH not a word did I understand I would just shown them the telex and pointed to their address ,like all foreigners they wanted to look at the whole lot, just being nosey so a tug of war would then begin ,id would say for zb sake ,and point at them then at the address, they knew ,I bet they thought lets zb the English man today and they usually did, so I might have dropped a case or two of their wine touché
I did notice the french trucks doing all the collections were not the trucks you will and did see delivering wine in to ENGLAND they used small 4 wheelers Some towns did have a main collection point and useda Danzas depot where all the customs was done but in the country no. also you had to handball every case of wine in then ,the owner would gently put the cases on the floor at the back of the trailer while you had to lift every one stack it up you had to decide how high to go ,layering it downbecause you never knew what the next collection was ,the telex was old by the time we got it orders changed.
You tried to keep each collection together if not you made sure all the labels were showing to the front once you started loading the front of the trailer looked like a mass of church steps ,not knowing how high to go best rule was stack it high because once before I never had enough room at the rear and the front was lower and I had to make a hole in the layers of boxes and move a lot to the front in fact the loading order was well and truly zb up by my inexperience but a good lesson learned
W herever you went to the small places they would want you to have a shot of their product you had to keep your[not silly head on],I must say I have collected from most of the wine regions in France and it still tastes like diesel .if you were lucky you may get a one hit wonder collection all on pallets loaded at a large vineyards warehouse where you got treated like normal just another driver no samples ,.but no handball also you may have a custom clearance near you or you would have to go miles to the next major city and find Danzas.
Danzas cleared most of the loads sometimes you may have had to load out of a Danzas depot or top up the load with extra drops if the trailer had room it was all worked out before you even got the telex
I got to learn to check all of the pallets going on ,for damage ,also missing cases they were nearly all shrink wrapped but you would not really know, by doing that ,they new you were aware of what went on, also they let you in the warehouse to walk around your load, no intensions of picking the odd case up “by mistake” it was mine-sweeping exercise, cases have !! been known to be taken off other [trucks] while on loading bays. if the warehouse goes for the dinner, pull off the bay ,and shut the door…just a tip,
One trip I had a full load of ice cream from Tewkesbury to Lisbon it was a regular run for some companies but new to me and I was allowed to take my wife with me we had paid for our own insurance [holiday]the only trouble was the ferries, and my wife did not mix .
Poole Cherbourg Truck line used by myself countless times
just a point =
Before I started they used to load the lorry’s on the ferry ,then fly some drivers over the next day as there were not enough cabins. The tales were that the plane would buzz the ferry at sea ,yes it is true but I never seen it ,.back to the trip…
After the crossing and my wife sick all the time I felt like flying back .no sleep looking after her.
Once docked and on our way it all seemed to go well until as in transit I do not think I went into Irun compound I honestly do not remember. I could have done However as you come through the border either from Irun or transit through ,you end up on to the same bit of road with not a care in the world until I start going up the hill ,very close to the border
You are now in the redcaps -Basque area the usual 4x4 with the police Basque, not garde civil they were waiting like money sharks ”come to me you foreign driver, they pulled me I think it was a parking are ,[all you regulars will remember I do not ] a foot bridge went over both tracks of road just where they pull you in I had been pulled before no problem.
Forgetting i had a replacement Mercedes hire truck in their normal dull white colour with the normal ROKOLD trailer i was sure there would be no problem, I had all the paper work, got out the truck paper work folder all checked then they went for the insurance green card ,no problem ,it covered all the lorries run by ROKOLD, however I had not got a backing sheet with the number of this [registration ] hire lorry it never crossed my mind well I would not have known, I had a typed form stating that it was Rokold hire , Captured ,.over the bridge I go to a little green hut, many drivers have been here before it was just for that purpose. Insurance office, they new .
I was fined and had to pay for transit insurance the amount eludes me I knew it put a hole in my money as I only used to have our float money also 2 euro checks in case of a emergency and a few quid for-our selfs, .as I was a self caterer i only wanted water money and the very odd meal out
.I remember when I got back to the truck with these 2 nice police men my wife said is it all right so I threw my wallet on the ground and stamped all over it and said these Ba–ards have taken all our money…they looked gob smacked but to no avail I was waved on…
It was down through Spain a round Victoria ,Valladolid ,Salamanca, on to Badajoz the border then in to the “lovely” compound in Lisbon ,my wife could not believe the shanty town and poverty .pre EEC membership.
It all went my wife had blond hair ,well you would have thought she had come from out of spacein a restaurant the kids all wanted to touch it .we did not go very far
The bog was a classic in the customs compound it looked as if elephants had been backed in and dumped their loads ,worse than Greece.
I was on sh-t house guard whenever she needed it ,there were other English drivers regular to Portugal they were helpful some liked their drink more than me I would put money on some supped as they drove.
.We got cleared no dramas’ and unloaded ok ,temperature perfect, minus 25 the product was “funny feet lollies” once unloaded we were up around near shanty town I still could not get my head around the abject povety ,in such a city stepped in history ,there was a definitely them and us in their society
The temperature was very hot and that poor old fridge had been knocking its nuts out at -25
peace at last, it had stopped, although to be honest the noise of the fridge did not really bother me I think my wife was pleased all though she did well every night it was blasting away never switched of from the minute I left we were top deck on the ferry so that was ok.
I cannot remember where I phoned the office from maybe I went back to the clearing agents, for reload instructions, the return load was go across Spain to Valencia, what I repeated it again and it was yes to the airport Valencia you have been to the pack house before I was told.the directions would come to me once I was on the airport road I new that.
Jesus right across Spain in the middle of summer no air-con then ,not good, all I had was 2 of them small fans on the dash, very popular ,they run off the ■■■ lighter switch about as good as chocolate tea pot ,it was like a convector cooker they just moved the hot air around, I used to have one of those plastic air catcher things that sat on you window glass and you wound it up tight to the top of the window it deflected wind-air in the cab but soon broke.
I doubt many have seen, a ships portholes with like half circle of metal sticking out of the port hole it was to catch the air to go in the cabin the same type of thing for truck windows did not last long.
I would put the fridge on -5 when we stopped get up inside the fridge and sit in our chairs in side it was job to get my wife up in to the back of the trailer ,no lifts but I had put some rope hanging off the meat rail just for the initial pull up in to the trailer from the back bumper bar. not for long as the flies would somehow get to know where you are ,yes I have forgot to mention flies and mosquitoes what a pain in the arse they are when your trying to eat out side and in .they put the mockers on the job ,until you get back home, forget about them ,and come back again for more…
No European driver went anywhere without a folding chair summer or winter]…however we made across no big hardship to be honest, once I got there ,c.m.r. to the office there was no produce picked for today nothing to load until “ tomorrow ”just what I did not need the heat was getting to my wife the hazards of having them with you, I thought quick load ,big licks out of Spain next stop DOVER well not quite .
I got permission to drop the trailer and we bob tailed around town just to get air bowing to cool the wife down-ish the massive Valencia has a wide ring road with flood culverts just like America massive in width
, Mc Donald’s was the next stop it was the only shop where there were guards, armed security…a bit off putting however it all worked out ok that day
I drove back to catch the office they told me that there was only enough strawberries for half a load they were processing them then the rest tomorrow so long as it does not rain tonight rain we were praying for rain ,but that brought humidity ,another close night, windows up to keep the mozies out, not happy bunnies
Then in the after noon of the 3 rd day a massive gang of workers arrived and all the action started it seemed the produce was already in the fridge all the time I suspect the price was the factor… they had just got to box it how I suspected I had not one tractor or lorry arrive with any produce ,unless it did when we were out.
The only problem I had was that , I had been up all day again with very little sleep and I was told that once loaded they would fire me off to clear near the border at Figuras- roses, and not first at Sugantu that would have been normal…then on to Figuras -roses .I let the office know what the crack is and at I am chasing through the night to get cleared the next day then chase on up through France.
After getting loaded “strawberries “it was well late the papers were given to me and the T form or T2I it said FIGUARS ROSES]
I think it was about 7pm when I finally got away the fridge set about +5, to see how the temperature went, I would stop in a hour to check it if it was on tick over, I then knew that all the load had already been in the chillier all the time ,I set the gauge at +3 and the fridge engine went straight to tick over .
By the time I was rolling my wife was fast asleep on the bottom bunk, cool air coming through the windows at last, I needed a jumper next stop the customs just before the border at figuars roses it was another bloody night mare getting parked up it was dark when i got there getting parked up finding the agents you could not afford to be asleep, as every one will pass you and block you itime for a good brew.
If you have never done revision, it was the same as I explained before in IRUN the quality of the fruit the sugar content etc is all checked by the Spanish authorities they all take what they want ,you cannot back on to a unloading bay until you have your agent there with you with all the paper work its a [bun fight]also being right hand drive you are always backing in blind side all bays are geared for left hand drive I can tell you it is a pain in the arse no one gives you any assistance unless another English driver is there .it is/was not all honey you had to stand your ground .
Imagine your in ENGLAND and you are next in line for whatever a Spanish driver wants to get in front of you, there is your answer zb em well that is what the Spanish were like . not all, because some established firms doing uk new that you would all be in DOVER at the same time or even a market at the same time. revenge is swee the rest of the trip went as normal my wife had just about had enough and ready for home, one of the main reasons we would travel together was that we would be together 24/7 10+ days would be enough for us both…then I would do the next year without much has
After about 3 years I had been with PULLEYNS a long term driver went in to the office to work as a traffic clerk years ago it was the natural progress of older drivers to go in the office but this man was not old, however he had been with them from the start-ish ,and he was not my favourite person PULLEYNS fleet had really grown at least 20 units if not more and all the smaller trucks they had a contract with TESCO to bring fresh chicken out from FRANCE and deliver it to all TESCOS hub depots for onward shop delivers ,some of the trucks were dedicated just for that work any overflow and general fridge men like me ,would do the odd load.
. My so called ex best buddy gave me so much local work that in the end ,i just rolled in one day asked to speak to BOB NEDOMER the 2nd boss one of the nicest men you could ever meet and told him my problem with all the local work, but as management they have to back each other up so he said nothing he can do give it time, it will work out i did appreciate what he said and could see his side of the story but my mind was made up, time to go that all happened within a week.
So it was goodbye .if any one was leaving and put notice in they would have to go there and then ,no notice worked ,you would be paid up in full there and then, get your gear and seen out of the yard i do not blame ADRIAN one bit as some one with a grudge could do thousands pounds worth of damage to the fleet ,but we all new the system you were told when you started and if anyone was ever stroppy or threaten anyone drivers or staff ,no matter who you would be escorted off, and you would not mess with the man . Not for me
So now i was slightly zbed I had done it as i had only just started back on my 3 week turn around i had all my gear in to my car and drove away …my own fault but you can only do so many inter cold stores it was like a van boys job some of the lads loved it but they had done zb all before, in transport anyway, and that is the type of driver they wanted now so i was better off away ,or so thought.
I had some cash all my monies due were paid ,and my salary went into the bank to keep the wife and home going ,so it was now down to me to get a job
IT WAS NOW 1990.
I knew in myself i could go and work anywhere on dry goods or fridge haulage on European and the reason for leaving was not nothing to do with conduct or problems I just did not want uk work.
.OPTIONS not a lot ,i had a diary with lots of companies and drivers names and phone numbers, i did not have mobile phone so i had to use the public phones s i will start nearest to my home… nr Banbury.
T WAS NOW 1992
.OPTIONS not a lot ,i had a diary with lots of companies and drivers names and phone numbers, i did not have mobile phone so i had to use the public phones s i will start nearest to my home… nr Banbury,
The first call was to ACH Aylesbury, i did not hold much hope but here goes ,then iRokold .
I spoke to Dennis who ran the office told him my story quick and he said come in the morning 10 oclock David Fowler would see me then ,i thought i wonder if they would remember me, i would have to wait and see,
That day I drove to Aylesbury booked in to a pub for bed and breakfast I could have gone home however at the same time my wife and her sister were in Blackpool looking for a house or bungalow or us .
A.C.H had moved from the village and were now on a factory estate I found that out when I went to the village where they used to be and I was given the address where they were now ,i found the yard ,drove in slowly and seen a visitors parking space and parked.
Dennis was there behind the counter, no handshake. , hello,what can i do for you,
As re- my phone call yesterday i am here to see if you need any drivers, at the moment as i am now not working, finished yesterday at Pulleyns ,please ring their office if you would like ,i did have a misunderstanding with a ex driver who now runs traffic ,and i decided it would not change ,so i thought it would be better for me and the company if we parted and you are my first call,
Well ok he said David will be in soon and he will make the decision, just tell me what you have been doing.
I told him all the countries i ,had been driving to and it was fridge work, and dry goods in tilts special trailers used for European work,and the border crossing etc procedures i knew.even Swiss.
Once Mr Fowler arrived ,[the bosses son] the interrogation began he wanted to know the ins and out of everything i had done connected to transport any this or any of that, accidents damaged ,done by me any insurance claims ,the whole lot any problems with fines abroad with the police ,a through grilling, as this was going on in walked another man his dad ,the boss Mr Fowler, he sat on the edge of the desk listening after time he said, you have worked her before haven’t you , and i replied yes for a short period years ago ,i did not have reliable transport ,He said have you now ,yes was my reply
I have been working 3 weeks away, and then my time off for the last few years and it works well for me and i still live where i did before about 40 miles away, he then said I only employ drivers within a 25 mile radius from here and you are out of that range .
I then replied yes, however i do not mind where i take my weekend brakes at all it can be anywhere ,to suit you, here or abroad.
He then said go and get a coffee from the drivers room on the other side of the yard and come back in 15 minutes that is what i did
Back in the office they asked me to go in and they offered me a job there and then. no particular run or unit to drive ,3 weeks here then 3 to 4 days at home wages were not mentioned ,and it was weekly pay. Kept here when you are not here ,no company [zb] or company book of dos and don’t just do as your told ,and that was that
I was not going to go home so i asked if there was a spare unit i could stay in until i got sorted out with my own and that was ok.
I could not give you the whole rundown of what type of work they had, they had to much to single out, this is what what i did.
they were a very well organised in the equipment they used ,the warehouse the clean trailers and 99% of the units were top range high line sleepers Volvo or Scanai also i knew a few of the drivers from ferry crossings some were not the most friendly, after time i knew wh
Import loads would come in all days of the week from mostly ITALY ,SWISS, GERMANY ,summer time from GREECE [FRUIT]
Some trailers would be dropped in the Aylesbury yard or some in the Kodak yard at Hemel Hempstead they were one of the main contractor or sometime at the AVON cosmetics yard in Northampton,
There was always a good reason for what they did it was very well organised the older long term drivers never had to mess around with tipping [unloading] many of the trailers,
There was also Patricks of Kettering they seemed to run in line with each other so you might get the odd load left there ,you were never ever able to sort of plan what you thought you might end up doing as it changed all the time.
That was good sometime but it seemed that all men were all running around.most drivers were treated the same Export work from the local area was a well oiled machine.
Typical day, start from the yard 6 am ready to roll you could have a trailer with 3 drops around the midlands ,never further north than Stafford .
After unloading that, you would maybe go back empty to the yard very unusual, or drop the trailer in to the Kodak works near Stafford and probly load it, or take one that was a full load for export but different delivers’that would be straight back to Hemel Hempstead, and some one would be waiting for some of the load on itand some to be transhipped ready to go out asap ,you would guarantee when you got there would be no free bay to back on to.
You would go inside to see the warehouse man he would say right pull that one off the bay…back yours on.we will only take half off ,take it off the bay.,then put the other back on, and then another one on ,the other bay needs closing up and pulling of the bay then that has to be sealed up [customs].all you do is end up shunting.but that was the way they utilised every one of you working hours if idid not like it icould go home no one never said that to me but I new the crack
I would bet you would never go to Kodak and pull a trailer out and getaway on a export run with out shunting trailers of course the office new that is why you were sent there free shunting.and if some one had pulled you trailer off a bay and not properly put the cord through the back rings down the sides from the top you would have to either back on a bay or drop the trailer and use your unit to stand on the catwalk to zip it up… very nice especially as you had to get to DOVER
. You had to make sure by 5.30pm any day while you were in the UK you had rang up to get your next days instructions-they knew you had a 15 hour work time spread over and the days driving would not be more than 9 hours so you might have to wait at KODAK until a trailer had been finished loading ,get it sealed up ,and take it back to the yard ,as someone would be coming in at 6 am to go export with it and you would be just in your spread over time and knackard.
You could well end up with another 6 am start and do the same again and that is what i did but i never moaned to any one just got on with it. I knew in the end it would pay off and that is what happened they decided to use me on Export .
One of the most funny things to be seen is a bunch of grown men scatter like buck shot when a certain car comes in to the yard ,around 9am and that is the car of the boss Mr Fowler, a red jaguar .he is like a shark looking for prey,
Most mornings there would always be at lest 3 or 4 drivers hanging around waiting for a load or unit from service so the job would be, put trailers through the useless old wash ,just water no chemical and the wheels had to be done it was a 2 man job ? also a space for 2 units to be washed, there was always units to be washed ,they never supplied any gear, washing up liquid, there were bald brushes ,old shirts, but it was to look busy.
If it was all done and the trailers were parked nice and neat in the lines , drivers would be in the brick built. tea hut plus toilets, however that was frowned upon by the boss in his eyes you could be tiding up the yard picking up litter,all types of jobs in his eyes, have you ever seen 3 men trying to get out of a door all at once because a red car has started to turn around the yard like a shark, cruising for his next victim
After about 2 weeks i was given the usual daily run around but with a export on the end of the day they new that was the bonus extra cash, it appeared no one spoke wages to any one else every one got different or else drivers would say it did not take me long to find out how,a long day but ended up in Dover i was glad to be back hoping to get in the rhythm of export .
I soon realised all was not what it seemed regarding the taco graph and the use of.the ferry i was booked on mostly to Zeebrugge meant you never had a proper break until the end of the next day men before me must have just queue up in the truck export lanes, and took what sleep they could load the truck on the ship at 6 am 4/5 hours on the ferry by the time you got off, [in theory] you had had a long break the truck might have but you certainly did not.
,After running straight at PULLEYNS i was amazed at how bent we were on A.C.H if that was the way,so be it. Over hours .no card inwell one in and out again.
I would be here for ever, telling you all the tricks we used to pull, but no one ever said a word, all the loads had been done a hundred times to the same customers it was standard practice we all thought it was good doing this and getting away with it.
One job sticks in my head is the “Kodak factory stutguart” after leaving Hemele Hempstead , you would go down to Dover,catch the Zeebruge ferry,after clearing customs ,once you get off at Zeebrugge from the afternnon boat get
off late -ish Saturday evening ,top up with diesel , no time for coffie your mind was set on driveing straight down to Aachen
Once at .the border you start your brake, parkup on the Belguim side … it would be about 3 to 4 am Sunday morning.Belguim was the same as England you could drive any time, different from GERMANY.10pm Sunday night.
You could be parked at the front of the queue in lanes however by the time the Border opened up it would be so jam packed with trucks mostly Belguims it would be impossible to get out,it was never easy once you had done all your paper work, customs permits etc we never used a agent ,as the goods got cleared at the end destination once you got the hang of it after quite a few times it was easy-ish other drivers were the problem by not being in their trucks to move as we were all forgieners no GERMANS TRUCKS
10 O CLOCK Sunday night you would start driving in GERMANY that was if you were in GERMAY but we were not it coud be well after midnight before you managed to actually get out of the border
,you drove down to KODAK STUTGART after one break, by the time you get down there you are about out of driving time, so you would think that normal thing to do was to drop your trailer in the factory and leave to their shunter to move around the factory,…
No chance you have to do the shunting for them in their yard also some outside delivers to other KODAK small factories you would be at it all day you would end up unloading other men s trailers who had been to the factory earlier the same day and they would have a empty one and go off to load somwhere …As some left England a day before you and were parked up at the factory Saturday…
It was all preplanned at the office nothing on ACH ever happened by chance ,you would do the same the next day after a sleep, go off with a empty trailer but not the one you brought down with you and re- load sometimes you had 3 collections that card would go out of the window
It looked as if you had had a 10 hour break on the card it looked as if you had done nothing all day,it was like magic
as some of the regular loading points had a spare right hand ACH unit used to go out and pick up colletions.for your load and for others to be left inside the warehouse that is how the tacho got theno work break you was not in it.
You could end up leaving at 10pm at night and drive back to the border if you had time so as you would be able to drive to ZEEBRUGE ,then the penny dropped you had got in their system, of going back to the depot in England with a loaded trailer, drop it off in the yard , pick a loaded one up and away again you got used to it.
The same system worked in ITALY ,NORTH OF MILAN ,in the middle of nowhere, Avon cosmetics from Northampton had as factory there some of the men were on a regular contract and had box vans and kept them all the time , unloaded and loaded them or picked a loaded one up ,good job as they had their own customs clearance at the factory we never had to clear anywhere else not in the northern area of Italy.
However it was never done fairly .you may have brought a trailer in to Italy with one drop and you would think yes that is good quick clearance and away, you could bet that would not happen ,one of the longer serving men may have brought a trailer from England to ITALY with 3 or 4 delivers you could bet he would have dropped it in their yard and gone off with a empty trailer and left it to the likes of me, however i was not on my own there was a few of us.
But i used to think while you are doing this you are doing nothing else.but i did respect loyal service should have its benefits and that was one of them.
I never did get in the A team,i did nor expect to because they knew i would be off whenever iy suited me [no loyalty] but the money was always good you could never work out how you got payed , was it hours, or loads or price of jobs, it was worth the effort and hours while i was working there my wife and i moved up to BLACKPOOL so i thought why tell them so i did not for nearly a year but they new when they had to phone my old number,my son had brought our house so it was still in the same surname and his wife told all,unsuspectedly. i was surprised when they rang me at home ,too late then ,i expect that was another nail in my coffin ,but as i said the money was good they had two choices .let me stay or go.
.however
A well known driver who lived in Appleby at least 250 miles from Aylesbury had worked for A.C.H for many years , not being local ,sadly he passed away while working for ACH in ITALY and i got on well with him ,what i am saying there were now 2 off us not local now and eventually more came from farther afield…
Mr BOYCE,was one of the few drivers who used the train from Koln to MUNich Saturday night to get you to Munchen Sunday morning. ROLL ON AND ROLL OFF .it was mostly for other foreign trucks and something to do with PERMITS that were used back then also it was a ■■■■ up ,so i was told and knowing the driver it would be right
. It meant that you were on your weekend break, but moving not driving you had to drive on and off but it was legal. And you had travelled that would have taken you at least 9 hours driving it was for the Avon cosmetics contract for just outside MUNCHIN
have been there a couple of years when in March 1994 trouble in camp . David Fowler the now boss ,and me never ever got on at all ,he was a verbally bully, how some of the men put up with him i will never know .
He knew i was not bothered ,i said once to him “i have had bigger and better bollickings, of better men than you” so but i did know when to stop as it was good money and not many jobs paid weekly and good .
However he did give me many loads of KODAK to GREECE because in the summer the photographic paper had to be kept at a even plus+15 and i was a fridge man ,and fruit would be also be the return load from mostly Italy, many other drivers also did the same , it was not difficult to do .but it used to surprise me because of our non happy relation ship that he gave me the loads , but i still did not like him one bit…
.LATER trouble with the MINISTRY OF TRANSPORT taco graph offenses.
The company will be paying all legal bills and will also in mostly cases if not all, meet any fines, that you face please discuss this individually with the company.
You have to plead guilty to… etc … niall Quinn =legal executives.
What the most amazing thing about all that was to take place ,most of the drivers did not have the slightest idea that we had all been caught and how many offences ,we all had god knows, i do not remember ,to be truthfully honest "no one driver knew"no one told us,we even did not know when it went to court we did not get told results of the court ,we were all as bad as the next man, so ye,s i hold my hand up and we did it "my lord"and they did pay the fines so some one at lest had that decency to do that who god only knows.because we all benefited from it .
NORBET DENTERSTANGLE were getting involved with ACH then, i was there when they did we were still going out of Calais the old road and we used to fill up at Norbert Dentrsangles depot for fuel.in fact it used to work out ,as we/i used their depots in france when transiting , for parking .having a dump.
Once things followed the ministry accusation, all types of rumours were going round and we were still messing about with the cards in Europe, but after time the office told us to run legal ,great, but some would or could not.
When it came to the interviews with the ministry man at the office, in David Fowlers office we knew they were paying fines so no comment on all questions the ministry men asked us.
However when i went in to be interviewed “.this is true” we go through the [zb] bit after the no comments i said to this man, do you know whose office this is,… he said yes…, so i said, well he will know all you have been saying,… what do you mean he said … i said he tapes all the conversations he has in here…how he said … i said look under the desk there will be a tape player…and he looks,that made my day, and said no there is not… ahh well he’s moved it it does not matter… .then he said, have you any more to add to the no comments ,i said yes.what he said … I SAID MR DAVID FOWLER IS A VERBAL BULLY…and the stupid person! said what do you mean, i have never heard that before… i said i rest my case ,and walked out .
To this very day i do not know what charges i had or what fine was paid my behalf ,at lest we never had any licence convictions. by the time all that in court happened i was long gone…
I think there were about 45 offences in total that lead to the loss of lorry Licences how many i do not know also NORBERT DENTRASANGLE had the running of the company however ,as a driver you will never know the full story, but it was obvious the FRENCH, wanted the good work that ACH had
why i could not settled down like a majority of drivers .
I AM going to write down different experiences that happened to me! all self inflicted no one told me where to go ,or what to do it is all purely on my own head and did i regret it,… no
Men that have stayed with the same boss, or company for years do so for many reasons they live local ,i have never had that, all kinds of things made me move on,i think it was when i was on the cargo ships as a deck hand AB in the end, when younger ,once you had got a year or two under your belt i.like hundreds of others would join ships going to whatever part of the world YOU wanted to go to, an my its a big place mostly it was what most other men did.
A lot of drivers mess a good job up ,because they only think of them self’s and they want to be home ,before they have even left ,and they go out of their way to show off, but the boss is laughing at them most of the time. it was always something about the job i did not like.
I did part company with ACH the way it was done was partly my fault but also petty in house squabbles .
Once NORBERT DENTRASANGLE had started to get to grips with ACH things did not seem to change for a time however the trucks were starting to be re sprayed RED and new MAGNUMS started to arrive and the long time served drivers were given them to drive and i was ok with that ,it did not matter, i would not be having one ,however it did mean that the better VOLVOS would be handed down the ranks so i had a reasonable chance to get a newer one they were all in good condition also the majority never cooked in the cabs except one .
Every time a trailer was in the yard loaded or empty it would get put over the inspection pit for the fitting staff to check it all over and tyres before it went any where near going on export,you in fact could not fault anything with ACHat all it was just me, i never ever heard of any of ACHs trucks or trailers break down any where on the continent, so good maintenance did pay off.
We knew no difference who was running the firm ,our work was the same although we never had any French deliveries, plenty of Swiss ,Italy , Germany.
There were always rumours going around about this and that, all started by drivers just a wind up. however we did have different people in the traffic office at times and one women in particular was very popular as she would tell you what you would be doing when empty different from all the others.
Also her husband, a driver for Norbert dentressangle, who was French and she was a northern english women, Manchester area ,over time her Husband Patrick got to know most of us drivers as we would see him Dover or Ashford truck stop it seemed as if we were getting more weekends away in england,no more flying home through the night like ghosts, not to been seen,we thought, that all stopped, instead of all trying to get back to the UK.that was the old way.
After time Patrick and his wife moved on ,she went to run a Norbert dentressangle depot north of Manchester at HEYWOOD .
All the trucks there were A frame road trains left hand drive .
I was in ASHFORD truck stop for 36 hours ,[years before we would just have ran home but not know] and Patrick was there i asked him if i could have a go at learning to reverse the Afram trailer he had , it went quite well, one thing i did not think about was that there were some other ACH MEN at the truck stop and they had seen me, i [found out after.]. i had got the basics , he was based up at Heywood and his wife was the transport manager also they were recruiting drivers , while i was there with him at Ashford truck stop, he rang his wife at home ,he explained ,i lived in Blackpool and wanted a change
plus nearer to my home as far as i was concerned it was a no brainer ,the same company i would be able to handle the truck after a weeks training.
I had a week to do before my break to go home so that could not fly quicker enough i was on a short run to SWISS KODAK,AND A LOAD BACK OUT FROM COMO tractor axles to massey Ferguson at Coventry, a no messing about load but it would take my full week up…
Once home i think a TUESDAY morning i arranged a interview with Michelle the manager and she said come right over that is what i did
once i got to the Heywood depot, she recognised me from Aylesbury and said no need for all the PRE company [zb], when can you start ,well i said i will go home ,ring up and give a weeks notice and work it ,that would be Wednesday to Wednesday, i did ask her what about David Fowler she told me it would ok leave that to me she said,f he gets awkward ,i will tell him your local to the north depot and i need drivers i know, so that was what she did.[allegedly] i have no idea.
I did not say on the phone where i was going to work and they never asked i arrive Wednesday And the message is David and Dennis want to see you in the office, i thought i bet they don’t want me to go…
I go in the office and FOWLER starts as soon as i get in .
