jakethesnake:
the maoster:
^^^^ that’ll be 20000kg of water thenSorry, but it won’t. When the vehicle was loaded (max weight with spirit = 24t ) there was certainly room for a few more hundred litres or kgs if you like.
As I said it was full to the brim with water so the weight (normally 24t) would have been much higher.
Agreed Jake.
I make it that you’re correct.
When you said ‘a 20,000L tank’, I understood you to mean that your tank normally carries 20,000ish L of Petrol/Kerosene/Diesel plus the required ullage* space, dependent on the exact product.
When you said that the tank had been filled to the brim with water, I guess that the reason was that some kind of hotwork (welding/cutting/grinding) needed to be undertaken for some reason.
Your tanker would (of course) feel much heavier to drive, even if you just had to shuffle it around in the yard.
Trying to keep this as straightforward (and un-scientific) as I can… ADR says that there are several forms of Diesel, which can include some forms of central heating oil, but they all ship on the same UN number, so for the purposes of this discussion… they’re Diesel.
*Ullage can be thought of as the free space above the liquid in a tank which is a legal requirement, and allows for changes in temperature causing product expansion within the tank which may be encountered during the journey.
Degree of filling can be thought of as the % of the total capacity of the tank that is occupied by the liquid to be carried.
Liquid being carried + ullage = 100%, so now the size of any given tank doesn’t matter.
Some people talk in terms of percentage fill, whilst others talk in terms of ullage, but even this doesn’t matter once folks remember that liquid being carried + ullage = 100%. That should take care of ‘volume.’
Overfill can be thought of as a situation when there has been ‘invasion’ of the required ullage space by allowing too much liquid cargo into the tank. This may lead to overflow on a bad day.
It does NOT automatically follow that overfill = overflow, it’s just that it might.
Malc made the point about specific gravity (SG) which can be thought of as the actual weight, which obviously has implications for axle/gross weights for both drivers and vehicle owners.
The SG figure multiplied by the number of litres to be loaded gives an indication of the weight of the load.
SG is usually based on the weight of water, so water = 1.
Some substances are lighter than water, so their SG figure will be 0.■■■ (A figure less than 1)
Some substances are heavier than water, so their SG figure will be 1.■■■ (A figure more than 1)
