try sdcard.org/consumers/formatter/sdfv2000.exe
set the Options to FORMAT TYPE: FULL (Erase ON)
can you put the card in something else other that your tomtom and copy the files to it?
Not really sure why it is doing that
[/quote]
The memory card is in a reader as it transfers quicker that way. Only put it in the tomtom once everything is copied.
bubsy06:
bubsy06:
That would give me a blank card? Shall I try copying the files from scratch again?
Mark28:
can you put the card in something else other that your tomtom and copy the files to it?Not really sure why it is doing that
bubsy06:
bubsy06:
yes, if that fails put the card back in your tomtom and try again
finally got the navcore and map files onto the tomtom card.
Only problem I have now is when I turn it on it says there are no maps installed.
Is there a step missing from the instructions or has something gone wrong?
step missing hang on
download this file rapidshare.com/files/176408002/S … 0.9589.rar and extract to tomtom, replace any files if it asks.
Have done that step and it runs through all the vehicle settings and then says no maps found still. Have I not copied a file into the right place?
Mark28:
Have you got all the map files in a folder called
Western_and_Central_Europe_TRUCK_815_2112
Sure have.
Mark28:
Sure have.
Have you patched the map correctly with the correct device id?
bubsy06:
Mark28:
Sure have.Have you patched the map correctly with the correct device id?
I assume I have. Followed the instructions in your guide. Shall I try patching it again? maybe I copied the files into the wrong place…I put them in the root of the tomtom memory card?
Mark28:
bubsy06:
Mark28:
No, the 3 files from the “insert meta from map here” folder should be pasted into the Western_and_Central_Europe_TRUCK_815_2112 folder, replace any files if asked
bubsy06:
Still no joy
Download this rs497.rapidshare.com/files/232064563/yDG.rar and run it and click patch file and select the ttsystem file on your tomtom and click go
says I need a password to open it?
demonfatal
Thanks.
Program keeps giving me an error message that reads:
Error - np01
Unable to complete operation
Reasons:
invalid OR already patched
only option is to click OK.
tried using the file on the tomtom and also copied it to my desktop but still gave me the error message.
pm me your device id and I will patch a file for you to try
