norb:
Cotswoldcrunch:
Norb, I had the bearing go on a 12 speed Eaton on the Alpha I drove. it was a very interesting experience trying to change on Birdlip Hill, considering two of the gearbox mounts sheared shortly after…I’m a jock and what where you doing up Birdip Hill
Doesn’t that place have a reputation
Problem with failed bearings is the shaft then is basically floating up and down and back and forth
I’m not a Jock I just had my passport stamped to deliver flour up there every 12 weeks (but Ido enjoy working up there)
Yes Birdlip does have a reputation (off the A419) I was going up the A417 Brockworth Bypass when the Alpha started jumping out of gear. In the end any gears off 1 or 3 wouldn’t stay in. Thankfully the Cat motor in it was happy to go up in other gears.
