Well what can I say I’m still at work at the moment but using it today and wow! It does everything I want it to do and more I can’t believe it ! Very happy the multi drop route planning in fantastic took 10 seconds to plan 15 drops in this morning which is crazy and I took a wrong turn it re routed me within 5 seconds! The screen is massive and crystal clear no negatives so far! Evil let me know when you test yours and we can compare ![]()
ash 001:
No need, yours is better! ![]()
Will do pal! ![]()
How do you know mine is better though?
It might not be ate you already admitting defeat lol
ash 001:
No Ash, I’ve eaten it! ![]()
Evil8Beezle:
ash 001:
It might not be ate you already admitting defeat lolNo Ash, I’ve eaten it!
Mmmm satnav for breakfast anyone… CRUNCHY!!
Ow and I’ve ordered the satnav you did ash. I hope your ready for any complaints from me if it doesn’t work ![]()
TheTrogFather:
Evil8Beezle:
ash 001:
Now you’ve eaten it when you talk do you talk in the sat navs voice?
also I hope there will not be any complaints lol I am only finding at the moment that when I charge it, it is knocking out my radio signal so I’m gonna try charge it via USB and use a naf USB 12 v adaptor and hopefully it will not ruin my radio
also when you get have a play about because I can’t work out when I’m doing multi drop it shows the time I will finish my route not the time I will arrive at my next drop which I would prefer it’s not a problem but would like to change it if possible but can’t seem to find out how. If you have ordered one I would order a little case for it and screen protector because I’ve been so careful with mine and it’s got little scratches on
needless to say case and screen protector are on there way ![]()
ash 001:
TheTrogFather:
Evil8Beezle:
ash 001:
Well it happened like this Ash… I’d had a few beers, you couldn’t spell (or had a typo), and the rest is history! ![]()
Sorry to hear you are getting interference, may I ask how far away the ■■■ socket is away from the radio?
It is like a foot or so below the radio if that
but a usb cable came with it like I said so gonna get a naf adaptor with bad output and see if I have interference ![]()
Sounds like a plan. Belkin make quite nice ones!
Evil8Beezle:
I don’t want one that good lol I want one that has an output of no more then 2v ![]()
ash 001:
Evil8Beezle:
Sounds like a plan. Belkin make quite nice ones!I don’t want one that good lol I want one that has an output of no more then 2v
http://www.ebay.co.uk/itm/like/381300584489?hlpht=true&hlpv=2&rlsatarget=&adtype=pla&ff3=1&lpid=122&ul_noapp=true&limghlpsr=true&ff19=0&device=c&chn=ps&crdt=0&ff12=67&ff11=ICEP3.0.0-L&ff14=122&viphx=1&ops=true&ff13=80
From a glance, this looks genuine!
USB is 5 volts mate! You are thinking of the current rating (Amps), which in simply terms is how hot it gets before it catches fire! ![]()
Sat nav case… Hummm, sock should do fine me thinks ![]()
This thread has got very disturbing.
Evil8Beezle:
ash 001:
Evil8Beezle:
From a glance, this looks genuine!USB is 5 volts mate! You are thinking of the current rating (Amps), which in simply terms is how hot it gets before it catches fire!
ahh yes the amps is what ■■■■■ up the radio I have one that 5amps output and I have no radio with this either ![]()
eagerbeaver:
just what you like beaver ![]()
ash 001:
Evil8Beezle:
ash 001:
Evil8Beezle:
ahh yes the amps is what [zb] up the radio I have one that 5amps output and I have no radio with this either
If it is the Cigarette adapter that is causing the issue, it will because it is a crap design, crap components & crap shielding. (Which is what is probably causing the problem) Buying a better QUALITY cigarette adapter independent of the current rating should be better.
P.S. Current is drawn by a device, it isn’t pushed. So if your adapter is 2 Amp, but the device (satNav) only draws 0.5 Amps, the adapter will supply 0.5 Amps, but have the capacity to supply more. Hope that helps! ![]()
thank you evil it is not an adaptor at the moment its just a normal plug that you get on a sat nav so hoping using an adaptor will help ![]()
ash 001:
I assumed it would be, hence my initial inquiry! ![]()
Want to know anything else boring about electrical crap, ask someone else!
P.S Got a bag with my SatNav! ![]()
Evil8Beezle:
You ate the bag too?!?!? ![]()
TheTrogFather:
Evil8Beezle:
P.S Got a bag with my SatNav!You ate the bag too?!?!?
You gotta have desert mate! ![]()