WHO the zb do you think you are.
what on earth a you on about.
[him] you and the zbing Michelle UNDRMINDING ME
[ME[ I DO NOT KNOW WHAT YOU ARE ON ABOUT,I CAN GO AND WORK FOR WHO I LIKE.
[HIM] NOT IN THIS COMPANY IT ALL GOES THROUGH ME
I TRIED TO TELL HIM, NO SUCH THING WAS HAPPENING, IT WAS NEAR TO MY HOME ETC ,HE WOULD HAVE NONE OF IT JUST LIKE A SPOILED CHILD I KNEW HE WOULD WIN .IT WAS HIS EGO
WELL YOU GO AND zb YOURSELF IM OFF.
[HIM ] YOU WILL NOT BE WORKING ANYWHERE FOR NORBERT I HAVE PUT A STOP TO IT ALL DEPOTS .AND THAT MICHELLE SHE IS IN DEEP [zb].I AM THE BOSS OF THIS COMPANY NOR HER.
zb OFF, IM OFF.
And that was it or so i thought how wrong i was .i drove straight back to Blackpool.
The bottom line was, he was ■■■■■■■ because he thought we had both undermined him. I had no idea what that even meant. However i did not know this. So i rang Michelle on the way up and she said come round that way to see her, i thought it was all ok .so by the time got there it was 6 o clock at night she waited .It was either [zb] or true i had no idea ,however she told me when i had left, Aylesbury ,Fowler, he has caused so much fuss at head office that she has to go to a meeting with FOWLER at AYLESBURY on Friday to meet their boss DANAIL LETARD.AND SO SORRY THAT SHE CAN NOT EMPLOY M
Well that went well didn’t it.So i am out of work partly my own fault, what i should have done is just left and said nothing then get re -employed but who would have thought that a man would let his ego get the better of him because me a driver dared to in his eyes undermined him.
Once i arrived home and gave the news to my wife it was time for me to hit the phones and try to get employment ,but where to go where you know is best and that is what i did i took a deep breath and rang Pulleyns, and took a chance i had two choices yes or no .
Once i got through i asked to speak to Adrian he was not around so Bob Nedomer came on the phone ,so i told him what had happened at ACH, he understood, and said ring back at 3 o’clock
I rang at 3 0,clock and spoke to him again ,he had been in touch with ADRIAN and the answer was yes ok, but you must do whatever work you are given, an no zbing about ! typical Adrian you knew exactly where you stood with him and the company, so i excepted that and was told to go down ready to start work FRIDAY, it was a bank holiday just what i did not need as i want to be home for a change ,hey ho, that was the way it goes .
1995.
I arrived Thursday there are always men around,also a yard Forman who lived on site with his wife
Once you get to know men,some have their own agendas and Barry certainly did, he wanted to get in the office and run transport I think he had his own truck.from Cirencester way,but iwill state Barry was all ok with me and I with him he would work all hours god sent in that yard ,loading up trailers all kinds of silly hours to get the job done.
He ended up being master of the large proper trailer and truck wash in the yard there was a lot of workings as it recycled all the water used, how god only knows to complicated for me however barry had got it sorted.
Once i had picked the truck keys up from the key locker
Some of the lads who were around were
very surprised to see me back there
Lots of banter going on ,the unit i was given was a Daf 95 twin steer ,any way it was weeks old ,in fact all the units and trailers were all kept in tip top condition the in side was immaculate they alllways looked new ,the blue all over colour was eye catching
I got all my gear stowed away made my bed up on the lower bunk i always used sheets then a good quilt, clothes put away on the top bunk and all my other bits telly ,video, food in the side lockers,gas bottlepots and pans it was amazing how much gear we used to have , or iused tov have it was for 3 weeks +?
I was to see the traffic manager in the morning ,then get my tacograph cards ,then my £1000 float in travellers cheques .i hoped to get away for the weekend ,if you were week -ended in the yard ,you only got UK night out money that was fair if you were away from the yard and loading a export load you would get European night out that was more cash
The office meeting with the traffic manager went ok,i could tell he did not like me being back he gave me my load details ,CMR, paper work for the truck, agency cards no permits needed ,and the verbal instructions, and a unsealed large envelope with a lot of permits and [export licences] for different meats
The trailer was already loaded and in the yard,
I had to go Ostend airport ,it is only a fright airport and the parking is outside the airport just like a lorry park his verbale instructions were to park outside the airport entrance and wait until someone will come to you ,that was it, and i repeated it. Unload at the fright firm Swiss Air .When I was empty go to Holland, address given and load Monday morning,then ship back to Dover The office will be shut until Tuesday morning owing to the holiday any problems ring Barry as he will be on duty.
And that was clear enough for me i pick the loaded trailer up from the yard and check it out ,diesel tyres door seals .put on from the loading point once hitched up i make my way down to Dover and ship out on the next zeebruge ferry after taking the truck into the customs parking so they can check the seals on the doors,once that was done i qued up for the ferry and i did not wait for long,i liked the zeebruge crossing as you got to have a sleep if you needed it or not nice to have a rest .allthough at that time i did not need it .
Once the ferry was docked and you waited for the dock workers to come to the ships hold to take the chains off all the trucks that held them down to the deck for if it gets a bit rough ,some of the drivers never learn and start their engines up straight away to buld the air pressures up so as the brakes will work proply before the main bow doors are fully open so we can all to drive out off “,the place is filling up with diesel fumes .
Once the quick customs paper show,was finished no need to fillup with diesel as we always left the yard with full tanks, no matter where you were going even to cheaper diesel in Zebrugge ,it did not take me long to drive to the airport in Ostend a route i was familier with,once there i parked up outside not another truck in site is was Saturday afternoon i was parked very close to the entrance gate no one could miss me ,as i was told someone would come to me [who i had no idea]from the office.
After about 1 hour the doors open and a chap comes out sort of dressed as a Agent not in high viz gear.and told me to bring my papers to the office in side of the hall it was a customs place .
I passed all the papers i had over to this chap ,he took them and walked away to a office so i did the usual walked out and sat in my cab if they want me they can see me and i just got comfortable.
He called me back over and asked me to bring the truck through the gate,he handed me back my C.M.R. and he pointed to me right over the far side of the air field there were some hangers ,all with names on them different air freight forwarding companies , the fridge was roaring away as it was frozen goods and on a defrost cycle ,under their canopy attached to their office ,i new they wanted my away from them as the noise was deafening .
The chap from the office came outside and pointed to the air fright hangers where I was to go
I could see the men they were using small electric tractors pulling small trailers,at one hanger i drove there observing the speed limit and parked out side the hanger that was for SWISS AIR i was asked to open the fridge doors the customs had broken the door seal under the canopy.
Once the door was opened i could see that there were about 10 very small loaded pallets with boxes on and frozen up the front end ,i thought how on earth would a small load like this ever pay, i had no idea.
A pallet truck was put upon the back of the trailer for me to pull the pallets to the rear and the fork lift take them away ,and that was what i did about 10 minutes of work,once empty the pallet truck lifted off i closed th doors up went inside the hanger for my CMR ,it had been signed a clear signature ,and handed back to me.i got back in to my truck and drove out to the same gate i come in under the canopy and that was me, I was now on my way up into Holland about 3 hours away, i had been to the freezer loading place before so i had no problem ,i knew where i was going to park up on a sports centre park.there were showers inside and a bar a small entrance fee ,another good weekend plus pleasnty to look at,also there was a cafe near by that sold the funny cakes!! However I was not in to weed,just old roll up baccy.
Monday morning 6 o’clock i was out side the cold store i was told to back on the bay and wait to be loaded ,22 pallets of frozen pork legs ,for a pie factory near Bristol knowing the Dutch did not worry about the weight ,i went to the office and said no more than 21 tons full load ,including pallets ,so they said no problem we load Pulleyns all the time with the same number of pallets , ok by their office, so i said if that was normal.
After about 3 hours i was loaded ,i pulled off the loading bay ,closed up the doors put the fridge on to minus -25, then the trailer doors were ready for a seal to be put on by their customs people, in Holland the customs used a piece of string ,then put a lead seal over it Belgians were the same, also i put a pulleyns plastic seal on with a number on that i would write down on the CMR before i signed for it…
After a hour ,it would be around 9 oclock at home ,i thought i had better ring Barry at the office just to tell him i was loaded ,i went for the CMR
In the office and had a look and it said nearly 22 tons, what !! i said to the man look, i cannot take this it is to heavy , he said no! it is normal !
I must ring the office before i leave here i said , the office man said you go we will not take any off, etc,etc.
They let me use the phone ,and I spoke to Barry, before i could say a word, he said thank god you have rang
The traffic clerk at pulleyns [my ex mate] is going ballistic and you must ring him immediately and he gave me his private number i have no idea what is going on.
I get him on the phone and the first thing he said to me was you [zb] the load up at Ostend the [zb] has hit the fan””
I had no idea what he was on about ,he goes on to say, what did i tell you to do ,
I said you said wait for someone to come to me ,and i did .a man came out to me to tell me to come in and get unloaded
He said it was the wrong man,
How the ZB would i know ,i said you never said who it was, just wait for a man to come to me .
He said, that load is still outside on the airfield, ■■■■■■■■ i said, you lying,
No im not he said.
Ok then i said how come i have got a clear signature on the C.M.R.
We will sort this out when you get back, yes we will, by the way this load is to heavy and they will not take any off, he said its normal just bring it back . i said by the way, you know, the meat hooks are still in this trailer there is the extra weight, anyway i want to see Adrian before i go anywhere once back home…yes he said too true and that was that …
Once back in Dover i get the load customs cleared , it is now Tuesday and i will make my way to Bristol ,the M25 was not finished you had to go up the A2 get on the motorway then do left near the Dartford tunnel and get down to the M25 there ,so that meant going up the hill in Dover it was a steep climb ,once up the top it was not long before the MOTOWAY
However there was a MINISTRY weighing station it was called “whitfield” at the top and ,yes you guessed a police motor bike officer was pulling the odd truck in, and it was sods law, if you got a pull or not and it was not my day, and i get pulled over, pulled over the weigh bridge ,they weigh each AXEL separate then total all up to see the gross weight, then they work out which Axel is over weight or how many are over weight , i knew i was ZBed, they asked for the CMR took a copy , and the gross weight was like nearly 40 tons on 5 AXELS.
The load weight]pork] was ok but it was the meat hooks ,and the pallets so they put a non movement order on the truck, not me ,we had to lose over 2 tons of weight however it would be a prosecution and court case also points on my licence .
I had to ring the office with the good news, they said ok a 4 wheeler will be there later and you will have to hand ball 3 pallets off on to him , great ,just what you need freezing -25 and handballing ,about 2 And half hours later another driver rolls up, and we get stuck in, trouble was, the pork legs are all loose inside a wire type of cage on top of a pallet so we had to empty the legs out of the cage. Put them on the floor then pull the pallet and cage on to his truck and fill it up with the pork legs from the floor . after 2 hours it was all done we were cold .
,We had a brew ,and he then got on his way and told me that we were both to go to the yard and sort the load out, i did not say a word about what had happened in case it was not general knowledge. I was cleared from the re –weigh and on my way, at a more sensible weight i must say though that the DAF i was driving was no different with the weight off.
Now the crunch was to come do i go home after 5 days or what??
I pulled in to the yard refilled the diesel tank found a space to park, i was sure all eyes were on me but it seemed normal.
Lots of banter from the yard man Barry shouted a greeting, i bet he knows more than me
I got out of the cab and made my way to the office where the drivers reported as i walked in the foyer b BOB NEDOMER asked me to go upstairs into his office i also new Adrian had a office there so i thought this is it “in the front door andout the back door” someone will clear the cab out ,they will pay me up and gone, back to square one.
Once sat down Bob said right Vic tell me what happened from the start of you coming back, so i relayed everything, what i was told and how , he was taking notes he looked at the CMR ,i gave him my tacographs, so he would see the movements i had made at Ostend.
Also the delivery address written on a piece of paper.
Right he said as far as i am concerned you did all you were told to do ,he said where is the yellow sheet with all your instructions written down, i have not had one.The yellow sheet was a new procedure,like a job work sheet with all your instructions to be carried out on that certain or any job you were given.
I said look Bob if it makes your life easier i will just get my gear and go i do not want to be here with a cloud over my head .
He said go down to the drivers room get a coffee say nothing, do not go to the traffic office and wait until i send for you.
After a time, on the yard tannoy Bob called for Barry to go in his office ,so i thought this is the heave ho, back to the phones for work…
As it turned out i was not asked to leave in fact it was nothing to do with me ,however others were involved and they would not tell me .all i had to do was forget the load in to Ostend the traffic clerk would not be a problem, he has been told he does not hire or fire ,just get on with the work.and that is what i did.
Then I told bob about the overload and he knew all about it he said they will pay any fine incurred not to worry
I had a very happy time while i was at pulleyns we had some really good work, however we had a lot of drivers, and they were recruiting all the time some of the men that came were ex army and made good drivers also good drinking buddies.
I can honestly say i never took anything that i was not entitled to all the time i worked for pulleyn you had the best of trucks, the trailers were second to none never any shortage of running money ,you never had to run bent unless you were asked to and that was very rare,
You went to any country you would never know where ,they would send you.
The war had finishd in Bosina C roatia [Yugoslavia, ] ESTER RANSON Started some kind of charity and Pulleyns got the delivery job thousands of boxes clothes toys all sorts were held at one of Londons Railway stations for loading ,some of the local men who never did Europe went and loaded 4 trailers i was one of the 4 to go and it was a bit hit and miss ,i went to a place called PULA in Croatia .
We had all kinds of paper work with us permits ,red cross papers ,T forms,CMRs we were told that any expenses incurred just pay and it would all be funded when we got back ,we had one driver with us who was a bit of a smart arse ,however he said he new all about transiting a country for free if doing AID work .
When we arrived at the KARAWANKA tunnel in Austria to go into Slovene there was a toll ,so he had the idea that we would go through for free ,there was no one in charge of us, so we all parked up on the hard shoulder and he marched in to the offices, it was snowing and cold, and we were just lorry drivers i bet they thought who the f— are theses 4 men in our office
The fun started ,knowing Austrians they like everything 100% correct ,they wanted to know the ins and outs of every thing, one phone call led to another and so on it went, it was a wonder their parliament did not know about us.
Mr smart arse thought he could speak German, he could order food ,but that was about it, but we would not know [zb] BEATS BRAINS. After wasting at least a hour, at the end a lady who translated arrived, shut MR smart arse up and in perfect English asked why we thought we should not pay for the tunnel you only get it free if its u.nfor. not red cross it went something like that we had given up and left him to deaL with it.
However as it was, lorries had come this way for a long time with aid ,the tunnel company would let us through for free this time only ,so it was worth it .however it was about only £10 each. He was sort of right…
Once into SLOVENIA not any movement at all ,we had to transit to CROATIA it was like ghost town vevery where we drove through was completely deserted. It started to get a bit ere like ,where is everyone we stated to spilt up and go our own ways i had to go to POSTOJNA, RIJEKA OPATIJA.THEN DOWN TO PULA that was my destination it was non stop,
I arrived after a few wrong turns in the town and kept stopping showing the address lots of finger pointing and in the end arrived at like a army barracks, with big wooden gates ,i blew the horn [first time ever] to attract attention the old gates opened ,they waved for me to drive in ,it was full of women , no men to be seen ,i was reversed in to a very large shed like warehouse already,it looked like thoudsands of boxes already there ,someone had been there before, and it was all unloaded by women not a man in sight.
They would not let me unload either, so i sat in the cab and had a good cook up ,once finished the lady in charge spoke good English and said come to the office ,they were so pleased with the load, while i was there in another office i could hear someone talking on the phone, and the next think this lady says to me someone wants to talk to you, i said no one knows i am here how to they know to talk to me.
[.now this is as true as i cannot believe it myself] she says the boss of theWORLD WIDE RED CROSS HE wants to thank you personally ,so i have a sort of one sided conversation ,he is asking me things as if i had driven through a actual war zone .and he thanked me for getting through i thought am i missing something here what on earth was he on about, i never seen any military, what so ever so that was that.
I made a call to the office, and was told to go into Italy make for BOLINGNA.
That was what i liked about working for Pulleyn you were given instructions and left to get on with it work your route out yourself i had a permit for Italy I do not remember if they were needed then ,but i had to do transit customs at TRESTI i was empty one wrong turn, and you would be back in Slovenia i took the bull by the horns when i came upon a queue and guessed they were loaded and what a poor looking bunch some of trucks they were old, falling to bits once i started going past i got no hand shaking of fist waving a right hand drive was a novelty,
Not many Brit trucks been this way for a long time ,i arrived at a compound and thank god there was a sign above, that in my book meant [transito] i went to the Slovenia office ,shed, took my signed CMR ,that was ok ,they waved a hand as if to say go on [zb] off ,and i did ,no problem with the ITALIANs shown him my permit he just waved me on i thought this is to good to be true ,i was and soon on the AUTOSTRADA heading for VENICE then BOLONGA.
I loaded peaches from a warehouse not the normal load from that area back to the uk .all semed to be going ok The company had some very good loads from most countries within Europe You may go to Italy with one of the sliding roof tilts dry freight goods with a [mixed load], and load back trees and plants for garden centres in England the loads normally came from around the south of Florence area ,nice and warm.
Loads of hair shampoo to Hungary reloading from Italy make your own way there, as driving went it could get no better than it was, i was getting no problems from the traffic clerk,! however they decided to employ another man ,as a man he was ok, however he had never delt with any European traffic at all and he did not know who liked to do what or anything, about keeping all the drivers happy ,he was brought in for a reason, he had local work.in the diary market world.
Mostly his knowledge was supermarkets and supply chain we all found out later ,he had come from a local dairy, bulk milk delivers, yes i know the management have the right to do what they think and to make money, however me,i have a liking for European work and not the uk.
You would start the week by loading at Eastleigh frozen meat for Iceland at Queens ferry, timed delivers, then when empty, over to Grimsby and load frozen any product for one of the major supermarkets or 5 drops to Small food outlets just like doing small van delivery jobs with a 40 foot trailer also work for ALDI warehouse where they made you pull the pallets of yourself, or use a electric truck and put them in lines so they could check them.
Also INTER frozen cold store work from FrigoScandi depots,also a lot from Grimsby, timed deliveries were coming in to supermarkets depots for their distribution .we used to load hams and meat from HERTA [BRAND NAME ]from germany that was ok untill sainsburys made us as drivers sort their pallets out o at their guilford depot['brake the pallets down] in products numbers, where as the Germans just made the pallets up with any product,my thinking was ,why should we as drivers do their work for the warehouse staff employed,most times the were lazy as it was.
Yes i know what i am going to say now ,will go against all i said early,but, sainsburys staff were 100%unionesed,but they new we were not,so they did not give two monkeys about job demarcations ,one job they did not want to do ,[brake pallets down]so let the drivers do it ,yes ok ,however their own, god bless them drivers ,would not do anything in the warehouse at all.
However it was work ,and i did as i was told but for how long i did not know
They had all of Noon Products work from Southall London all the frozen curry’s for BIRDS EYE, to all the major wholesalers I absolutely hated it.It seemed as if the Euro haulage was being given a miss for me, as there were a lot of us doing this work ,and he did not care, a truck is a truck as far as he was concerned not our own egos ,yes i get that but we were also losing European night out money ,that was what made you wages up not the uk night out money that was less also he would get you back to the yard if he could, so no night out money.
It was not going down very well with me so i thought right,zb it, time for a change .i had done shop/supermarket delivers’ years ago i did not want it now.it was good work for a lot of the young men who wanted local work and also it must have paid good money.
The straw that was the last one for me was after unloading at Iceland supermarket ware house in Queens ferry i was told to go to a dairy near Shrewsbury once there, i washed the trailer out [no problem] and then book off…
So it meant i had done about 5 hours work ,it was now dinner time 12 o’clock and i would have to start work again in 8 hours time and go through the night doing milk delivers, however during my time off i could not leave the trailer dropped on their warehouse loading dock and park the unit up away from all the noise ,like i would normally.
You had to stay on the loading bay with the trailer while loading through out the 8 hours with a fork lift going in and out whenever a pallet was ready, like being on a rocking horse , i was thoroughly ■■■■■■ off ,to think that some other drivers had been here and done it and never said a word it was just unreal, the job was going back wards, however i bet it paid well , that I understand ,i new this was the way it was going ,long gone were the good euro loads for me anyway ,[ some one got his own back on me]indirectly ,my mind was made up there and then i would do this load, when i get back i would be gone.
That is what i did, however i was asked to wait until the court case for the overloading had been dealt with in DOVER ,any fines,for me would be paid and my transport to Dover would be by them just hoping there was no points on the licence.
After 6 weeks the date had been set i was ready to leave, where to i had no idea but the supermarket hubs were the worst job you could have in my opinion not for me.a big zb you, one place i unloaded at was a Aldi OR lidl warehouse near Nuneaton i think i had 22 pallets i have forgotten what the product was i was given a unloading bay number so i backed on then went to the cab for a brew ,i sat there for about a hour and i thought jesus they are slow, ill go in and see whats happening ,nothing was ,the warehouse door was open,and a chap is sat in the small office ,and i asked him if he has a problem,he said no, you have.my god the red mist came down , so the usual argument ,whats my problem ,he said you have to unload your self here and put all the pallets in the lines on the floor then we check the load,you can use the electric lifter or a hand pull pallet truck, at that moment another driver came in he had a word with my friend ,then the driver came to me, and said you will sit here all night if you do not unload yourself. i got the message,and did it now that was the final straw.
The date arrived and i was driven down to Dover by Bob Nedomer company director a very fair man to work with.The overloading was explained to the court that it was not the actual load that was over weight it was because someone [not me ] had forgtten to take the meat hooks out of the trailer causing the extra overhaul weight,however it fell on deaf ears and they were fined and as the driver i was but no licence endorsement for me ,also none for the company so in all a good day.
On the way back Bob tried to get me to change my mind about leaving but he could not guarantee me any European work ,as he said the UK work at the moment was the way to go of course there was still European but it was nothing to do with him who did what load and where to.
Iexcepted that they did let me stay until the end of the week, they new i would not do anything wrong ,it was only the work that was my problem, so once again i was on the move i had yet to tell the wife however she knew she would have no influence on where i worked .however she knew i would not be long out of work…
The strangest things happen sometimes ,when i was driving from the motorway in to Blackpool now home, i ended up following a smart looking powder tanker ,i thought it would be going to the ICI Thornton but it did not make the turn and carried on towards Fleetwood ,so i made my turn towards home and left it at that.
Once home i explained what was going on to my wife I unpacked the car and the next day i will start ringing around for work.
I did not have many numbers left that i did have a book that i used to write down firms name and numbers and that is the only reverence I had or have to any stories I have written on here all out of that old wooden block for a brain the teachers used to tell me I had at school.
.I did not want to do the UK but the way it looked that might be the path i must go when you are actively involved in European driving you see all the trucks on ferry’s but when you think about it there are more owner drivers doing European than i suspect large companies .
My target had to be small hauliers who sub contract work from larger companies i brought all the truck magazines that i never ever used to read also anything connected to Transport.
After nearly a week of getting no where i got a reply from CURRIES of Dumfries would i go and see them I drove up to their depot, went in for the interview, i took all my paper work from before where i was driving etc
It went well, however it meant that a lot of the time i would not be getting nights out basically it was shunting for the European men, not having your own unit .
They offered me the job there and then without even a driving test, however some of the time it would mean staying in digs there until a unit became spare for me to drive permantly i was not prepaired to do that.
I declined the offer and thanked them they were fine about it .
Next was DUKES of Northern Ireland i had their number from my old book, i was getting down to the last resort, they had a UK depot at Crick that was my old home ground area i rang them and was told Ireland did the meat and European not CRICK
And the most strangest conversation I ever had again true I ended up talking to a traffic clerck asking about any work at all and could i speak top the manager about a job and he was,pumping me,I said is it you is going to employ me or the manager ,he said the manager so said I would like to speak to him please
He asked my name and I told him,he said he will speak to the manager hold on the line ,so I did,about 2 mins later a voice said did you ever work at Northampton,I said yes I did and told them jcs,but rokold then the voice said well zb me,I laughed and said well who are you it was not only Alan Webb who first employed me at rokold in 1982ish
I could not belive it he was the uk manager, for Dukes at CRICK after about 20 mins I gave him my history and my home number he said he will do the best for me wait for a call how strange was that…
After a phone call he made I had phone call from Irland a interview was arranged for me to see a MR Bertie Marshal in a Morecombe Hotel on Friday i had no idea who or what he was, so on the day i drive there,walk in to the hotel, and ask at the reception if a MR Marshal was around and they said yes and they took me too him .luckily he was on his own .
I introduced my self and it went from there he said i can start at CRICK straight away if i wanted to with my experience however not in BELFAST as the meat was slowing down ,out of the blue .he said he had a old friend who used sub contracted from him, and has some trucks and works out of Fleetwood, it was news to me so he said i will ring him now and tell him about you ,and he did there and then after a few minutes he said right victor! in his loud ,growly Belfast accent you go and see him tomorrow and he might just sort you out
I asked where is his place ,and he said go right to the very end of Fleetwood dock and you will see his yard, he thanked me for coming and i the same to him and i drove home…
Next morning i made my way top the end of Fleetwood dock only 15 minutes from home ,i could have got the tram there ,but it was a walk through the dock so i drove.
At the bottom was this yard just like a scrapers yard .one gate open but it was hard standing so i drove in, there were a few odd trailers parked about two high sided scrap car tipper type, with crushed cars loaded.
I though no way am i messing about with scrap. I had done a bit before all muck and [zb] no thanks, a double porter-cabin in the corner a few mixed type of cars typical driver type so my expections at the time were going very fast.
I knocked the door ,a very load Lancashire accent shouted its OPEN, so in i go as i walk in a pair of heads swing round to see me the first word to be said was Lancashire-
NOW THEN!!
In local terms it means a greeting , like how you doing lad …for a start,to me, it sounded so aggressive, it was if you had confronted whoever and they wanted a confrontation,]
Hows you doing my name is john and this is my wife ,and small chat started, he asked why i was seeing Bertie Marshall ,so i told him the reasons and as i looked up where his wife was sitting just above her head was a Pulleyns calendar, i walked over and said, see that motor there ,I drove that it was a yard scene all the trucks what!! he said you worked for PULLEYNS, i then told him my history of all the work i had done he could not believe it he told me he had admired Pulleyns for a long time .
The rest is history ,in fact he was pleased that i was there so they both go on to tell me parts of their history within haulage [.some bits missed out ]after time it was all a bit of a mess.
The main part of there haulage was like spot hire if anyone needed a unit to pull any type of trailer they would be on it ,however they had 3 units on permant hire to a firm called B.E.T.from DOVER who had a main contract to Smits of HELLBRION [D] the bulk powder transport company one of the biggest in Germany so it was like 3rd hand work he wanted to get with Smits as the main Northern contractor to cut out EBT.
To help get this he wanted drivers that would tramp around Europe for Smits direct and that was the only way ,some of EBT drivers and one of his own driver were on weekly jobs home every Saturday and they did not want to do it, so by luck for me, one had told him he wanted to finish hoping john would relent, little did he know that i was willing to do that and was looking for work also the driver was his longest employee they even had his name painted on the drivers door “our john” blue, on a white rental DAF right hand drive .
That would defiantly have to come off if i drove it.
I was given a run down on how a powder tanker works , but would get more training next week if i want the job.So that was that, start Monday…
You did not need haz –chem –cards as dangerous materials were not carried inside powder tankers.
Monday came i parked in the yard there was this newish DAF unit empty of gear and i was told go put your stuff in there was a change of plan ,Iwas given a book with all relevant phone numbers ,GERMAN addresses ,shell card, insurance all the usual inside the door lockers he shown me some bolts on a ring and said they are the shear bolts if you need them…all new to me.
He gave me this massive chamois leather as big as the door windows ,i thought must be knock offs ,a box of tachographs that was about it the change of plan was ,i was to go to Sandbach off the M6 find this other powder tanker yard and pick up a 20 foot powder tanker [container and take it to a works in Widnes unload it [blow it out] Take the empty back and ring the office when empty
Fuel tanks were full, solo down the M6 off at SANDBACH and find the yard that was on a small main road out of the town.
I find the office i go in after knocking, walk in and heads turn round and stare at me as if to say who the zb are you ,Hello i said i have come to pick up trailer so and so no one speaks so i said this is the right place .etc
.I was used to this type of reception “.normal for a traffic office” from years of experience[ the silent treatment] so i said ok im off, must be the wrong place john has sent me bye, smartly out, to the cab as quick as i can jump in,i fire her up and start to pull away, as the man runs out of the office waving his arms about, so i stop wind the window down and said ,WHAT!!
He starts to say ohh sorry mate, we were used to “john” the driver of the lorry ,i said say no more mate, its me now, do you want me to stay or will i just f— off because i do not give one monkeys [zb]
. Ohm yes sorry, you have got to deliver this tank as it is booked in and it cannot loose the booking ,so yes please tip the load for us .
