My wonderful company will give you a written warning for persistantly over speeding, eg going over 100 kph for short periods downhill, (the long descent northbound m74 near Cairn lodge services).
When the FTA first took over our tacho analysis they had a 90 kph limit, which meant every driver in the depot got an infringement letter.
bugcos:
Thats crap mate, 40 is 40 for everyone, you should change instructors
I agree, I donât know where this guff comes from, itâs the same with the rubbish about overspeeding. The limit for trucks on a motorway is 60! Read a sodding highway code if you donât agree.
P.S. Rikki is spot-on regarding VOSAâs interpretation of overspeeding.
Itâs in the C & U regulations somewhere. I canât find it on the net and I canât remember where else Iâve read it apart from the sign on the board at work. The exact wording was, the national speed limit for a HGV on a motorway is 60mph unless a speed limiter is fitted in which case the speed of the limiter becomes the speed limit for the vehicle. Its a Euro thing apparently. But at any rate when our new digital tacho equipped 85 km/h limited trucks arrive weâll collect overspeed infringements for exceeding 85 km/h.
Work Shy:
Going over 100 kph is speeding thoughâŚThats over 62 mph.
jc69817:
In my training I was told
speed limit over 40 knock off 10 for hgv
under 40 do it in hgv (upto of course)
hope this is right
Iâm sure its what I got told
That works on motorways, but duelâs are 50 unless signposted lower and singles are 40, again unless signposted lower. A single with a national speed limit would be 60 for cars but only 40 for HGV.
Itâs also worth remembering that a duel carraigeway is a road where the opposing traffic is seperated by a physical divider (grass verge, kerb, barrier, etc.). A road with 2 lanes of traffic running each way and only a white lane between them is a single sp the limit is 40 and a duel may only have one lane running each way but as long as there is a physical divider the limit is 50.
I had my first trip out last weekend with a digital tacho.
My impression?What a load of old â â â â â â â â .
On the Axors we run,on a downhill stretch,the exhaust brake comes on automatically at 2mph over your limiter,eg.58 mph,BUT,at 57 mph you get an overspeed warning!
I tried applying the exhaust brake when sensing going over 56,that immediately brought the speed down to 55 mph,so when I knocked the exhaust brake off it accelerated back up to 56 before starting to over run again.
The result is,power on off,on off,shunting back and forth!Watching your speedo and operating the exhaust brake,and not concentrating on the road,IS THIS SAFE?
On the other hand,the speed can be better controlled by using the brakes.
BUT,as soon as you touch the brake pedal,it knocks off the cruise control,and defeats the object of having an exhaust brake?
If on the other hand you leave the cruise control on and allow the Exhaust brake to come in at 58 mph,and maintain that speed,that seems perfectly safe and reasonable to me.
If I am told that exceeding 56 mph is an offence,then thereâs a well worn Class 1 licence going in the bin.
Being retired,I do this job part time because like most of us,I love driving,not because i have to,the job has been very good to me over the years,but if itâs going to get this petty,well itâ time to call it a day.
Like most things to do with road transport,the rules are made up by people that have never done the job,so expecting anything sensible is hoping for too much.
When I was tramping I got fed up with that over speed as it was putting me off pressing the o/k button and even anticipating it was hopeless as it would come on five minutes later when back down to 56.
I went through the tacho and found the over speed setting and it allowed me to change it to 99kph but it doesn`t seem to work on newer tachos so have they locked this now as its a pain in the hole.
DAF95XF:
As some of you may know, Ive just started my class 2 training and today I was told that if the speed limit is 40mph then trucks are limited to 30mph - is this correct
ROG:
I would ask your instructor again - just to see if you get the same answer
mrpj:
NB For the record I wasnât told this by my instructor.
Which is why I suggested he ask his instructor again - it has been known, on more than one occasion, that, whilst on training, with the brain trying to take so much in, that trainees can mis-hear or get âthe wrong end of the stickâ at times.
Trainees - if you are not sure of anything do not be afraid to ask your instructor, a thousand times, if necessary - a good instructor will not mind
bestbooties:
Ignore it.Pull it back and hold 60 mphâŚItâs stupid.I was told that a digi head will book at an overspeed if you do more than 60 mph for 1 minute.In reality it can on some heads we have book you for 57 mph for 20-30 seconds.
I ignore it , nothing to worry about.
As the guy before me said, ignore it, I always do, I wonât go over 60mph so I know Iâve not broken the law. If I know Iâm going to be going down lots of hills then Iâll just let the digi tacho do its own thing until i get to some flat ground, then Iâll press OK to stop it flashing.
Speed limiters are only fitted to vehicles for fuel economy. Next time you hit 56mph, look at your rev needle, youâll see that itâs only just in the green zone, meaning any faster (57-60) and your revs will be outside the green zone, making you uneconomicalâŚthats the only reason for speed limiters! I canât understand why they cant just put in an extra gear, thereâs 16 of them already, making one more isnât going to be a hard task! Then we could just be done with 56mph!
tofer:
Lot of rubbish posted on work notice boards as a rule, usually by someone who is designated a trainer but hasnât got a clue or just repeats any old nonsense they hear without checking its validity.
tofer:
Exact wording was made up then, you wonât find that in any legislation. The speed limit is the posted speed limit for the type of road and the type of vehicle whether that vehicle has a speed limiter or not.
tofer:
Ah ha, the cry of the desperate when they are trying to get people to believe an urban myth, blame it on âEuropeâ.
tofer:
I wouldnât sign for them as it isnât necessarily an infringement, it would depend on the road it occurred on.
A speed limiter must prevent a vehicle being powered beyond the set speed, there is nothing in any legislation which makes it an offence for momentum to take the vehicle beyond the speed limiter setting and up to 60 mph on motorways.
