Test Day.
My test was not till dinnertime so had all the time in the world to let the nerves kick in. Morning drive was good no major issues just needed to prepare for hazards more in advance. (Maybe hazard perception test was correct ).
Back at the test centre and onto the reverse pad, nailed it everytime.
Test time came and first and off he went with the questions. One that made me laugh was :- What do you check before placing your key in the ignition. I replied handbrake applied, gear in neutral seat belts work and seat position. Then silence from him as if waiting for something else, so what did I say make sure that the indicator and light stalks if applicable are not broken snapped. We then moved on.
Reverse pad first and on reversing back as previously mentioned decided I was going to stop short and get out to have a look before hitting the barrier. Reversed back no problem into the bay. Stopped short got out had a look. If gone back any further would have hit the barrier, turned out to be perfect if do say so myself. Onto the road and couple of mistakes that I kicked myself about before being told to pull over. Hill start and did not switch the switch down. Luckily realised before taking handbrake off so reset myself and started again off we went. Out on the road and onto the motorway we go. From the roundabout and joining the slip road sure I took too much of both lanes. Once on the motorway couple of overtakes and no problems. Started to settle down a bit. Once off the motorway and recognised where we was became to complacent relaxing to much. What happens go to do the overtake on a bus as I pulled out and got level with the back of the bus he signalled and set off pulling out causing me to brake quite hard. Think I got an apology from the driver as on passing him within a minute later he put his had out as an apology I take it.
Back to the centre and on pulling up, the magic words YOU HAVE PASSED.
Very happy just need to complete my cpc and onto my C+E.