So i have calmed down, and backed under the tank, gone in the office, got the CMR and said any instructions please i have never done this powder tanker before ,ohm!again, john never said nothing to us about anything ,we normally work well together ,as we are all sub contractors
I told him the circumstances how I got the job, the driver has jacked and i was looking for work and here i am to tell you the truth i am a fridge man, but i am sure i will learn.
He then explains to me that at the factory i am going to, they use their own air lines to blow the product out of the tank, that is cradled inside a steel 20 foot container on a 20 foot skeleton trailer=
[ meaning a very light constructed trailer just for pulling containers ].
The men there know all there is to know about the job, they will do the job for you .
Once i had found the yard,it looked like a chemical works of some type i was told where to go and someone would meet me there, that was what happened ,i told the man that i did not know anything about what was going to happen ,and i would be all eyes, he backed me up into a position [the truck] very close to a big cylinder silo ,like the once you see in the fields for corn
I back On to a ramp he said apply all the brakes switch off the engine and give him the keys
He explained to me once he had connected their air pipe to the container fitting ,he then connected a bigger hose next to it [it was like a little control panel on the rear of the container, and then opened a valve ,we then had to move away as once they started to the unloading the whole of the truck and trailer start moving upwards on a massive platform
I had never seen anything like it before, it must have risen to 45 degrees it was to get the powder product in the tank to help loosen up so it would blow out of the tank and up in to the massive silo .
I was amazed, he then explained to me that was what you do when you have you own tank behind you ,
You have to get the air pressure right ,blowing in to the top of the tank from hose that is connected to the compressor from your unit that makes the air pressure.
To unload your self is going to take a time to master HE SAID and my god he was right.
he trucks have about four flexi 4 inch diameter pipe [you see on the side of powder tankers] they are the main pipe you use for going from the exit valve on the back of your tank that will be connected to the pipe going direct in to the host silo, sounds easy that is the theory. i will try to give a full explanation on loading and blowing out a full tank on its own ,unless you fall asleep.[ First time I was pooping my self] if i now try to tell you about a powder tanker you might later get what i am on about what i am going to write now, took me a long time to get to grips with.as in doing it properly and feeling confident [well a little bit .
A powder tanker is not used for hazardous materials they are mostly used for powders, dry goods, plastics, anything that will be able to be blown out of the pipe and up in to silo.a silo is the holding tank at any company you go to to unload your goods in to…
A POWDER TANK TRAILER.
On the top of the trailer are five lift up lids on hinges with locking down large wing nuts on the side of the tank top ,making the lids to be air tight once screwed down by the driver…
When the lids are open for loading you look in and it is a massive looking space if you fell in,it made me aware of what I was doing when them lids were open on your own if you fell in you would never be able to get out ever .[true]
One locking down wing nut on every lid has a ring welded on the end so as the TIR “tilt ”cord is able to be threaded through each one on a locked down lid.
Then it is threaded along all the 5 lid tops, that are individually locked down with another 4 threaded swivel clips on each lid top and back down and threaded through the rear of the unloading nozzleat the back of the tanker you have all see one when you get to close the back end of a powder tanker normaly it is customs sealed if going to Europe also it makes sure no one has been tampering with the lids or the rear end of the powder tank.
Also at the front of the trailer where the the TIRcord starts from it is in a small type box and the small opening lid has lots of customs seals inside on the clasp.
The rear end has a large lid that is big enough for a man to get in with ease and belive me you DO, who would ever have thought it ,I never did but every wash out you were inside and yes with the big zb off chamos-leather with our socks on or with but no footwear ,getting out when you think it is bone dry inside, getting out of the rear is another work of art, as you have no shoes.on,but you soon learn to put some shoes on the trucks bumber to get down with…no one told me I just watched others ,that was 99%of me learning the job ,no one person ever come and said are you ok mate ,the reason all the time I was doing it I never ONCE came across another ENGLISH man and very very few English speaking driver so that tells you something .
The rear lid/rear of the trailer round opening, also has large wing nuts to close it up ,inside the rear lid is a space/like a rim that is for a filter[called a cone and that is what it is shaped like] that can be placed so as no lumps get blown down the exit tube and blocks it up…like a filter paper in a cooker hood. However you have to know when loading a procduct that it will be needed to stop the cloging [did anyone tell me no] I just watched others and hoped]
In the centre off the rear lid hatch, are a number of bolts that hold a lever down that lets you control the flow of the product leaving the tank and the most important bit of kit is a threaded end that is sticking out of the housing holding the lever that you attach ,exiting pipe or hose some time you can get one with a sight glass fitted in the centre so you can see the product moving out of the tank.
Just about at eye level is a small round gauge off the main air hose and that is giving you the air pressure [the air pressure is coming from the engine of your unit, on tick over, after you have engaged it in gear, so it works as a compressor making air] that is actual going into the tank to blow the product out ,the air enters the tank from the top of the tank .
Also a hose right by your eye line is a lever that you can contro; the air preesure going in to the tank, sorry it is easy to show someone how it all works,but no one did for me .
If by any chance all the top lids are not completely screwed down by the large wing nuts ,and it is leaking very small air pressure [you will know as powder will form on the top of the tank after time] also you may have threaded the TIR cord through so hopefully it is not that side that leaks…even the back lid /hatch could well leak air so for a start you have to be on your toes …
Back to my first unload ,after the man said the tank is empty they lowered the whole truck and trailer down to ground level ,he uncoupled his air supply hoses, said here is the CMR signed and off i went back to Sanbach.
Once back there at their depot i drove around the back and there was a place to drop trailers but i thought i will go in and ask in case i have to take it somewhere else, i was told to drop it then come in the office, there were now 2 white painted powder tankers dropped in the yard .
There was a, like ,a small drivers room i went in there and 2 drivers also in there ,so i said the usual greeting and I got a response and they wanted to know where the other driver was so i told them my bit and i asked why they seemed a bit awkward to me ,so i said look !whatever the other chap was I have no idea I never met anyone else from the company except the bosses ,i am here now trying to earn a few bob like you i am not new i have been on European driving a few years but not on powder tankers but been a fridge man and now fancied a change and left it at that.
I was told to wait in Sandbach for a 40 foot powder trailer,that will be dropped here for me and to leave at 6 am for Grangemouth Scotland.
I was back in the drivers room and asked for more advice on how to operate the trailer and do it safely ,they could not believe that i had no instructions on the sequence of what to do at a delivery.
The driver who was there was very good and went through the whole sequence at all delivery’s it was nearly all the same routine but safety always first.
First thing to do,was without fail was attach the wire clips to the STATIC to the anchor point at all deliverys or loading points, the wire was furled up inside a box on each side of the trailer you pulled it out like a hose reel and clipped it to the anchor point on the floor[like a lightening conductor, and the trailer end was attached to the trailer.
Make sure the truck and tank are level at the rear end ,there are 2 wind down legs each side of the trailer ,the same as the landing legs under the trailer on a chassis bar ,under the valve that you attach the blowing out pipe for unloading is a built in “spirit level” [can you believe that]. the trailer must be level for when you start to lift the trailer up once unloading starts[another thing i did not know].it goes up to near 45)degrees absolutely frightening the first time on my own.
Another lever at the rear of the trailer operates theHydraulics that lift the tank off the trailer to start lifting it up in the air
I asked why do you lift the tank up out of the chassis,
It lets the product inside slide down the inside of the tank as when the air is pushing the product [powder especially] out it creates a tunnel inside the product in side the tank.the lifting movment stops the tuneel being created
Example if you had a bag of flour and you put one hole in the middle at the top and lift it upside down to empty it would not come out ,if you put another hole in it the other end it would for a while but then clog up, the air pressure inside of the trailer does the same however that can clog/block up,then you have a hammer that has a rubber head and you go around banging the side of the tank so release the product stuck inside the trailer it does work [lift the trailer and then bang].the same sort of equipment i first seen in the zeebrugge garage on my very first trip now years later I am using them.well hopefully try to
You also have to keep a eye on the pipe that is taking the product out of the trailer up in to the silo, if the pipe starts to move[dance] around ,like starting to jump about, you know that more air is going through the pipe then product ,so you lift the tank up higher to get the product to fall to the bottom in side of the tank after banging the sides as well with the rubber hammer.
To get to grips with what i have just written , i learnt by asking and watching, and no way was the last explanation ,half of what there is to do and learn, i doubt you could learn it in a school ,it is on the job, and by your own mistakes ,and you did not make many of them .
Finding my first ever solo delivery in Grangemouth was not straight forward but i got there in the end ,the gate man directed me where to go, i could see the silo above the warehouse roof ,once i had turned around and backed up , there it was a concrete pad top place your rear wheels on to it was not to far away from the silo connection pipes once out of the cab i started to make out as if i knew what i was doing, getting the hoses out of the side containers , hoping someone would soon arrive to give me the ok also help me to start connecting up.
Years ago len the B.R.S. man used to say “IF YOU ACT DAFT YOU WILL GET AWAY WITH MURDER” in a sense he was nearly rig ht,however bluffing ,was another thing,no way could i pretend to know what i was doing because i could not, and did not ,i do thank every one ,who “will never remember me” on the powder tankers for their assitance
NOW THEN!!
A Scots accent was heard by me,” HI there jimmy how is it going” turning round .a massive chap in overalls was walking towards me ,it turned out he could not have been more helpful once i told him my situation that i knew very little about what i was doing he helped and guided me through all the sequence of unloading.
You always check with someone at any delivery to see if their silo is full,if not,if you put procuct in to a silond it is full it will blow the product out of the top of the silo you are trying to put in,the silo overflow cuts in [in fact a disaster,] .thank god that never happened to me
It will be to boring to go through all the things i had to do and learn i will say! if the silo man had not been there i would still be there today, i had no clue ,in fact it was stupid to send me out untrained, but you get on with things, he even was able to show me how to put the pumping lever in gear, from inside my cab,by dipping the clutch and gently p utting it the correct position that drove the compressor that put the air in to the pipe to the tank and leave the engine in gear ticking over
Ihave seen lorries ,powder tankers that used to have a engine on the chassi infront of the tank I always assumed that was the donkey engine for some kind of power now I know but a lot have exit pipes for the product under neath the tank,.
He also showed me when to start lifting the tank up so the product would flow smoothly out of the exit pipe ,he said if the pipe taking the product out of my tank started to want to bounce around it was time to lift it up more so product kept flowing, i can tell you for nothing, it was the most scariest thing ever,i got used to it also the power of the air is about one and a half bar pressure i am still very grateful for his assistance .
They let me use their phone once unloaded i was told to make my way down to Dartford in Kent ,to go under the tunnel come off at the first exit, turn right go over the other side and you will see signs for the power station make you way there, and they will know you are coming and load up for Germany they have all the details you need, once loaded go to DOVER .
Once inside the power station i was told where to go read the signs and please obey them as this is a secure area, so for once i did and arrived at a loading area ,with a Shute hanging down ,made out of sort of canvas ,the instructions on the board out side told me what to do.
Go and sucure the anti static line, pull the lever at the rear end of your tank and pull it ,it will operate the walk railings on top of the tank for your safety, go on the top of the tank and open all the lids get back down ,and ring the bell on your left and wait ,this was in numerous languages .
After 5 minutes the tannoy -speaker came on the instructions . were go to your cab, start your engine up,
When the green light comes on in front of you slowly move forward when the red light comes on ,you stop, do this until a person will come out to you ,keep you windows up tight, stop your engine when on a red light, do not in any circumstances get out of you cab as you will be surrounded by a thick dust…if you have any old clothes put them on …
I followed the instruction to the letter ,i could feel a product going in to the tank, the dust was like a sand storm [i have never been in sand storm] however ,i moved forward as instructed and the final red light come on, because next thing i knew the cab window was being tapped, outside was a chap with a breathing mask on ,he held a sign up that said wait until all the dust has settled stay in your cab,then by the door on the side of the building.is a phone pick it up I did as i was told, and out came this man with a shovel and a big soft brush and a face mask.
He said unclip the static line pull over on to the concrete pad over there then re clip the static line up again, go on top and brush all the product off the tank, after you have done that close all the lids make sure you have cleaned the rims so they close good ,because when you go to unload you do not want any air leaks what so ever, very important!
And do not put the product from the lid inside the tank just push it off on to the floor tighten the clips holding the lid down keep the one with the hole on top all facing the same way as the TIR cord is to go through each lid.
.Once you have brushed it all off, unclip the static line and move forward to the wash bay that you see over there ,it is hot water and then wash every bit of the product off the unit and trailer under neath as much as you can especially the wheels as it must not be put on any roads ,your truck will be inspected before you leave
The product was every where but i knew i had to do it correct ,once done i moved over to the wash and nearly forgot the static line, but i did unclip it and did a walk- around before i moved [just luck]
.When you are finished bring some clean clothes and shoes, with you will need them , there is a shower and plunge pool for drivers once inside it was like a swimming pool but I just had a shower I could imagine drivers ■■■■■■■ in the pool just for a laugh there was even a bag to put you old clothes in or just leave them there.
They had their own customs ,and they sealed up on site ,T forms were done there,and the CMR .i would still have to produce paper work at Dover, but idid not need a agent once all {done up the stairs] all drivers doing customs knew about the queing on the stairs]ihad got my ticket coming in the dock I then parked up in the lane and waited to be called forward to load on the ferry the next ferry available to Calais
I parked up in CALAIS and had a short break for transit of BELGUIM down around Brussels ,if you catch brussels at the wrong time it is as bad as any city although you are miles from the city but it has it different districts areas, the northern belgiens are called FLEMISH dutch speaking, the middle areas are called WALLOONSfrench speaking going towards LILLIE and a smaller group from the ARDENNES going towards Luxembourg,and across toAachen are GERMANspeaking peoples so bit of a mixture
It had been a while since i last went through Aachen frontier, they did not disappoint me at all the arrogant men were still there the usual routine . god knows what their problem is
The transit of GERMANY went ok by this time in my euro driving I had at last brought some maps and the German maps were cald Falk plan, they are so good they were made like the japanise paper folding [macramie] they just keep opening up to show more detail.
I arrived at the Krupp factory around late pm , [old habits,] I had had a good 10hours plus shift not caught speeding,after going first to the wrong industrial estate, i was given correct directions to the chemicial looking sitei followed the sign to the truck parking ,pulling up as quite as possible as there were 2 powder tankers parked up so i joined them on the park.
I walked with my T forms CMR ,to the gate house i assumed somewhere on the site they would have to come and check the seal on the tank ,the gate keeper looked at the papers, picked a phone up and spoke to someone he handed the phone to me, a German/with a English accent said that it would be 12 midnight before i would be unloaded ,customs would be done here, and someone will come to the truck and get you .Another English truck is at the unloading dock i was told.
The gate man looked at me and i said could i have a “pass please” he knew the routine he wrote one out and gave me a plan of the factory, it looked a long walk ,i thanked the gate man, and make my way down a maze of just like streets of buildings it was like a town ,brick built walls like houses, street names you would never belive that you were in a industrial factory i followed the map eventually i could see the front end of a truck unit, ,with the tank half way up, it was getting unloaded it had E.B.T.DOVER. on the tank the first time I had ever seen one, after all the years of in and out of Dover well I would not have took any notice it was a tank.
I found out later that they had some sort of contract to do internals in Germany inter factory work, some drivers stayed a long time just working in Germany for smits
As I got closer I could here some banging at the rear of the tank so i moved back away from the truck and walked to the back at a distance, i could see the driver doing something ,so i waited untill he had finished ,i said the usual “all right mate” how you doing ,he looked over ,not the best of pleased he walked towards his cab he did say yehh ok,but never put his hand out to be shaken like most euro drivers do
I knew then that I was not most welcome ,maybe he was tired like I was, any way in for a penny Isaid my name is I am new to this work this is my first trip i never done this before, i got the job by pure chance ,i do not know anyone who had driven powder tanks,i am experienced in European fridge work that is it. I just thought i would say hello .
He sort of steps back a bit ,ohh ok ,the story going around is that you were from another tanker company and wanted the DA.F I said ,“i have had all the top range double sleepers “god ever made” why would i want a small sleeper like I have,now with someone else’s painted on the door.and they all knew the driver i was told later.
He said sorry misunderstanding , shook my hand and said lets have a brew.
I said ok ,nice,after tea please show me what you were doing, with the pipes he said you keep giving them a good clout with the rubber hammer to keep the product flowing and keep check on your air pressure do not let it drop below one and a half bar[ 1.1/2 bar]
Once the product starts to slow down you lift your tank up a little more,the telescopic rams do the work for you pushing the product to the rear of the tank but not to quick where you have your exit product pipe attached there is a product site glass that you can see the product flying past
Where did you get that from, “i asked” it belongs to the truck you will have one in the side box on the trailer you use it all the time when you are un loading i have not had any proper training it is ,like fridge work learn on the job but this is worse than fridge work, he said i also did the same ,but you will soon learn.”
He told me what i had let my self in for, you just get messed about by the factories you go to if they do not want the product, they send you somewhere else to unload if you have time limits for collection you are stuffed.
He told me this job is a regular for them ,[smits] when you are empty you will drive to Smits yard where you get the tank washed,what he meant was you!! wash the tank inside ,and the man who gives you your cleaning certificate is a right [zb].
The wash man is so particular about the inside he will get in the tank with his socks on and feel all around the joints in the tank and under the tank lids .” Have you got you leather“yes! “that is what you need to make the inside bone dry, “now i got it” you will be absolutely drowned soaking wet by the time you have finished, about 5 tankers will be in the same area but differnt bays whatever you do, do not splash other tanks If you do the chap who dishes the certificate out ,will not give you yours.
You will see some tanks having small machines in the tops and a lot of steam coming out of the lids, these are called “spinners” high pressure, quick clean, mostly used if any type of non hazardous type product has been used ,mostly oily or detergent products in different d powder form that can be hard to get off the side wall as they are coated with like a bronze fine skin,that will flake off if spinners are used too much you must never use spinners unless you are told to by your boss no matter what the wash people say where ever you are. it is very expensive, and the hot /power takes a film off the inside of the tanks and leaves a blotchy whitish coat ,clean but you can tell if a spinner has been used,
The man in charge of you once you get to smits speaks English as well as you and me and you have to do exactly as he says as it is him you are working for and you represent your boss i seem to remember his name was like PETER. Yes peter the knob.
At the wash the boos wash man he will not pass your tank the first time he will make you wash it again, DO not get the hump, just do it, he does it to all new drivers he will know, as he will know the truck and that your a new driver just humour him once you get used to him he is ok …
My mind is already made up this is not the job for me ,to much f------g about, I am glad i have met this chap he either is telling the truth or [zb] i asked him why he does the job, he said ,he is going with a German girl from the village and hopes to settle down here ,well that was fair enough .and the tank cleaning man is her dad at the depot and he then laughed.
I ask how do you get round the Tachograph if you have to break you break to get tipped, and it takes 3 hours to tip ,he said you write on the back and when you leave you go to the gate man at krupps or any of the German factories they will all do it and he will put a big krupps stamp, AND over scribble in GERMAN
Do you finish you break once tipped” “,no” Smits office will ring to see what time you have tipped and expect you at their depot ,that is the way they work, they are not bothered about your rest time ,the tank is important you will find out.
BLOODY HELL just as fridges…After all the good information, I walk back and got in the bunk fully clothed,except shoes,i did have a break once I got of the boat a CALAIS but I was now ready for bed, i had this feeling that this work was going to be as bad as fridge work as regarding rest and sleep.
At 2.30 am the door is getting banged ,i get up, pull the curtains, the gateman is shouting something i put my thumb up ,pull the curtains right back,got dressed ,i can see no one else is parked here, bloody only the lonely again.
or it could be leave the English man to last.
I fire her up ,and move to the gatehouse, the man gives me a road plan of where for me to go, it was like a London underground plan, however I followed it and it took me to where the other driver was.a town of its own.
.I got my self all set up, on the unloading pad ,correct i hope , i start getting the hoses out of the side box ,and the flow type meter it takes two hoses to reach their pipe on the silo that i have to attach my hoses to
I know that there is a sequence of loading, and unloading ,to be honest you did need proper training, and maybe a book on the dos and do nots.
However i had to find that out for my self and that is what i did… it took a few loading, and unloading times,but i did get it in the end, however i was always aware that any time it could go ■■■■ up or make a stupid mistake , and just imaging getting it total wrong and the whole tank could topple over that is why the two back wind down legs plus the built in spirit level are used to stabilize the tank when it is right up as high as it goes.
Finally when the tank blows empty ,you hear the air rushing you have to switch your air supply off, straight away, from blowing just air in to their tank that is why I stand at the rear of the tank all of the time while I was unloading, I never moved from the rear any time,untill all the product had been blown out I made sure I had a warm coat, ■■■■ ,anything I thought I would need.thank god i never needed a dump or that would have been another load to contend with.
I was told by the other driver, that where you are unloading, and they are not sure their SILO will take all of the your load ,or they! have made a error, and you start blowing your product in to the silo, it will blow the product everywhere out of the top of the siolo if its a powder,it will be like a cloud [so i was told] a air horn will start blasting away, letting every one know.you would all ready know because you will be covered in the product.
You will by now might have guessed ,that I would have the biggest problem with Smits truck wash man. He did make me do the tank twice before he passed it inside under the rims where the lids drop on, there were smudges of left product,he may have been correct , but i know he got the best of my tongue I zbing hated him from then on he knew what i had said to him I though zb this no way will I be doing this regular.
If you have ever been to a self car wash, you know what it is like, imagine doing a 40 foot tank inside from the top then going inside and doing the upper top of the tank,of course all the regulars had all the proper wet weather gear, they looked like frogmen ,i had a coat and a flat cap,and you had to take your shoes off inside so you imagine what my socks looked like,a clowns big shoes not one of my better days.
BEFORE i had a full change of clothes i went in to their wash /rest room.one thing about the GERMANS they need no lessons in providing facilities for their workers large showers,a clothes dryer they must have known us english would not have the right gear! lots of room, not like our rest rooms ,a BEER vending machine, but they know that their workers will not go daft, as they have a beer for breakfast [as normal] not like us back home ,a beer machine would be temptation for a ■■■■ up.[what, really] jolly jack ,must keep up tradition.
Once i was sorted i went in to the office for loading instructions not a word was said about the wash they gave me my tank clean certificate also some running money maybe john had asked them to give me some ,the clean tank certificate was to be shown to where you were going to load up ,no matter what country you load, they are to have a clean wash cert presented to them [no cert no load].I was sent Ingolstadt to load for Civitavecchia just up from Rome now i get the running money road tolls.
Once there the same procedure, wait and they would come and get you ,i hoped later on and not through the night,i all ways made a point of getting to where i should be loading ,than getting up earlier in the morning,no matter where i worked.i would never have a alcoholic drink in the week at all ,i knew i would have never been able to do the job ,lots of men did ,some times you never got time to have a brew.
After i was loaded that all went ok no problems i was to catch the TRUCK train from near Munchen[i have completly forgotten the name of the place] to the top of the Brenner pass , it is so you miss the weekend driving ban in Germany and Austria, i had used the system before with a fridges from the same TRAIN place .
Once parked up in the yard ,i went to the office to collect my ticket and train loading instructions, i remembered it was the same office ,very clean and lots of signs i did not understand none however standing there not sure which window to go to in case they had changed the procedure ,another driver walked in and i watched him to see where he went and i followed him i assumed he was going on the train.
At a window he wanted all my the paper work, plus the truck registration papers i had with me [a must in Europe] they hand the papers back after about 10 minutes ,he gave me a number and it had a large B on it that was for a lane to park up in ready for boarding the train. to put in my windscreen.
He did a routine of pretending to put it in the screen ,yes!! i had got it,. and then a little box with a sandwich, apple,a small water and a flimsy paper sheet.for the couchette.
Back in the truck i got ready i had no idea when i would be leaving ,i parked up in lane B there were trucks already parked up in it ,there were about 10 lanes of full trucks next to me, so i could be a while, they were going to lots of different destinations .
What you had not got with you once in the sleeping compartment you went without .These trains are very low to the ground, when you looked out of the window it looked very close to the track i realized they must have smaller wheels
When loading the truck on the rail flat bottomed like a low loader, you were following the truck in front you drove on until a man stopped you he then put chocks under your wheels [just like the tunnel train,]or did I have forgotten.
You took all you will need with you thank god for duty free plastic bags ,as I knew the crack I had a single small gas burner a small kettle ,water tea bags [a must] ,sleeping bag pillow ■■■■ lighter,book, getting out of your cab with all your stuff and you run to the end of the train where there is a accommodation coach years of training take everything you will need.
The fun starts now, getting up the steps on the accommodation coach with your gear ,once you done that, you are in a corridor with sliding doors behind each door is a compartment with 4 bunks two are long seats and two bunks like luggage racks ,so the art is let no other fu-zb-er in the compartment ,so you draw the curtains and sit with your "foot"on the flat handle and hope no one comes in ,i have had it before, being on the train nearly last , getting in to a compartment can be frustrating in the end i have been banging on a door,and there is one chap inside, there is is enough room for all, but who likes to be on our own ,[we all do] .
We left the yard lots of clanging but once they get going it is not a bad ride it was at least 6 hours to the top of the “Brenner pass” time to get some food then sleep, if you could, because of the squeaking brakes.My that was worse than a fridge.
Once the train arrived at the very top of the Brenner the routine of getting off was easy, getting back to your truck, the chocks had been removed from the wheels no paper work to do, just drive off, straight down to Italian border, /customs at vipiteno compound for road, and rail/road traffic, it was a silly o’clock in the morning, once in the compound i went to bed, i was not bothered what others had done or were doing ,bed for me.
Up at around 9 am their time, in to the agents ,i was told it would be 2 hour clearance [i liked the way they stuck two fingers up] if only they knew,c i could tell, he was trying to say you are late. i just shrugged the same as they do and walked out.
It was all cleared by 12 o’clock-ish my route would be Trento .Vicenza , Bologna, Firenze, Siena Grossoto,direction destination port Civitavecchia. How I remember it, when on pullens i took a load of steel for a ship in the dock in a tilt ,if I had come from the Aosta route it was a straight forward route. but from the BRENNER a bit different ,however it is fairly straightforward driving in Italy so long as you stay on their autostradas they incorporate nearly all of the major cities, you have problems once you start trying to cut across the country, the road may look ok but believe me you can get your self in a right messso cutting over form east to west or vise -verser you best bet is all ways stick to the major routes even when it looks longer in the long run it is quicker.
I never made it in one hit ,they had not given me a time for unloading soa nights proper kip in the bunk,all this in and out of the bunk does catch up with you in the end,the next morning i was not to far away .
Once I had found the unloading place it was a big chemical works , the routine of unloading was good , blowing off in to their big silo it took about 2 hours. I was getting better and more confidant i would go and make a quick brew before it was time to raise the tank and bang the sides, it took me a long time to get used to leaving the back of the tank while unloading for just in case it went wrong i was never 100% .however most men always stayed at the rear of the truck when unloading you never knew ,one good thing there was,there was never anyone to distract me by talking, it would be me, not them.
When empty i went for my C MR they said in good English you must ring SMITS In Germany.i got through to the English man, told him where i was etc he said you are reloading from there for Denmark, and come back via SWISS you will be heavy ,but use the train from Como it is called the [humpback] or something like that,it is all booked, ring when you are empty in Denmark.
I asked if i was to wash out and they said no it is the same product, i could not believe it.
After about 1 hour they told me where to park and indicated for me to open all the 5 lids on top of the tank, i thought they are going to check the inside of the rims, i did that and then climbed down, along came a fork lift loaded with pallets of product in[polythene in bags] and started placing them close to the truck. a small tractor arrived with a orga with a long Shute attached as high as the top of the tank .
Now i was seriously thinking ,what is going on, after 10 minutes 2 men arrived both had a breathing masks, hanging around their necks .i am still puzzled as what was going to happen, one man got up on top of the tank, and guided the nozzle on the end of the orga, over the tank top hole ,his mate lowered it down until it was inside the rim of the tank …then i got it… they were going to load the tank through the lids with the product from the sacks that would get taken up to the tank via the orga , with the man at the bottom splitting the sacks ,so the loose polythene goes up and drops in to the tank Jesus, who had ever heard of loading a tank [via handball] this is going to take for ever.
After a while 2 other men came so it was three men cutting the sacks open it was nearly 7 pallets worth of polythene sacks in to each lid, total about 28 tons,. after loading i was a gross weight of 44 tons .i was in no position to argue they knew what they were doing and the load was distributed evenly .it must have took about 5 hours to load, all the customs was done there i had finished locking the lids down a tight as i could i put the TIR cord through and attached the end to the rear unloading [door] and it was then sealed up
I moved around to the wash ,and washed all the dust off the whole tank and cab, i went and collected the CM R. T. FORM and a transit document, i was ready to leave now i had a longish run in front of me
My route was back up to BOLONGA up to MILANO, COMO. CHIASSO ,
I knew the route very well however I had never been on the train from Como.
The very first time i ever transited como ,1984 ish like a ■■■■ I went in the the town ,on the old road i was on fridges [I kept it quite back then]and ended up at the old border in the town, down the narrow street I thought i am f—ked,luckly at the actual border to the right was a narrow entrance with a small blue finger post sign you would miss if you blinked in to a compound,thank god ,I still had to turn around and go back ,at lest I could , however it was tight ,it was the old border the drivers before my time used to use
. That back then was my first royal zb up but many more were to come ,only in this job you could have them . all is going well ,until something you!!!do yourself puts you back down to earth.
  1. Getting to the actual train you go on past all of the COMO,chassio,compounds something I had never done before in fact I did not know you could, times before when i/you go to turn off the duel track to que up for the transit area ,over the flyover bit you drop down in to the compound it was very easy to miss or the signswere confusing or if you were not taking notice of the signsfor the transit compound i often wondered what would happen if you missed it well now I know there was another turn of so you would be able to return but it would not have been straight forward.
Transit Swiss via the train ,just the same routine as the German one , they gave you apple, i had to wait about 5 hours before i could get on a train and leave, so snatching sleep ,i decided to take the tacho card out as if i had booked off and was already parked up at the German border in my head but I was not , iwas still in swiss
Once the train had got me back at the German/Swiss border ,i would start a fresh a new day a new card.as if i had been booked off for 10 hours.the job seemed to have a certain way of swaying me towards being illegal again.
Out of the Swiss/German, border the drive was to FREIBERG FRANKFURT, HANNOVER ,HAMBURG. [DK] PAD BORG, deliver to Aarhus. With breaks, not much to say a good straight run,over ground I had covered a lot of times all though DENMARK, was new to me I had heard a lot about it ,and the danes are very big in to fridge work ,also they are one of the very best paid drivers through out Europe .all the tractor units have a large locker fitted on their units with a fridge installed just a added comfort for the driver,
Arriving at the deliver destination it was not hard to find i could see the silos from a long way off It looked more like a big farm complex, long low flat buildings ,lots of room to park up .i made my way to the office that was like a farmers kitchen, and a friendly greeting in Danish, they soon knew i was English, that is a lot of peoples second language in Denmark so at last no problem also they did not mind speaking English
I was soon told that they did not have room in their silos to take the product, they said it will be 8 am in the morning ,[what a result just what I like a full night sleep]there was nothing i could do about it. I could park where i was, i was told i could use the toilet and showers, open 24 hours ,they were they clearing the custom papers on site so all was good.
I had to make a telephone call to the smits office to let them know what was going on ,they were not pleased, and they [GERMANS]asked to speak to the boss ,who was there, lots of verbal went on but it made no difference it would still be tomorrow. ring when empty i was told, i bet that has put all the plans for me ■■■■- up did i care no!another full nights sleep.
s i did not have hardly any cash, especially Danish kroner about 10 DM to my name some English sterling, that was it but i did have quite a lot of cigarettes [my duty free 200 hundred ,as i smoke roll up tobacco i thought i would try to sell them here.
I walked in to the office and asked how much for one packet of cigarettes they all looked at me as if i was mad , they said they are very expensive here you should have brought them from Germany, so then i said i have 200 hundred English Bensons /hedges to sell !as i have no money, for beer
.The boss said, it is illegal to sell cigarettes here in this country, not allowed ,so i said ok, and walked out,i went back to my cab, however the seed had been sown ,but i did not know it , about half an hour later, a knock at the cab door, it was worker from there, asking for ■■■■, i said no sorry not allowed ,he said in English ,it is ok, the boss has sent me he smokes, he had kroner in his hand i think the ■■■■ were about worth £12 English, and i got about 15 kroner it turned out a good deal for me ,but i did not know until later.
As i had no idea of any prices for beer as i had never been to [DK]before, i walked in to a supermarket to look at the bottles to see how much, Jesus the beer must be gold, it was so expansive nearly 2 kroner one bottle 600 mls about 1 ½ pints but i did not want much and i brought 4 bottles ,that was enough… back to the cab ,fresh bread cheese ,beer, what more could you want.
I was woken up around 7 am and told that i could go to the silo to blow out the product. so i asked will it take it all, yes was the reply ,i am getting to know the right things to ask now,also make out as if it was a normal thing for me to do {just blow out a powder tanker
The ant static clipping point both sides of the unloading are were very visiable once that was done I got all the pipe I needed out clipped in to their silo then went and fired my engine up engaged the drive gear without shearing the shear bolts [lucky], air presser up to about 1 ½ bar started to slowly open the valves and away she goes you can hear the product rushing out through the pipes
It seemed as if it took hours to blow it all in ,i knew when i was empty the air is rushing in to the pipes no resistance, i had got in the habit of standing at the rear of the tank ,watching and listening ready to shut the exit valve of and run and shut the engine off so as no more air is produced.
Back to the rear of the tank ,there was a valve up by the ladder that takes you up on top of the tank you just slowly open it and it expels all the air in the tank so it is safe to go back down, to take the hoses off although no air can get into them .
You then uncouple your hoses from the silo, lift them up to get any product out of them that maybe in them ,[you wash the hoses through when your at a tank wash] you put them back in the side carriers on the side of the tank ,there are larger plastic pipes, and you push and clip the hoses back up inside them.
So no one can see the proper hoses ,why I do not know,.then you take off the rear coupling from the rear tank door ,then screw the plastic cap over the thread hole.you then do a proper walk around
You pick up your hammer ,and anything else you may have used, lift the rear landing legs up make sure all is secure, walk around again, make the TIR cord secure. make sure the donkey engine drive for the air and power is out of gear .it is like taking a power drive out from a tractor. then sit and think, then relise you have the static line still clipped and make sure you have done everything i should have .Iwalk in their office to get my C MR, and ask where there is a tank wash ,but first i would like to ring SMITS in Germany.
What I sort of begain to relise there is more movment of plastic pellets around Europe than you would belive,maybe they mix it with different products who knows ,as why did a load have to go to Italy, unloaded platic pellets then another of the same procduct get loaded then go to DENMARK the mind bogeles ,I expect that is why I was a driver, not in the loop.to know
Once my loading instructions were clear I asked what route to take it was not that far away i am loading fish meal for Germany,do i need to get a cleaning certificate he said yes ,however you must do the wash at the factory you are loading from ,so that was good all in one go.
The fish processing plant was called Triplennie, Esbjerg how i remember is the “lennie” bit in the name, once there i soon found out that the attitude was 100 %better than the Germans at the wash plant inside the factory.
All though you had to do it your self there was no rush at all i was told i would be loading later that day so i had plenty of time to get the inside of the tank to clean and dry it out with the help of a hot air blower pipe put in the lid top, like a flex hose from a household tumble dryer.
And then to finish off drying with the massive chamois leather that i was given on my first day the inside of the tank gets quite warm ,as you are just standing inside the tank in your socks.and clothes of course,
I am able to reach the top of the tank inside with the help of a soft brush that i put the leather on, once inside they are much bigger than you think ,they would make a ideal nucular bunker under ground.
. As I have mentioned before you would never get out if the back door/lid was accidently shut with you in it as reaching the top lids from inside is impossible.it would be a good test for theses illusionist to get out of if the lids were open,instead of working for a living?
I always made sure that the rear lid could not fall and drop shut lots of tieing up with the tir cord.when I used to have to go inside to dry it out there is/was always the doubt.
The foreman at the factory s cleaning department gave you your cleaning certificate, and you were ready for loading, you had to go and park under a gantry that had a large canvas type hose hanging down from the roof gantry, that fitted over the open lid in to the tank, there were some workers up on the top on a walk way above the tank the guard rail was up so they were able to walk on the tank top ,and position the hose over the tank top lids that where open to receive the product .
My instructions were to drive forward when told and to stop when told by a man on the floor, by my cab. That is what i did you could feel the product dropping in to the tank, by the weight.
After about 5 moves forward, i was told to stop the engine and go up on top to close the lids down, they had a type of vacuum cleaner up on the top to ■■■■ up all the product dust.
There was not much, i brushed around the lid tops and then screwed them down, collected the TIR cord from the front and threaded it through the screw down handles around the lids and then to the back of the tank and the valves at the back…a customs man from the factory came and sealed it up, the office gave me my CMR. and T, FORM it had already been cleared just drive to the boarder .at Padbourg
Padbourg to me was like a mecca of transport firms on every road it was full of trucks and trailers nearly all fridges large transport yards all nice and clean so different .
Next stop was SMITS at Heilbronn i was going to change over trailers ,drop this loaded one and pick a fully cleaned out empty trailer and load at MASTRICHT [NL] for the UK now that was more like it for me, as i had been out a while and it was time to go home,
left all the paper work i had for the trailer ,the fitter Forman looked over the trailer with a view to find some defects, he checked the wheels ,tyres, hoses, tir cord ,every thing you could think of luckily all was good ,it was a trailer come what may.
I did the same checks to the empty one and asked him in broken English to do the same with me ,he made out he did not know what i wanted ,so i did no more and went into the big office and asked to speak to the English speaking chap who run us ,usual response from the receptionist making out she did not understand.she understood ,[zb].
I knew i was going to finish when i got back ,they did not,she soon comprehended
The man [john i think] soon come out from his office being verbal to me in English ,so i said i am doing a walk around checks with the fitter it was easy, so off we go to the workshops [gods kingdom] he said a few words ,i get a few stares ,and out comes a fitter ,not the boss, we soon do the trailer inspection done.they could have put 12 defect tyres on ,[just for their crack].
I went and got the paper work, cleaning certificate, i am not coming back that i knew this is the last time i will ever be here again.
I made my way to Aachen ,stopped and did all the usual paper work being empty it was just formal,then a straight run-ish to Maastrict in Holland and followed the signs for industry[indutch] the loading factory, you could not miss it eventually i found the entrance and end up queuing behind other tankers to go on to the weighbridge, once that was done , i parked up and walked in to the loading office.
Being in Holland i would have thought they would be all nice and friendly they normally are the Dutch ,No, ,these seemed a bit cold,they may have been germans or belgien/dutch ,germans, you may laugh, but they are so zb up nationality wise in border area they do not know who they are,for all I knew, i put it down to them being so close to Germany and Belgium none of them need any lessons on being [zb], well, I meant anyone connected to transport in any way.in them area,s .
I was given my loading instructions verbally, and a paper diagram,in all languages except i have never been good with anything written down telling you what to do i am a ■■■■ it and see. i should have sat in the front of the class at school and not at the back with all the BRIGHT ones.
Instructions ? i am basically fu–ed, i have learnt to watch the others[especially when in a brothel at 16 in HONG KONG] and when my turn comes try to do the same!! as them [that is why a fanny is made round, to go round] there are 3 loading gantry’s so 3 trucks load at the same time next to each other in the same area.
Basically the system of loading is this = you drive under the gantry pull your ladder up on the tank, climb up, i have opened the lids before and it is not raining ,attach a flex static line that comes out of a reel ,from the tank.
You are standing on your tank top, the first hole/lid, is directly underneath a large flexi plastic material hose that the product will drop down in to the tank… however there is a electrical cable, also flexi hanging down on the end with control buttons marked red, and green,… you have to prees the green button to let the hose drop down first. and also plus and minus buttons… if you want 4 minutes you press 4 times however i had no idea how much product you get in how many minutes .
ie tonnage, so now i am total screwed , there is so much noise of banging and hissing, all the lorry engines are running on tick over and you are getting all the diesel fumes, i had to start i thought i will press the button for 3 minutes and see how much goes in to the tank, [i did not have a watch]so i pressed to 3 mins then the green button, and hey pesto, product started to drop out of the large pipe in to the tank, and it came out like a torrent
Whoosh, dust was coming off it ,[zb] me in side the tank a massive pyramid was building up of product, as if it was going to come over the lid but it was starting to slide down inside, i had no idea of what weight was going over the front axel then it stopped. 3 minutes of time i am uncertain [have i done right] ]like a idiot ]i got on my knees and looked in side the tank and could see there was a fair amount of product inside so i judged that was enough , i had to press the button to lift the hose up, then get down. Get in the cab and drive forward to get the hose !over the next tank lid hole.!!
I guessed about the distance, so as the hose would be over the next tank lid,i stopped the truck and switched off the engine …went up on the tank top and i was miles away ,[not far enough]] so i thought about it ,it needed two men
The others seemed to be getting on better than me, but it was so noisy they would not here me …i thought perhaps one driver stood on his tank top and the driver wanting to move would be told when to stop going forward by shouting. Ie “you work together]”but that did not seem to be working like that i could tell ,i tried shouting oi,oi, but no response to much noise .
How do i get to know when to stop, because you can not see the lids from the driving seat, and you need your neck to be on a swivel , it was a matter of distance between the lids on the top of the tank , converted to the distance of how far you drove forward , to get it right.
I thought for a while and could not work it out at all, i thought it is no good i am going to have some help here or i will be here all day so i looked around to the lorry in the next bay ,as he was left hand drive and i was right hand were togrther both doors and he was on top of his tank, i have to shout him down, as i walked down his side but you have to stand back because if you stand by the tank, look up you cannot see the top.i noticed there were two working gloves on the floor by his wheels, but they looked placed not just dropped, i still could not work out how to do it.
After 2 minutes he dropped down off his tank, looked at me ,and grunted something walked passed me ,bent down and picked the furthest glove from the front of his cab up, and then paced himself, one foot in front of the other about 8 foot, then placed that glove down on the floor ,he then got in his cab put her in gear [as it was on tickover]and drove forward until his rear drive wheels on his tractor unit came to where he had placed the glove, and that was the” gap between the lids on top of the tank” ,converted back down on the floor the right distance you had to move forward to get them in line.
The penny dropped ,i did not have any gloves, so i got some socks and put some dirt from the grass in them ,and that is how you do it [and that is truth…i could go on for hours about how i put to much product through one lid ,not enough ,in another what i did not know was!! no matter where you put the hose in to the tank, only the amount of tonnage, that was allocated to that time you were under that gantry would be distributed while you were there
if you put it in through 3 tank lids it was down to you. so i need not have worried about the weight because there was movement with the product once you were moving and a few quick braking stops would settle the product down i found out all this later,.
After what seemed a long time i pulled out from the loading, bay parked up closed the lids down real tight threaded the TIR cord through and attached it through the end of the exit valve at the rear of the tank and used the company seal they gave and clipped that on.then took the static line off and moved away…
Apparently the customs were cleared at the factory works they would put there own seal on i went to the office, .they knew who i was ,and the man asked me for something and i had no idea What he wanted, another lady said in English where are the samples of the load, what did you do with the plastic bags you were given when you went to load , my reply was what samples ,she said you were supposed to take a sample from every time you used the delivery system that is what the bags are for. You could imagine my reply ,so what it meant was i was to go and get a sample of the load and put it in 5 plastic bags how the zb was i going to do that i had no idea.
I was in their parking area, so i new i would have to break the seals so i would be able to open the rear exit pipe just to get a sample, when i looked at it it was not possible to open it, if i did ,imagined it not stop pouring out under the pressure,you could imagine it a full pyramid of product at the back on the deck with me in my head sticking out of the top and say [did you mean this]. i walked back over to the loading area to see if there were any heaps of product on the floor i could just get and put in the bags , but there was not one bit.
My next move was undo the break the seal on TIR CORD, go up top ,open one lid get some product out fill the bags, then go back and explain the seal being broken ,get resealed and away … i undone the seal on the T.I.R cord. climbed up to pull the ladder, up it comes up automatically,so as i would not fall off the tank, i thought if i just pull the TIR cord up and out through the last tank lid that will be fine ,the ladders have 3 safety wires from the back to the front of the tank …
I undone the screw lugs holding down the second from rear lid so no one could see me,i opened it up and looked in the product it was not to far down inside, like a pyramid i would be able to get some out how. ,”Jesus do i create my self some problems…
The next thing that happened was one of the most stupid things i have ever done in my driving history i knelt side wards to the open tank lid and i had a plastic bag [a duty free bag] put my hand down in to the product scooped up a big handful of product squeezed it in the bag so as not to lose it as i done that i got a tingle static shock that gave me a jolt ,I threw myself from the top of the tank, against the guard rail , that saved me from going off the top, it all happened so quick i did not believe what just happened…you sometimes get static shocks from some type of clothing when you switch a light switch on well I do and it was like that.
.definitely stupid thing to do and i was very lucky and the best bit is that no-one seen it or knew what i was doing ,i put it down to not being connected to the static line as i was in a parking area.
Once i had got over the initial shock i still had the product tight in my fist and i put some in each of the sample bags ,and told them i had to break the seal and the customs seal ,the dutch use string seals and clip ot with a birt of lead, that went down like a lead balloon however it was all sorted after a hour.
If they told the head office i do not know ,and i did not care . I rang the office at home told them i was loaded and i would be finishing when i get back in 2 day and said i was going back on the fridges, they assumed back to Pulleyns .
The old saying “the grass is always greener” do not believe it, if it is a change you want do it, but always leave a job on good terms.as i have done more than once. If managers know that you can do the job and be left alone to a certain degree you will always get a job.
I was once again in the world of the unemployed, my decion my fault i got my old diary out with numerous names of firms all over the UK and beyond i used to just jot,/scribble, drivers names mostly fridge companies.
I did try to get on Bowkers, at Bamber Bridge, Preston , 20 minutes away from where i now lived, but at the moment no spare trucks ,all their work was dry goods, tilts ,i did not want to go back driving in the UK at all so i had to start thinking further a field.
However out of the blue I received a phone call from BOWKERS, would I go in to see MR Turner it was a Wednesday ,once there I was taken up stairs and walked into the office then in to another one, where I met two of the most fairest men I have ever met in all my transport driving years MR Bowker MRTurner I will state the very best!! company and bosses and,staff.
I was asked would I like to work as a relief driver on the European side I do not know how or why, I was not bothered and of course I said yes iot would be for about 2 months never had a driving test either.
What the big suprise to me was the were left hand drive road trains with the bed /UP the top just two seats and your back was on the bulkhead I had never seen anything like it before, also you did not need a class one to drive them back then
It was strange going up through a hatchway in the roof to your bed,there was a escape hatch in that roof so you could get out and get on to the tilt top,thank god I never needed it,I got used to it for the time i was there I new it was not a permanent position but I thoroughly enjoyed it there all the drivers I met were ok ,there was bit of banter between the HULL depot drivers and the Bamber Bridge LANCASHIRE and YORKSHIRE i never got involved i was a Foreigner,from down,south.
You would never believe the war of the tea pots [sorry roses]still existed you would get blokes not drink tea if it was made with lankashire water[water]and vise versa all good stuff but i was never included again as far as they were all concerned I was a southerner ,well they thought I was,buti was from the midlands but that did not count …
AS far as LONDONERS or southerners as far as northern transport drivers was concerned there was never no quarter given just a dislike and being in the middle I could side with who I liked because I lived UP north lad.ehh.
Ithink all the European trucks Bowkers had were BELGIEN REG they had a depot in ZEEBRUGE right behind the very first garage that I ever went to and the same bloody system still existed, men would leave their filling hoses in the tanks filling up and they would be sat around the same table talking crap and not bothering about the others , waiting to fill up that used to annoy me about the only thing that did.some of the English men were as bad but this time i was in no hurry to get moving.
They had some very good work, nearly all ITALY, a country I got to know my way around before ,well any one can with a map, cant they!.i must have been working there for a couple of months or maybe longer my dates are never right plus I have never written any at all down I go by different thinks what happens around me.
Time for me to move on again I think someone was off sick and got back fit for work back to the drawing board, however I had a idea where I would try my hand i would be driving in DENMARK i hoped.
As you know i had recently been there and while i was there i did ask around about getting a driving job to most drivers I met up with,in fact most men i came in to contact with ,their response was overwhelming yes
However there was more I did not know.
The now modern trend of Employing drivers from Eastern Europe was not yet in the Danish thought of cheap labour like it is here in the UK ,so that was not a concern of mine then.
I talked it over with my wife ,no guarantees ,what so ever of getting work ,so i said i would give it a week, if no work i would drive down to Holland and try there if no good i would come home ,Money was the main goal.i did not have a lot to throw around ,well the credit card did.
I did no more than got in touch with the ferry company from Harwich to Esbjerg and booked ,one way car and me ,for the next crossing the next day, all my gear was in the car just my clothes to put in i had to be there by 5 pm so it was a fair old trot from Blackpool to Harwich but it had to be done.
I made a point of getting a early start i decided to drive down the M6 then cut over around Northampton more or less the old route that is now the new-ish A14 i did not stop until i needed fuel ,way over the east side of the country. I reached Harwich about 3 pm , in fact MORTONS briefly had a depot there.and BRS elmstead market was near by.
I had not been around that area since the late 1970s it had not changed much. Once i had pulled in to the parking area i made my way to the ticket office, there was no problem there at all i was given a lane number, go wait there until called to load i was in a multi occupancy cabin ,it was cheaper, what did i care i only wanted to sleep anyway .
I had just a night bag, i was used to traveling on ferry’s ,so it did not need much sussing out, i found my 4 berth cabin after getting a key from the reception, found out meal times , and knew it was time for a beer or two.
Once i had settled down from my long drive, the pint never touched the sides,[ i did, and do still like a beer] so i was soon up for another at the bar there were lots of men just like myself so you just hang around ,the bar and you will soon get talking to someone [well I do],there sounded like a lot of north east [Geordie ] accents so i figured they are not drivers as they all seemed to know each other, so i asked one of them if they were go to a match, [what match i have no idea]
And he said no we are all oil rig workers, well that got my attention straight away anything to do with sea, rigs ,ships i am interested in, it turns out they normally sail to Denmark from Teesport but the ferry had a problem so they were all bussed down to Harwich, then taken onwards when they dock
It turned out, i am in the same cabin as 3 of them, so in the conversation they asked what i was doing so i told them, no job just on the off chance, one of the men who was a Forman said to me if it does not work out come to us in the north of Denmark and he gave me his card and said with my ships experience and driving as they were land rigs as well[not a pun] there would be a job for me, and he was sincere , i asked the other men when he left ,and they said, if he said it, that it was true…
Only a couple of pints, a dinner and i was soon of to bed…no sooner was i in bed ,the other men were getting up ,I must have died ,it was time to disembark and i had missed breakfast, it was straight down to the car deck and not long before i was driving off in to the unknown .
I stopped at the ticket terminal on the way out to change some money up ,i had forgotten on the ship ,another blunder…it gave me chance to look around get my bearings and get the exit right instead of driving around looking lost…
Once i had studied the signs and i had changed about £200 into Kroner
I knew where i was going, it was to the border town of PADBORG when i was there that once before i had never seen so many road transport companies in one place, if there was work that had got to be the place…
Once i was on the correct road, it was signposted ,and you had to drive in daylight with your side lights on ,i was soon away from the port it turned out to be not such a busy road and it was not long before i was driving in to PADBORG.
It was about 90,odd ks 1hour and half ,blimey i did not realise it was so close, i pulled in to the massive transport ,garage ,estate and started to drive around the roads to get my bearings of what was there it was like a village on its own .
There seemed to be a awful lot of trucks parked up in neat rows in all the transport yards .more trucks that i had ever seen i did not give any thought to it at all, after driving around there were 2 main truck stops, diesel pumps ,restaurants /shops and parked up trucks some filling up with fuel, so i found a safe car ■■■■■■■■■■■■ away from the trucks, i did not want my car crushed by accident by being parked in the
i s ussed the place out, got out and rolled a ■■■, did not see many people around i locked my car up ,and walked in to the shop /restaurant , and had a look around again to see what was on the food menu and could i understand it, it seemed and looked like they had a lot of types of pork ,roasted, pork ,baked pork ,fatty bits pork with the fat all baked brown it looked good, but i went for the spaghetti.without pork.
There were a few men busy eating ,and i kept a close ear to see if they spoke English but they did not ,i had my mealand my first danish black coffee,[me and coffee are not the best of friends] and i thought i would go to the fuel filling kiosk get a can of drink and try to get some information from people working in them places all overeurope knew most things what went on, and you could also get a coffee Free,!!
In my mind i was pricing things up that we had at home/ chocolate, etc,also [truckers trash] my biggest pet hate all the bloody stuff some men put in the cabs and windscreens,i us to tell men when the old windscreens were scratched, and like square port holes ,and mirrors like the size from a budgerigars cage you would not fill the screen up with crap ,also and it seemed a bit more expensive here, i got chatting to the man behind the counter and asked if he spoke English, of course was his reply so i asked him if i could ask a few questions please ,and he said no problem.
First i asked where i would be able to stay in a bed and breakfast around here he looked and said it is not called a bed and breakfast here, it is called [A CROW] and yes there is one close, but why are you not staying in your truck,[he assumed i had a truck that would be normal]i then said “i am in my car and have just got of the ferry and i have come he to get a driving job,he then said you already have a job to go too” no i replied have come here to look for one on Monday
He looked at me and shook his head, and i said, “why what is the problem with me looking for a job on Monday”
He said we are on our months shutdown holiday every where is closed down for the month except a few local transport firms, and swedes and norwegians transiting .
OH Bloody hell what the zb have i done you stupid [zb]…
He said ,go find the CROW he told me the road name, and come back Monday morning and see me i will be here i will see if i can help you ,bloody hell !i thought I could go back get the next ferry and forget it, treat it as a quick weekend break[what you cannot afford]
At that moment my guts just nearly fell out, you zbing idiot
Driving around the estate looking for the [crow] hotel, was proving to be a waste of time i will have to ask someone ,trouble was it was like a ghost town no one around ,well you would not normally walk around a factory estate on a Saturday would you,i went back to the garage, and got him to write the name of the place and road down, this time ,it turned out it was about 5 minutes drive from the garage.
Once there ,i just took the small ruck sack with me , like a overnight bag with just essentials just to look like a traveller, it was nothing like a hotel it was a ordinary house from the front, until you went in and it was massive, i took a room for one night, signed in ,paid in advance ,no food served, until breakfast and settled down to review my future.my dinner was biscuits chocolate and water.i still cannot believe it ,my wife would say typical [bull in the china shop]
After a fill up at breakfast “i was going to have my monies worth” all continental , cheeses, hams cold sausage ,eggs, toast, i thought that will do me for a time, i signed out, and said i will probably be be back tonight I spotted a visa sign on the checking in desk, yippie, and left in the car, back round to the garage, to try to get information about any type of driving job.
He was a very helpful man, he wrote down some companies addresses but did stress.he knew they were closed maybe some had skeleton staff there was no more he could do for me ,he printed of a map of the estate and marked where they were and that was it. I just drove around trying to get the layout of the area like a nomad.it was not a populated area at all.i did not see any type of community .
So another good night,no dinner, but i had filled up all day with junk food, after another fill up of their breakfast the adventure [zbup] begins ,and i was none to hopeful, as every transport yard i went passed was full with trucks and trailers parked up gates and locked.
However there was one yard that had movement, so i parked out side and walked in towards the warehouse [no dogs]there were two men ,well dressed,on the loading dock, they spotted me and said something, i waved and walked over,and told them what i was doing ,they said come back in 4 weeks they could use meas i told them all while we stood on the dock they could have been cleaners for all i know. it was anders-anders company for north africa well that but some spring in my step.and one of the men was a duty manager.i filled that away in the old brain. then the last one i spoke to in perfect English said i think the agencies are still working, ”
It did not register for a minute of what he had said ,for some reason i turned and said “AGENCIES”
“Yes” he replied, i said “sorry” “what agencies “the driver agencies” he said, i was still not sure what he meant, so he then said the company that supplies drivers when other companies need more drivers when they are busy , i had heard of agencies but never had anything what so ever to do with one.
He tells me where to find them he felt sure that going to see them would be a good idea as they were about the only people working in the area.
He wrote down the name and address Euro Driver Service.Lejrevej4 Padborg. What had i got to loose ,nothing it looked as if i had made one big mistake ,coming here on day one, however only i knew .
Luckily it was not far at all i had been past the Bungalow/type house/yard/warehouse before, but there were no signs about the building at all it looked like a large bungalow on a trading estate.
There were a few cars parked so i stopped outside on the road and knocked the front door ,as if visiting family, and waited. Soon a rather large man emerged and spoke Danish, i interrupted him and said” excuse me am looking for the driver agency, that was fine because he said “yes it is here what do you want!
“I have come here to Denmark to find a driving job and i did not know it was the holiday time ,my mistake, he asked me to come in to the office, it was a ordeniary living house with no furniture in it.
He told me yes this was the driving agency and then said would you like a coffee ,yes please i thought i will be bloody hyper if I have any more.
He started to ask lots of relevant transport questions , about transport in general ,i had written a list of my list of driving jobs, and companies and what countries we ran to, and cargo carried, refrigerated or dry goods and the main Phone numbers and names of bosses or manager , also a short history of my other work and included my old discharge book from the M.N.all good stamps so it was now up to him.
He said go and get a coffee [again] in the other room, and have a seat it was like a proper house kitchen ,i looked like a driver, check shirt jeans ,where as the other man had shirt and trousers on ,and he would see me in a while , after a few minutes, another man came in and i could tell he worked there in some capacity they way he walked about the place he did not speak for a start ,but later he came and got a coffee so i said hello ,and he replied in a Lincolnshire accent
Now that pleased me a lot, so i started chatting, and told him what a [zb] i was for coming here in the holiday time ,i should have thought as Italy, Spain ,Germany, all take the same break, but it was too late i said i will just get on the ferry and go home, he said No just hang about a bit, there maybe a opening here ,as yesterday one of the regular drivers has been caught drink driving in his car and here, it is a complete no , zero tolerance.
We got chatting , he come from Lincolnshire a ex owner driver, and never elaborated so i just asked what happened here ,what do you do, but first he asked me who i had worked for and to see why i was here so i told him the lot.then he started to tell me what work they do.
To start off the company have a large bungalow, divided into 6 single rooms ,shared kitchen ,and large walk in bath room ,tv lounge ,all services paid ,however they de duct the rent out of your wages plus service but he said it is very good ,some of the drivers are away home at the moment and there are only four at the moment ,well 3 now as one has just got done for drink driving in his car
, He will not be able to work here from today ,with any type of charge regarding drinking here, zero limit, so he will have to move out as the accommodation is for drivers only so maybe when they have checked you out you and they will, you might be lucky .
Well that was maybe good news for me, yes I know some readers may say what a load of load [zb],it was true .
The job! entails you drive, a persons truck[ a shift] to wherever the office say, as the driver will be taking their rest period in the truck asleep, in other words you are getting the truck another 8 or 10 hours further on in the journey so then the original driver goes and starts another shift whenever you are told to be
.[double manning the wrong wayagain us in England take thelaw to the extream we are supposed to start a journey together and not operate the way they are here??
If you are getting the job and live in the bungalow ,we all share cleaning the shower room toilets kitchen,general cleaning all round ,they check every week if its not good they charge you more rent you have your own fridge in the kitchen we all have our own locks ,there is a communal cupboards if you don’t mind sharing dry goods if you use the oven or cooker you clean it etc,it sound ed good
Some jobs You will be woken up by the other driver you are to take over from , it could be at any time 12 midnight .3 am when ever they get here you will be given a near time to set your alarm,but you know trucks hold ups etc …each company they work for [the agency ]have a key to the front door and they will be told what room number to knock on, to get you up, it takes a while to get used to it, you will have time for toast and coffee, then you must go as the driver will be knackered or pushing for time That is if you get a job first ,after a time i heard someone call this chap and he said excuse me and left, i never thought anything about it at all and sat down.
About 15 minutes later, another young man came in the rest type room and said my dad wants to see you …” ok”.
I walked in to the office and it was like a family gathering and he did not ■■■■ about he said victor! i would like to offer you a job ,as from now .that was it, he introduced me to his family they all run something within the company, and the other chap was there Frank
Frank , said get in your car, and follow me, i will take you over to the bungalow and get you settled in ,to be honest i could not believe my luck, apparently they had cleared the other chaps gear out, and cleaned the small room up, wardrobe, small chair ,table bedside table, lamp a window blind big enough, like a small cabin on a ferry. I did not take my gear out of my bags yet i had some ferry sheets, from years ago just right for a lorry s bunk bed that was the size of the bed in the room.
Once i had settled in after a hours lie down i walked in to the kitchen and Frank was there, and he said they did ring some of the numbers you gave them ,and then he said i was asked to pump you as well ,and i knew you knew the job.
He then explained that there were 6 cupboards one each some still locked, put your name on stuff in the fridge, if it is not named it means it is free for all, most times milk is used by all we all clean up when we are finished ,the big shower room gets cleaned by all, a vacuum cleaner is provided ,do not use if any one is on nights or at night.
. So, i would soon get in to rhythm, weekends if not working we all chip in for a big dinner, we all try to cook he said , i said no problem there with me i can cook ,and idid later on for all ,I even introduced them to Yorkshire puddings ,some thought it strange but frank and my self scoffed them
As i was told by Frank early you are there for pushing the trucks further down the road [basically] on their journey and the name given to us/me /you/ is “A SPRINGER” That makes sense you jump from one truck to another ,hence “Springer.”.
All Scandinavian ,and most European drivers now what a Springer is, however in the UK i/ we have never heard of them.
You are best always take a sleeping bag with you ,a change of clothes and a pair of shoes [slippers] to drive the trucks in, and always take you shoes off when you get in any ones cab.
Most drivers have carpets[drivers side] and drive in socks only, as there is not much gear changing on the Auto- bahns, etc i.have a pair of clacks shoes ,slip ons .also the driver is in charge if he says this is where we change over and i have to get out that is it.
Once the truck,me, and driver get to where I have finished my shift i am to sleep normally in [a motel] already booked by the office they had permanent rooms booked every day or night in most places they were needed.
I would not know where I would be going once ,with another truck, once I had my sleep break, you would be picked up by another driver going back to DENMARK. or it could be another way ,some drivers were ready to get in the bunk once you got in to the cab ,well ,you did not have to try to talk over the engine noise, some drivers would just drive until they would have had enough,I would not have liked to have trusted many of them because they did not respect the law ,sometimes when I opened the tacho head to put a card in their card was like a big smudge but they did not care god knows where some of them had come from .i never asked. and i never seen any paper work.
On quite a few occasions I was dropped off at the border for GERMANY AND HOLLAND AT EMMERRICH OR HENGLO
Then you make your own way back to Denmark after you have got over the other side of the autobahn by stealth ,
No bridges ,then you either thumb a lift, or get to the nearest town and catch a train, coach whatever, you will be on pay all the time even sleeping time ,and all expenses paid ,from when you left the Bungalow until you get back to the office all are paid whatever .
A lot of the jobs, you will drive maybe a full shift through the night and then go to a MOTEL the room will be booked in the company name, and you hopefully sleep through the day you will be told by the motel ,what time you will be picked up when they wake you up.
Another truck will pick you up, you will not know where you are going until it arrives, it could be going to Italy, or back to Denmark wherever , you will drive a shift as soon as you get in the truck you stay with the truck and driver and complete the round trip with him that never happened to me although others did,you never know knew what work you will do…
Some of the drivers at this[agency][Padbourg] have been doing full time work for some of the firms based in Padborg but still working for the Agency, the majority of local firms will not give you a full time job, because you are working for the Agency, as most of the haulage companies relies so much on their service the companies will not take the drivers “like me” away from the agency because drivers were always needed
.Frank one of the drivers staying in the bungalow said he has tried for a year [that started to ring the alarm bells]with no luck to get a permanent job with any of the firms, and he is a experienced ex-owner driver from England it seems once you get onto the agency books ,you will not be employed by any local firm for distance work for the reason stated.
I did meet 3 other English men who had been working within Denmark for a time but were unable to move around the companies, they seemed to have good jobs however where they were living was a bit rough ,in fact is was not good at all
someone ,the owner of the house i expect, had made a large room out of a very large attic room, low joists ,covered in hard board, on a 4th floor 3 beds were portioned off with hard board with little finesse.
My first thought was it was a fire trap no way would I have lived like that ,odd bits of furniture odd chairs ,not the place to call home however, they did , it was the best they could get also they were away most of the week but one man had a local driving job he had managed to brake away from the same agency.
A few year ago.apparently the laws have changed for foreign workers and that was it.,however i did not think too much about it. as such, they were short of drivers and the foreign drivers filled the gap .when I think back it was not a lot of difference from the situation now here in the uk by foreign drivers the difference was the Danes had to pay us the same going rate.
The Agency company took me to the local council office to get you registered ,as a foreign worker ,and for income tax ,etc. so you are legal.
i had no idea as what to do but it all has to be done legal to protect the company and me, also to open a Danish Bank account as all wages are paid in to the bank plus i set up a direct debit to send home money every week once i got paid…l one of the bosses sons did it all, in Danish ,but i felt it was the right start .
That was on the firstMonday all done there was a direct phone from the office to the house and they new where every one of us was at most times we were like on call, they told me i would be picking a Scania fridge truck up at dinner time at the main garage the next day the details would be in a pigeon hole box outside the office if i wanted to fetch them …
I was to drive the truck to LOCKEREN Then sleep in the drivers motel, the same driver and truck would pick up next morning, the drive back to PADBORG…He was going on to a market in northern France , i knew all that area well so it must have been around Calais Lille area.
Next day i was a bit nervous ,found the truck ,the driver was waiting the fridge was roaring away. I knocked the door and opened it he was already in the passenger seat , i got up took my shoes off put my clacks on then shook the drivers hand ,he grunted, a hello.
I asked do you speak English he said “gruffly," of course” so i said my name ,and said sorry i do not speak your language, he just looked at me vacant so i said to him i do as i am told, if you are not happy with me to drive your truck just pick up the phone and phone the Agency, ” he said no i was expecting the irish guy,are you from ireland, i said no i am English” ok he said ,we must go I think the usual driver he had was the man who lost his job.
We shook hands again and i stated the truck up i
I was ok with left hand drive so that was no problem I checked mirrors, got ready to pull away pushed the clutch down started to engage 2nd gear and it just stated to crunch, i thought what !I tried again and the gear would not engage at all ,well the look on the drivers face was a classic ,as if to say what the [zb] are you doing.
By now i am starting to wonder is this different to what i have had, so i pushed my left foot down hard again, tried to engage gear ,still no go, so just by chance i looked down it to the foot well where the pedals were, my left foot was pressing the foot-rest down a! i soon said sorry ,and a smile come on his face ,so i used/ the clutch ,promptly drove out of the Garage and all went well.
The load was FISH, he soon went and got into the bottom bunk all his gear on, once we were on the main autobahn i knew i would have to have break ,but if i got out and the door opening would i assumed wake him up, so i just smoked a few more ■■■■, had my break, and drove on it was not far and not hard about 7/8 hours driving i gave him a shout as i was turning off to go in to the garage at Lockeron
Everyone knows this stop,[i dId show it to you BEN] i turned the truck around, took my gear ,and he said he will pick me up at about 5/6 pm that night i went into the Motel, a room was booked and off to bed.
I had asked for a call at 4 pm ,that went well, he arrived about 6 pm god knows what he was loaded with but the truck was heavy i did mention about me getting out when i have a break, [waking him up ] he said ok no problem .
It was a straight run to Padborg i arrived about 4 am the driver was well awake he smoked nonstop when awake i drove round to the bungalow ,grabbed my gear said bye and off he went.
I soon made a tea and in to bed however i was not tired, as i had not done much at all, i thought this cannot be the job, but it turned out it was it was regular and irugular and we all took turns doing that run.and more like it.easy money as we got paid on the kilometres how that worked i have no idea…
I soon got in to the run of things i under stood i was last in so i would not get the good jobs, but i excepted what they gave me ,there was now the 6 of us in the bungalow when they were there , then gone again what jobs they have been given i have not the faintest idea but I sussed I was at the bottom of the job dish out.
You could be on days ,then nights then afternoons however they made sure you had your proper rest /time off every time you got back to the yard/office. I cooked a Sunday roast for about 4 drivers it went down well all except the oxo cube gravy that was all i had.
No one every mentioned about getting full time employment with the companies, they all seemed satisfied with what they had got. I never asked where any had come from, or why they were here, i could tell they were not old hand experienced drivers, driving up and down from A.to B was about right from them doing nothing else.
,I did start think i am a bit to old for this type of life like a wandering nomad i sort of released some of the others did not have family they gave me that impression, you never knew from one day to another what would be happening
.One day i was told to catch a train to Esbjerg , get a taxi to the docks and there would be a road train parked up there, keys in the office i was to change the two boxes from empty, to two full ones in another compound #
To be honest i said yes ok, and never thought about it ,but when i got there Jesus it was a Scania 6 wheeler and a dolly with the trailer the usual european rig, that was a tandem not a straight frame, with a A bar coupling, like at home i was out of my depth. Just the same as a farm tractor and trailer
.First i got in the cab started her up, went on tick over so i went and looked around i was told to drop the empty boxes where they were and the ones i wanted were next to them, ZB ,i walked around the container boxes and undone all the twist locks .
After i had the air pressure right up i went and lifted the trailer up on the air bags to its max, and pulled the landing legs out from the sides of the trailer where they are kept [fixed] and pulled them out to the max, un done the twist locks dropped the chassis of the trailer down the box will stand firm on its 4 legs you have pulled out from under the box on to of the chassi
so you can drive the chassis out from under it leaving the box standing up on its legs ,i hope you get the picture,…
i had forgotten to lift the front end up at the same time so it was not good to pull out from the box as it was not level after i had undone the 4 twist locks so i thought i will now drop the chassis down from under the box, so i just did it and the chassis dropped down slowly with me on the lever letting the air pressure out.
Do i now do the same to the front box drop it there or pull the trailer out from under the rear box and park it up somewhere so do the same to the front box and leave it in front of the rear , i did that and it worked ok only half the job done now for the hard part…
The 2 boxes i had to pick up were behind each other, so i have got to back the rear chassis for the trailer through under the front box so it is under the rear box… how the am i going to do that.
Because the box at the rear had got to be on the rear trailer, so i thought i would drop the empty rear chassis, now , and with the front end, go under the front box, lift it up pull it away, from the rear box and then drop… it pick up the rear chassis again,
So now i can see the rear box to get under ,i now have the rear chassis attached to the empty front end ,i am trying to get the rear chassis under the rear box, well as i was not used at all to the sharp turning it was hopeless ,lets face it i had never done it before, i suspect i was drawing attention from the high office window
I did no more i went to the office where i got the keys from i asked for a person who spoke English and they nearly all did so i explained my situation ,held my hands up ,and asked if there was anyone who would back the trailer under for me as i was useless the trailer was going every where except under where i wanted it to be,
.Next thing the same chap pulled his florescent coat on ,and said to me you must have one of these ,so i said sorry i have not, he shrugged, gave me a coat and walked over to the cab of the Scania i got in the passenger side and sat opened mouthed by the time i had looked in the mirrors he had got the chassis under ,that was what i called a experience.
I could not thank him enough, i did not know what to do offer him money ,i had hardly any, so i said to him is there anything i can do for you He said no i know you English do not have hardly any of these combinations , only on farm tractors… and he was correct, i made sure everything was secure and said my good bys .
Once i arrived back at the depot/base i went in to the office and told them what had happened ,they were not worried one jot, so i asked am i taking the truck somewhere, and they said no another driver is taking it into GERMANY.
That was me finished for the day ,no run tonight so that was ok , i was a bit ■■■■■■ off that i was not taking the road train ,however it would have been a bit embarrassing for me if i could not reverse on to a ramp somewhere so on reflection i was glad i was not going with it.they had probly rang the agencie
I had done numerous runs in to BELGUIM and slept over, also fish runs with other drivers, we stopped over in Holland at a house the Agencies use . 4 bunk beds very clean.
We arrive about 5 am at this fish type factory ,and the driver said [we get coffee] like a command, we walked past this old wooden type warehouse on the side of the quay with double doors half open.
and i could hear some type of music like chanting, i looked in through the doors and i was blown away, something i had never seen in my live before ,there was a long oblong table that was covered in a small type of fish , about twenty ladies ,young girls, all swaying , all doing the same movement in unison like a rhythm ,they all had a very thin bladed knife in there right hands and a fish in the other. they were gutting the fish at the same time… it was mesmerising .
Why they were doing it to a rhythm? i did not find out, it was impressive they all had clogs on and like the Dutch national dress type head scarf’s done up like from the 1940s
We had another black coffee i must say i am getting sick to death with bloody coffee ,that is all they think about in Holland and Denmark We eventually went to the house there were other drivers,
First thing they said you want a coffee,this place was like a small hostel i knew iwould not be having in depth conversations with them
. Another driver took the truck and went off and did the other deliveries then loaded it for us to drive back to Denmark, it worked very well as i did not do a thing, the driver he was not Danish but the truck was he had the same sleep as me and. drove it himself and i was passenger. god knows where he went too but we made a short stop in a street in Hamburghe was not long, unless he went and had a “short time” at some brothel i did not asked,so i said can idrive as i was falling asleep.i did not want him falling asleep to be honest I never thought of the danger being with other drivers driving,mind you they probly thought the same about me.
I drove back to Padborg stopped outside the Bungalow [not tired] but silly o clock 4 am and went to bed…
Life in the bungalow was ok for me and we all seemed to keep all of the communial areas clean.as well as our rooms ,we were told that they would be checked by the boss at some time ,that was ok by me.
Work seemed busy for all us drivers, i knew i would not get the best of runs ,but I was glad of the work up to a point
.Afew times the job I had was drive the truck to the border at Bad Bentheim park in the border layby
,[why I did not take it further to a truck stopI do not know as it would have been better for getting home,]
Waking the sleeping driver up from the bunk, and I would then get out rain or shine and make my own way back,by crossing the carriage way and thumb a lift,or make my way to the nearest town and get a train, time was not a problem untill I got caught in the rain I would be paid until I got back to Padborg .
It was normaly around 7am ishwhen we arrived at the border,
At that time in the morning most of the drivers in trucks parked up were still in bed,I would walk around and look at the reg plates to see if I had a chance of a lift , danes ,swedes ,norwiegens would give you a ride ,normally they all would be heading HAMBURG WAY.and they all used [springers]
One such trip took me a while I was dropped atBad Benthiem the route home would be Osnabruck Bremen Hamburg the truck I was in broke down so a double f—k up, it was a low loader slow as it was.it had a ■■■■■■ car he was behind, he was not a fitter so they said the would take me to the next service station ,that was fine but wherev we were they would not let me out at any road junction like in England
If you know the german roads they work different so I had to go past the turn off to Osnabruck and the service station was on the directionHanover ,however I got back by luck the same day.as it was a direct route to Hamburg /Denmark And that made me relise a driver my age should not be zb about doing this work ,as good as the money was it was for younger men ,that was the biscuit .
The next day I was off until the night time ,I went around in my car looking for a permant job again for myself with no luck anywhere I wondered if the people I approached told the agency boss .
I did the nights run I stopped in lockerenand was collected by the same driver,with a load back for somewhere in Denmark,a lot better than thumbing a lift.
The next morning I went into their office and told them my decision that I was leaving ,they did not like it one bit I told a large [porky] because they had been so good and nice to me I thanked them all and walked out
I went back to the bungalow it was empty of drivers i got my gear ,put it in the car,did not see anyone else I went to the bank.with the cheque they had given me changed it back to English ,and drove to Esberg got on the ferry the agency even booked me on the ferry that is how good the were, to Harwich ,off the ferry at Harwich the next morning and here I was back in England no job agai
I had thoughts of going back to ACH ,but then maybe Pulleyns, I looked in my book of “rubbish” and SOLSTOR fridge work stood out ,they were in Charlton London I was on the A12 why not.
This is a long story so I will be brief I phoned David the boss told him a brief history I knew some of the drivers etc I was ready to start anytime ,ok come and see us he said ,I did ,i was there in a bout 3 hours ,we had a chat and he gave me the job,as a relief driver ,i had no where to stay, i did not like not having a truck of my own,however there were always empty trucks everyone shared in the yard to sleep in.
I was not the only relief driver i did now some of the drivers , there were quite a few like me waiting in line for the next truck to have for your self ,so you had to take turns in doing European, Spain for the, sainsbury veg contracts i knew i was never going to get my own truck as there were a drivers before me waiting to have their own unit to drive on a regular basis.
After a time I had seen the light, I knew what my role was,there were some good lads on the company in fact i knew a few of them one had just left A.C.H after many years,two from up north good lads,in fact all I met were,but I think I just wanted a permanent job and a truck to drive I did the same again and i left.
I had told my wife where I was working ,as a relief driver ,she did say you will not last long and she was correct I was going home again no job
Once home my wife was ok about it ,she knew I would not be out of work for long after 3 days I had to get something going ,I went back to my book of rubbish, [I call it that ],as it has nearly every European haulier I knew of ,i did just put company’s phone numbers down,for that "you never know"moment from the early start of my European driving my reverence book.indescribable to others but i knew.
Back home,I started to think maybe I should go back to the uk driving ,although I did not want to, as European gets as a way of life.
Flicking through the trusted book again, PandO “Pandora” had been written down ,and I could not remember why, i know they used to use the Fleetwoods docks ,but that was not why I had written the number down.
Then it come to me “Transcon”PandO out of Waterford ,Rosslaire southern Ireland .i thought never, they would not ,but the only way to find out was to ring them.
At this time the peace agreement with the North and south had just been signed ,i got the number from the telephone service, and I dialled it,it was answered I asked to speak to the recruitment person ,or the transport manager, and I briefly told her,that I wanted a job, she asked where I was, my age,i also told her I was a experienced fridge man.
,She told me to hold on some one will speak to you…,time just seemed to go nearly 10 minutes then a mans voice said ,hello victor,[now that was a good start to use my name from the start]I replyed and his next words were ,as true as I sit here were. “if you want a job come over and see us”…and he put the phone down.this is a Friday afternoon…
I thought ,bloody hell,i knew i would have to go over to southern Ireland but with no job in the bag , just as a off chance…then I thought about it,maybe ,it was test to see if i did want a job.
I did not more thinking, i told my wife what was said to me,and she knew I would go, at this point I did not have a lot of cash but a trusted credit card.
The passenger ferry went from Pembroke south wales to Rosslare , the ferry was Sunday night, I loaded all my gear up in the car the whole lot cooker ,telly ,tinned food ,clothes ,bedding,you would be surprised how much gear we used to have ,well what I had…
I was driving from Blackpool to Pembrook it was quite a long way, I was trying to decide what to do ,to take my car or just go as foot passenger and take a chance,I would decide when I got there.
That was one long driver I only stopped for petrol and ate on the hoof,like a bloody seagull.
Arriving at the ferry port that was also the rail station the were a lot of parking areas,I picked one close to the exit from the port ,as I might need to unload my gear, however I put some clothes in a small suitcase just to keep me going,iwas making it up as I went along I could well be back on the returning ferry.
I asked about parking ,and it was free i am at the P.O.ferry ticket office,I brought a open return ticket and waited to board the ferry,It was time to board as I walked to go through the security to the ferry i was stopped and asked not so politely, where I was going ,and how long for ,so I told the police man [special branch]what my intentions were ,he said fine ,however you can only board as a foot passenger with one plastic bag.gods honest truth, and I am not religious
No suitcase,for a foot passenger,[true]he said you go and leave it where you got it from, I was bloody furious , no wonder the Irish did not like the English Police, I had to run outside ,go to my car it seemed miles away ,I put inside a plastic bag, a razor,tooth brush etc,scarf, gloves,undies[2] socks [2] a balaclava hat,■■■■. Wallet passport .that was it I still could not believe it .
I ran back the same way to the ferry, the same man stopped me again made out he had never seen me , he let me pass, and I was on the ferry,it was now getting late, I was hungry and tired, there were no cabins -beds left ,all couchettes taken. Jesus I thought this is a very good start –not…
Other people around me were in the same situation, but all Irish ,I never spoke to anyone,the lorry drivers were in another area and they had their own eating area ,I had a sandwich,and believe it or not I settled down under some stairs as i was ,on the carpet .dont ask I just did it.
Others were all over the floors sleeping ,apparently there had been a big rugby match in England,and Ireland had lost ,that is why it was crowded…
After a sleepless crossing,in need of a good sleep after the drive down in the car I was not in the best of form…the Tannoy announcement told every one to get ready to disembark looking out side it looked foggy and icy…once off the ferry I stood out side the termal to get my bearings,but having never been to Ireland before ,it did not make much difference, however I had a tongue in my head…
Most of the trucks had driven out of the ferry ,also the cars just people waiting for taxes or cars, here was me not knowing where to go ,I went back in to the terminal and asked at the desk if they had a map of the area,one thing led to another and I am quite good at talking ,and told the women where I wanted to go she told me husband, just happened to be a dock shunter driver pulling the trailers off the ferry, into the dock or up to transcon yard she said she would go and ask him to see if he would arrange a lift up to Transcon,s yard with a shunter .
,That is how I got to the yard at 7am only a night security man was there and me, and the shunter he took me inside to where the security man was it was like a little room off the workshops ,they made me a brew and I told them my [abridged] story.
It would be 8 o’clock before anyone from the transport office turned they told me all so the day shift fitters, I knew I would not be of any intrest until they were ready, I was right, however they let me stay in the room apparently they were used to drivers in their mess room, that was good of them.eventually I was taken to see the transport manager, he said he remembered talking to me last weekend but did not expect to see me, he said he normally says that [come over and see me ] just to put people off ,and laughed.
It all went well,I had to go and open a bank account with the allied irish bank,that was fun I only had about £10 sterling no irish punts but the old trusted visa credit card worked its magic also I drew some ]punts out]also i was getting hungry, a little shop next door served its purpose it had pies in a little heated cabinet,just like Lancashire pies i was better after them…
When I got back the manger said take my car and go to the company doctors for a medical,[a first] it was a few villages away it took me some time to fined after sketchy directions , it was just a ordinary house a few cars in the drive ,like a normal property.
I parked up, knocked the front door and a lady told me to go in the waiting room with the usual doctors afternoon surgery ,and quite a few stares i got as they seemed to know that I was not local,i did not speak to anyone,not long after elderly man called me in by the name of “Transcon”the name of the company .
Usual medical ,then a urine sample, I had to walk through the full waiting room holding a kidney shaped dish and fill it up no lid so i balanced my way back through the chairs, hoping not to spill a drop…all was good until the blood pressure check, a bit high!! he said, I said, I have been up since Saturday morning ,travelling, he said when you go to your own doctor when you get home and that was that ,however I knew I had a problem as I was all ready taking tablets for high blood pressure it was now Monday late afternoon…and i had forgotten to take the days tablet too much going on.
Once back “I was about bushed “ tired out …and the manager said right victor I want you to take this unit and trailer to Dublin and work out of the dock they will give you instructions via the gate man.
I had to tell him, that I was so tired I would kill myself if I was driving right now I need to go to sleep and explained how long since sleeping ,he agreed ,and said be here for 8am and now we will put you in digs down the road it was now 5pm =ish
Someone drove me to the house on the main road, they were expecting me I received a warm welcome, and made to feel at home, the lady told me dinner would soon be ready, I was just about keeping awake ,it was toasty warm in the lounge, sitting in the arm chair looking around at the well placed photographs on the four walls, they were all portrait images of men, on closer inspections they were all of the I.R.A. High Command from the 1916 uprising.blimey I thought jesus, I am in a I.R.A.stronghold of republicanism, that was to expected, as I was in the south of IRELAND I.R.A.territory however never being as close to the “troubles” I was now very awake.
I never let on to the landlady about her photographs ,and not a lot conversation was had over a very nice meal.As it looked ,I was the only guest that night .Her and her husband[I assumed” ]started to chat and asked about me about myself ,I made sure that I said I was in not or ever been in military service ,but the Merchant Navy
Then it got a-round to why I was there ,I told them I have come over for a job driving European for Transcon.and have got a job start tomorrow ,she then replied my,you are lucky two ENGLISH men stopped the previous night ,doing the same as you and they were told they were not needed, and went back to England.
Bed time, there was a old paraffin heater on the landing ,stinking fumes, it was freezing in the bedroom, and I opened the window [I thought might get murdered ,but not by the fumes!! ]I retired to bed in all of my clothes including my balaclava hat, just my boots were left outside of the bed, I just hoped” no one came to look in on me.
Breakfast was special, all you could eat, so I did not let the side down. I was taken up to the depot for 8 am by the man of the house in his car I thanked him again ,and was left on my own to go to the office ,they were expecting me, I was given keys to a unit , no [zb] or companies regulations just get on with it no driving test,I was told where to fill up diesel in Dublin, then go solo to Dublin Docks collect a empty trailer from the pandoro depot, then drive to a large peat factory within a massive peat bog,area then take the trailer when loaded and drop them at the docks the gate man will tell you where i carried on for nearly 4 days just doing that work .
I was living in the cab,any work instructions were left with the dock gate man by phone then a note given to me,it would have been easier for me to phone them direct but that was what I was told to do, I had little money,nothing, I ate at a dock cafe that was cheap,also sometimes in a village on the way from the factory, I had also brought a sleeping bag, with my credit card and my megar supply punts were soon going down.
At the peat bog place/open factory bloody hell it was vast the odd driver going past gave me a usual driver wave like we all do a little sign of recognition,I bet if they new I was English they would not have …
Idid not come into contact with any men from the same company all though there were pleanty of other men from different firms there loading some did not bother with me at all only the fork lift driver seemed ok he would sort of make the time of day,also the man in the portr cabin office did at lest talk ,I had the feeling they did not want me there I wonder why !
The method of loading was they blew loose peat in to the trailers from a large blower machine fed by a fork lift putting bales ofit looked like compressed peat in to a hopper ,then it was like minced up and blew in to the box van trailer with sides like a taught linner and a soft top roof there were a few side bars from the floor to the roof looked as if the bars were holing all the trailer together when the trailer was nearly full they put polythene up at the back doors shut one door then blew more in so the side bellowed out, they pushed the rear doors shut with a fork lift, job done I had no idea where the loads were going to.
On the fourth day I was asked to unload a trailer within Dublin area which I did and gained a little insite to some of the roads within Dublin Industry area I did not have a map just kept asking.and bits of paper with map drawings on.
Back to the depot at waterford that evening,and was asked to pick a trailer up with four delivers in England,I did not show any excitement, however I would be able to collect my gear from my car…,and that is what I did ,that other job was hard lots of hand- ball.
So after a hard days work I was catching the the night ferry to fishguard /pemborke,once loaded on the ferry, tacho card went flying as with the previous 4 and put one in for it to show the rest on the ferry and if anyone asks I have just started with the company[officer dibble].
I went in to the drivers eating area and obviously they were all southern irish so they were all full of chat [but not me included but i expected that] eat and bed was my main thought.
I reloaded from England in a million years you would never guess from back to Ireland,no other than BANBURYgenerial foods what no one would never know I actually worked on the building of the said factory on HOD CARRYING for the bricklayers then on S.G.B SCAFFOLD COMPANY FROM BIRMINGHAM also when on BANBURY BRS from 1967 untill 1971 ish yes years ago but here I was and a lot of my family was 9 miles away but I had no time to go any where near.
Once loaded I shipped from Liverpool.deliverd to Dublin, I was now getting in to the swing of things, and feeling ok .
Next load was to Spain, 5 delivers of groupage, no main agent all deliverd to companys,funny groupage I ended up ,well west in spain,OURENSE AREA not to far from VIGO the trailer was a step frame,small wheels, when empty I was told to reload ceramic tiles, 3 collections from quarrys , god knows what weight was on the trailer I did not even care then a full fill out shoes on top meaning not a space to be had completly full .god I never stopped.
Once loaded I was told to ship from Cherbourg they gave me my booking number and the whole run that gave me like 36 hours.
I never moaned I just got on with it ,but I had just seen the light it went [■■■■] stop soon.no wonder drivers saying the Irish did not give two f-cks was correct ,total disreguard of the law I did it caught the ferry I was booked on, I was now officialy a “nutter”IE as running bent as the others.
A good calm crossing ,I slept well and got back to normal,if you have never” knocked your bollocksd out””drive nearly non stop” you will not know the feeling of proper rest,and if you avoid it well done you…
Once docked in Roselair, I drove up to the yard, nothing was said to me,it was normal to drive “one hitters”I had gathered that, I was told to go to Dublin and tip the trailer around 6 delivers .
The tiles had to be deliverd first,I asked about the moving of the boxes of shoes ,around off the tiles i was told where I was delivering they would do it and they did also they new where the deliverys were ,had no idea so I let them get on with it.at one delivery there was a mcdonolds on the estate that is where I went
After doing 2 tile deliverys the third one was within the fruit market I was told all this at the previous delivery, there were factory type warehousing in the market area so I was told however I did not know this[but others did??] I was given rough instructions of how to find it, once over a river bridge turn left at the first lights,drive on unti I would see a small paper shop on a corner named [ mc something] go and ask there and they will give me instructions,and they did ,I was only 3 minutes away, they also told me where the warehouse I wanted.
Once in the market, turn sharp left ,and drive down to the end and there they werethe paper shop chap told me ,and that is what I did slowly, I reached the road end ,and there was no tile place to be seen, I stopped and looked about, I never got out of the cab ,I looked into my offside mirror and in like a dream the rear door was open ,then I looked in the other mirror and that door was already open ,I thought what do I do now, if I drive back I could kill someone so I just laid on the hooter and pumped the brakes so hard and made lots of air noise.
I thought I am not walking back so I put the truck in reverse and drove backwards with the rear doors swinging back and forth i thought if the doors come off im still out of here.the trouble was I could not ,reverse direct back as there were like concrete raised platforms that were for loading hand ball on to lorries for men to stand on ,like steps at a horse riding stable to lift you up higher.
Once I was back to the start of the road I thought I have to close the doors and f—ck the tiles I am off I will go to Dublin docks, the depot is there [not manned], when I got to the rear of the truck they had taken, god knows how many boxes of shoes,two whole rows had gone , stolen
Once i had closed the doors I managed to get the truck turned around and headed out to the main road ,at the market entrance there was a house with railings around it, I never noticed it going in,there were about ten young teenagers all sat on the railings, laughing and jerring me , given me the fingers etc ,they new !! I was not Irish
It dawned on me quickly,it had all been set up from the last delivery,as I drove out of the market ,thinking that was that,I turned right, down to the lights past the shop i had to stop at some red lights before I went over a bridge to turn left towards the docks.
I do clearly remember a PUB called something like the “quill” or the “quin” I was stopped at the red traffic lights then I could hear car horns blairing I looked in my mirror and zb me the back doors were open again for zb sake.I thought no way am I getting out until the lights change ,they did, I pulled away, I left the doors swinging the blokes car hooter was non stop once over the bridge I stopped, I jumped out, he also got out and said a load of youngsters had run off with lots of boxes , I thanked him closed up again ,and drove off to the docks at least I knew where I was.
Once on the dock, the gate man let me in I parked up and had a think,what to do, it was to late to tell the office it would be closed if I told the gate man he could help himself I had no lock for the trailer doors
I had to make that delivery to make at the market again in the morning I new it was at the end of a building, not near where I was sent to go , I knew I had been set up.that was then ,zb um.
Idecided to lift the tilt cover at the front ,and get in there were boxes all over the place so I started stacking the boxes at the rear doors as if a block of a full trailer when they open the doors as it will be back door delivery why I did that god knows but I did.my thinking was that the forst shoe drop people will not know that some were missing .
I decided to go early to the tile delivery and just wait, and say nothing,to see if anyone mentions it ,they never did, I lifted the tilt sheet side up with the side boards so the fork lift could get to their tiles lots of moving boxes around to get to their goods ,they took all there tiles they made me a tea and gave me directions to the next delivery, that left three shoes delivery ,now I knew that some one was going to be short by a lot
All the boxes were labelled to each customer it was going to be pot luck I had no idea.i did not say a word, the first customer signed 12 boxes short, the next was 6 boxes short I now knew that the last one was well short, but I never said anything just found the place it was like a old school yardi opened the doors and left them to it ,they were well short like 15 boxes.
I asked to use their phone to phone the traffic office and tell them what happened, I got through,the manager was not there,it was now going home time however I told his deputy what had happened ,and when I get back I am going home ,leaving.
I asked when the next ferry is going to Pembroke ,he said about 10 pm tonight I said right I am going to come back solo, and that is it ,I will leave the unit at the dock he said no come to the yard and a fitter will drive it to the dock.
And that is what I did my TRANSCON days short and sweet .
Once on the ferry I was pleased that I had made the move to leave quickly ,not as if I did not want to face the traffic office and try to explain the shortage of shoes again as I had told the traffic clerk.
.The one thing I never thought of untill I was driving home, was ,that they maybe think I had somethink to do with it,that would be rubbish, I put all thoughts out of my head.i never heard another word ever again from anyone and I was paid my wages maybe they were all in on it■■?
The drive home was slower than going down, the car was all intact quite remarkable really just left where it was ,good old people from Pembroke…I phoned home and asked my wife to get fish and chips for two.
After 2 or 3 days doing odd jobs around the house I thought it was time to look for employment again ,I knew what I wanted, that was European not uk work ,I worked the phone and phoned transport firms all over the country just asking for a job.
I had one good responce from Hereford they asked for a cv to be sent ,I sort of made it up on lined papernote paper ,it was European work in fact I had done some subcontract work before for them [Sun Valley transport] Turkey meat producers however they wanted drivers to be based in Hereford as when the trucks returned from a European trip they are used for local day, and night deliverys, so a driver would not be able to sleep in it at nights and there was no exception all trucks were used in the operation.
The traffic manager had also been a employee of Blue Funnell shipping he remarked on my CV.there was a connection, small as it was ,however I was not preparied to live in bed and breakfast while waiting for a euro trip,and doing local work so that died a death.
A week had passed and not a lot was happing for me I thought maybe i will have to rethink my strategy and get in to uk work I decided to ring Bowkers once again and ask for anything not just European, after speaking to the traffic they said come and see us ,and I did.
I was offered a job I think it was replacing someone who was retiring,or whatever came up,I snapped it up there and then,I was told to report 8 am Monday
I took all my gear with me and I would stay at the depot some nights instead of driving back to Blackpool every night whatever the time also it would show them that they could use me, there were some old units to sleep in I did check with the manager first and he ok it that is how I started at Bowkers.a pub and supermarket nearly next door good toilets in the yard, it worked out very well of course I did not get any night out expenses while in the yard ,that was down to me
Some euro work was coming up as a drivers were going on holidays the majority of Bowkers trucks were “Volvo” units, also road trains.
.The road trains were twin axel rear chassis /boxes, some were demountable ,some were normal type trailers, with sliding curtain sides,but were attached to the chassis.the boxes for the cargo were all fitted with side boards just like a old type tilt and to keep the cargo sucure, also ring bolts in the floors for attaching straps all the cargo boxes had rear doors.
Some of the trailers were telescopic, there were no dollys like most of the European ones,plus they are harder to reverse as these road trains are the same as a articulated trailer.
The majority of work was to ITALY I was to find out it suited me they had some wll established work and customers I should have went on to drive dry freight years ago instead of fridge work .but for Bowkers not ACH.
Once I had got my first trip out of the way, via the Hull depot that was where all loads were transhipped, extra put on or loads swapped around altogether you could leave Preston with a load you think you will deliver but by the time they finished the delivers would change I liked that you never knew where you would end up.
The HULL ferry to either ZEBBRUGE, or ROTTERDAM was like the BOWKERS own private ferry,good food good everthing it made part of the job enjoyable.and of course a beer or two.
Once off at Zeebrugge a short run up to the garage another Bowkers home the drivers were all well known there ,it took me a long time to get used to getting off a ferry, then within 5 minutes you would all fill up with diesel then park up ,stroll over to the office incase any change of plans, they would all sit about chat.
They would drink,another horrible [not boiled water coffee] no sence of time to get on the move, get going ,get something done ,it was such a relaxed job I loved it and I had only just started but I could see this is the way they work in actual fact over my time there 70% of the drivers had no idea about hurry up.where did I go wrong!!!
I seemed to have been doing European all the time and loved it,I thought [ you know what I have earned this]what a job .
As with all jobs, men, move around for all kinds of reasons the only draw back I could see at Bowkers was it was mostly weekends away or shipping out Saturday or Sunday ,a lot of the younger men did not like it after time it takes a time to relise what you are missing and European starts to loose its draw.
I was lucky to be employed at BOWKERS as apperently they would only employer men from their Lankashire area so I was told ,however another man from the south had manged to get a job there he paved the way I am pleased he did ,lots of banter was to be had all and a couple more southerners arriverd [knees up mother brown]
All .of the work was really good you could leave BAMBER BRIDGE at 1200 hrs drive to Phillips warehouse or factory in DURHAM load a full load of television screens in special pallets by the time you had dropped the boxes and loaded it would be around 1700 you then drove to TEESPORT caught the night ferry it left about 2200hrs to zeebrugge only freight drivers single cabin ,room for about 10 drivers excellent food ,tv video beer,comfortable lounge .that would arrive around 1400 then you had a drive to Milan,MONZA you had some much time it was unreal .
If you were unlucky you would have loaded for Paris a local however you would probly go to ITALY empty from there all Phillips were timed deliverys as the screens were coming from every where.
Also when I first started on European I said that there were like wooden boxes and table tops that fitted /clipped near the windscreen storage or cooking on,very neat but basic plwood I now know where theycome from one of bowkers drivers makes them and they are sold in the zebbruge garage one of the long standing drivers.
I found out some of the drivers did not have a “class one” LGV however they could drive road trains.
BOWKERS still used the system of the oldest driver gets the new trucks and it goes down the line, like it used to at most companies.that was fine as all the trucks they had were 100% maintained no exception.
Some of the older hands [I was about the same age as most of the exsperanced older men there ] would only drive artics not the road trains, fair enough ,however some seemed to be a bit,” do as I say” to the younger men on the road trains ,it was a different job to the artics, some were a bit of a bad influence they were exsperanced, but only in there regular runs a bit like being on a milk run.
I was being treated the same as all the other road train men ,we had some realy good work from all over Italy lots of weekends away but the night out money.was good .
After time a few men had left and some new faces came there was never no lying from the traffic office all very relaxed and the boss would chat to you if fact I could not fault any one working there at all.
I had a change of road train,from a top sleeper to a proper sleeper ,I had got used to the roof sleeping however the doulble bunk is better also Volvo have introduced a tracking system and Bowkers are testing it back then I did not have a mobile phone, let alone used a lap top or computer it was completly new to me, it was like the now SAT NAV you could follow your driving progress along the road you were going plus orders from the office would come in on the screen no looking for a phone also a delivery address would come via that, plus you could sent a meesage to the office .
found it brillent ,also the first time I used a key pad all new back then.
What I liked was you could and would go whichever way through France OR Germany you wanted to within reason ,in fact I used to go most ways on my own, we all knew each others destanations and would arrange where we would be for the week end.
I could tell you most of the customers and destinations we went to, but it would take for ever, they had some really,really, good long distance work.
Some of the work was just brillent ,sam Anderson from Scotland would take to the hull depot 3 cast like cruciblles fof steel works
,they would load 4 into a road train [legal in Europe ],they would go to a steel works near Marseille at port-st Louis in the camarg region,then once you striped all ther side boards, out a massive fork lift would lift them off you were right next to the finesses you could see the inside of the steel works .
Once empty normally I went and had a shower in their massive shower block then all set up for a drive to numerous places sometimes I would dip my toe in to MARSEILLE and go down the dock area just to look at the ships then along the coast a bit but as you neared NICE it was time for the autoroute you would be able to look down on all the resorts cannes monaco etc some of the parking areas have the best view you could see.
Up through the VENT now defunct [customs boarder post] then coast road direction Genova [WHEN YOU drive from AOSTA GENOVA] the road drops so fast you actually go past blocks of flats you can see in the rooms then you would look left and trucks would be going way up high above you ,then you drop down to the docks and the road goes right out over the docks in a semi circile like floating then you rejoin the auto strada .ONE THINGi will say about the ITAILIENS Austrians Swiss and the FRENCH they need no lessons of road,bridge ,and tunnel buildings they have got that sewn up.
More than once I tried to count all the `bridges and tunnels you go through along that route and never finished, ever, lots of the tunnels were still as the miners had finished the roofs and sides not smooth concrete down to livorno then inland as far down as Caserta ,or Potensia and load washing machines or any white goods ,no hassle from the office just get on and do it and with BOWKERS I can honestly say on all the runs we had I did not run bent whatsoever you never needed to,you would have been sacked immediately.
You would load laminate from Blackburn perhaps 6 drops all over Italy then return to ASTI[yes the plonk place]and load lamanite back to the uk.full loads of cookers ,light bulbs,mama-papas kids buggeys ,range cookers,fridges,all kinds of goods from ITALY and AUSTRIA cookers,BAXI BOILERS BASSANO –DE GRAPPA in the hills.
It was the best job I have ever had ,mind you it only took around 30 years of looking for it ,but sadly that all ended for me on March the 9th 2002 around 2pm.
We had a brillent job from near TRENTO bassano- de grappa ,bring back central heating boilers back to BAMBER BRIDGE we used to come back Austra then please your self which way you come back from germany stuttgart to luxembourg ,[cheap diesel ] and ■■■■ and tobacco for the cigarette tobacco barons .
All so another cracking job was Kellogs from either Manchester or Wrexham no rush you were given a DAY when to deliver if you were to early they would not unload you so we learnt to go the proper day and time as the Kellogs product was coming from Spain and France,we had some hazels there with obivisioly the Spaniards they would leave there motors on the unloading bay and just zb off, when it was our time to unload to get on there bay they were no where to be found.
There was one little irritant ,the man who swept around the yard most of us English lads did not leave litter but he would blame us ,he rode around on a 3 wheel bike with a basket on the front to pick anything up around the loading bays,also he rode inside and used to leave it by the bogs [big mistake] as you could imagine it only wanted two of us and that was enough the bike would end up all over the place with the chain off. Chewing gum under the handlebar, it was so funny ,once someone tied a plastic tie clip ound the spokes of the wheel to the frame ?
We had to walk through all of the warehouse to have a wash and he hated us using it but we never left it messie well I did not non the wiser but grunting he hated us out of all the drivers going there us bowkers were the only one that seemed to use thev wash facilitys we had permission to do so.
anyway there were 3 of us there and the manager came out and asked us to go in the office and told us about the bike etc it had to stop ,etc so that was that in the end he had to leave his bike by the office and walk like us -result
A couple of weeks later I was on my own I pulled in etc and went to take my cmr in [no customs papers] then “mussolini the bike” came round to my cab and stated waving his fists and shouting something he had some paper like crisp packets in his hand ,I looked at them and the were Spanish packets I told him where to and in the office I go and shown the chap this is not English rubbish, this was getting ridiculous ,he follows me in and starts mouthing and the office chap tells him to go this office bod his English is good .
The office bod tells me apparently someone had jammed his handle bars so tight that they would not work, [I knew who did that ].anyway it all is good i am on the bay .
,I go to the toilet to wash and shave] and he is there again, so I say zb off and do my bit and come out then get my stuff together and he goes in the loo,if any one who knows Italy they all ways have big keys in the doors,i thought right ,he had forgot to take it in with him,so as true as I am sitting here I went and locked him in and zb off.back to my cab.
I put my gear away ,sat about a bit ,then made my way back ,he is zb ing screaming, so I banged on the door and used our native language and did not let him out I, next thing a italien came in to go to the loo, and he could hear and see what was going on so I walked out and the key in the door.
I went back quite a few times after there was always a bowker truck delivering ,nothing was ever said to me ,and he never came anyway near he got the message.he did have some clout with the loaders we were told later his brother was one of the unloaders forman, that is why some of the other trucks were left on the bay .
DRIVING left hand drive, was normal to me by now and all the other drivers if fact I had not driven a right hand drive [normal] lorry/truck for 5 years , this day I have just had a break at Wolverhampton truck stop ,next stop home, traffic is quite heavy ,on the M6.
Am I botherd, now I am , approaching the first Stafford turn ,traffic is starting to back up a bit ,it is getting heavy both sides of the motoway ,I just keep in the nearside lane still moving 20/30mph then it picks up and then we are all way again, for about a mile ,all flowing normall ,then quicker than normal brake lights are blazing and the cars in front are starting to get closer as i am braking.
Next thing I knowI!!! I am lifted out of my seat,I am standing up and my foot has pressed full down on the accelerator pedal and I am picking up speed i am in second gear,what the zb is happening.
The cars in front are so getting closer, my mind is telling me to brake, my left foot is on the exhauster and I move my right over to the brake and I am pressing both through the floor,and trying to steer the truck i could not take my hands off the wheels to snap the hand brake on, I was hoping the engine would stall as I was still in gear, I was trying to steer on to the hard shoulder and I cannot, I am standing up holing on to the steering wheel .l and I glance in my offside mirror and its like what the zb,some cars are going past blowing their horns,and the cars in front are getting so close i thought ohh no i am going to plough in to the back of the cars.
I am trying to steer in to the hard shoulder and its not working ,then out of the blue the cars in front slowly start to move away,in slow motion, still to this day they have no idea how very close they were to being crushed from behind.
Then there is none ,not a car in front all gone,in seconds all 3 lanes ahead are empty by this time I have stopped,hand bake on run back down the hard shoulder to see what has happened,I get to the rear and zb me, this is this massive ,I think a scania unit green I think, with its trailer over on its side full off ■■■■ seed.flowing out over the carriageway .
It all looks a disaster ,and smoke is starting to come from the back of the unit ,the wheels and tyres of the unit still are at a hard right steering angle,the cab is upright, its a mess then I look up and the driver is sat still in his cab his head on his arms as if asleep ,smoke is starting to come up from the back of the unit ,but the driver is still in his cab not moving .
I turn run back to my truck pull the little fire extinguisher out and run back and no one else is there only me,!!! I start to spray the flames now coming from under the back of the cab, its no good the small useless fire extinguisher, and like a prick I throw it down and it goes under the unit,
I turn and run around to the cab ,and stand on the right offside tyre which is below the drivers door,and try to open the door and its jammed
I bang on the window the driver looks at me and indercates his foot is stuck,and he cannot open the door and smoke is starting to get in the cab,I am still on my own, until at that moment a young chap runs round ,I shout, find some to break this zb window, like a prat I had threw the fire extinqusher under the unit.
I am still standing on the tyre trying to open the door ,no chance,the chap runs back with a pice of metal from the unit,I have no idea to this day what is was, I lean back and smash the window.
I grab the driver by the right arm ,smoke all around us both, he must be near choking ,he must have freed his foot as he was trying to lift himself out of his seat ,but no to good I lean in and put my arm under his arm pit and pull him up,and get him moving out and he is pushing ,so his his head and shoulders are out of the window ,the other chap is on the road, and I pull and heave the driver is pushing it is starting to get hot ,the cab is full of acrid black smoke now we are both coughing it was very close that I was going to have to leave him.
The drivers shoulders are out and he helps, but he is now coming out he is upside down, his head by my chest, his legs higher up I pull him again and the other chap now has his head and shoulders I grab his waist and heave ,we both fall/jump on the deck his legs are all over the place I had fell off the tyre and we are now a big zb heap we get up –ish and bounce him on the floor and drag him away, just as all that happens you would not believe it, both tyres explode,right where were ,not even seconds we felt the heat rush from the cab is a blazing inferno ,we only just got him, and we both[all three of us] were lucky,
the cab was a blazing haulk. I do not know to this day, who the driver was ,or who he worked for, i never met him again but it was his lucky day.
.Many have done the same and/or would do BOTH OF US WERE AWARDED BY THE POLICE AND FIRE SERVICE BRAVERY AWARDS. I never went to collect mine they sent it buy post, to busy working …
What puzzeled me after why there were not more people around but they could not get passed the blazing truck it took the whole 3 lanes, the other chap who helped was going to a interview for a job at ASDA he was a god send.I wonder if he got the job ?
After it all calmed downish for us there where police in civilian clothes and police baseball caps on and the firemen where every where all the load went up in flames the motoway was a mass of black smoke but it was blowing away from us,I looked at my trailer and my god, he had whacked and crushed a great number of the boilers not all of them.i had pulled away from the flames.
,After a while the police told me I can drop the trailer where it was and go home with the front end.and that is what I did I RANG THE OFFICE told them what was going on I got back to the yard and reported all I knew then went home…
.How the press got hold of my home phone I do not know, however my wife said they wanted a interview, and she would know that would be the last thing I would want or do and told them that however it was in the papers but they got it wrong.
After 3 days off I went back to work nothing more was said or done I had a new trailer and it was work as normal,At that time I was wearing glasses and had been for a few years,all was good also been on high blood pressure tablets for years it was under control as was I from the doctors every 3 months
I
It must have been about 3 months after the bump on the M6 I was on the M62,coming back from Hull on a tuesday morning after getting off the Ferry I was approaching Manchester area I looked at one of the road overhead signs why I do not know as like us all we knew that road like it was our local route,however all the words just all seemed to mush up together I could not read it, I thought the zb bloody glasses,I just rubbed my eyes it seemed a bit foggy haze but carried on back to base ,then home for 2 days off as per normal.
Once home,I told my wife about my eyes,and said i am going to the optician tomorrow and sort these [zb] glasses out ,maybe get some new ones, I had a appointment 3pm next day .
Everthing was normal that day,I went to the optician had a eye test and told her what had happened ,so she said I will give you another type of test ,and she did, what I did not know was, while I was in having the second test again,someone from there shop had rang my doctors as they have all information ,and they were close by in cleveleys ,Blackpool.
When she had finished the test, basicially it was a light test and I had not seen the projected lights showing from 9oclock around to 12 oclock like a quater of a circle ,to them that indercated the blood vessels were broken, meaning I was very close to a stroke ,however I have had T.I.A TRANSIENT ESCAMIC ATTACK. And must now go to the doctors immediately .ok ,so that is what I did…
Once there he told me of there findings and he said, sorry, but that is you finished with your HGV,you lose your liecence, from now, he was notifying Swansea today and that was it.
I rang Bowkers and told them, and that was that ,I never set foot in their depot again or in any lorry again.
My life changed in a instance I could drive my car,I had been taking blood pressure tablets for years ,they never increased my medication,after time I had tests at the hospital with forms from Swansea to get my license back but twice i completed the tests well I thought I had .
Swansea refused me my lic,ence The main test is a walking machine is starts ok then starts to go on to a incline in the end it is like trying to walk up a sand hill with flip flops on, the man[technician ] there tells you nothing ,apparently it is strain on your heart [ the test]who knows I never fully found out ,they just refuse I had the opportunity to go to court to try to get the licence back however my Doctor told me that I will never get it back as t.i.a is so unpredictable just live you life ,so get on with it.
So I realized that was it.everything has its reasons I would not be living where I am now ,if I had stayed in Blackpool.i could have worked in the yard ,but insurance says that I was a risk …THAT IS IT THE END OF MY WORKING HISTORY
I am not sure if many have read my journal however i have done this back to front because i have written from the start of my driving from 1966/7 up until 1982 there are lots i have not written down as i find it sort of difficult to put it into word form if that makes sense to
i will carry on printing it will start from my early life dbp.
I
he start of the channel tunnel train if you have never used it it was a novelty at first.
There was no such trouble as there is now, you could see the BP garage when you run off the train it was all close by,on the out skirts of Calais you then made your way to catch the train, you went through passport control ,then the ticket booth ,then off to a new control thing ,you got out and you cab was searched then they looked over the roof and on the trailers, underneath the whole chassis a team of brit customs people were doing it all then they would if sealed up, shove a probe up inside of the curtain it was a CO2 sensor to see if you had any illegals inside the truck that you did or did not know about,all the now troubles in Calais was not new ,back then the customs were aware of stowaways on trucks.for a very long time
We never used to stop once we had left RIEMS if going home via Calais in FRANCE anyway.
Once cleared by brit customs you go and rank up for the train you watch the traffic lights ,if you are in the front if not you just follow the truck in front,movment was very quick different from when it first stated you could be waiting at least half a hour,and as they were competing with the ferrys they did not like to do that so as a bonus after 10 mins wait, a van would arrive with a meal ,gods honest truth obviously they were controlling the situation and vans were waiting so you took the proper meal if you wanted it or not ,well you would keep the plates and cutlery ,all stamped and numbered “TRANSMARCH”,once you started to eat you could bet the lights would change and off to the train you would go.
The system was,you drove down a ramp and along the train about one carriage then there was a open flat bed carriage about 60f oot long so you drove on to these, and it guided you down through all the carriages until a person told you to stop behind the truck in front ,you would stop the engine, handbrake on close the door and stand out side you cab on the platform …
. and wait for a bus to pick you up that takes you to the drivers rest carriage compartment, where as soon as you were seated another meal would arrive,[its all different now but that was the way it was]also as this compartment was right behind the engine, once it got going they would let two drivers at a time the to walk inside along side of the engine along a small narrow noisy corridor escorted by a employee and up to the front with the driver .
That was a very good experience but after time you got fed up just looking,what struck me as old fashion on the railway tracks there are signs for the drivers telling the driver what incline they are at ,a oblong painted sign painted with a / in the middle and numbers each side to tell the driver the track incline just the same as the old steam train days the track goes up and down it is not flat at all ,so back to the compartment you went and another two would go up.you would just get a 45 minute break in .
Once back in FOLKESTONE 2 small buses would pull up one at the front door, and the other at rear door,OF THE COMPARTMENT what 90% of the drivers especially foreign never took any notice when getting on the train at which door they went in THE COMPARTMENT,front or back nearest to the train engine [well no one told them too so they would not care.
It meant when the train is loading there are two platforms working to load the lorries on the train 20 on the front end and 20 on the rear so when you get off the front drive out of the train at one exit and the rear another ,[complicated] not really however if you get on the wrong bus and are not taking notice for instance.
…The bus would drive on the platform down to the rear end of the train passing the front 20 trucks,and if you are not aware, that bus would be at the rear end dropping drivers off for their trucks at the rear, and your truck could be on the front end so all trucks parked behind you cannot move off from behind your parked truck .
.you hold up all the drivers until the bus takes you back to your truck when all the others have been dropped off…it happened all the time so a lot of us who were regulars would take note who is on our bus most of us brits did ,so going back to getting off if a driver was on the wrong bus you would try to tell them you would be able to tell because when the bus goes past his truck a certain panic would be seen on his face the bus drivers were in radio contact with each over and their radios and would transfer the driver to the other bus after they had dropped the others off lots hold ups unloading caused by that problem . just look up your self on internet.that is definitely
,I was on leave from the Merchant Navy, after an enjoyable working trip around the globe totalling one year. I ended up paying off with £100 cash plus money sent home every month to my mother via the company.it was called a allotment.
Most voyages were around 3 months + £13 per month in 1960.all found not bad ehh I can elaborate on what our duties were in another post.
We all used to draw money in every port we visited, I was young and enjoyed myself in every port and you needed money. In addition, you had to pay for your beer and tobacco, plus sundries .on the ship. However, all food and accommodation is free.
After having a months earned leave, after a trip of 1 year and 1 day travelling around the globe.
I decided I would try to stay at home and work around my local area and put some roots down ,i did not have any contract stating that I had to stay in the Merchant Navy after one trip with a company you could stay on the ship for the next voyage if asked ,or you left and took your chances at the” Shipping Federation”
tThe employment office for seamen a agency that all shipping companies used at major ports within the uk and Northen Irland for their crews,you could be obligated to them for two years if you signed a contract and they would gurantee you work on a ship, however you had two choices of what ship to crew if you wanted to ,if you refused two shipping lines to work for you had to take the third job on a ship they offered
A example would be, the first two choices could be ships on long voyages ,maybe you would want a short trip or the countries they were going to .or if they were passenger ships or just cargo ships.lots of factors ,however if you were not contracted to them ,you could go to any shipping company on your own and ask for work.they all had a personal department just for employing crews
I arrive home very late from Paying off the ship in HULL, catching a train from Hull to London London,then a train from LONDON to Banbury , then a train fron BANBURY to my villageWoodford Halse a bit of a worse for wear in a state of drunkeness , it upset my mum and dad understandable, they had not seen me for a year, we were brought up with no hugs and kisses,and the drunken state I was in at the time I did not deserve any,and I did not get any…
Next day my dad said to me if you come home again like that again I would not bother going away to sea another mistake I took that to heart after a couple of weeks enjoying my self I took driving lessons and passed after 19 lessons within less than two weeks with the british school of motoring,I was able to take any lessons that they had cancelled ,I would go and wait in the local pubTHE HORSE AND JOCKEY”in BANBURY,no drink and driving in 1964/5.and passed first time in a Austin A40…
I managed to find a job, van delivrey with a fruit and vegetables wholesale merchant, early morning starts and late finishes, I should have realized then, that what transport was about.
However, it was new to me I went along with it. I did have thoughts that I should have gone straight back to sea ,however i did not go back,my life with Lorries started. I stayed for about 3 months getting used to driving around the local area ,but I wanted to just keep going longer distances,they also had a small comer flat bed four wheeler, I could not wait for them to ask me just to move it around their yard.but they never did.
After a short time working there i would go out with the driver of the comer to collect produce from farms local and he would let me drive it off road down lanes but not using many gears,but the keenness was already there for me to drive,I was not getting enough out of the van job and I knew within my self that I would be able to manage a larger lorry ,well I thought I could
Work of any kind was very easy to find on the manual labour market, and not having any trade you took what you could in total I had about 10 different types of work all manual some dirty, eventually my type of training from sea time came to my rescue, my job at sea from working on deck ,we were classed as riggers ashore.AS I WAS NOT 21no driving job I expect you could drive like 3 tonnners then but not around where I lived.
I started as a “trainee linesman” for B.I.C.C.company building the large electrical pylons and masts that you see all around the country side ,after 6 weeks training I was passed as able to work in a erecting gang.the training took place just behind where the now rugby truck stop is.at a village called Clay-Cotton.
We were housed in the local Y.M.C.A. at Rugby there were about 12 of us young men from all over the country ,as I had my Morris van I could have travelled from home every day but idecided to stop with the others at least you were there on time every morning although the food was not that good, a lot of fish and chips were eaten after beer at night ,however we drank very little at night as the longer we were there learning and the more dangerious the work was and you had to have a clear head at all times .we all passed out FIT FOR WORKING HEIGHTS
For erecting pylons or masts ,no one left the job after the course, we all went our different ways and I never set eyes on any of them again.we were sent where they needed us
The work was in different areas where new electricity power lines were needed. you lived in bed and breakfast houses where you as near to the site you were erecting pylons at the time, mostly the bed and breakfast places where lorry drivers used to stay for the one night, where as we would be in the same place for 2 or 3 nights although I did not know much about drivers I knew they had a little suit case for overnight gear, where as we had all our clothes in cases and I was reluctant to leave clothes in a room with strangers every day but we had to.
Travelling at work was in a Bedford /type ton lorry with a crew cabin on the back with all our equipment needed, also towing a “donkey engine winch” that was the most important piece of equipment we used every day it travelled every day attached to the back of the lorry until we reached the erecting site then it was unhitched and used by us after finishing work it was reattached to the lorry for safety…from being stolen out from the fields where we worked erecting the pylons.
Sometimes the designated driver would let me drive as I had my car licence if there were only 3 of us going somewhere we would sit in the cab ,a lot of the driving was off road, getting to where we were erecting the pylons
The driver would let me drive up and down the hills in the fields and i used to enjoy that when the fields were very wet the deliver lorries could sometimes only get to the field gate at the roadside and the steel would be pulled of the lorry bed by us by hand and left for us to take on to our site.
I used to envy the delivery driver because I knew he would be long gone before we had to reload the steel by hand and transport it up to the pylon building site it would take 2 or 3 trips of very heavy work in rain and snow or sun.to get the days delivery from the farmers gate way
I realised that the erecting job had its attractions, work abroad was one possibility and I did enjoy the work and the climbing ,also very hard work , outside all weathers.
One particular job within the bulding of the pylon was putting 4 stable outrigger bases in the surrounding ground that involed useing a sledge hammer knocking altogether 12 steel pegs ,like you use for a tent however about 5 foot long ,they had to go in the ground at lest 1 foot,mighty hard work…
With no stable place to live, changing digs,[bed and breakfast] at least twice a week , you would be moving further away from where you started erecting the first pylon.
After not a lot of thought I took the quick decision to leave,”another of my life’s big mistakes “the lorry driving was siting in my head, I had made my mind up that was what I wanted to do, so I had to go back home and try to follow what I wanted to do, once home my parents were not that pleased they thought I was setteled ,because my father and brother were well setteled working on the railway my mother could not understand why I was not the same I new I was not yet I should have just gone right back to sea.however shipping was in a decline .
Once home finding a “driving job” was not easy so I went and worked with some of the local lads on a building site [HOD carrying] that was loading cement or bricks ready for the bricklayers to use in a” HOD” they were made of metal when I used them
Once you had done that for a few weeks I got to think this is not for me, the work was endless.BRICK LAYERS SHOUTING “MUCK UP”all the time meaning they wanted more cement and quick…
Once working there you got to know other trades I got on well with one of the scaffolders they worked for S.G.B.based in Birmingham main office but these men came from Northampton once they found out my background[ I told one of them]that iwas trained at working at heights while on the ships also on the pylons I was the ideal scaffoders labourer and I was asked by their boss if I wanted to join them ,working where we were ,so that is what I did ,and ifound out that I was good at it doing the job, being not frightened of heights at all helped.
Also the money was better I did that for nearly 8 months ,the boss said I was capable to go on my own and do any job also I was strong enough to lift up the 20 foot poles on my own.
When the job came to a end they asked me to travel with them as a gang member and work away all over the country unfortunally for them I had found a girl friend for the first time andi had no intenion of leaving the village.
I followed 3 of my friends and went to work on the British RAILWAY AS A PLATE-LAYER, The office was in Banbury by the railway station ,the gang I worked with worked from Cropredy-to claydon crossing. just up the track from FENNY COMPTON on the main line Birmingham to LONDON.
A Platelayer the job = railway track mantainace ,keeping all the rail banks tidy and the grass a d bushes cut backThe main job OF THE PLATE LAYER GANG OF MEN was to keep both main line rail tracks ,safe,and level.you were using a shovel all day
After time we had to work 3 Sundays out of 4 I found it was not what I wanted so I gave my notice and left
Advertised”, driver wanted a owner driver rate of pay £5 a day, I had no idea , I thought give it a go and I got the job. I did not realise how desperate companies were for drivers, I think if you were blind, they would have started you, the company called Study concrete in Blackley a concrete garage manufacturing company
After being told what to load by the yard man ,and to load only what he said later the boss came out and said have you got all load sheets, yes, I replied ,he then gave me money for diesel and I remembered him saying [only put in what you need] that did not make sense to me , also the spare wheel carrier was broken, that was under the chassis so the spare wheel went on top of the load I was still none the wiser.
I was now ready, first thing to do was sort the gears on the truck it was a old commer,the gear box is not like the normal H system as I was used to in a car the gear stick had been so well used you could not see where any gears were marked on the top of the stick so as to give me a clue what gear to select ,they were all back to front so with the load weight on i knew if I got into first or second I would pull away from the yard.
, I was a new to the game driver. A comer two stroke engine had its own calling card you would hear it miles away before you could see it.also the crunching of the gears gave irt away this particular lorry had been used so much the markings on the round knob of the gear stick had been worn smooth away ,I had no idea what gear I was in until I fathomed it out ,that took me a while …
First day, after hours and hours of driving and delivering I am at place called Newcastle -under line. near stoke-on -Trent.
Parked up on this waste ground site, it was like a bombsite with ruts and holes that would lose at least a car.
It was a transport cafe with bed and breakfast, I asked about a bed for the night, and was told yes there is one vacant [lucky] I found the room and the bed however it did not look to clean, a driver was dozing on his bed, with his clothes on, so I thought that has got to be the way I dumped my small canvas bag with toiletries and towel and made downstairs for some food if you liked fried you were in for a treat if not ,go without. so fried it is
…When i got up in the morning not refreshed at all, like all the other drivers had a massive fried greasy breakfast it was the norm the same as the previous evening.
It came with a big mug of [chipped mug of course] you could stand your spoon up in tea, i had had no trouble finishing of the breakfast the grease went down with the tea…time to go out to the lorry ready to start again, to my shock-horror the ropes had been cut ,and the spare wheel was gone.
No working public phone inside or out of the cafe i was scuppered, i just re-rope d the load and left… by the end of the day I had forgotten about the wheel i just kept plodding on i ended up around Manchester, all delivers done, no idea where i was with a empty lorry and it was late, right find your way home ,and that’s what i did .i do know i passed joderall bank telescope as it was the same way i had driven in, in the morning, god knows how many hours i had worked but the thought of going home spurred me on, the log book did not mean a thing to me back then it was like a lot of lines and you made a graph out of it.
I was newly married at that time but we didn’t have a house phone so i
Had no way of contacting my wife so i just kept going and got on with it once i got to the A5 i knew where i was i got back very early in the morning.
The same day it went like a double lead balloon first the boss confronted me about the deliver notes that i did not take .so i bluffed him and kept quiet, he knew what the drivers did anyway, then he said i had sold the spare wheel to make a few bob. i did not know ,there was a ready market for lorry spare wheels.
he did not realise i was that green but i was. he said my time was done with him so that was that .i do not remember what money i ended up with but i kept the diesel money what was left. it was the first and last time in my whole working life that i ever was asked to leave or get the sack.
I do not remember what i did the next few weeks regarding work, i was never without a week’s wage doing anything that came along it would have been hard work whatever it was normally involving a shovel .digging ditches or carrying bricks on a site or working for agricultural contractors all cash in hand ,meaning no tax or insurance stamp .in lots of country s it was called black market work.
The next job to come my way was 5 miles away from where I lived at Fenny Compton not the concrete but CW Night all round haulier all types of trucks ,what I did not know was that 90% of the fitters, and the drivers were all related to the boss who lived within in the village . I started to drive a 4 wheeler flat bed and we had to load and deliver 2 loads of cement every day from rugby cement at bishops itching –ton to anywhere within a 50 mile radius. And it was very rare to get any help to unload your load at any building site. So your day was all ways full on .
One of the main collections was Avon mouth to load by hand all kinds of cattle foods etc ,and deliver it all the same day .you would get up early, leave the yard by 6 am to get loaded and get it done, you could guarantee when i was just about down to the docks to load one of our other lorry’s would be coming out loaded i used to think how do they do it ,i had no idea. weeks later i found out they had a allowance for sleeping a night out because they would go down very early in the morning or the night before but i never ever got offered it .
In the yard was a brand new Leyland lorry, it was parked in my way where i had to park, I went and asked at the garage for the keys to move it ,and Mr. Night was in there , he said something like you are not getting in that new lorry ,so don’t thing about moving it, you ask my son in law to move it for you,
I walked back in to the yard and the son in law was there talking ,i said excuse me john, MR Night said you have to move the new lorry for me please, his reply was move it yourself the keys are here.-in his hand and he passed them to me, I opened the door got in ,the cab layout was completely new to me also the gear stick ,
I started it up, then tried to get it into gear ,well that went well after a lot of scrunching, i moved it forward, then i had to go backwards, well could i get reverse ,no way !i could not figure it out i could see on top of the stick where the markings shown you where each gear was, was to be pushed down but it would not go [what I did not know was you had to lift the gear-stick] then put in to reverse .i soon learned. for future reverence.
By now a few drivers were watching, after the scrunching of the gears by me also watching, out of the office, Mr night! he flew out grabbed the door to open it and started yelling, he went off on one, i tried to explain .,however , he would not listen so I still had the gear stick in my hand , i give it a yank and bloody hell the gear leaver came away right in my hand [it was not on purpose]… it was a type of ball socket i did not know
… so i jumped out faced Mr. night gear stick in my hand and said [you can stick this gear stick and your f–king lorries up your f-----g arse !the whole lot of drivers melted away. no one said a word i knew that was it… so basically that was it I went to my car and went home that was me done but it was not the end, well nothing bad however,
I cannot truthfully recall where i went to work again for a time i would just do anything on building sites i had a old moris van if you did not have transport of your own in our area you were more or less unable to travel for a job however in the end there was a smallish transport company 6 miles away that specialised in Cattle Transport , i went to see them about a driving job i had sort of a interview told them the truth ,i knew a lot of the drivers already there ,which helped, I had a local driving test as to say just around the street , and i got the job.
Having not knowing anything about livestock transport at all ,my life was about to get very busy,covered in [zb] ,working day and night ,all hours god sent. also a good laugh a lot of the time.
The basic job was in the mornings early, you would go to the farms and collect the animals that were to go to the market first, you would collect the clean ones like sheep or pigs that you would separate with a portable gate, hinged on the side of the cattle box, then maybe a dairy cow at the rear of the box, you were told where to unload once in the market normally dairy-cows had their own spaces.
The farmers were at the market before you got there shouting waving etc trying to get your attention it was always a good start to the day it could only get worse or better, trouble came where the pigs were unloaded in one place, the sheep in another With the help of the staff and of course ,they were in charge and they would all ways be looking for a [drink] as well, for opening the pen gates etc… drink= a money inducement.
When you collected Dairy cows you were given a number sticker by the farmer to put on their hind quarters, a pot of glue was already at the market and you had the find the correct pen number where the cow should be you also had to put. a loose chain around their necks so they would not move around, and the correct numbere place on the cows rear booked for that cow then the farmer would go in and give the udders a good wash and the rear end to look good in the sale ring ,so to look their best they were like the young models of the market…also if you were lucky the farmer may give you [what s called a drink]ie= a tip that was maybe a 2 shilling or even half a crown that was 2/6 in old money .enough for 2 pints of course…the whole system worked on backhanders ie drinks.
When you arrived at the market to unload , the fun started most times the farmers were at the market before you got there so they would be ,shouting waving etc it was always a good start to the day it could only get worse
All the livestock haulage firms had a foreman working the market for you and the in coming stock to help sort it all out so you were not on your own all livestock markets had a all day pub with food…and it was always well used by every one including all drivers ,yes you would have beer with all the meals more than one and it was the place where our foreman would do the transport deals ,all by word of mouth.
The abattoir runs were usually 2to 3 hr s away ,so by the time you got to where you were then home again it may well be nearer 11 to midnight so a good a day probably a 18 hour day ,and when you got back to the yard you had to fill up with diesel and then go and see in the out door cubby hole, where the orders for the next day that told you where you would be going and what time to be at your first collection ,and 9 times of10 it would be like 6 30 am… time after time it wasn’t worth going home but you did and there was always a dinner in the oven loads of gravy rings on the plate but you would eat it anyway a quick swill[wash] dump all your [zb] stinking clothes in the out side a bucket all ready there and up to bed ,look into the kids bedroom just to see them, ,set the alarm ,it was 6 in the morning before you knew it, then it would be the same all over again…we only used to see our family’s on sat ,afternoon/ night .
Most cattle export in the 1960 s went from the port of Sheerness was about 4 plus hours away from our base and the markets we used, so by the time you had done you local work you would end up with a export and that’s when you were given you night out money[lovely money for ■■■■ and beer] free but it never was, however to have some cash was all ways good even if you worked out the hours you worked and the wage you got it was still poor but you got into the work and never thought about it ,it was and is years later that you wonder how you did it all the hours. so the main thing was to get loaded up and off to London out through the Dartford tunnel down the A2 and then to sheerness.
from the main A2 to the dock there-was a pub called the half way house ,the main aim of all of us was to get there before last orders and get some pints down us who-ever got there first if two were together you would get at least 3 pints each[[that s where the night out money came in handy]] and you were never on your own. being sheerness was the only export port for live livestock in England. there would be lorries from all over the counties at the pub we would all be doing the same.
you would have. no idea of the time ,you could not wear a Watch as the constant shaking of the steering wheel ,no power steering then ,direct from the steering wheel…
Some drivers all the time I had been working with I had never ever seen them without their hats off .i would not have know if they had hair or not and it was the norm to wear a flat cap, with a nice greasy peak ,you all ways had to be on your toes ,for any kind of joking around you never stood still, or you would end up with some kind of [zb] in your pockets or down you wellies ,or another one was you would get whacked by the old flat cap . It was a form off greeting with a laugh that is why all the peaks of the caps were nice and shiny from the cow [zb] covered hands… some drove all day and night and never took their wells off. or nice great big ex army boots .
The clothes we wore were so smooth with grease ,muck and [zb] they were water proof, before they ever brought in wax jackets [joke] in ,we all had our own ,even then some men would wear their old suits ,as working gear , stinking and shiny, through years of use the thought of buying clothes to work in was not even thought about what you had ,you used to the last I remember the first time a old driver Lenny, he looked like the cross between a scarecrow and a to ff. a complete mixture of clothes also the boots, we all had what you called as “hod-nailed –boots ”big old leather thick soles , with loads of what was called “s kegs” they were like flat nails.
Back to old Lenny the driver he went every where with a ■■■ in his mouth, I can still see him drinking in the bars but I never ever saw him eat at the cafés, his boots were classic great awkward and large ,he all ways wore a neckerchief like a cravat , the puffs used to wear but Lenny always wore a spotted cut down tea towel with frayed edges ,but no one ever said anything about it to Lenny.
He used to drive cattle lorries during all the 2nd war with lots of others drivers ,and he would tell us they would be commandeered by the ministry of Transport and had to wash out all signs of a cattle lorry ,
they would be used to distribute all kinds of food to buffer depots, they never knew where they were going until loaded and it would be any- where in the uk , no date for return home .
He had one bad habit though you would be sat in your old cab and Lenny would saunter up to you and mumble something and you would just agree with him and then he’d be gone, it would not be until you were driving again and using your brakes ,you would get this horrible ammonia smell when in traffic, Lenny used to ■■■■ over your front wheel. And then clear off he was re noun for it if you ever saw him walking up to you if you were parked up first thing you would do get out of the cab .stand back as you knew he would try to flip you with his cap, and to make sure he did not ■■■■ on your wheels.
Some drivers habits were a bit strong some when in traffic would ■■■■ down the steering column straight on to the road in stead of stopping and going somewhere else. It was a common thing when filling up at diesel pumps in any yard to ■■■■ while filling up it saved time
Once you were finished and back to the yard you would look into the outhouse next to the office and all the drivers work tickets for the next day would be on a peg, with name attached no mater what time it was
when you finished the start time would be there ,as it was Saturday evening I am all ready for home and my ticket said Sunday morn in the yard for seven do not be late,i thought [zb] me it is never ending so home go, and back at five in the morning.
finished and back to the yard you would look into the outhouse next to the office and all the drivers work tickets for the next day would be on a peg,with name attached no mater what time it was
THE CAFE IN STOKE WAS CALLED DUROS or JUROS something like that i think i am sure someone will know from 1965
thought double time so I drive to work and pulled in to the yard not a happy bunny park up and no one seems to be about the last thing you did was to knock on the bosses door to see what was occurring not even a Sunday. it was all right for me to [zb] about but not the boss, no way.
After a short time I could hear a lorry coming up through the village ,got to be one of ours ,it turned down the lane ,approaching the yard but is sounded very heavy, after a while you get to know what different lorry’s sound like light or heavy this was heavy -heavy .i had no idea what was going on
however ,what turner d into the yard was this massive low loader with C ■■■■ on the front a new Leyland named a super beaver the new dogs ■■■■■■■■ of lorry
the driver jumped out ,as he had seen me came over and asked me if I was vic I said yes he said well you are coming with me .as second man we are going to Bodmin Cornwall .
First I had no idea where it was, second my face must have had a grin as big as any-one could grin.
Then he said where is your bag ,What bag ,i replied, ,what bag, he said ,your night out bag a change of clothes ,washing gear shoes. WHAT !are you on about I replied, he said you cannot go into digs in working gear-clothes , . So as I lived on the way we were going, I run down home managed to wake my wife and up and we found a old bag like a old doctors bag, god knows whose it was and put enough clothes in for a week and that would have to do for my trip into the unknown world of long distance driving I forgot all about shaving and washing gear and a tooth brush
It turned out to be one of the best educations I could have had on driving a Articulated lorry. gear changing ,hill climbing, really getting into it I learned that driving was by your ears. Yes your ears, you had to keep the engine revs high then at the right moment just as the exhaust noise peaked nearly screaming at you as if to say for [zb] sake do something, you dipped the clutch ,whipped the gear stick out ,on you way to the next gear also as you were passing through neutral you had to select either high or low ratio on the gear stick button ,double de clutch ,then glide the stick in to the next gear, look where you were going ,have a drag of your ■■■ ,and also chat to the passenger ,and drive ,and on and on it would go, and I loved it.
Work went back to normal .all though I had now seen the other side to driving a lorry it is not all working a full day and half the night .clean ,free of cattle [zb] I did start to think I wouldn’t mind some of the easier life [silly me ,rose tinted glasses] so I just did what I was told and thought no more about it lots of long hours a few laughs ,lots of beer and ■■■■ normal driving life ,well I did not know any other YET
What I found out after , was that my low loader trip had been planned to see if I would be able to handle bigger lorry’s and articulated lorry’s .also the older drivers had turned it down .and being the younger it was me lined up for the Articulated cattle truck when needed. and that is what happened. The start of my voyage around the roads of England and Europe .however I did not know it would last a life time.
One Saturday morning in the yard, the office told me I would be taking the articulated unit and boxed trailer to Northampton market. the driver was off. He had finished however I did not know.
I checked the units oil, water, checked no flat tyres, picked the trailer up and off I go ,very careful out of the yard ,and away. not thinking of what is to come ,i realised I had never reversed a trailer before ,all good forward never reversed ,one good thing was the market was massive and loads of room also there would be other articulated lorries ,drivers ,for advice[ ha bloody ha] it turned out I just got on with it .
it must have taken me a least 10 shunts at getting the trailer near to loading dock which was I might say was not back- on straight, after all that I had forgotten to open the back gates, so I had to pull off and open the gates and perform again ,but better this time. Phew. i still remember it as if it was yesterday, years after if someone was having a problem reversing I would all ways ask them .did they need any assistance not to shout out instructions or wave arms about like some people do. I have never forgotten that market day.
All the cattle loaded 12 big cows in the front ,a gate in the middle12 at the back all weighing about half a ton not a lot off room for them to move about, so off down the M1 to Luton my first trip out on my own ,all went ok lots of room at the other end to reverse and back up , the trailer and thank god all the animals were ok ,sometimes if if they are loaded to tight in the back of any cattle truck when you start to get going things start to change in the back of the lorry, if you imagine when any animal runs up into a space with no exit it is head first [the narrow bit then it is followed by its rump the wider bit] so the ones in the rear push up towards the others so they are all squeezing to the front
That is when the trouble starts if whoever in charge tries to put to many animals in as it all ways looks as if there is loads of room, however once you start driving and the lorry starts rolling around and the animals are all tying to find there own space they try to turn around and face the light coming from the side vents, and do start to turn around .so if one to many was loaded there will be a weaker one that will go down onto its knees and they can and do end up in a sorry old state normally covered in [zb] , as it has no chance of getting up, that it why we were taught to keep stopping and keep a good eye on your cargo . Sometimes you get the angry aggressive beast who wants more room than the others [the school bully],and will not stopping trying to move around they can cause a beast to go down. times when cattle were being transport care was taken for their welfare by all drivers I knew .
As a rule normal cattle are very passive i have had times when I and other drives have had to get in with the animals if one was down and on a longish run [ normal Birkenhead to Banbury ] We They were Irish store cattle from Ireland mostly youngsters ready to be fatten up for the food chain by the time they had come across the sea all the fight had gone out of them and they were like people waiting hours at a airport weary, had enough.
However it never was that simple. as you were nearly all ways overloaded by one and they were the ones we used to get in with they had no horns [ Hereford breed] and had been feed on grass only so imagine the floor of the lorry! the way we tried to get them up was one twist its tail ,and the other keep its head up while you were trying to get room with your back pushing the others no mean task. Sometimes we did . If not successful we had to find a farm yard and ask if we could run them off normally they would not let you [because of foot and mouth ]or then a large parking area ,we used that road and knew it well ,[ we called that road the goat track] that road was the main A41 used by all cattle lorry firms .so there was extra help around ,once parked up after a smoke ,we would then reverse one lorry up to the others rear doors…
cattle lorry doors drop down the same as horse box doors do, then you have a set of gates inside that fold out to the sides so as to make a ramp with secure sides with only one way to go. however now the hard bit came ,one lorry had to drop the door down but keep the gates shut, and hope the cattle did not push the way out against the gates when the daylight hit them with the door down but lots of shouting hhe -ups ,banging with our sticks we all had a ash plant stick a very necessary piece of equipment then.]We would then reverse the other lorry back to the other, drop his door on to the one already down so now at the same time you would open the gates in double quick time so they opened into each other like a[ / a lot flatter.] And you would hope they all the cattle stayed in one lorry while you would let one or two out in between the gates from the lorry where the the beast was down in, and with the extra room it would be able to get up which they did .all in a days work
then hopefully the ones out did not knock the gates down you would be able to get them back in
to the lorry, you would not try it if only two drivers were there.
you all ways had a long clear space behind any cattle trucks on any road as it was like a fine spray flowing with the wind and the windscreen behind would be smeared [nice]
When the lorry was full of [zb] and ■■■■ all nice to slop around while driving
Articulated driver at our yard now and did not have another truck to drive and some days there was nothing for me to do. i know new why no one else wanted the job as I found myself helping the mechanics in their workshops doing all the [zb] jobs ,however what I did not realise I was learning more and more of the whole working of a lorry the bits i had never seen also the working of the engine, minor repairs ,electrical wiring the whole thing very useful in years to come but never realised then.
The main company under a different name was in Northampton c,butts and were doing all types of general haulage so they had a idea to keep a flat bed trailer over at our depot so at lean times I would go and do general haulage that was fine by me I started to think it maybe time to move on I had now seen how other firms worked and the massive amount of different types of work that was out there and I have had a taste of it yes a lot of hard work, on some days when on the flat trailer we would have to go to the main brick yards in Bedford area[ now MILTON KEYNES] and load 15tons of bricks all by hand ,full of dust and ash as they had come out of the kiln the night before also they were still warm you had to use gloves ,next I thought I would be back loading the cement like before soon I was on the lookout for a company that did not do lots of handball like before. However I did get the change around driving the cattle box then seemed easier than the bricks.
When we used to drive into Banbury Market it was the largest cattle market in the country ,we used to pass by a old railway station and it was used by the British Road Services as their depot I used to see all the neatly parked up trailers all nicely sheeted loads or box vans and used to thing if only ,i might get a job on the B R S. however I thought if I get time I will go over and ask. however we were always covered in [zb] and had no clean clothes so after a period of time I made the decision to go and see them muck or not .so the opportunity arose one Thursday and I rang them first from a pay phone [NO MOBILES THEN]explained the situation about unable to get time off to see them would they send a application form, that went well and I arranged for the next Thursday for a
Interview
. The usual background checks ,previous employment so all went well also I told them about MR Night and the present work I was doing and the hours .they said they would let me know by post as we did not have a home phone .not a lot of people did then. The next week they gave me a job and a start date so I could work my notice at work .they were ok about it they new I was young and wanted different work so I left .[for about 10 years]
The B R S was run on a ex military grounds as it was the nearly the last nationalised industry left in England
Nearly all the drivers had done some type of service that required that you would and could do as you were told even us ex Merchant seamen I was told later on that is how I got the job from my old discharge book.
The first couple of weeks I was the yard shunter ,that was you would go to the local factory’s and load the trailers , sheet them up and then rope them up to a high standard and back to the yard ,pick another up and do it again and again the B R S had a lot of work by the end of the day you knew you had been to work. But I was getting to know people ,and getting good a sheeting up loads however I was all ready good at working with ropes .so I did not have any problems [yet]
After I was let loose on fairly local loads and using a longer trailer maximum length then was 33 foot , with a marker light half way down the side of the trailer, now that was something new, lights down the side of a trailer whatever next ,also a 24vault electrical system it used to be 12 vault .But the same type- of tractor unit .is was a Leyland Super Comet, However this was a Air brake system ,not like the old vacuum system that was a bit hit and miss .
The mirrors were larger in size than the old ones ,they previous ones were small like out of a budgerigar cage. With the new ones you could see a far way behind however you were unable to adjust them like the present time they were rock solid one tap against anything a that was a a shattering “experience or a nice crack and you would get double vision not good ,however the worst bit was back in the yard you had to make the usual defect report [in fact it was a big drama] you had to right a accident report for even that, to the traffic office ,then to the garage foreman [ Lord god almighty himself]
they always seem to take everything to a personal level ,as if it was their own ,out of their pockets. it took me a while to get used to it however after time I did see their point i.e. insurance ,costs, and even the smallest thing down to you all went down in a report against you the driver.
The only trouble driving certain runs to the same delivery points was there were some good days and some bad ,no mobile phones very few phones on major roads ,very few stopping places for phones only transport cafés would have a public phone and no guarantee it would work. So phoning back to base was at delivery points, then it was reverse charges, there was a stigma about letting lorry drivers use the phone anywhere, some factory’s would not let you [second class citizen] however you usual phoned if you could .
However you got to know the routine, and we always had the B. R. S drivers bible the little RED BOOK only B R S drivers had it given them by the office for many reasons ,first it shown you where all the digs ,overnight stops ,bed and breakfast were at most towns and the phone numbers ,some of the digs would only take in B R S drivers in as they Knew you would behave and pay and the depots would leave messages with the owners if any change in plan etc. it worked both ways however you would not be able to use their phone .Because if your were empty in a town that was not yours when finished delivering you would have to go and get filled up with diesel for the return journey and we used to have a running sheet called [ops 6] renown through the B. R. S.
it was your lifeline, you never left the yard without it. You could draw your night out money on it from another depot they would not refuse you so long as you had not already drawn it before ,your days work was recorded in it , your days running mileage. also your load and off loads and you had to go to the traffic office when ever in a depot to report ,so if you were empty you were easy meat for some type of [zb] load that they did not want if it went anywhere south near your area .well anywhere London area was always near to Banbury .or so a lot of people thought ,and that is how I started to learn all I knew
As the majority of towns throughout the UK then had a B RS depot within the area as it was a government company Nationalised industry however it was gradually getting back into private hands.[ deregulation] so they need digs to put men in the same was with the BRITISH RAIL they would have accommodation that was called barracks the same as the military type used by working men within the industry who lived away from home and they would put us up for the night for a charge, also the SALVATION ARMY had large houses ,well large house the were [zb] sleeping factory’s, for accommodation in the big cites
for the obvious tramps .down and outs etc ,however they always kept a floor free for overnight lorry drivers, different from the roughs, we then were not the second class for a change we did not eat breakfast there ,I must say we were in and out. i think it was 10/0 shillings a night now 50 pence…also if you parked out side the “sally- ann [salvation army hostel for men]” their were always kids waiting to look after your lorry for a couple of shillings if you did not give it to them your load and truck would be a problem the next day, it would be damaged…
Once you were on a regular run you would get to know the factory times and when they would load empty stilages’ and when they would not ,different fork lift drivers did different tasks so if you could you would try to get a full load of empty still ages if available loaded as you went around the deliveries that would mean a return load back to your base. However as time went by I got to learn the ropes as they say . At some factory’s they would have the empty stillages that would help you to make a nice return load back to your base all belonging to LOCKHEED , however they would not let you have them, so off you went empty to the local B R S depot and ended up doing the [zb] for some other depot ,as a lot of our Banbury based delivers were serviced by our depots lorry’s twice to 3 times a week.
It got me wondering why they would not load you up with the still ages as I was a new face to a lot of the fork lift drivers at a lot of the factory’s it did not take that long to ask around, and I had not worked it out myself ,what was happening to all the empty still ages it worked like this=.the driver who was a regular to the factory on a Thursday was giving away jars of coffee to the fork lift drivers at the factory as a [ bunce], backhander, or black market. Stolen coffee .
MAXWELL HOUSE COFFEE so he would always have the empty still ages saved for him Well !what they did not know I was probably more into that sort of thing than they would believe, so it was game on ,[that was a challenge to me ] the ever [zb] you syndrome, now every where I went, once I had got my stash of coffee , if I knew I would need it on a trip I would bring it from home ready, it usual worked everywhere to give the fork lift driver a little bit of something ,■■■■ ,small amount of money when needed just to ease the way. I had been around a little bit however no one knew anything about me so I liked to keep it that way [I did know the score as the saying goes]
I have always given people the benefit of doubt in most circumstances unless they take the ■■■■ then it changes. Most of us drivers would not suffer fools gladly however a lot of the fools were other drivers ,not that I was perfect far from it I was just as much as a [zb] about, as most others .anyway, how we got the coffee?
General foods ,the name of the company that was originally bird custard powders from Digbeth the centre of Birmingham ,relocated to Banbury about 1965/6. how I know as I worked on the construction. Another story
.However they used to refine then the raw coffee beans and it ended up as MAXWELL HOUSE COFFEE one of their many products they used to manufacture ,custard powder ,angle delights. All good family products that we all liked, so the security was very tight at the loading bays a lot of the goods were loaded into box vans that is as it sounds , a box fitted onto a trailer , a container .
.That had two doors at the rear, of the trailer that would be backed onto a ramp at the loading bays at the factory as it is done today at all factory’s.
The box van trailers were constructed of a marine ply wood board, very sturdy, with steel reinforcing in between the sheets of ply. The outside of the trailers were always painted red the B.R.S. Standard colour, inside the box trailer was a flat bar of
steel that run all the length of the trailer with holes drilled in to it that would take a spring loaded end of a 8 foot tubular steel bar that was to fit in the holes on the side, to form a barrier to hold the goods up in the back of the trailer that was stacked on pallets .
however it sorted of worked when the trailer was full to the back and it looked good from the loading bay as if the load was good and secure however once you had the first deliver off it was never nice and neat boxes ended up everywhere
As a deliver would have not just one size box every product was a different size box so you had to re stack the rear of the load after every deliver sort of slope the load back like making steps so as the whole lot never went ■■■■ up. so if you had 5or6 deliveries it got a right mess in the trailer ,
in the end if you did not do the job correct. that is how we used to end up with the coffee that we would keep ,[naughty] the odd jar. the customer would sign the load with a damage report however they would nearly all ways keep the whole of the pallet damaged then put a claim in later .for more damage than there was so we knew that was some for us thank you very much.
You had to keep it hidden when back at the depot and in them days they were very small cabs so not a lot of room to hide stuff away from nosey drivers ,no side lockers ,no sleeper cabs your driver seat was right back to the back of the cab.
.what we used to do was as you come in through the gate to the big yard ,every time you had to go to the fuel pumps for the diesel and there was the fuel man .a near retired driver and his job was filling up the lorries dish out the oil if needed. it was his domain he was the man you never ■■■■■■ off it was his little kingdom because he had hiding places and he was always in on anything that needed to be stashed away. there were some drivers who were greedy and they would nick off each other, but he would never give your stuff away and he would get his .
So once you had got sorted you would have to go a part of the yard to get your returned goods or damaged goods off the trailer ,some times with a shovel, powdered coffee ,and custard powder make a right mess all mixed up. however a lot of the mess was checked by the prick of the yard who worked for the maxwell house company.
They would try to see that the lids of the coffee jars were still screwed on to the broken jars and not been opened and the bottoms of the jars were broken they new you would not take loose coffee off the floor. So that is why we used to get it at the other end of the job the delivery…also they would count all the packets of crushed custard powder so as to see that you had not stolen any [how dare they].
Most of the food customers were small shops or small cash and carry outfits. Not big stores like now but if you did have a bulk order ,ie the whole trailer for one customer you never got a thing for yourself…
That was one part of the driving at BR S it was not all food delivers in box vans they were the cream jobs, the majority of the work was all roping and sheeting and it was nothing for us drivers to have to do sheeting and roping the load on your own if a load had been [transshipped]`it would be a load of lots of different delivers as well as mixed up goods of all descriptions maybe known as a [zb] load… within the yard by the yard gang they would disappear when they had done their bit and leave you to get on with it .if you were lucky they would have lifted the big 8 panel sheets on top of the load for you to begin ,it was normally good if it was ■■■■■■■ with rain and the wind blowing just the thing you did not want however all in a days. Good experience.
Sometimes when we had a load of the food from general foods ,on a flat bed trailer ,when roping the load down to secure it lots of the top boxes would end up damaged ,so by the end of the day of delivering you would have a nice mess on the trailer ,custard powder mixed with angle delight and also some coffee it used to get rather sticky and you could be covered in powder. Not good when you then had to find some digs [B an B] smelling rather sweet…
After a while I knew I had made a good move from the cattle trucks however the traffic manager was a right prick and sometimes you can have enough [zb] from a man so in the end the big bust up came. =
We had loads delivering around Nottingham ,after I had finished for the day I went to my in laws who lived just out side Nottingham on a R A F camp. I went to the guard house ,asked where to park, I was told it would all be ok ,parked up near the houses and went to the house ,got up in the morning all ok carried on finished my jobs ,collected pallets for the return and back to BANBURY.
all fine so I thought, Back in the yard ,did all the routine, went to the office to clear to go home, was told the depot manger wanted to see me. The story was a routine police car doing rounds saw the lorry parked up. Yes it was not normal for a commercial lorry to be there.
They went to the guard house at the camp, they new nothing as they could not see the lorry so they did not know it was there and it was not recorded in their book. [I never left a note in the screen to say where I was] so the police take over they have now got a stolen lorry on a R A F camp [I am asleep] so the [zb] starts they in the end find out its from Banbury ,wake the depot manager up, he wakes jock up [all by phone] god knows what else .so they never thought old on ,its locked up, all the sheets and load is secure, the police do not tell them this .so I am missing ,lorry stolen ooh zb
At 7 am I go back to the lorry start up and go no one stops me nothing. so you can visualise me in the office gob smacked… what is going on I did not know .so in the end I hold my own with the pair of them and that is sorted and go home ,however my dear old jock o. holds grudges
days later I am told jock wants to see me , so now I am ready for this ,the little scotch [zb], and he was little. He wanted to suspend me for not parking at the Nottingham depot .so I told him to go [zb] him self and said I’m jacking [leaving] however. Little did I know but the union man was on my side, and told them [after]so long as all is secure ,and your are not off the load route you can stay where you like in digs so long as the load is secure.
So I did not finish in the end but he had my card marked and he would and could make my life a misery but he never as it turned out he was ex RAF so it must have made a difference as my father in law was AIR CREW. [ Also a jock] Why I do not know but it worked out all right after that episode.
Within the B R S they had a lot of different categorise of drivers
Day Trunking.= drivers would drive from one town or city to another B R S depot drop the trailer ,collect another and drive it back to their own depot That is all they would do ,not touch the load at all ,
Night Trunking. =
they would do as the same as the day men but at night.
Trampers= They would start at their depot and just go wherever the load is for ,then just get sent anywhere with another load and so on and make a sort of round trip not allways getting home that week that was the start of things to come however the B R S did it first
Day men =That is what we were mostly working out of your own depot with the odd night away
Weekend Work = was unheard of unless you were Scottish they had such long distances to go we did the very odd Saturday morning but that would be all. However there was one very good weekend run but that was a special to Glasgow [■■■■■■■■■■■■ and one man to do it yes a jock ,double time for a Sunday, leaving Saturday, time and a half, good money .After about two years there I eventually got a crack at the Scottish run , Now I was driving where I had never been before
I had not been north of Manchester , the M6 only went as far as Preston ,Lancashire from the A5 Cannock, north of Birmingham .Then up on the dreaded A6 a notorious road with all the hair raising stories up the dreaded climb called SHAP with a café half way up called the Jungle .
Stories of lorry’s trapped for days on the Icy roads no gritters then ,well few if any ,well the time came for me and it was summer for me so [zb] it. it was fine ,however even to this day it was and still is a very dangerous road it was the only west coast road from Scotland to England., the M6 goes up SHAP now but it is 3 lanes. wonder where all the ladies went to
When we finished the delivery in GLASGOW we then went into the depot there and you would be loaded there from the depot most times it was called a Bonded load and it would be spirits whisky. Normally for the LONDON CUSTOM BOND via our depot .when we had sheeted the load and then roped it secure, the customs officers came round, and on every knot we tied in the rope [called a dolly knot] they would attach a wire customs seal in every rope knot on that load ,then you would be told when to leave and to stop only at B R S depts Preston for the first night for diesel and secure parking also there was a car ■■■■■■ running behind you however you never got to see it,
i think that was [zb] however no one ever knew or put it to the test and if we broke down we were to stay put at all times never leave the lorry ,if you had a flat tyre on the B R S you were not allowed to change a wheel, we did not have the equipment any how and wait for the police. So it would be Preston, then on to Banbury or if you could not make it you would go to WOLVERHAMPTON. Then on the next day to Banbury, where all the ropes would be checked over. by the local customs most towns had the own customs offices. Many people would not know that. so that would be the end of the trip for you ,if all went well you would wait for the next one, I had my share of then Distance work. As the years went by for me within the road haulage the custom officers were allays the same never said a word, unless they wanted to know something…
The fitting of a custom seal is still today the same as then,the seal=a soft circular piece of lead ,about the size of a new penny 2013 penny. not the old £.shilling and pence,penny .they would tie a piece of waxed string through the knot [like a figure of 8 knot] so it went around the whole rope knot then push the string through the rope[ the lay of the rope] so it was tamper proof ,get the two ends of the string together, push them through to small holes drilled through the lead penny, and put the lead into like a pair of pliers [made for the job] and squeeze together to flatten it so now it looks twice the size ,and it would also have a imprint of a crown on one side and a number on the other the number being of the office that did the sealing. it was up until the end of customs in the uk
r EEC export the same. out side of the EEC customs procedures would apply…i will elaborate later on about the ITALIANS CUSTOMS…
So life at the B R S was all right the money not the best, but we all seemed to manage . all drivers who lived in villages had to have a car if you did not you were basically zbked .petrol was cheapish you would be able to put 4 gallons of petrol in your car for £1 .beer was 1/9d a pint ■■■■ for 20 were about 2 shillings [2./00] wages were not brilliant £20 £30a week. Very, few men in manual labour jobs managed to afford mortgages, that was like a middle class thing, professional people only, in fact every one had their wages paid in cash . Bank accounts not heard of for workers .most people rented from the state or private and it was normal ,life was fairly good.
Mrs THATCHER WAS A LONG WAY OFF. she did the workers one good thing that was the right to buy Your council house it put 100% of workers who lived in council houses on the ladder to moving up to the better housing estates and owning your own property ,the government gave you a percentage discount for however long you had been living in a council property ,that reduced the amount you had to pay for the house you lived in, also you had to get a mortgage from a bank as most people did not have bank accounts that was the first step ,Banks then were rather how would you say middle class but they new there was a lot of “new” money going to be around. and their stuffiness seemed to mellow.
Also we had the new currency to contend with moving to decimal from the pound shilling and pence. Lots of horror stories flying around you would loose this and that ,however it did not really bother the average working man he had his weekly wage packet and got on with it. it is such a long time ago I do not remember now any mishaps to us. at least getting paid monthly to the bank had not yet arrived 1980s for that.
Now the 1970s were starting to change quite a few things for everybody ,some good and some not however the transport industry was at last starting to grow from the old drib and drab 1950/60 s
the government were starting to finish with the massive B R S industry that were 100% subsidised and let more work go to the private haulage companies ,they were always there but never in a big way so some of the work we were doing sometimes we would find a total stranger loading loads we used to do. so the union would get involved and try to stop the loading through the factory workers and it sometimes worked not in our area ,but in the big cities and docks where the union used to rule and that was the way it was especially in the car manufacturing facilities .[[that is a whole story on its own]
We just carried on doing our jobs not thinking then that the way we were working that was completely normal to us was in the throws of change.
I do thing my time at the BRS was about the best sort of learning anyone could get within the transport industry, all though I did have the occasionally ■■■■ up normally it was your won doing but at least you learned and hopefully it did not happen again. As time went on you got as they would let you do all type of loads and you trusted others to do their job correct ,wrong, big mistake .
The B R S had a contract to deliver to BROKE BOND tea and coffee company at ST ALBANS ,for us a local job ,the trailers were always loaded at the tea warehouse by one of our intrepid shunter’s roped and sheeted dropped in the yard and left, so you did put a lot of trust in them and you thought they would do a good job ,and they knew who would be taking the load the next day as the loads were always put on a notice board for all to see. So when you had finished doing whatever you would look for tomorrows loaded trailer hitch up ,check the ropes ,sheets. And all the other things and get home as quick as you could, next morning everything is fine start up the lorry, Pull out the yard, turn right no problem off I go.
It was a bit of country road ,well we were in the country ,and I was making for Towcester the main A5 that was one of the main junctions north or south or east west, busy place .The back road brought us out at near Silverstone, [the race track] that was the A43 then down to TOWCESTER the main traffic light there were horrendous at times with traffic, my route was sharp right turn at the lights through the small town and away .My turn came lights green and having to do a full 90degree turn your unit and trailer were at the maximum turn without jack-knifing into each other I was just pulling out to straighten up when I heard this crunching, wooden ship like sound ,i thought what the [zb] looked in my mirror thought I have crunched a car but all was well that side then I looked in to my offside mirror and all i could see going over the path and resting on a building a massive green bulge.
oh no. the whole side of the load had just decided to leave the trailer and rest in the sheets, the trailer was not clear of the traffic lights . I had made a perfect turn slowly ,however when a sharp turn is made the trailer will lean on the turntable .that tilts it to one side and that had happened, when a load is secure it will not or should not move this load ,in this instance something was not right with it and it slipped. In a big way ,no place to hide,
All the traffic was stopped all 4 ways at the traffic lights . My next move, gear stick placed out of gear ,hand brake on ,switch engine off… that done I run round to see if anyone is under the load thank god no one was walking on the pavement at time.
The police come ,check around, and tell me to go and ring the office and say it is major indecent the whole load is hanging in the sheets. a pity we did not have cameras like today’s digital, and have been able to snap a few shots off .
After time a party came out from the Depot, all taking this ■■■■ etc ,if no one is hurt and a big ■■■■ ups there is all ways humour ,one of the foremen was there so it was decided that we needed another lorry to tranship the back loaded tea chest of the load on to another lorry. then get away to deliver them ,It was a hand ball load so no pallets. That was done after a time , it was time to cut the ropes and sheets to let the bulge at the front drop on the pavement , to get at the lose load so we could then re stack it all on the my trailer again ,it came apparent that when it was loaded originally by hand it was not done correct as when you load any boxes you put a binding layer every other row going up and across ,ie put some boxes long ways and some the short way because most boxes are oblong not square and is enough to make a good stable tier and load that was not done , I was no way to blame.
It ended all satisfactory, no prosecution ,however the Scottish prick of the manager never forgot, he blamed me he never said so ,but he did not need to ,as it caused a big [zb] up day all round ,I knew by the loads I got later on, I never gave him the satisfaction of moaning ,i just got on with the job as you do and I knew one day my day will come.[ it did however I had left by then and it was not good for him]
What happened was when the office staff used to have to go the whare -house they walked through what was the old booking office from the railway in side doors went of to toilets ,and there was a long cage attached along side of a wooden wall with a run that had a opening for a dog to be in and out side whenever it wanted and when out side it would be going mad jumping up and the usual practice was to tease it ,as we walked out of the office by everyone. just to get it barking , and we would be gone or round the corner cracking up with laughter ,-so out would come the manager and go just as daft to get the dog to be quiet yelling in his broad accent. It was classic entertainment for us not the dog.
The manager used to resort to get the dog in to the inside part where it would be quiet if he could …in the end he started using a broom stick on the dog pushing it through the wire netting to push the dog in ,well the dog loved that didn’t it ?It was the yard Forman s job to feed the dog etc and tie him up to clean it out. As you have guessed he was away and who took the job on. the manager ,well the dog did not forget and the ALSATION a big brute of a dog seriously mauled
the manager when he first opened the door .[just rewards ] I do not think he ever recovered properly. I had moved on by then I had no sympathy for him.
So I had now learned enough to know that I would be able to go to any transport firm and be a competent driver [my words] [ however as time went by your are only as good as your last load].i doubt that there were not many loads that we had not roped and sheeted ,that was the main part of the job then was to be able to secure whatever anyone gave you to do also able to drive a lorry .at a good standard,there were no automatic gear boxes, the art was using them [the gears ]to your advantage and get good fuel economy ,even then cheaper running cost were the key to firms going under or surviving .
My time had come to move on, but to get another job first was main thing in the 1970s there was a lot of employment around in all sorts of business. And the transport was one of them so long as you had a car.
The Len is this is not Len from before.
I eventually got a driving test at a firm about 6 miles from my home at a old RAF base that was using the old hangers ,as work places and the the old runways as storage for the finished packing cases, some of them massive in size, and heavy.
In the export packing of all types of machinery it was called C K D cars ,knocked ,down. land rover was their main customer at the start later on they had all the major car manufacturers from Midlands as their customers it got really big. as exporting was the main stay of the country ,of earning money.
The haulage company came from Coventry and had opened a depot at Chipping Warden within the facilities at Chipping Warden. I had never seen them or heard of them .and once I had the driving test with a forty foot trailer, fully loaded weighing 30 tons, I passed ,and was offered a job ,however it was to do local runs to the midland factory’s 2 trips a day, and was told when some more larger lorry’s arrived I would be engaged to do the dock work so I took the job.
Just after I had started the Government brought in the then new Licence ,for all types of lorry’s, different classes i.e. 1,1A.2.2A.3,3A. 4. 4A.my licence was first issued in1.11.1970 THEY WERE VALID FOR 3 YEARS and you had to apply for a renewal. One problem was that you the driver if you wanted a class 1 that was for all groups ,1 was for maxim weight articulated . you had to prove to the ministry that you had been driving that class of lorry for the allotted time luckily for me I had been on a articulated at Challis and the B .R .S
. The ministry of transport did check up on me as I had word from the challis office that they had filled the forms in and said that I had been on articulated since I was there, so with that and the B. R S .i had no problem and received my licence by what they called GRANDFATHER RITES, if you were unable to prove that you were in- tilled to the licence you would have had to have taken a lorry driving test what that was I have no idea, nothing like the young people are put through today. When you think we had not 1 days training you just got on with it, maybe some needed training I do not know.
The using of GRANDFATHERS RITES is a age old custom us by industry’s, it is the handing down whatever from father to son to keep it in the family Dockers in London were the main users of the system ,so they were all the same minded lazy [zb] .they called it the BRIEF, taxi drivers were the same it was never heard of outside the London area. But it was now, one good thing to come out of it. There was a lot of underhanded going on all over the country over the getting of the class one they were easy to come by if you new the right people and needed the service.
In all types of export-+ industry it was known that they usually kept to what they did ,you would not have dreamed ever that post men would be driving their own lorry’s absently unheard off. The unions both sides would never allowed it ,[example] the Export packing company we hauled for strip down machines and mostly all types of cars and packed them in crates for export .
,example = steel mills made steel, coal miners mined coal, etc car makers made cars. and they would use haulage contractors to do haul the loads. So that is why they did not haul loads for themselves [yet] even for local factories manufacturing for the car makers although it was in theory there own work, the unions would not allow it ,it would also put a lot of extra expense buying lorry’s ,having a transport department ,and all the drivers to deal with .so they stuck to packing ,or manufacturing all though they had their own union within the packing or production factory they normal did not want to buy their own lorry’s and be bothered by a load of moaning drivers…
The company at Chipping Warden was attached to the Coventry B R S it turned out that the drivers from Coventry wanted to do all the export work and not the local, as we found they out later they were a very organised union, as they were working around all the major car factory’s that at the time were very militant so as time went by if any of the factory’s we needed to go to collect loads from for export packing and they were on strike ,we were also on strike, as we dare not or would not cross their picket lines .
so basically we were zbed and the old adage came round if you cannot beat them join them ,so over time that is what happened to all us none militant men it was the way to go and yes it was them and us. However in my defence I have always known and thought ,that the management reserve the right to manage their own company ,not the unions run them for them ,that is what union higher management wanted they wanted in a bigger picture .it basically was to bring the workforce into their way of thinking that was communist. And that was their downfall the unions. However there is still to this day certain men who would like to see this country under the rule of Moscow and it is good that they get stopped .Once you have been on a strike for over 6 weeks you will know what is right.
PICKET LINES=when the people who worked at a factory had a disagreement over anything ,working practice ,wages, overtime, with the management they would ,the union, would withdraw their labour ,stop work, if it could not be sorted out by the management and union and it would involve all of that factory ,it could be just one department with a problem however they all stuck as one and would go on strike .and stand outside of the gates to that factory ,with the unions say so and stop anyone at all connected to the working of that factory delivering goods or collecting goods to not go in and so not to cross their PICKET LINE ,that was a unwritten working man ,s law and it did not leave the working environment until the late 1980s1990s
After Mrs Thatcher that is why she was hated so much by nearly all working union men in areas of the industrial working regions ,i will leave that part of my transport journey, I will say in all my working life I was a union member all ways on the outside fringe never bothered about meetings or politics, that went with unions. Paid my [dues] dues is the collective term for paying your union monthly subscription.
Two of the main reason I kept up my payments was if you ever needed a legal representative for any reason whatsoever, they had and you were entitled to them solicitors ,and if you were sick you would get a small payment ,also a death benefit .but that was it, as in the 1980s1990s haulage companies would not entertain any type of union activity.
My first union was the National UNION OF SEAMAN.1960.
Then the T. G. W . until 2002.
Time kept marching on, the work got boring, I got fed up and could not understand how some of the men would ,and could , get satisfaction from driving two trips a day to Birmingham or Coventry
in to the car factories ,and back to the depot, I knew it was not enough for me, and I tried to get into the zone of the other drivers heads ,how could you do this for the rest of your days. in respective every job is the same yes I know but you have really got to like it ,the draw back for me was at the Coventry depot they had all the good runs and work, long distance all the docks in England and all the Dock work from our depot.
On our daily runs you never had any chance to earn any extra money at all as we had no night money jobs at all meaning it was like 7am to 5 pm yes it was good you could arrange family and kids thing to do weekdays you knew where and what you would be doing, that was good all round however I wanted a bit more ,and I would have to wait as the regular money was manageable .
I did think about going back to Challis not on the cattle but general haulage ,but it was the handball loads that kept me away. they did have some [zb] work so in the end I stuck with it.
About 1975 Coventry depot managed to get a large contract car deliveries ,with car transporters to Scotland ,that was a mega buck job for drivers 100% controlled by the union stewards at the union house in Coventry, all drivers for that work were recruited by the union officials, they had their own waiting list for the jobs, and not the companies that run the actual haulage firms.
All the so called union executives ,conveners ,shop stewards from all the car components suppliers within the Coventry area were all in the same frame of mind, and militancy they were Trotsky supports, when you went into the big auditorium [we went once a year] the walls around all the side were covered in a Russian mural men on horses carrying, flying banners hammer and sickles everywhere just like a revolution scene.
So you knew they were militant, yes, I was a union man however I could never get myself to think the way they did .we sat board to death no idea what the were on about, after them meetings ,you would come out and think that they were running all the companies not the actual owners .
How the top men of the union got to think the way they did used to puzzle me what they had not done ever was see how the communist people lived ,I had ,and you would not want to go there ,but their way of thinking was, collectively ,workers could rule a country. thank god they never got the chance .Mrs Thatcher saw to that.
After our Coventry outing we would end up at the pub, another Sunday ,however we had a drive home ,about 20miles,it would not have mattered as there was no such thing as drink driving or even breathalysers ,you would only be in trouble if you were absolutely ■■■■■■ , and had a accident and you would be done for as being incapable .how thing have changed.
Once we were sent bigger units and trailers some of us went on to do the dock work ,now things were looking up, so now the art of the job was to get as much petty cash into your own pocket ,yes I know the management reserve the right to manage however it was the era to look after yourself.
One problem ,the manager hated paying us out from the petty cash flow and we used to fiddle as much as we could. if you like will go into great level of how we used to do it ,so if you are board now, and go and tut tut,sorry but that was the way it was. but was it the way it was. ?
Most of the major docks that took our export were ,I will write down dock distances from our depot and times of driving to them.
Southampton=110 miles distance. Hours drive normal day=4hrs
LONDON royal docks 90miles. ……3to4 +
Tilbury ,greys Thurrock, wharfs 90…3to4+
Kings lynn…100…3to4+
LIVERPOOL,BIRKENHEAD,…110…3to4+
Hull 140…4+
Felixstowe ,Harwich, Ipswich, Colchester wharfs130 +…4+
LONDON CITY wharfs90,over TOWER BRIDGE…4+
Avon mouth, Bristol 100 +…4+
CARDIFF,NEWPORT ,SWANSEA 130…4+
There were other small coastal wharfs that used to load in to small barges and then load ships out side of the docks, that were in private hands and the workers did not belong to the big national dock labour board, in other words they were not under the influence of the dock workers union that was the most powerful and militant in the country, from the 2nd war onwards until the closure of the big LONDON DOCKSin 1970s 80s .They did try to picket some of the smaller wharfs in the London area however they did not come under the P LA port of London authority so the Dockers did not have any authority over them ,all though they did all belong to the then T G W TRADES GENERAL
WORKERS, union like we all did.
So, wherever we drivers used to go to deliver goods you could bet there would be some kind of trouble, and if there was any hint of rain at all that would be it down tools and off they would go, that was the “Dockers” we were all supposed to be “brothers” but they would zb you about, as it pleased them .but woe betide it when they went on strike. they knew you would dare not cross there picket lines and it would then be on the news “[yes all the transport is supporting the dock workers]” no we were not you lazy [zb]…
